WinBlue Soft Help Please
Page 1 of 2 1, 2  Next
Re: WinBlue Soft Help Please
Post by Belahzur on 30th May 2009, 4:38 pm
Lets give this a go, but I doubt it will work.
Please close all anti virus, anti malware and any other open programs/windows so they do not interfere with the running of RootRepeal.
  • Please download RootRepeal.zip from [You must be registered and logged in to see this link.].
  • Extract the program file to your Desktop.
  • Run the program RootRepeal.exe and go to the Report tab and click on the Scan button.
  • Select ALL of the checkboxes and then click OK and it will start scanning your system.
  • If you have multiple drives you only need to check the C: drive or the one Windows is installed on.
  • When done, click on Save Report
  • Save it to the Desktop.
  • Please copy/paste the contents of the report in your next reply.
Points Points : 245121
Post by PatTheBaker on 30th May 2009, 4:47 pm
I couldn't run it but someone PM'd me and the said they checked their drive for all files modified on the infection date and got rid of files and he is now able to run .exe. I think I'm going to give this a try unless you disagree.
PatTheBaker
Posts Posts : 67
Joined Joined : 2009-05-29
OS OS : XP Home Edition
Points Points : 27605
Post by Belahzur on 30th May 2009, 4:53 pm
Worth a try, but note down the file names and dates, one wrong move and there goes your OS, you'll trash it if you delete a needed system file.
I was wrong about that winav file located.
  1. Open My Computer.
  2. Go to Tools > Folder Options.
  3. Select the View tab.
  4. Scroll down to Hidden files and folders.
  5. Select Show hidden files and folders.
  6. Uncheck (untick) Hide extensions of known file types.
  7. Uncheck (untick) Hide protected operating system files (Recommended).
  8. Click Yes when prompted.
  9. Click OK.
  10. Close My Computer.
Now follow this path and see if winav is present here.
C:\Documents and settings\USERNAME\Application Data\winav.exe
If so, delete it.
Post by PatTheBaker on 30th May 2009, 5:09 pm
I couldn't find any winav or sysav so I'm trying to find and delete those files. I'll post back with an update.
PatTheBaker
Posts Posts : 67
Post by PatTheBaker on 30th May 2009, 5:24 pm
OK, I deleted most of the .exe and .dll files on that day. They were all found in windows and system32 folder. I can now use my internet browser on the infected computer but it won't work after I had to reboot. I can't run hijack this but it's letting me run MGTools. The only files left from that day are:
d47adwa5e14z99.dll
blocker.dll
z497add5are2568.dll
z4dba9kdoor20385.dll
z9665ackdoor1568.dll
PatTheBaker
Posts Posts : 67
Post by PatTheBaker on 30th May 2009, 5:36 pm
OK, once it gave me the blue screen, I can't run the browser nor MGTools. But I'll give you what MG Tools put in my C: before my comp rebooted.
the log file .zip
the tools .zip
PatTheBaker
Posts Posts : 67
Post by Origin on 30th May 2009, 5:39 pm
Hello can you download files from Safe mode and Networking or do you have to install them via a USB stick?
Posts Posts : 2685
Joined Joined : 2009-05-05
OS OS : Windows Xp Sp3
Points Points : 31533
Post by Belahzur on 30th May 2009, 5:53 pm
Hey Origin, I'll PM you shortly, new theories I've found on beating this somewhat.
Were getting somewhere. Since INF worked once before, were gonna use it again.
    [Version]
    Signature=$CHICAGO$
    [DefaultInstall]
    AddReg=Del.Settings
    [Del.Settings]
    HKCU,SOFTWARE\Microsoft\Windows\CurrentVersion\Run,setup2.exe,0x00000000
    HKCU,SOFTWARE\Microsoft\Windows\CurrentVersion\Run\setup2.exe
    HKLM,software\microsoft\windows\currentVersion\Run,WinBlueSoft,0x00000000
    HKU,DEFAULT\Software\Microsoft\Windows\CurrentVersion\Run,setup2.exe,0x00000000
    HKLM.software\microsoft\windows nt\currentversion\windows,AppInit_DLLs,0x00000000
  • Save this as fixreg.inf, save it to your desktop.
  • Right click fixreg.inf and select install.
Can you delete that setup2.exe file now?
Post by PatTheBaker on 30th May 2009, 5:56 pm
I could dl MG Tools on Regular Mode and could use an internet browser and it worked for about 5 until it gave me the blue screen.
