Little help required please
Post by fubar1010 on Sun May 31, 2009 11:53 am
downloaded a video file and played through windows media player....wmp downloaded some codec forgot what called but i removed from add/remove programs urgently
since that happened when i go on to google and search for something i get the normal list of links for what i have searched....i then click on the 1st link and it opens up a new window (use to open in same window) but 1st time it goes to some site completley different i could search arsenal when i click that link for [You must be registered and logged in to see this link.] opens up a new window and goes to youtube and starts playing girls aloud Let me think or it will open up a myspace page (Gunsmoke) .....so firstly its opening up in a new windown leaving the 1st window with the searched items there ODD....and 2ndly its opening up random other sites strange...
i came to a site that said to download MALWAREBYTES click the link for it and get ERROR PAGE CANNOT BE FOUND
try bout 10 different links from 10 different places and all the same no page can be found...
installed malwarebytes finally and now wont open
installing spybot search and destroy from disc and from the internet...crashes laptop gives blue memory dump screen
went on microsoft website tryed download malicious software removal tool all i got was page cannot be found
i try install avg all i get is an error at the end
try open kaspersky links to download or install all i get is page not found
seems anything that will help remove whatever i got is blocked
any help would be appreciated many thanks in advance
any information required please ask i will get for you thanks
fubar1010
OS : windows vista home premium
Re: Little help required please
Post by Belahzur on Sun May 31, 2009 12:57 pm
Post by fubar1010 on Sun May 31, 2009 5:01 pm
hi thanks for quick reply
i did as u said 1st time it crashed me to blue memory dump screen
2nd time it installed its there in program files etc
i double click it but it WONT open up Sad tearing
fubar1010
Post by Belahzur on Sun May 31, 2009 5:13 pm
Find Hijack This inside the Trend Micro folder in Program Files.
Right click > Rename.
Rename it to whatever you want to, but doesn't what it's called.
Post by fubar1010 on Sun May 31, 2009 5:19 pm
Scan saved at 18:18:43, on 31/05/2009
Platform: Windows Vista SP1 (WinNT 6.00.1905)
MSIE: Internet Explorer v7.00 (7.00.6001.18226)
C:\Windows\system32\Dwm.exe
C:\Windows\Explorer.EXE
C:\Windows\system32\taskeng.exe
C:\Program Files\Windows Defender\MSASCui.exe
C:\Windows\RtHDVCpl.exe
C:\Acer\Empowering Technology\eDataSecurity\eDSLoader.exe
C:\Windows\System32\hkcmd.exe
C:\Windows\System32\igfxpers.exe
C:\Windows\system32\igfxsrvc.exe
C:\Users\LISA4J~1\AppData\Local\Temp\RtkBtMnt.exe
C:\Program Files\Launch Manager\LManager.exe
C:\Program Files\Apoint2K\Apoint.exe
C:\Program Files\Windows Sidebar\sidebar.exe
C:\Windows\ehome\ehtray.exe
C:\Program Files\Windows Media Player\wmpnscfg.exe
C:\Program Files\Webroot\Spy Sweeper\SpySweeper.exe
C:\Windows\ehome\ehmsas.exe
C:\Program Files\Apoint2K\ApMsgFwd.exe
C:\Acer\Empowering Technology\EPOWER\EPOWER_DMC.EXE
C:\Windows\system32\igfxext.exe
C:\Program Files\Apoint2K\Apntex.exe
C:\Acer\Empowering Technology\ACER.EMPOWERING.FRAMEWORK.SUPERVISOR.EXE
C:\Program Files\Trend Micro\HijackThis\eatshit.exe
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
R3 - URLSearchHook: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - (no file)
R3 - URLSearchHook: TorrentMan Toolbar - {7c5c0f58-e061-457d-9033-77307f5ed00c} - C:\Program Files\TorrentMan\tbTorr.dll
O1 - Hosts: ::1 localhost
O2 - BHO: WormRadar.com IESiteBlocker.NavFilter - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - C:\Program Files\AVG\AVG8\avgssie.dll (file missing)
O2 - BHO: (no name) - {5C255C8A-E604-49b4-9D64-90988571CECB} - (no file)
O2 - BHO: TorrentMan Toolbar - {7c5c0f58-e061-457d-9033-77307f5ed00c} - C:\Program Files\TorrentMan\tbTorr.dll
O2 - BHO: ShowBarObj Class - {83A2F9B1-01A2-4AA5-87D1-45B6B8505E96} - C:\Windows\system32\ActiveToolBand.dll
O2 - BHO: AVG Security Toolbar - {A057A204-BACC-4D26-9990-79A187E2698E} - C:\PROGRA~1\AVG\AVG8\AVGTOO~1.DLL (file missing)
O3 - Toolbar: Acer eDataSecurity Management - {5CBE3B7C-1E47-477e-A7DD-396DB0476E29} - C:\Windows\system32\eDStoolbar.dll
O3 - Toolbar: TorrentMan Toolbar - {7c5c0f58-e061-457d-9033-77307f5ed00c} - C:\Program Files\TorrentMan\tbTorr.dll
O3 - Toolbar: AVG Security Toolbar - {A057A204-BACC-4D26-9990-79A187E2698E} - C:\PROGRA~1\AVG\AVG8\AVGTOO~1.DLL (file missing)
O4 - HKLM\..\Run: [Windows Defender] %ProgramFiles%\Windows Defender\MSASCui.exe -hide
O4 - HKLM\..\Run: [RtHDVCpl] RtHDVCpl.exe
O4 - HKLM\..\Run: [eDataSecurity Loader] C:\Acer\Empowering Technology\eDataSecurity\eDSloader.exe
O4 - HKLM\..\Run: [IgfxTray] C:\Windows\system32\igfxtray.exe
O4 - HKLM\..\Run: [HotKeysCmds] C:\Windows\system32\hkcmd.exe
O4 - HKLM\..\Run: [Persistence] C:\Windows\system32\igfxpers.exe
O4 - HKLM\..\Run: [SetPanel] C:\Acer\APanel\APanel.cmd
O4 - HKLM\..\Run: [LManager] C:\PROGRA~1\LAUNCH~1\LManager.exe
O4 - HKLM\..\Run: [WarReg_PopUp] C:\Acer\WR_PopUp\WarReg_PopUp.exe
O4 - HKLM\..\Run: [Apoint] C:\Program Files\Apoint2K\Apoint.exe
O4 - HKLM\..\Run: [Acer Tour Reminder] C:\Acer\AcerTour\Reminder.exe
O4 - HKLM\..\Run: [Skytel] Skytel.exe
O4 - HKCU\..\Run: [Sidebar] C:\Program Files\Windows Sidebar\sidebar.exe /autoRun
O4 - HKCU\..\Run: [msnmsgr] "C:\Program Files\Windows Live\Messenger\msnmsgr.exe" /background
O4 - HKCU\..\Run: [ehTray.exe] C:\Windows\ehome\ehTray.exe
O4 - HKCU\..\Run: [WMPNSCFG] C:\Program Files\Windows Media Player\WMPNSCFG.exe
O4 - HKCU\..\Run: [SpySweeper] C:\Program Files\Webroot\Spy Sweeper\SpySweeper.exe /0
O4 - HKUS\S-1-5-19\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /detectMem (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-19\..\Run: [WindowsWelcomeCenter] rundll32.exe oobefldr.dll,ShowWelcomeCenter (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /detectMem (User 'NETWORK SERVICE')
O4 - HKUS\S-1-5-18\..\Run: [Acer Tour Reminder] C:\Acer\AcerTour\Reminder.exe (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [Acer Tour Reminder] C:\Acer\AcerTour\Reminder.exe (User 'Default user')
O4 - Global Startup: Empowering Technology Launcher.lnk = ?
