Little help required please
Re: Little help required please
Post by Origin on Sun May 31, 2009 9:49 pm
Hope Belahzur doesn't mind me stepping in,
Glad to hear everything is running well Wink
The reason that maybe is because they still maybe in your downloads folder located here:
C:\Documents and Settings\COMPUTERNAME\My Documents\Downloads
Check to see if they are still there so you can delete them
Posts Posts : 2685
Joined Joined : 2009-05-05
OS OS : Windows Xp Sp3
Points Points : 31483
Post by fubar1010 on Sun May 31, 2009 10:00 pm
nope cant find them anywhere little odd but sure they will turn up somewhere
thanks for the advice i have successfully installed spywareblaster spybot search and destroy adaware and avg internet security 8.0 with firewall etc etc
many thanks to you guys for helping posted good feedback for you guys
dont mean in bad way hope to not see u guys any time soon ;) haha keep up the good work
fubar1010
Posts Posts : 90
Joined Joined : 2009-05-31
OS OS : windows vista home premium
Points Points : 28085
Post by fubar1010 on Fri Jun 05, 2009 1:43 pm
hi only me again Smile
right as i have said above i removed bitlord from the laptop and still cannot find these damn downloads even tho my drive is still as full as it was so they obviously somewere i even redownloaded bitlord see if they would magically pop up but no such luck can anyone help me find them please would be much appreciated Smile
fubar1010
Posts Posts : 90
Post by Belahzur on Fri Jun 05, 2009 1:49 pm
Uninstall BitLord again.
If BitLord is anything like uTorrent, the avi/whatever type files maybe gone, but even after uninstalling a torrent program, the folder in Application Data gets left behind with the recorded .torrent files in there, and the .torrent files are the same size as the movie.
Points Points : 245069
Post by fubar1010 on Fri Jun 05, 2009 1:51 pm
so where will these files be so i can delete them thanks
oh and any chance you could look over my question in software please Smile
fubar1010
Posts Posts : 90
Post by Belahzur on Fri Jun 05, 2009 2:02 pm
Sure, I'll check that now and see if I can do anything. Usually Doc answers post in the Software/other areas.
If it's anywhere, it should be here.
C:\Documents and setitngs\YOUR USERNAME\Application Data\BitLord
You won't be able to see the Application Data folder because it's a hidden system folder, so you'll need to show hidden files, do you know how to do that?
Post by fubar1010 on Fri Jun 05, 2009 2:49 pm
cant even get to documents and settings folder cant see it anywhere new to vista so im lost trying to find it haha
fubar1010
Posts Posts : 90