I tried again on Safe Mode Networking but it still won't let me run any .exe or anything of the sort. Up until that point, I had been trying to use a USB and if it failed I trid to directly install the programs on the USB itself but nothing works.
PatTheBaker
Posts Posts : 67
Post by PatTheBaker on 30th May 2009, 5:58 pm
[You must be registered and logged in to see this link.] wrote:Hey Origin, I'll PM you shortly, new theories I've found on beating this somewhat.
    [Version]
    Signature=$CHICAGO$
    [DefaultInstall]
    AddReg=Del.Settings
    [Del.Settings]
I deleted setup2.exe already. Should I still keep the .inf file?
PatTheBaker
Posts Posts : 67
Post by Belahzur on 30th May 2009, 5:59 pm
Sorry, don't know how that got in there, didn't see that bit.
I need you to run my new inf script there, it will delete some run values and tools might work then.
Post by PatTheBaker on 30th May 2009, 6:06 pm
Alright, I saved it onto the desktop and hit install. My icons blinked a bit but no installation wizard or anything of the sort.
PatTheBaker
Posts Posts : 67
Post by Belahzur on 30th May 2009, 6:24 pm
Yeah, the blinking normally happens.
The registry values should be killed off now, see if you can run anything you haven't been able to.
Post by PatTheBaker on 30th May 2009, 6:38 pm
No dice. I tried all the programs you posted and Avenger but no response. I did manage to delete all the .dll files I listed before except for blocker.dll
PatTheBaker
Posts Posts : 67
Post by Belahzur on 30th May 2009, 6:46 pm
I made another mistake on the inf file, time for another inf file.
    [Version]
    Signature=$CHICAGO$
    [DefaultInstall]
    AddReg=Del.Settings
    [Del.Settings]
    HKLM,software\microsoft\windows nt\currentversion\windows,AppInit_DLLs,0x00000000
Try and delete blocker.dll now.
Post by PatTheBaker on 30th May 2009, 7:01 pm
It won't delete blocker.dll but the .inf is letting me running my browser. I also dl'd CounterSpy and installing it right now. Counterspy won't scan because I don't have any risk definitions.
Update: OK I deleted blocker.dll. I'm running MGTools again, do you want me to upload the .zips to mediafire?
PatTheBaker
Posts Posts : 67
Update Again
Post by PatTheBaker on 30th May 2009, 7:11 pm
Blocker.dll is gone. I can run taskmgr and regedit. It still won't let me run Hijack This but the computer doesn't auto reboot for me anymore.
I can install Hijack This and Malwarebytes but after installation it won't let me run it.
Also, I checked the Registry Keys and found 2 setup2's. Both are in the Windows folder, should I delete?
PatTheBaker
Posts Posts : 67
Post by Belahzur on 30th May 2009, 8:04 pm
The registry value? yes, delete it.
Post by PatTheBaker on 30th May 2009, 8:21 pm
Alright, I deleted all the setup2 values but only CounterSpy works but won't let me update definitions for threats so I can't use it.
PatTheBaker
Posts Posts : 67
Post by Belahzur on 30th May 2009, 8:47 pm
I didn't see your last post, please upload the new MGlogs for me.
Run a scan without updating it, see what happens.
Post by PatTheBaker on 30th May 2009, 8:57 pm
CounterSpy just says I haven't defined any threats and tells me I need to update my definitions.
MG Log:
PatTheBaker
Posts Posts : 67
Post by Belahzur on 30th May 2009, 9:13 pm
More logs, more detail.
Them few files you deleted, I don't know what they are, but there's hundreds of them. There's also a rootkit, which I suspect is causing all these problems.
Are you able to run regedit.exe, or regedt32.exe?
Post by PatTheBaker on 30th May 2009, 9:19 pm
I can run regedit in Run, but don't know how to run regedit32.
PatTheBaker
Posts Posts : 67
Post by Belahzur on 30th May 2009, 9:26 pm
Good, we can do a proper reg fix.
I also have a new way to go. The logs come with a proper Hijack This log, meaning the Hijack This that is included in MGTools was able to run.
Open this folder in bold:
C:\MGTools
Inside there, there is a file called "Analyze.exe", try running it for me, does it run?