O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~2\Office12\ONBttnIE.dll
O9 - Extra 'Tools' menuitem: S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~2\Office12\ONBttnIE.dll
O13 - Gopher Prefix:
O16 - DPF: {67DABFBF-D0AB-41FA-9C46-CC0F21721616} (DivXBrowserPlugin Object) - [You must be registered and logged in to see this link.]
O17 - HKLM\System\CCS\Services\Tcpip\..\{2AEC3DE6-CA55-4741-9B18-3F7B52AAA50A}: NameServer = 85.255.112.69,85.255.112.209
O17 - HKLM\System\CS1\Services\Tcpip\Parameters: NameServer = 85.255.112.69,85.255.112.209
O17 - HKLM\System\CS1\Services\Tcpip\..\{2AEC3DE6-CA55-4741-9B18-3F7B52AAA50A}: NameServer = 85.255.112.69,85.255.112.209
O17 - HKLM\System\CS2\Services\Tcpip\Parameters: NameServer = 85.255.112.69,85.255.112.209
O17 - HKLM\System\CS2\Services\Tcpip\..\{2AEC3DE6-CA55-4741-9B18-3F7B52AAA50A}: NameServer = 85.255.112.69,85.255.112.209
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: NameServer = 85.255.112.69,85.255.112.209
O18 - Protocol: linkscanner - {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - C:\Program Files\AVG\AVG8\avgpp.dll (file missing)
O23 - Service: Agere Modem Call Progress Audio (AgereModemAudio) - Agere Systems - C:\Windows\system32\agrsmsvc.exe
O23 - Service: eDataSecurity Service - HiTRSUT - C:\Acer\Empowering Technology\eDataSecurity\eDSService.exe
O23 - Service: eLock Service (eLockService) - Acer Inc. - C:\Acer\Empowering Technology\eLock\Service\eLockServ.exe
O23 - Service: eNet Service - Acer Inc. - C:\Acer\Empowering Technology\eNet\eNet Service.exe
O23 - Service: Symantec Eraser Service (EraserSvc10910) - Unknown owner - C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe (file missing)
O23 - Service: eSettings Service (eSettingsService) - Unknown owner - C:\Acer\Empowering Technology\eSettings\Service\capuserv.exe
O23 - Service: Google Update Service (gupdate1c9c348f584b505) (gupdate1c9c348f584b505) - Google Inc. - C:\Program Files\Google\Update\GoogleUpdate.exe
O23 - Service: MobilityService - Unknown owner - C:\Acer\Mobility Center\MobilityService.exe
O23 - Service: ePower Service (WMIService) - acer - C:\Acer\Empowering Technology\ePower\ePowerSvc.exe
O23 - Service: XAudioService - Conexant Systems, Inc. - C:\Windows\system32\DRIVERS\xaudio.exe
End of file - 8355 bytes
fubar1010
Post by Origin on Sun May 31, 2009 5:55 pm
See [You must be registered and logged in to see this link.] for how to disable your AV..
OS : Windows Xp Sp3
Post by fubar1010 on Sun May 31, 2009 6:20 pm
when i click on that combofix link it comes up to run or save i click save and nothing happens just closes the box
click run it goes as if going through then nothing happens
i did the other part fixed the ones with hijack this
fubar1010
Post by Origin on Sun May 31, 2009 6:22 pm
Ok please do the following:
OS : Windows Xp Sp3
Post by fubar1010 on Sun May 31, 2009 6:24 pm
same happens with this
fubar1010
Post by Origin on Sun May 31, 2009 6:28 pm
Alright let see if this works, if not we are going to be doing some things in safe mode Wink
Note: This tool was posted specifically for this user. If you are not this user, do NOT follow these directions as they could damage the workings of your system.
2. Now, start The Avenger program by clicking on its icon on your desktop.
  • Leave the script box empty.
3. Please copy/paste the content of c:\avenger.txt into your reply.
OS : Windows Xp Sp3
Post by fubar1010 on Sun May 31, 2009 6:42 pm
that wouldnt work also so im guna download avenger on my pc and send to the laptop via msn and do it tht way
AVENGER done just waiting for reboot now and will grab the logfile for you Smile
Last edited by fubar1010 on Sun May 31, 2009 6:58 pm; edited 1 time in total (Reason for editing : save space :p)
fubar1010
Post by fubar1010 on Sun May 31, 2009 7:05 pm
Rootkit scan active.
Hidden driver "gxvxcserv.sys" found!
ImagePath: \systemroot\system32\drivers\gxvxccqipppmqfuxhuwiyfnmxwwkybeifmnxm.sys
Driver disabled successfully.
Rootkit scan completed.
Completed script processing.
Finished! Terminate.
fubar1010
Post by Belahzur on Sun May 31, 2009 7:21 pm
1. Copy all the text contained in the code box below to your Clipboard by highlighting it and pressing (Ctrl+CCrying
Drivers to delete:
gxvxcserv.sys
Files to delete:
C:\WINDOWS\system32\drivers\gxvxccqipppmqfuxhuwiyfnmxwwkybeifmnxm.sys
Post by fubar1010 on Sun May 31, 2009 7:41 pm
No rootkits found!
Driver "gxvxcserv.sys" deleted successfully.
File "C:\WINDOWS\system32\drivers\gxvxccqipppmqfuxhuwiyfnmxwwkybeifmnxm.sys" deleted successfully.
fubar1010
Post by Belahzur on Sun May 31, 2009 7:47 pm
Try running Combofix now.
Post by fubar1010 on Sun May 31, 2009 8:20 pm
ComboFix 09-05-30.06 - lisa4jock 31/05/2009 21:10.1 - NTFSx86
Microsoft® Windows Vista™ Home Premium 6.0.6001.1.1252.44.1033.18.2037.1133 [GMT 1:00]
Running from: c:\users\lisa4jock\Desktop\Combo-Fix.exe
AV: AVG 7.5.560 *On-access scanning disabled* (Outdated) {41564737-3200-1071-989B-0000E87B4FB1}
FW: AVG Firewall 7.5.500 *enabled* {8DECF618-9569-4340-B34A-D78D28969B66}
C:\Autorun.inf
c:\windows\system32\gxvxcngpvnpeeqfvcpsbroktnmesthcjqjtfb.dll
c:\windows\system32\gxvxcvuesoqkbleifplwrnqnhoboiwyubcqjb.dll
c:\windows\system32\x64
c:\windows\Tasks\{5B57CF47-0BFA-43c6-ACF9-3B3653DCADBA}.job
((((((((((((((((((((((((( Files Created from 2009-04-28 to 2009-05-31 )))))))))))))))))))))))))))))))
2009-05-31 20:13 . 2009-05-31 20:14 -------- d-----w- c:\users\lisa4jock\AppData\Local\temp
2009-05-31 19:46 . 2009-05-31 19:46 24064 ----a-w- c:\programdata\Grisoft\Avg7Data\avg7upd\install.1\avgwlx64.dll
2009-05-31 19:46 . 2009-05-31 19:46 17928 ----a-w- c:\programdata\Grisoft\Avg7Data\avg7upd\install.1\avgclnit.sys
2009-05-31 19:46 . 2009-05-31 19:46 13832 ----a-w- c:\programdata\Grisoft\Avg7Data\avg7upd\install.1\avgcln64.sys
2009-05-31 19:46 . 2009-05-31 19:46 40448 ----a-w- c:\programdata\Grisoft\Avg7Data\avg7upd\install.1\avgwli64.dll
2009-05-31 19:46 . 2009-05-31 19:46 36352 ----a-w- c:\programdata\Grisoft\Avg7Data\avg7upd\install.1\avgsea64.dll
2009-05-31 19:33 . 2009-05-31 19:19 55304 ----a-w- c:\programdata\Grisoft\Avg7Data\avg7upd\backup\avgwfp.sys
2009-05-31 19:33 . 2009-05-31 19:19 905728 ----a-w- c:\programdata\Grisoft\Avg7Data\avg7upd\backup\avgctrl.dll
2009-05-31 19:33 . 2009-05-31 19:19 582656 ----a-w- c:\programdata\Grisoft\Avg7Data\avg7upd\backup\avgcckrn.dll
2009-05-31 19:33 . 2009-05-31 19:19 579072 ----a-w- c:\programdata\Grisoft\Avg7Data\avg7upd\backup\avgcc.exe
2009-05-31 19:33 . 2009-05-31 19:19 510976 ----a-w- c:\programdata\Grisoft\Avg7Data\avg7upd\backup\avginet.exe
2009-05-31 19:33 . 2009-05-31 19:19 389632 ----a-w- c:\programdata\Grisoft\Avg7Data\avg7upd\backup\avgvv.exe
2009-05-31 19:33 . 2009-05-31 19:19 131072 ----a-w- c:\programdata\Grisoft\Avg7Data\avg7upd\backup\avginet.dll
2009-05-31 19:33 . 2009-05-31 19:19 1282560 ----a-w- c:\programdata\Grisoft\Avg7Data\avg7upd\backup\avgres.dll
2009-05-31 19:33 . 2009-05-31 19:19 435712 ----a-w- c:\programdata\Grisoft\Avg7Data\avg7upd\backup\avgabout.dll
2009-05-31 19:20 . 2009-05-31 19:30 -------- d-----w- c:\users\lisa4jock\AppData\Roaming\AVG7
2009-05-31 19:20 . 2009-05-31 19:20 9216 ----a-w- c:\windows\system32\avgwlntf.dll
2009-05-31 19:19 . 2009-05-31 19:19 10760 ----a-w- c:\windows\system32\drivers\avgclean.sys
2009-05-31 19:19 . 2009-05-31 19:47 53768 ----a-w- c:\windows\system32\drivers\avgwfp.sys
2009-05-31 19:19 . 2009-05-31 19:19 821856 ----a-w- c:\windows\system32\drivers\avg7core.sys
2009-05-31 19:19 . 2009-05-31 19:19 4224 ----a-w- c:\windows\system32\drivers\avg7rsw.sys
2009-05-31 19:19 . 2009-05-31 19:19 27776 ----a-w- c:\windows\system32\drivers\avg7rsxp.sys
2009-05-31 19:19 . 2009-05-31 19:19 26952 ----a-w- c:\windows\system32\drivers\avgmfx86.sys
2009-05-31 19:19 . 2009-05-31 20:03 -------- d-----w- c:\programdata\avg7
2009-05-31 19:19 . 2009-05-31 19:19 -------- d-----w- c:\programdata\Grisoft
2009-05-31 16:53 . 2009-05-31 16:53 -------- d-----w- c:\program files\Trend Micro
2009-05-31 10:46 . 2009-05-31 10:46 -------- d-----w- c:\users\lisa4jock\AppData\Roaming\Lavasoft
2009-05-31 10:46 . 2009-05-31 10:46 -------- d-----w- c:\program files\Lavasoft
2009-05-31 10:42 . 2003-10-15 22:42 150528 ----a-w- c:\windows\unSpySweeper.exe
2009-05-31 10:42 . 2009-05-31 10:42 -------- d-----w- c:\program files\Webroot
2009-05-31 10:39 . 2009-05-31 10:39 -------- d-----w- c:\program files\Kaspersky Lab
2009-05-31 10:34 . 2009-05-31 10:35 -------- d-----w- c:\program files\SpywareBlaster
2009-05-31 10:19 . 2009-05-31 10:19 -------- d-----w- c:\program files\Spybot - Search & Destroy
2009-05-28 23:57 . 2009-05-28 23:57 23832 ----a-w- c:\windows\system32\drivers\avgfwd6x.sys
2009-05-28 23:49 . 2009-05-28 23:49 -------- d-----w- c:\program files\AVG
2009-05-28 23:32 . 2009-05-28 23:32 -------- d-----w- c:\programdata\NortonInstaller
2009-05-22 16:59 . 2008-04-12 03:32 784896 ----a-w- c:\windows\system32\rpcrt4.dll
2009-05-22 16:59 . 2008-04-26 08:26 891448 ----a-w- c:\windows\system32\drivers\tcpip.sys
2009-05-22 16:59 . 2008-04-05 03:34 15360 ----a-w- c:\windows\system32\pacerprf.dll
2009-05-22 16:59 . 2008-04-05 01:21 72192 ----a-w- c:\windows\system32\drivers\pacer.sys
2009-05-21 19:27 . 2009-05-21 19:27 -------- d-----w- C:\PerfLogs
2009-05-13 23:40 . 2009-05-13 23:40 -------- d-----w- c:\users\lisa4jock\AppData\Local\Activision
2009-05-13 23:35 . 2009-05-13 23:51 -------- d-----w- C:\cod waw
2009-05-13 23:33 . 2009-05-13 23:33 -------- d-----w- c:\program files\MagicISO
2009-05-13 20:30 . 2009-05-13 20:33 -------- d-----w- c:\program files\Windows Live Safety Center
2009-05-03 14:54 . 2009-05-28 11:11 -------- d-----w- c:\users\lisa4jock\AppData\Roaming\dvdcss
2009-05-31 18:08 . 2009-04-19 20:16 -------- d-----w- c:\program files\TorrentMan
2009-05-31 11:17 . 2009-04-19 20:48 -------- d-----w- c:\program files\BearShare
2009-05-31 10:32 . 2009-04-19 17:52 -------- d-----w- c:\program files\Yahoo!
2009-05-27 12:30 . 2009-05-27 12:30 0 ---ha-w- c:\windows\system32\drivers\Msft_User_WpdFs_01_00_00.Wdf
2009-05-21 19:30 . 2006-11-02 12:37 -------- d-----w- c:\program files\Windows Calendar
2009-05-21 19:30 . 2006-11-02 12:37 -------- d-----w- c:\program files\Windows Sidebar
2009-05-21 19:30 . 2006-11-02 11:18 -------- d-----w- c:\program files\Windows Mail
2009-05-21 19:30 . 2006-11-02 12:37 -------- d-----w- c:\program files\Windows Collaboration
2009-05-21 19:30 . 2006-11-02 12:37 -------- d-----w- c:\program files\Windows Journal
2009-05-21 19:30 . 2006-11-02 12:37 -------- d-----w- c:\program files\Windows Photo Gallery
2009-05-21 19:30 . 2006-11-02 12:37 -------- d-----w- c:\program files\Windows Defender
2009-05-21 19:27 . 2006-11-02 10:25 665600 ----a-w- c:\windows\inf\drvindex.dat
2009-05-21 19:05 . 2006-11-02 10:32 101888 ----a-w- c:\windows\system32\ifxcardm.dll
2009-05-21 19:05 . 2006-11-02 10:32 82432 ----a-w- c:\windows\system32\axaltocm.dll
2009-05-13 02:05 . 2007-07-26 03:06 -------- d-----w- c:\programdata\Microsoft Help
2009-04-30 15:28 . 2009-04-30 15:28 -------- d-----w- c:\program files\DFX
2009-04-30 13:29 . 2009-04-30 13:29 2560 ----a-w- c:\windows\_MSRSTRT.EXE
2009-04-30 13:20 . 2009-04-30 13:20 -------- d-----w- c:\programdata\DFX
2009-04-30 13:20 . 2009-04-30 13:20 -------- d-----w- c:\program files\Common Files\DFX
2009-04-25 22:13 . 2009-04-25 22:13 782664 ----a-w- c:\programdata\Microsoft\eHome\Packages\MCESpotlight\MCESpotlight\SpotlightResources.dll
2009-04-22 12:51 . 2009-04-22 12:50 -------- d-----w- c:\program files\Google
2009-04-22 12:50 . 2009-04-22 12:50 -------- d-----w- c:\program files\DivX
2009-04-22 12:50 . 2009-04-22 12:50 -------- d-----w- c:\program files\Common Files\DivX Shared
2009-04-22 12:31 . 2009-04-22 11:45 -------- d-----w- c:\users\lisa4jock\AppData\Roaming\vlc
2009-04-22 11:44 . 2009-04-22 11:44 -------- d-----w- c:\program files\VideoLAN
2009-04-22 08:56 . 2009-04-22 08:56 269312 ----a-w- c:\windows\system32\es.dll
2009-04-22 08:52 . 2007-07-26 03:10 -------- d-----w- c:\program files\Microsoft Works
2009-04-20 20:41 . 2009-04-20 20:41 1915520 ----a-w- c:\users\lisa4jock\AppData\Roaming\Macromedia\Flash Player\[You must be registered and logged in to see this link.]