Post by PatTheBaker on 30th May 2009, 9:33 pm
Runs perfectly. Here's the log
Scan saved at 3:32:37 PM, on 5/30/2009
MSIE: Internet Explorer v7.00 (7.00.6000.16827)
C:\WINDOWS\system32\LEXBCES.EXE
C:\WINDOWS\system32\LEXPPS.EXE
C:\Program Files\Dell AIO Printer A920\dlbkbmgr.exe
C:\WINDOWS\BCMSMMSG.exe
C:\Program Files\Dell AIO Printer A920\dlbkbmon.exe
C:\WINDOWS\system32\hkcmd.exe
C:\Program Files\PowerISO\PWRISOVM.EXE
C:\Program Files\Veoh Networks\VeohWebPlayer\veohwebplayer.exe
C:\Documents and Settings\Khank\Local Settings\Application Data\Google\Update\GoogleUpdate.exe
C:\Program Files\Common Files\Nikon\Monitor\NkMonitor.exe
C:\Program Files\Symantec\LiveUpdate\AluSchedulerSvc.exe
C:\Program Files\Sunbelt Software\CounterSpy\SBAMSvc.exe
C:\Program Files\Viewpoint\Common\ViewpointService.exe
C:\Program Files\Compact Wireless-G USB Adapter Wireless Network Monitor\WLService.exe
C:\Program Files\Compact Wireless-G USB Adapter Wireless Network Monitor\WUSB54GC.exe
C:\Program Files\Sunbelt Software\CounterSpy\SBAMTray.exe
C:\Program Files\iTunes\iTunes.exe
C:\Documents and Settings\Khank\Local Settings\Application Data\Google\Chrome\Application\chrome.exe
C:\Program Files\Vuze\Azureus.exe
C:\MGtools\analyse.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = about:blank
R3 - URLSearchHook: (no name) - {37D2CDBF-2AF4-44AA-8113-BD0D2DA3C2B8} - (no file)
O2 - BHO: DriveLetterAccess - {5CA3D70E-1895-11CF-8E15-001234567890} - C:\WINDOWS\system32\dla\tfswshx.dll
O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - C:\Program Files\Google\Google Toolbar\GoogleToolbar.dll (file missing)
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.1.1309.3572\swg.dll
O2 - BHO: Google Dictionary Compression sdch - {C84D72FE-E17D-4195-BB24-76C02E2E7C4E} - C:\Program Files\Google\Google Toolbar\Component\fastsearch_A8904FB862BD9564.dll (file missing)
O3 - Toolbar: Veoh Web Player Video Finder - {0FBB9689-D3D7-4f7a-A2E2-585B10099BFC} - C:\Program Files\Veoh Networks\VeohWebPlayer\VeohIEToolbar.dll
O3 - Toolbar: Google Toolbar - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - C:\Program Files\Google\Google Toolbar\GoogleToolbar.dll (file missing)
O4 - HKLM\..\Run: [Dell AIO Printer A920] "C:\Program Files\Dell AIO Printer A920\dlbkbmgr.exe"
O4 - HKLM\..\Run: [BCMSMMSG] BCMSMMSG.exe
O4 - HKLM\..\Run: [StorageGuard] "C:\Program Files\Common Files\Sonic\Update Manager\sgtray.exe" /r
O4 - HKLM\..\Run: [IMJPMIG8.1] "C:\WINDOWS\IME\imjp8_1\IMJPMIG.EXE" /Spoil /RemAdvDef /Migration32
O4 - HKLM\..\Run: [MSPY2002] C:\WINDOWS\system32\IME\PINTLGNT\ImScInst.exe /SYNC
O4 - HKLM\..\Run: [PHIME2002ASync] C:\WINDOWS\system32\IME\TINTLGNT\TINTSETP.EXE /SYNC
O4 - HKLM\..\Run: [PHIME2002A] C:\WINDOWS\system32\IME\TINTLGNT\TINTSETP.EXE /IMEName
O4 - HKLM\..\Run: [igfxtray] C:\WINDOWS\system32\igfxtray.exe
O4 - HKLM\..\Run: [igfxhkcmd] C:\WINDOWS\system32\hkcmd.exe
O4 - HKLM\..\Run: [igfxpers] C:\WINDOWS\system32\igfxpers.exe
O4 - HKLM\..\Run: [NBKeyScan] "C:\Program Files\Nero\Nero8\Nero BackItUp\NBKeyScan.exe"
O4 - HKLM\..\Run: [PWRISOVM.EXE] C:\Program Files\PowerISO\PWRISOVM.EXE
O4 - HKLM\..\Run: [UnlockerAssistant] "C:\Program Files\Unlocker\UnlockerAssistant.exe"
O4 - HKLM\..\Run: [SBAMTray] C:\Program Files\Sunbelt Software\CounterSpy\SBAMTray.exe
O4 - HKCU\..\Run: [NetZero_uoltray] C:\Program Files\NetZero\exec.exe regrun