2009-04-20 11:02 . 2009-04-20 11:02 61440 ----a-w- c:\windows\system32\winipsec.dll
2009-04-20 11:02 . 2009-04-20 11:02 361984 ----a-w- c:\windows\system32\IPSECSVC.DLL
2009-04-20 11:02 . 2009-04-20 11:02 28672 ----a-w- c:\windows\system32\FwRemoteSvr.dll
2009-04-20 11:02 . 2009-04-20 11:02 272896 ----a-w- c:\windows\system32\polstore.dll
2009-04-20 10:59 . 2009-04-20 10:59 94720 ----a-w- c:\windows\system32\PortableDeviceClassExtension.dll
2009-04-20 10:59 . 2009-04-20 10:59 241152 ----a-w- c:\windows\system32\PortableDeviceApi.dll
2009-04-20 10:59 . 2009-04-20 10:59 160768 ----a-w- c:\windows\system32\PortableDeviceTypes.dll
2009-04-20 10:51 . 2009-04-20 10:51 376832 ----a-w- c:\windows\system32\winhttp.dll
2009-04-20 10:50 . 2009-04-20 10:50 296960 ----a-w- c:\windows\system32\gdi32.dll
2009-04-20 10:47 . 2009-04-20 10:47 212480 ----a-w- c:\windows\system32\drivers\mrxsmb10.sys
2009-04-20 10:46 . 2009-04-20 10:46 562176 ----a-w- c:\windows\system32\msdtcprx.dll
2009-04-20 10:46 . 2009-04-20 10:46 38912 ----a-w- c:\windows\system32\xolehlp.dll
2009-04-20 10:43 . 2009-04-20 10:43 28672 ----a-w- c:\windows\system32\Apphlpdm.dll
2009-04-20 10:43 . 2009-04-20 10:43 4240384 ----a-w- c:\windows\system32\GameUXLegacyGDFs.dll
2009-04-20 10:43 . 2009-04-20 10:43 1695744 ----a-w- c:\windows\system32\gameux.dll
2009-04-20 10:41 . 2009-04-20 10:41 303616 ----a-w- c:\windows\system32\wmpeffects.dll
2009-04-20 10:40 . 2009-04-20 10:40 2048 ----a-w- c:\windows\system32\msxml3r.dll
2009-04-20 10:40 . 2009-04-20 10:40 1191936 ----a-w- c:\windows\system32\msxml3.dll
2009-04-20 02:29 . 2009-04-20 02:29 3 ----a-w- c:\windows\AFirst.cmd
2009-04-20 02:04 . 2009-04-20 02:04 2048 ----a-w- c:\windows\system32\tzres.dll
2009-04-20 02:02 . 2009-04-20 02:02 428544 ----a-w- c:\windows\system32\EncDec.dll
2009-04-20 02:02 . 2009-04-20 02:02 293376 ----a-w- c:\windows\system32\psisdecd.dll
2009-04-20 02:00 . 2009-04-20 02:00 8147456 ----a-w- c:\windows\system32\wmploc.DLL
2009-04-20 02:00 . 2009-04-20 02:00 7680 ----a-w- c:\windows\system32\spwmp.dll
2009-04-20 02:00 . 2009-04-20 02:00 4096 ----a-w- c:\windows\system32\dxmasf.dll
2009-04-20 01:53 . 2009-04-20 01:53 2927104 ----a-w- c:\windows\explorer.exe
2009-04-20 01:45 . 2009-04-20 01:45 5071872 ----a-w- c:\windows\system32\NlsModels0011.dll
2009-04-20 01:41 . 2009-04-20 01:41 6656 ----a-w- c:\windows\system32\kbd106n.dll
2009-04-20 01:41 . 2009-04-20 01:41 988216 ----a-w- c:\windows\system32\winload.exe
2009-04-20 01:41 . 2009-04-20 01:41 927288 ----a-w- c:\windows\system32\winresume.exe
2009-04-20 01:41 . 2009-04-20 01:41 40960 ----a-w- c:\windows\system32\srclient.dll
2009-04-20 01:41 . 2009-04-20 01:41 378368 ----a-w- c:\windows\system32\srcore.dll
2009-04-20 01:41 . 2009-04-20 01:41 318464 ----a-w- c:\windows\system32\rstrui.exe
2009-04-20 01:41 . 2009-04-20 01:41 14848 ----a-w- c:\windows\system32\srdelayed.exe
2009-04-20 01:41 . 2009-04-20 01:41 46592 ----a-w- c:\windows\system32\setbcdlocale.dll
2009-04-20 01:41 . 2009-04-20 01:41 19000 ----a-w- c:\windows\system32\kd1394.dll
2009-04-20 01:41 . 2009-04-20 01:41 615992 ----a-w- c:\windows\system32\ci.dll
2009-04-20 01:35 . 2009-04-20 01:35 441400 ----a-w- c:\windows\system32\drivers\ksecdd.sys
2009-04-20 01:35 . 2009-04-20 01:35 9728 ----a-w- c:\windows\system32\lsass.exe
2009-04-20 01:35 . 2009-04-20 01:35 72704 ----a-w- c:\windows\system32\secur32.dll
2009-04-20 01:35 . 2009-04-20 01:35 1255936 ----a-w- c:\windows\system32\lsasrv.dll
2009-04-20 01:35 . 2009-04-20 01:35 24064 ----a-w- c:\windows\system32\amxread.dll
2009-04-20 01:35 . 2009-04-20 01:35 13824 ----a-w- c:\windows\system32\apilogen.dll
2009-04-20 01:33 . 2009-04-20 01:33 425472 ----a-w- c:\windows\system32\PhotoMetadataHandler.dll
2009-04-20 01:33 . 2009-04-20 01:33 712704 ----a-w- c:\windows\system32\WindowsCodecs.dll
2009-04-20 01:33 . 2009-04-20 01:33 347136 ----a-w- c:\windows\system32\WindowsCodecsExt.dll
2009-04-20 01:30 . 2009-04-20 01:30 443392 ----a-w- c:\windows\system32\win32spl.dll
2009-04-20 01:30 . 2009-04-20 01:30 37888 ----a-w- c:\windows\system32\printcom.dll
2009-04-20 01:29 . 2009-04-20 01:29 113664 ----a-w- c:\windows\system32\drivers\rmcast.sys
2009-04-20 01:29 . 2009-04-20 01:29 14848 ----a-w- c:\windows\system32\wshrm.dll
2009-04-20 01:26 . 2009-04-20 01:26 288768 ----a-w- c:\windows\system32\drivers\srv.sys
2009-04-20 01:23 . 2009-04-20 01:23 268288 ----a-w- c:\windows\system32\schannel.dll
2009-04-20 01:19 . 2009-04-20 01:19 622080 ----a-w- c:\windows\system32\icardagt.exe
2009-04-20 01:19 . 2009-04-20 01:19 97800 ----a-w- c:\windows\system32\infocardapi.dll
2009-04-20 01:19 . 2009-04-20 01:19 11264 ----a-w- c:\windows\system32\icardres.dll
2009-04-20 01:19 . 2009-04-20 01:19 105016 ----a-w- c:\windows\system32\PresentationCFFRasterizerNative_v0300.dll
2009-04-20 01:19 . 2009-04-20 01:19 781344 ----a-w- c:\windows\system32\PresentationNative_v0300.dll
2009-04-20 01:19 . 2009-04-20 01:19 43544 ----a-w- c:\windows\system32\PresentationHostProxy.dll
2009-04-20 01:19 . 2009-04-20 01:19 326160 ----a-w- c:\windows\system32\PresentationHost.exe
2009-04-20 00:59 . 2009-04-20 00:59 96760 ----a-w- c:\windows\system32\dfshim.dll
2009-04-20 00:59 . 2009-04-20 00:59 41984 ----a-w- c:\windows\system32\netfxperf.dll
2009-04-20 00:59 . 2009-04-20 00:59 282112 ----a-w- c:\windows\system32\mscoree.dll
2009-04-20 00:59 . 2009-04-20 00:59 158720 ----a-w- c:\windows\system32\mscorier.dll