O4 - HKCU\..\Run: [IndxStoreSvr_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA}] "C:\Program Files\Common Files\Nero\Lib\NMIndexStoreSvr.exe" ASO-616B5711-6DAE-4795-A05F-39A1E5104020
O4 - HKCU\..\Run: [VeohPlugin] "C:\Program Files\Veoh Networks\VeohWebPlayer\veohwebplayer.exe"
O4 - HKCU\..\Run: [Google Update] "C:\Documents and Settings\Khank\Local Settings\Application Data\Google\Update\GoogleUpdate.exe" /c
O4 - HKUS\S-1-5-18\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe (User 'Default user')
O4 - Global Startup: Microsoft Office Fast Start.lnk = C:\MSOffice\Office\FASTBOOT.EXE
O4 - Global Startup: Microsoft Office Find Fast Indexer.lnk = C:\MSOffice\Office\FINDFAST.EXE
O4 - Global Startup: Microsoft Office Shortcut Bar.lnk = C:\MSOffice\Office\MSOFFICE.EXE
O4 - Global Startup: Nikon Monitor.lnk = C:\Program Files\Common Files\Nikon\Monitor\NkMonitor.exe
O8 - Extra context menu item: Display All Images with Full Quality - [You must be registered and logged in to see this link.] Files\NetZero\qsacc\appres.dll/228
O8 - Extra context menu item: Display Image with Full Quality - [You must be registered and logged in to see this link.] Files\NetZero\qsacc\appres.dll/227
O9 - Extra button: AIM - {AC9E2541-2814-11d5-BC6D-00B0D0A1DE45} - C:\Program Files\AIM\aim.exe
O17 - HKLM\System\CCS\Services\Tcpip\..\{329C4D81-999D-4FA6-9362-30ADD9F66163}: NameServer = 85.255.112.7,85.255.112.88
O17 - HKLM\System\CCS\Services\Tcpip\..\{43FD5B7D-2EAB-408E-8A51-0AD2B20A8475}: NameServer = 85.255.112.7,85.255.112.88
O17 - HKLM\System\CS1\Services\Tcpip\Parameters: NameServer = 85.255.112.7,85.255.112.88
O17 - HKLM\System\CS2\Services\Tcpip\Parameters: NameServer = 85.255.112.7,85.255.112.88
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: NameServer = 85.255.112.7,85.255.112.88
O18 - Filter: x-sdch - {B1759355-3EEC-4C1E-B0F1-B719FE26E377} - C:\Program Files\Google\Google Toolbar\Component\fastsearch_A8904FB862BD9564.dll
O23 - Service: Automatic LiveUpdate Scheduler - Symantec Corporation - C:\Program Files\Symantec\LiveUpdate\AluSchedulerSvc.exe
O23 - Service: FLEXnet Licensing Service - Macrovision Europe Ltd. - C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe
O23 - Service: LexBce Server (LexBceS) - Lexmark International, Inc. - C:\WINDOWS\system32\LEXBCES.EXE
O23 - Service: LiveUpdate - Symantec Corporation - C:\Program Files\Symantec\LiveUpdate\LuComServer_3_4.EXE
O23 - Service: Macromedia Licensing Service - Unknown owner - C:\Program Files\Common Files\Macromedia Shared\Service\Macromedia Licensing.exe
O23 - Service: Remote Packet Capture Protocol v.0 (experimental) (rpcapd) - CACE Technologies - C:\Program Files\WinPcap\rpcapd.exe
O23 - Service: CounterSpy Antispyware (SBAMSvc) - Sunbelt Software - C:\Program Files\Sunbelt Software\CounterSpy\SBAMSvc.exe
O23 - Service: PC Tools Auxiliary Service (sdAuxService) - PC Tools - C:\Program Files\Spyware Doctor\pctsAuxs.exe
O23 - Service: PC Tools Security Service (sdCoreService) - PC Tools - C:\Program Files\Spyware Doctor\pctsSvc.exe
O23 - Service: WUSB54GCSVC - GEMTEKS - C:\Program Files\Compact Wireless-G USB Adapter Wireless Network Monitor\WLService.exe
End of file - 11182 bytes
PatTheBaker
Posts Posts : 67
Post by Belahzur on 30th May 2009, 9:47 pm
Well, that's something. We can do a proper reg fix now.
  • Viewpoint Media Player
Next,
  • Open HijackThis (Analyze.exe)
Try updating CounterSpy now.
Post by PatTheBaker on 30th May 2009, 10:01 pm
It says the same thing, something about an error. I checked its system stats and it says it can't download threat definitions because of internet connection problems.
PatTheBaker
Posts Posts : 67
Post by Belahzur on 30th May 2009, 10:05 pm
Now we've lifted some weight, lets try Combofix again.
See [You must be registered and logged in to see this link.] for how to disable your AV..
Post by PatTheBaker on 30th May 2009, 10:43 pm
Here's the Log:
ComboFix 09-05-30.03 - Khank 05/30/2009 16:26.1 - NTFSx86
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.510.265 [GMT -6:00]
Running from: c:\documents and settings\Khank\Desktop\Combo-Fix.exe
C:\autorun.inf
c:\documents and settings\Khank\Application Data\EurekaLog
c:\documents and settings\Khank\Application Data\inst.exe
c:\windows\10459nzt-a-viru945a.bin
c:\windows\10592spambot35dz.dll
c:\windows\105955pz24b.bin
c:\windows\10760v5rus590z.ocx
c:\windows\10929virus15z.exe
c:\windows\1099back5zor2954.ocx
c:\windows\10b9a5d9are27z1.cpl
c:\windows\1105a9dwaze5945.bin
c:\windows\11309zi5us41a.dll
c:\windows\11358s5ambot39dz.cpl
c:\windows\11561vi9us5cz.ocx
c:\windows\11666wor59zf.ocx
c:\windows\11996vzrus3535.exe
c:\windows\119z9spye5.cpl
c:\windows\12003hac5too969z.ocx
c:\windows\12049or56ze.cpl
c:\windows\1211haczt9ol755.ocx
c:\windows\12571not-5zvi9us15f.bin
c:\windows\12863sp915z.cpl
c:\windows\12999zrus3d5.bin
c:\windows\129z9sp51ce.ocx
c:\windows\12bt95zf1278.ocx
c:\windows\13114zot-a-virus6539.dll
c:\windows\135255ormz9.exe
c:\windows\13739zacktool567.bin
c:\windows\13763hacz5o9l632.bin
c:\windows\13782vizu9695.dll
c:\windows\1389spy76z5.dll
c:\windows\13976worz79f5.dll
c:\windows\1397spy5aze757.bin
c:\windows\13993zac9tool355.cpl
c:\windows\13b9ba5kdozr1690.cpl
c:\windows\13d695r1857z.dll
c:\windows\13z37sp9m5ot79f.bin
c:\windows\14500tzoj978.dll
c:\windows\148899o5m6z.bin
c:\windows\1502ste59143z.dll
c:\windows\150z7worm9c7.exe
c:\windows\151zdow5loa9er1893.ocx
c:\windows\1520zs9a5bot392.ocx
c:\windows\153ethre5t1z928.exe
c:\windows\15558w9r547dz.dll
c:\windows\15569wo5mz5d.cpl
c:\windows\155bsparse9z2.ocx
c:\windows\1567spaz9ot6225.ocx
c:\windows\15832spz5699.ocx
c:\windows\158939py5z5.bin
c:\windows\15903hack5o9l5bz.bin
c:\windows\15964h95ktool127z.exe
c:\windows\1596backdozr294.ocx
c:\windows\15985worz77d9.bin
c:\windows\1629spywzre5524.bin
c:\windows\16405ha9ztool5aa.cpl
c:\windows\164105acktool590z.exe
c:\windows\164739zck5ool50f.bin
c:\windows\16592s9z366.ocx
c:\windows\16995wo9z595.exe
c:\windows\1721zhie92905.ocx
c:\windows\1761znot-a-9irus5c6.exe
c:\windows\1762do9nloader2535z.ocx
c:\windows\17754hazkt9ol681.dll