2009-04-20 00:59 . 2009-04-20 00:59 83968 ----a-w- c:\windows\system32\mscories.dll
2009-04-20 00:28 . 2009-04-20 00:28 2868736 ----a-w- c:\windows\system32\mf.dll
2009-04-20 00:28 . 2009-04-20 00:28 98816 ----a-w- c:\windows\system32\mfps.dll
2009-04-20 00:28 . 2009-04-20 00:28 53248 ----a-w- c:\windows\system32\rrinstaller.exe
2009-04-20 00:28 . 2009-04-20 00:28 24576 ----a-w- c:\windows\system32\mfpmp.exe
2009-04-20 00:28 . 2009-04-20 00:28 2048 ----a-w- c:\windows\system32\mferror.dll
2009-04-20 00:28 . 2009-04-20 00:28 996352 ----a-w- c:\windows\system32\WMNetMgr.dll
2009-04-20 00:28 . 2009-04-20 00:28 94720 ----a-w- c:\windows\system32\logagent.exe
2009-04-20 00:25 . 2009-04-20 00:25 84480 ----a-w- c:\windows\system32\INETRES.dll
fubar1010
"Sidebar"="c:\program files\Windows Sidebar\sidebar.exe" [2008-01-19 1233920]
"msnmsgr"="c:\program files\Windows Live\Messenger\msnmsgr.exe" [2009-02-06 3885408]
"WMPNSCFG"="c:\program files\Windows Media Player\WMPNSCFG.exe" [2008-01-19 202240]
"SpySweeper"="c:\program files\Webroot\Spy Sweeper\SpySweeper.exe" [2004-02-25 665088]
"eDataSecurity Loader"="c:\acer\Empowering Technology\eDataSecurity\eDSloader.exe" [2007-04-25 457216]
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 8.0\Reader\Reader_sl.exe" [2007-03-08 40048]
"IgfxTray"="c:\windows\system32\igfxtray.exe" [2007-05-25 142104]
"HotKeysCmds"="c:\windows\system32\hkcmd.exe" [2007-05-25 154392]
"Persistence"="c:\windows\system32\igfxpers.exe" [2007-05-25 138008]
"LManager"="c:\progra~1\LAUNCH~1\LManager.exe" [2007-07-16 768520]
"WarReg_PopUp"="c:\acer\WR_PopUp\WarReg_PopUp.exe" [2006-11-05 57344]
"Apoint"="c:\program files\Apoint2K\Apoint.exe" [2007-06-06 159744]
"Acer Tour Reminder"="c:\acer\AcerTour\Reminder.exe" [2007-05-22 151552]
"AVG7_CC"="c:\progra~1\Grisoft\AVG7\avgcc.exe" [2009-05-31 590848]
"RtHDVCpl"="RtHDVCpl.exe" - c:\windows\RtHDVCpl.exe [2007-07-06 4669440]
"Skytel"="Skytel.exe" - c:\windows\SkyTel.exe [2007-06-15 1826816]
"AVG7_Run"="c:\progra~1\Grisoft\AVG7\avgw.exe" [2009-05-31 219136]
Empowering Technology Launcher.lnk - c:\acer\Empowering Technology\eAPLauncher.exe [2007-7-26 535336]
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\avgwlntf]
2009-05-31 19:20 9216 ----a-w- c:\windows\System32\avgwlntf.dll
"AppInit_DLLs"=c:\windows\System32\eNetHook.dll
@="Driver"
"UacDisableNotify"=dword:00000001
"InternetSettingsDisableNotify"=dword:00000001
"AutoUpdateDisableNotify"=dword:00000001
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\DomainProfile]
"EnableFirewall"= 0 (0x0)
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\FirewallRules]
"{B865A331-0198-4E67-8AB0-0829040F707B}"= UDP:c:\program files\Microsoft Office\Office12\ONENOTE.EXE:Microsoft Office OneNote
"{FFF9EBCC-F1FB-45DC-A85F-F986FB6DFA59}"= TCP:c:\program files\Microsoft Office\Office12\ONENOTE.EXE:Microsoft Office OneNote
"TCP Query User{25F9255C-1FAF-4FA3-AC26-B879D92A7D65}c:\\program files\\bitlord\\bitlord.exe"= UDP:c:\program files\bitlord\bitlord.exe:BitLord
"UDP Query User{53034FAF-AAE8-4C56-8FF6-E69489D0F6D0}c:\\program files\\bitlord\\bitlord.exe"= TCP:c:\program files\bitlord\bitlord.exe:BitLord
"{32FA88CD-192C-4F63-987C-0D79E983CABF}"= UDP:6348:bearshare
"{CB2013E6-2A20-4A44-9A3C-7FCDE8A34ED2}"= UDP:c:\program files\BearShare\BearShare.exe:BearShare
"{E246F5EF-E3E1-4611-A971-8186B8B4F637}"= TCP:c:\program files\BearShare\BearShare.exe:BearShare
"{4CD597D5-5A45-4277-9877-B0316A6EA517}"= UDP:c:\users\lisa4jock\AppData\Local\Temp\7zSA06C.tmp\SymNRT.exe:Norton Removal Tool
"{349838E8-AF51-466D-8EED-A5D624D21C7B}"= TCP:c:\users\lisa4jock\AppData\Local\Temp\7zSA06C.tmp\SymNRT.exe:Norton Removal Tool
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\PublicProfile]
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\StandardProfile]
R2 AVGFw2kv;AVG Firewall Service;c:\progra~1\Grisoft\AVG7\avgfw2kv.exe [31/05/2009 20:19 793600]
R3 AvgWFP;AVG7 Firewall Driver x86;c:\windows\System32\drivers\avgwfp.sys [31/05/2009 20:19 53768]
R3 b57nd60x;Broadcom NetXtreme Gigabit Ethernet - NDIS 6.0;c:\windows\System32\drivers\b57nd60x.sys [26/07/2007 02:02 179712]
S2 EraserSvc10910;Symantec Eraser Service;"c:\program files\Common Files\Symantec Shared\ccSvcHst.exe" /h ccCommon --> c:\program files\Common Files\Symantec Shared\ccSvcHst.exe [?]
S2 gupdate1c9c348f584b505;Google Update Service (gupdate1c9c348f584b505);c:\program files\Google\Update\GoogleUpdate.exe [22/04/2009 13:50 133104]
2009-05-31 c:\windows\Tasks\GoogleUpdateTaskMachine.job
- c:\program files\Google\Update\GoogleUpdate.exe [2009-04-22 12:50]
HKCU-Run-Acer Tour Reminder - (no file)
HKLM-Run-SetPanel - c:\acer\APanel\APanel.cmd
HKLM-Run-Acer Tour - (no file)
SafeBoot-procexp90.Sys
Rootkit scan 2009-05-31 21:14
Windows 6.0.6001 Service Pack 1 NTFS
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0000\AllUserSettings]
@Denied: (A) (Users)
@Denied: (A) (Everyone)
"BlindDial"=dword:00000000
"MSCurrentCountry"=dword:000000b5
- - - - - - - > 'winlogon.exe'(644)
- - - - - - - > 'lsass.exe'(704)
Completion time: 2009-05-31 21:15
ComboFix-quarantined-files.txt 2009-05-31 20:15
Pre-Run: 22,170,292,224 bytes free
Post-Run: 22,429,052,928 bytes free
283 --- E O F --- 2009-05-31 18:54
fubar1010
Post by Belahzur on Sun May 31, 2009 8:27 pm
Go to Start > Control Panel > Add/Remove Programs and remove the following programs if present.
  • BearShare
  • BitLord
  • TorrentMan
  • TorrentMan Toolbar
Now open a new notepad file.
KILLALL::
Driver::
EraserSvc10910
Folder::
Registry::
"TCP Query User{25F9255C-1FAF-4FA3-AC26-B879D92A7D65}c:\\program files\\bitlord\\bitlord.exe"=-
"UDP Query User{53034FAF-AAE8-4C56-8FF6-E69489D0F6D0}c:\\program files\\bitlord\\bitlord.exe"=-
"{32FA88CD-192C-4F63-987C-0D79E983CABF}"=-
"{CB2013E6-2A20-4A44-9A3C-7FCDE8A34ED2}"=-
"{E246F5EF-E3E1-4611-A971-8186B8B4F637}"=-
"{4CD597D5-5A45-4277-9877-B0316A6EA517}"=-
"{349838E8-AF51-466D-8EED-A5D624D21C7B}"=-
Post by fubar1010 on Sun May 31, 2009 8:54 pm
ComboFix 09-05-30.06 - lisa4jock 31/05/2009 21:41.2 - NTFSx86
Microsoft® Windows Vista™ Home Premium 6.0.6001.1.1252.44.1033.18.2037.1148 [GMT 1:00]
Command switches used :: c:\users\lisa4jock\Desktop\CFScript.txt
c:\program files\BearShare\BearShare.dat
c:\program files\BearShare\db\config.bin
c:\program files\BearShare\db\gwebcache.dat
c:\program files\BearShare\db\Hostiles-Chat.txt
c:\program files\BearShare\db\Hostiles.txt
c:\program files\BearShare\db\library.2.db
c:\program files\BearShare\db\library.2.db.lastgoodload.bak
c:\program files\BearShare\db\library.db
c:\program files\BearShare\db\library.db.lastgoodload.bak
c:\program files\BearShare\db\searches.ini
c:\program files\BearShare\FreePeers.ini
c:\program files\BearShare\Logs\hosts-state.txt
c:\program files\BearShare\Logs\memory.txt
c:\program files\BearShare\Logs\ordinal.txt
c:\program files\BearShare\Logs\streams.txt
c:\program files\BearShare\Temp\TMPBSInstall5.2.5.1.dat
c:\program files\BearShare\Temp\TMPBSInstall5.2.5.1.dat.bak
c:\program files\bitlord\Downloads\AlbumArtSmall.jpg
c:\program files\bitlord\Downloads\Angels and Demons (2009) ENGLISH CAM XviD-MAXSPEED\Angels and Demons (2009) ENGLISH CAM XviD-MAXSPEED\Angels and Demons (2009) ENGLISH CAM XviD-MAXSPEED [You must be registered and logged in to see this link.]
c:\program files\bitlord\Downloads\AVG Antivirus+Firewall & Anti-Spyware [AVG Internet Security]\AVG Serial.txt
c:\program files\bitlord\Downloads\AVG Antivirus+Firewall & Anti-Spyware [AVG Internet Security]\avg75f_516a1225.exe
c:\program files\bitlord\Downloads\AVG Antivirus+Firewall & Anti-Spyware [AVG Internet Security]\avgas-setup-7.5.1.43.exe
c:\program files\bitlord\Downloads\AVG Antivirus+Firewall & Anti-Spyware [AVG Internet Security]\Instruction.txt
c:\program files\bitlord\Downloads\AVG Antivirus+Firewall & Anti-Spyware [AVG Internet Security]\SSG keygen.exe
c:\program files\bitlord\Downloads\AVG Internet Security 8.0 + serial (EXPIRES YEAR 2018) (CLEAN) [blaze69]\avg_iswt_stf_all_8_199a1387.exe
c:\program files\bitlord\Downloads\AVG Internet Security 8.0 + serial (EXPIRES YEAR 2018) (CLEAN) [blaze69]\Serial.txt
c:\program files\bitlord\Downloads\City.Rats.2009.DVDRip.XviD-GFW.[[You must be registered and logged in to see this link.]
c:\program files\bitlord\Downloads\dexter season 3\Dexter.S03E01.REAL.PROPER.HDTV.XviD-aAF.avi
c:\program files\bitlord\Downloads\dexter season 3\Dexter.S03E02.HDTV.XviD-0TV.avi
c:\program files\bitlord\Downloads\dexter season 3\Dexter.S03E03.HDTV.XviD-NoTV.avi
c:\program files\bitlord\Downloads\dexter season 3\Dexter.S03E04.HDTV.XviD-0TV.[VTV].avi
c:\program files\bitlord\Downloads\dexter season 3\Dexter.S03E05.HDTV.XviD-0TV.avi
c:\program files\bitlord\Downloads\dexter season 3\Dexter.S03E06.HDTV.XviD-LOL.avi
c:\program files\bitlord\Downloads\dexter season 3\Dexter.S03E07.HDTV.XviD-LOL.avi
c:\program files\bitlord\Downloads\dexter season 3\Dexter.S03E08.HDTV.XviD-LOL.avi
c:\program files\bitlord\Downloads\dexter season 3\Dexter.S03E09.HDTV.XviD-0TV.avi
c:\program files\bitlord\Downloads\dexter season 3\Dexter.S03E10.HDTV.XviD-0TV.avi
c:\program files\bitlord\Downloads\dexter season 3\Dexter.S03E11.HDTV.XviD-aAF.avi
c:\program files\bitlord\Downloads\dexter season 3\Dexter.S03E12.HDTV.XviD-aAF.avi
c:\program files\bitlord\Downloads\Dexter.S01\dexter.105.hdtv.xvid-notv.avi
c:\program files\bitlord\Downloads\Dexter.S01\dexter.106.hdtv-lol.avi
c:\program files\bitlord\Downloads\Dexter.S01\dexter.107.hdtv-lol.avi
c:\program files\bitlord\Downloads\Dexter.S01\dexter.108.hdtv-lol.avi
c:\program files\bitlord\Downloads\Dexter.S01\dexter.109.hdtv-lol.avi
c:\program files\bitlord\Downloads\Dexter.S01\dexter.110.hdtv-lol.avi
c:\program files\bitlord\Downloads\Dexter.S01\Dexter.111.HDTV.XviD-LOL.avi
c:\program files\bitlord\Downloads\Dexter.S01\dexter.112.hdtv-lol.avi
c:\program files\bitlord\Downloads\Dexter.S01\ehthumbs_vista.db
c:\program files\bitlord\Downloads\ehthumbs_vista.db
c:\program files\bitlord\Downloads\everybody hates chris\Everybody.Hates.Chris.S04E03.HDTV.XviD-LOL.avi
c:\program files\bitlord\Downloads\everybody hates chris\Everybody.Hates.Chris.S04E04.HDTV.XviD-LOL.avi
c:\program files\bitlord\Downloads\everybody hates chris\Everybody.Hates.Chris.S04E05.HDTV.XviD-LOL.avi
c:\program files\bitlord\Downloads\everybody hates chris\Everybody.Hates.Chris.S04E06.HDTV.XviD-LOL.avi
c:\program files\bitlord\Downloads\everybody hates chris\Everybody.Hates.Chris.S04E07.HDTV.XviD-LOL.avi
c:\program files\bitlord\Downloads\everybody hates chris\Everybody.Hates.Chris.S04E08.HDTV.XvID-NoTV.avi
c:\program files\bitlord\Downloads\everybody hates chris\Everybody.Hates.Chris.S04E09.HDTV.XviD-LOL.avi
c:\program files\bitlord\Downloads\everybody hates chris\Everybody.Hates.Chris.S04E10.HDTV.XviD-LOL.avi
c:\program files\bitlord\Downloads\everybody hates chris\Everybody.Hates.Chris.S04E11.Everybody.Hates.Mr.Levine.HDTV.XviD-FQM.avi
c:\program files\bitlord\Downloads\everybody hates chris\Everybody.Hates.Chris.S04E12.HDTV.XviD-LOL.avi
c:\program files\bitlord\Downloads\everybody hates chris\Everybody.Hates.Chris.S04E13.HDTV.XviD-NoTV.avi