c:\windows\17821troj3z95.dll
c:\windows\17931wo5mz27.cpl
c:\windows\179435zrm23e.bin
c:\windows\17f19ddware5z23.bin
c:\windows\17ffd9wnlo5derz776.bin
c:\windows\18367zpambo9345.ocx
c:\windows\185fstezl9101.dll
c:\windows\18e0backd9orz3415.exe
c:\windows\190169pambot57z.bin
c:\windows\1937zhacktoo519b.ocx
c:\windows\19529ha5ktool57z.dll
c:\windows\19846not5a-vi9uz7b2.cpl
c:\windows\19az9ownloader3865.dll
c:\windows\1a5f5hzeat19613.exe
c:\windows\1a90t5reat2z575.exe
c:\windows\1b85backdoo9570z.dll
c:\windows\1b969i5867z.ocx
c:\windows\1bb8addwarz5095.bin
c:\windows\1cc4threat15597z.cpl
c:\windows\1d915zeal1594.bin
c:\windows\1e54zi91804.dll
c:\windows\1fzspar5e1921.bin
c:\windows\1z053troj59b.ocx
c:\windows\1z135spy489.bin
c:\windows\1z399sp5359.bin
c:\windows\1z53w9rm409.cpl
c:\windows\1z55thre9t21710.exe
c:\windows\1z69st95l2012.cpl
c:\windows\1z872hackto59705.cpl
c:\windows\1z9bsteal549.exe
c:\windows\1z9vir853.bin
c:\windows\1zbc9hief195.cpl
c:\windows\2057zv9ru538e.bin
c:\windows\205z1worm95c.exe
c:\windows\206425pz295.ocx
c:\windows\206795pyza0.dll
c:\windows\21099zroj335.dll
c:\windows\21339spambo5680z.dll
c:\windows\21395viruscz9.bin
c:\windows\21539spz437.cpl
c:\windows\2154ztro95a5.exe
c:\windows\215795or9z61.cpl
c:\windows\215z3not-9-virus348.exe
c:\windows\21774tzoj954.dll
c:\windows\22049h5ez2926.bin
c:\windows\22097nzt-a-virus54c.exe
c:\windows\22298wzrm58e5.dll
c:\windows\22572szy6d29.dll
c:\windows\22584w9zm53e.exe
c:\windows\227dback5o9z2581.bin
c:\windows\22890spamzo5652.bin
c:\windows\22993spy5z7.ocx
c:\windows\22c15ddware95z.bin
c:\windows\23458tz9563a.cpl
c:\windows\234zs9y445.bin
c:\windows\237039p5z41.exe
c:\windows\2379vzrus35c.ocx
c:\windows\23922spambotz295.bin
c:\windows\23985troz948.dll
c:\windows\239fvir15z9.bin
c:\windows\23z75tr9j419.dll
c:\windows\240049pzmbo51c8.ocx
c:\windows\2418ha5ktozl199.ocx
c:\windows\2440wor9755z.bin
c:\windows\24428sza5botba9.dll
c:\windows\24561not-a-zir9s3f8.dll
c:\windows\24562worm49z.bin
c:\windows\24571hzckt9ol1c0.bin
c:\windows\24707n5t-a-zir9s13f.bin
c:\windows\24796tr5z49f.exe
c:\windows\249735rojzb.bin
c:\windows\24f295zkdoor510.bin
c:\windows\25005zacktoo91fe.dll
c:\windows\25123vizus1a9.ocx
c:\windows\2517threat7649z.dll
c:\windows\25291spzmbotee.dll
c:\windows\25296wozma.bin
c:\windows\2533z5ot-a-virus3679.dll
c:\windows\2550threat89z5.dll
c:\windows\25552s9az5ot516.exe
c:\windows\255z9virus567.cpl
c:\windows\2580s5yz69.cpl
c:\windows\25817wzrm91f.cpl
c:\windows\258409py1b5z.cpl
c:\windows\25937not-azvi9us427.exe
c:\windows\25z639irus3c5.exe
c:\windows\2619z5roj9d3.ocx
c:\windows\26200hacktoo93e5z.bin
c:\windows\26855virzs5509.bin
c:\windows\268ezhrea514910.cpl
c:\windows\26995hzeat22591.dll
c:\windows\27291not-a-vzru569e.dll
c:\windows\273919azk5ool777.bin