c:\program files\bitlord\Downloads\everybody hates chris\Everybody.Hates.Chris.S04E15.HDTV.XviD-NoTV.avi
c:\program files\bitlord\Downloads\everybody hates chris\Everybody.Hates.Chris.S04E16.Everybody.Hates.Lasagna.HDTV.XviD-FQM.avi
c:\program files\bitlord\Downloads\everybody hates chris\Everybody.Hates.Chris.S04E17.Everybody.Hates.Spring.Break.HDTV.XviD-FQM.avi
c:\program files\bitlord\Downloads\everybody hates chris\Everybody.Hates.Chris.S04E18.Everybody.Hates.the.Car.HDTV.XviD-FQM.avi
c:\program files\bitlord\Downloads\everybody hates chris\Everybody.Hates.Chris.S04E19.Everybody.Hates.Back.Talk.HDTV.XviD-FQM.avi
c:\program files\bitlord\Downloads\everybody hates chris\Everybody.Hates.Chris.S04E20.HDTV.XviD-LOL.avi
c:\program files\bitlord\Downloads\everybody hates chris\Everybody.Hates.Chris.S04E21.HDTV.XviD-2HD.avi
c:\program files\bitlord\Downloads\everybody hates chris\Everybody.Hates.Chris.S04E22.HDTV.XviD-LOL.avi
c:\program files\bitlord\Downloads\Folder.jpg
c:\program files\bitlord\Downloads\Gnaw.2009.DVDRIP.XviD\Gnaw.2009.DVDRIP.XviD-ZEKTORM.avi
c:\program files\bitlord\Downloads\Laid.To.Rest.2009.DVDRip.XviD\Laid.To.Rest.2009.DVDRip.XviD-MoH.avi
c:\program files\bitlord\Downloads\Lost.S05.A.Journey.In.Time.Recap.Special.HDTV.XviD-2HD.avi
c:\program files\bitlord\Downloads\The Devils Tomb 2009 dvd rip XviD.Rets\The Devils Tomb\The Devils Tomb 2009.avi
c:\program files\bitlord\lang\lang_ar_ae.xml
c:\program files\bitlord\lang\lang_bg_bg.xml
c:\program files\bitlord\lang\lang_ca_es.xml
c:\program files\bitlord\lang\lang_cz_cz.xml
c:\program files\bitlord\lang\lang_da_dk.xml
c:\program files\bitlord\lang\lang_de_de.xml
c:\program files\bitlord\lang\lang_el_gr.xml
c:\program files\bitlord\lang\lang_en_us.xml
c:\program files\bitlord\lang\lang_es_ar.xml
c:\program files\bitlord\lang\lang_es_es.xml
c:\program files\bitlord\lang\lang_et_ee.xml
c:\program files\bitlord\lang\lang_fi_fi.xml
c:\program files\bitlord\lang\lang_fr_fr.xml
c:\program files\bitlord\lang\lang_gl_es.xml
c:\program files\bitlord\lang\lang_he_il.xml
c:\program files\bitlord\lang\lang_hu_hu.xml
c:\program files\bitlord\lang\lang_it_it.xml
c:\program files\bitlord\lang\lang_jp_jp.xml
c:\program files\bitlord\lang\lang_ko_kr.xml
c:\program files\bitlord\lang\lang_nb_no.xml
c:\program files\bitlord\lang\lang_nl_nl.xml
c:\program files\bitlord\lang\lang_pl_pl.xml
c:\program files\bitlord\lang\lang_pt_br.xml
c:\program files\bitlord\lang\lang_pt_pt.xml
c:\program files\bitlord\lang\lang_ro_ro.xml
c:\program files\bitlord\lang\lang_ru_ru.xml
c:\program files\bitlord\lang\lang_sk_sk.xml
c:\program files\bitlord\lang\lang_sl_si.xml
c:\program files\bitlord\lang\lang_sr_sr.xml
c:\program files\bitlord\lang\lang_sv_se.xml
c:\program files\bitlord\lang\lang_th_th.xml
c:\program files\bitlord\lang\lang_tr_tr.xml
c:\program files\bitlord\lang\lang_va_es.xml
c:\program files\bitlord\lang\lang_zh_tw.xml
c:\program files\bitlord\rules\ipfilter.dat
-------\Service_EraserSvc10910
2009-05-31 20:44 . 2009-05-31 20:47 -------- d-----w- c:\users\lisa4jock\AppData\Local\temp
2009-05-31 20:26 . 2009-05-31 20:26 10520 ----a-w- c:\windows\system32\avgrsstx.dll
2009-05-31 20:26 . 2009-05-31 20:26 12936 ----a-w- c:\windows\system32\drivers\avgrkx86.sys
2009-05-31 20:26 . 2009-05-31 20:26 90632 ----a-w- c:\windows\system32\drivers\avgtdix.sys
2009-05-31 20:26 . 2009-05-31 20:26 98440 ----a-w- c:\windows\system32\drivers\avgldx86.sys
2009-05-31 20:26 . 2009-05-31 20:26 -------- d-----w- c:\windows\system32\drivers\Avg
2009-05-31 20:25 . 2009-05-31 20:25 -------- d-----w- c:\windows\LastGood.Tmp
2009-05-31 20:25 . 2009-05-31 20:25 -------- d-----w- c:\programdata\avg8
2009-05-31 19:19 . 2009-05-31 20:26 26824 ----a-w- c:\windows\system32\drivers\avgmfx86.sys
fubar1010
2009-04-20 00:25 . 2009-04-20 00:25 738304 ----a-w- c:\windows\system32\inetcomm.dll
2009-04-20 00:24 . 2009-04-20 00:24 1645568 ----a-w- c:\windows\system32\connect.dll
+ 2009-05-31 20:25 . 2009-05-31 20:25 23832 c:\windows\System32\DriverStore\FileRepository\avgfwfd6.inf_ca037d13\avgfwd6x.sys
- 2009-04-19 17:46 . 2009-05-31 19:40 16384 c:\windows\System32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
+ 2009-04-19 17:46 . 2009-05-31 20:32 16384 c:\windows\System32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
- 2009-04-19 17:46 . 2009-05-31 19:40 49152 c:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat
+ 2009-04-19 17:46 . 2009-05-31 20:32 49152 c:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat
- 2009-04-19 17:46 . 2009-05-31 19:40 16384 c:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
+ 2009-04-19 17:46 . 2009-05-31 20:32 16384 c:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
+ 2006-11-02 10:25 . 2009-05-31 20:25 86016 c:\windows\inf\infstor.dat
- 2006-11-02 10:25 . 2009-05-29 00:05 86016 c:\windows\inf\infstor.dat
+ 2006-11-02 10:25 . 2009-05-31 20:25 51200 c:\windows\inf\infpub.dat
- 2006-11-02 10:25 . 2009-05-29 00:05 51200 c:\windows\inf\infpub.dat
- 2006-11-02 10:25 . 2009-05-29 00:05 143360 c:\windows\inf\infstrng.dat
+ 2006-11-02 10:25 . 2009-05-31 20:25 143360 c:\windows\inf\infstrng.dat
fubar1010
Post by fubar1010 on Sun May 31, 2009 8:55 pm
Note* empty entries & legit default entries are not shown
"Acer Tour Reminder"="" [BU]
"AVG8_TRAY"="c:\progra~1\AVG\AVG8\avgtray.exe" [2009-05-31 1235736]
"LoadAppInit_DLLs"=0 (0x0)
"AppInit_DLLs"=c:\windows\System32\eNetHook.dll c:\windows\System32\avgrsstx.dll
@="Driver"
"{68FA17A7-FD22-4046-9662-845DCFC34EDE}"= c:\program files\AVG\AVG8\avgam.exe:avgam.exe
"{B8B1F74A-5B40-4021-A031-ADDD0F19B3F4}"= c:\program files\AVG\AVG8\avgemc.exe:avgemc.exe
"{2733DF70-8194-4A9C-8109-A0802AC1FADB}"= c:\program files\AVG\AVG8\avgupd.exe:avgupd.exe
"{0CB2FD28-F1DD-4FCD-B4EF-81BD94E646FA}"= c:\program files\AVG\AVG8\avgnsx.exe:avgnsx.exe
R0 AvgRkx86;avgrkx86.sys;c:\windows\System32\drivers\avgrkx86.sys [31/05/2009 21:26 12936]
R1 Avgfwfd;AVG network filter service;c:\windows\System32\drivers\avgfwd6x.sys [29/05/2009 00:57 23832]
R1 AvgLdx86;AVG AVI Loader Driver x86;c:\windows\System32\drivers\avgldx86.sys [31/05/2009 21:26 98440]
R1 AvgTdiX;AVG8 Network Redirector;c:\windows\System32\drivers\avgtdix.sys [31/05/2009 21:26 90632]
R2 avg8emc;AVG8 E-mail Scanner;c:\progra~1\AVG\AVG8\avgemc.exe [31/05/2009 21:26 874776]
R2 avg8wd;AVG8 WatchDog;c:\progra~1\AVG\AVG8\avgwdsvc.exe [31/05/2009 21:25 231704]
R2 avgfws8;AVG8 Firewall;c:\progra~1\AVG\AVG8\avgfws8.exe [31/05/2009 21:26 1212184]
*NewlyCreated* - AVGLDX86
*NewlyCreated* - AVGTDIX
Rootkit scan 2009-05-31 21:47
- - - - - - - > 'Explorer.exe'(3436)
c:\windows\system32\MsnChatHook.dll
c:\windows\system32\ShowErrMsg.dll
c:\windows\system32\sysenv.dll
c:\windows\system32\BatchCrypto.dll
c:\windows\system32\CryptoAPI.dll
c:\windows\system32\keyManager.dll
c:\acer\Empowering Technology\EPOWER\SysHook.dll
c:\windows\System32\audiodg.exe
c:\windows\System32\agrsmsvc.exe
c:\acer\Empowering Technology\eDataSecurity\eDSService.exe
c:\acer\Empowering Technology\eLock\Service\eLockServ.exe
c:\progra~1\AVG\AVG8\avgam.exe
c:\progra~1\AVG\AVG8\avgrsx.exe
c:\acer\Empowering Technology\eNet\eNet Service.exe
c:\program files\Common Files\LightScribe\LSSrvc.exe
c:\progra~1\AVG\AVG8\avgnsx.exe
c:\acer\Mobility Center\MobilityService.exe
c:\windows\System32\drivers\XAudio.exe
c:\acer\Empowering Technology\ePower\ePowerSvc.exe
c:\windows\System32\wbem\unsecapp.exe
c:\windows\System32\igfxsrvc.exe
c:\program files\Launch Manager\LManager.exe
c:\users\LISA4J~1\AppData\Local\temp\RtkBtMnt.exe
c:\program files\AVG\AVG8\avgtray.exe
c:\windows\System32\igfxext.exe
c:\program files\Apoint2K\ApMsgFwd.exe
c:\program files\Apoint2K\ApntEx.exe
c:\windows\ehome\ehmsas.exe
c:\acer\Empowering Technology\ePower\ePower_DMC.exe
c:\acer\Empowering Technology\Acer.Empowering.Framework.Supervisor.exe
c:\program files\Windows Media Player\wmpnetwk.exe
c:\windows\System32\wbem\WMIADAP.exe
Completion time: 2009-05-31 21:51 - machine was rebooted
ComboFix-quarantined-files.txt 2009-05-31 20:51
ComboFix2.txt 2009-05-31 20:15
Pre-Run: 23,657,050,112 bytes free
Post-Run: 23,380,676,608 bytes free
424 --- E O F --- 2009-05-31 18:54
fubar1010
Post by Belahzur on Sun May 31, 2009 9:08 pm
ComboFix /u
Post by fubar1010 on Sun May 31, 2009 9:14 pm
am i doing this and leaving combofix to run again?
fubar1010
Post by Belahzur on Sun May 31, 2009 9:36 pm
The /u uninstalls Combofix, it shouldn't need to run again.
Post by fubar1010 on Sun May 31, 2009 9:45 pm
sorry haha
when i was doing that it confused me because it was bringing up warning message that avg internet security was running etc
its uninstalled now avg is is installed a.virus/firewall,anti-spam,internet security etc all up and running smoothly
all seems back to normal and perfectly fine many thanks for the help guys done a brilliant job 12 out of 10 Smile GREAT ******
1 more question tho
running 1 of the programs when uninstalling BITLORD i lost my films etc they have gone BUT the space on my hard drive is still taken up as if they where there :s
fubar1010
Post by Origin on Sun May 31, 2009 9:49 pm
Hope Belahzur doesn't mind me stepping in,
Glad to hear everything is running well Wink
The reason that maybe is because they still maybe in your downloads folder located here:
C:\Documents and Settings\COMPUTERNAME\My Documents\Downloads
Check to see if they are still there so you can delete them
OS : Windows Xp Sp3
Post by fubar1010 on Sun May 31, 2009 10:00 pm
nope cant find them anywhere little odd but sure they will turn up somewhere
thanks for the advice i have successfully installed spywareblaster spybot search and destroy adaware and avg internet security 8.0 with firewall etc etc
many thanks to you guys for helping posted good feedback for you guys
dont mean in bad way hope to not see u guys any time soon ;) haha keep up the good work
fubar1010
Post by fubar1010 on Fri Jun 05, 2009 1:43 pm
hi only me again Smile
right as i have said above i removed bitlord from the laptop and still cannot find these damn downloads even tho my drive is still as full as it was so they obviously somewere i even redownloaded bitlord see if they would magically pop up but no such luck can anyone help me find them please would be much appreciated Smile
fubar1010
Post by Belahzur on Fri Jun 05, 2009 1:49 pm
Uninstall BitLord again.
If BitLord is anything like uTorrent, the avi/whatever type files maybe gone, but even after uninstalling a torrent program, the folder in Application Data gets left behind with the recorded .torrent files in there, and the .torrent files are the same size as the movie.
Post by fubar1010 on Fri Jun 05, 2009 1:51 pm
so where will these files be so i can delete them thanks
oh and any chance you could look over my question in software please Smile
fubar1010
Post by Belahzur on Fri Jun 05, 2009 2:02 pm
Sure, I'll check that now and see if I can do anything. Usually Doc answers post in the Software/other areas.
If it's anywhere, it should be here.
C:\Documents and setitngs\YOUR USERNAME\Application Data\BitLord
You won't be able to see the Application Data folder because it's a hidden system folder, so you'll need to show hidden files, do you know how to do that?
Post by fubar1010 on Fri Jun 05, 2009 2:49 pm
cant even get to documents and settings folder cant see it anywhere new to vista so im lost trying to find it haha
fubar1010