c:\windows\27391z9rmf75.dll
c:\windows\27392tr5z979.ocx
c:\windows\273z5sp9mbot73a.bin
c:\windows\2751d9wnloader2859z.exe
c:\windows\2755th9ea512885z.cpl
c:\windows\27583wzrm19e9.exe
c:\windows\277695roz1b59.exe
c:\windows\27917szam5ot29e.cpl
c:\windows\27951hackt9olza2.bin
c:\windows\279849py25z.exe
c:\windows\279945pamboz41e.bin
c:\windows\27997troj4c5z.bin
c:\windows\27ad9wn5oadzr3241.dll
c:\windows\27z589or5230.exe
c:\windows\284z5ownloader14059.bin
c:\windows\28678s9azbot5715.exe
c:\windows\28715h9cktoo577z.ocx
c:\windows\28779pywaze559.cpl
c:\windows\28795spambzt54.cpl
c:\windows\28864ha95tzolc6.dll
c:\windows\28870w5rz4f09.ocx
c:\windows\2893th5ef1z.exe
c:\windows\289595z28e.bin
c:\windows\29008hzckto5959c.ocx
c:\windows\2906bazk9oor195.cpl
c:\windows\29142hacztool475.ocx
c:\windows\29155spy291z.cpl
c:\windows\29572spyz95.dll
c:\windows\29592spaz9ot20e.cpl
c:\windows\2959threatz9400.cpl
c:\windows\295bth5eatz1925.bin
c:\windows\29705trzj2b9.ocx
c:\windows\298375pz6f1.bin
c:\windows\298425zoj4e99.exe
c:\windows\298fazd5are573.dll
c:\windows\298z5worma.ocx
c:\windows\29915hackt5ol579z.bin
c:\windows\29b7a5dzare903.exe
c:\windows\29z84hackt5ol18.bin
c:\windows\2a2b5zdware16629.bin
c:\windows\2bc95hrzat29716.dll
c:\windows\2bzf5hie9973.exe
c:\windows\2d6c5hr9zt8592.dll
c:\windows\2db1s5azse7899.bin
c:\windows\2e079ackdozr5799.ocx
c:\windows\2e9s5eal10z3.exe
c:\windows\2eb2backdo9r3z56.bin
c:\windows\2f0dz5yw9re1673.dll
c:\windows\2f3a9pywaze16645.dll
c:\windows\2f5a5ir559z.dll
c:\windows\2fd59ownloadzr1889.dll
c:\windows\2z147s9y4915.cpl
c:\windows\2z17addwa5e759.cpl
c:\windows\2z511not-a-vi59s7e1.dll
c:\windows\2z75v5r2596.cpl
c:\windows\30024hack9ool651z.bin
c:\windows\301a95ezl2836.exe
c:\windows\30460h9cktool5dz.ocx
c:\windows\30504not95-virusz4e.ocx
c:\windows\3051zac5door2987.ocx
c:\windows\3061thief5939z.dll
c:\windows\30921tro5692z.cpl
c:\windows\3095py963z.dll
c:\windows\309z5spambo51f5.dll
c:\windows\30d5stealz940.dll
c:\windows\311cbac5zoo9195.exe
c:\windows\31256virus2z9.ocx
c:\windows\31331spam5z959a.cpl
c:\windows\31343not-9zvirus5db.ocx
c:\windows\31595sp9zb5.bin
c:\windows\3195zpy5b8.dll
c:\windows\319ddownlo5der320z.ocx
c:\windows\31b2spyware93z05.exe
c:\windows\31z01tr5j596.cpl
c:\windows\31z58not-a-vi5us4d9.ocx
c:\windows\31z95sp536a.bin
c:\windows\32145troj920z.ocx
c:\windows\32154zi9us3de.dll
c:\windows\329cbac5dzor1725.exe
c:\windows\335zspambot9fd.bin
c:\windows\336bs9zr5e2642.bin
c:\windows\34bedzw5l9ader3052.cpl
c:\windows\3514zirus7c39.dll
c:\windows\35223troj591z.cpl
c:\windows\3575t9oj6z8.cpl
c:\windows\3588zownl5ader2449.cpl
c:\windows\35899irz120.cpl
c:\windows\3599thzef994.ocx
c:\windows\35bzaddw9re20615.bin
c:\windows\382zvi95735.dll
c:\windows\3834down5zader988.ocx
c:\windows\391bthzea543589.ocx
c:\windows\39201s5yzae.bin
c:\windows\397bt5iez80.cpl
c:\windows\3989troj55z.dll
c:\windows\398aviz1859.cpl
c:\windows\3999s5y5fz.bin
c:\windows\399d5teal239z.exe
c:\windows\39b3spyware56z9.dll
c:\windows\39f9sp5rze659.exe
c:\windows\3a07downl5azer8549.bin
c:\windows\3a1abazkdo59753.cpl
c:\windows\3a25ba9zdoor1565.bin
c:\windows\3aabdow9loade5218z.dll
c:\windows\3aaz9i51063.bin
c:\windows\3b18t5rezt29982.cpl
c:\windows\3b9bthief5z46.bin
c:\windows\3bacthrea91469z5.cpl
c:\windows\3c56ste9z2261.ocx
c:\windows\3cb89py5zre720.cpl
c:\windows\3d8c9hie5z92.bin
c:\windows\3f94bac5dzor2624.dll
c:\windows\3fz2s9y5are1081.bin
c:\windows\3z0aspy59re364.bin
c:\windows\3z191sp918b5.cpl
c:\windows\3z59hacktool9105.cpl
c:\windows\3z856wor9614.exe
c:\windows\4102ha9kzool2795.cpl
c:\windows\4132vir9s7z5.cpl
c:\windows\41d6zhief95195.dll
c:\windows\4202virzs597.ocx
c:\windows\420caddz5re649.dll
c:\windows\426zvir5099.dll
c:\windows\42d9zhief2845.dll
c:\windows\4391zpyw5re2593.exe
c:\windows\4455vzr497.exe
c:\windows\45315ac9zool9d.exe
c:\windows\4565ackdooz3931.dll
c:\windows\45eeth5zf9554.bin
c:\windows\45z55ir1981.ocx
c:\windows\45zbaddw9re25085.bin
c:\windows\46829tealz253.bin
c:\windows\4698zirus6755.cpl
c:\windows\46ethi5fz099.dll
c:\windows\470hzcktoo59f1.exe
c:\windows\472fv5rz0399.ocx
c:\windows\4770szeal5691.exe
c:\windows\4778z5t-a-vir9s6b1.dll
c:\windows\48509pazse2113.cpl
c:\windows\485cb5zkdoor297.ocx
c:\windows\489ebac5dzor3057.bin
c:\windows\492dst9al5z59.cpl
c:\windows\4993sp5waze2430.cpl
c:\windows\49faa5zware916.exe
c:\windows\49zdvir3506.cpl
c:\windows\4a2thi5f2696z.exe
c:\windows\4a80ztea59694.bin
c:\windows\4b8aaddwaz51409.exe
c:\windows\4be65ackdoo92057z.cpl
c:\windows\4cdezte5l30039.bin
c:\windows\4d47thre953z436.exe
c:\windows\4e92az5ware943.ocx
c:\windows\4e9zspa5se1506.exe
c:\windows\4f4995ief349z.exe
c:\windows\4fethz9at48585.ocx
c:\windows\4z57ste9l2998.dll
c:\windows\504zspy569.bin
c:\windows\5079v5z351.cpl
c:\windows\5091vzr2598.exe
c:\windows\50c9th5ef3z59.cpl
c:\windows\50z37s9ambot212.cpl
c:\windows\510cspazs92914.exe
c:\windows\516hackto9l35z.cpl
c:\windows\5188w5rm579z.ocx
c:\windows\5198sp5mbzt5d2.bin
c:\windows\51z2ba5kdoor2795.bin
c:\windows\51zadd9are1228.exe
c:\windows\52053spzmbote09.cpl
c:\windows\523d9hz5f761.bin
c:\windows\525z9ot-a-vir5s22d.dll
c:\windows\529e5pyzare434.cpl
c:\windows\53018hacztool2b9.ocx
c:\windows\5345bzckdoo91570.dll
c:\windows\53479ack5oor1751z.dll
c:\windows\53751nzt-a-virus349.cpl
c:\windows\539parse5813z.exe
c:\windows\53e0szeal979.exe
c:\windows\53z7thre5t29693.cpl
c:\windows\54195hacktoolzbc.cpl
c:\windows\541cth9ef977z.exe
c:\windows\54293zroj5f0.ocx
c:\windows\542fadzware2591.dll
c:\windows\5441notza-virus9ad.cpl
c:\windows\5473t9zj2b5.exe
c:\windows\5486spy5are299z.bin
c:\windows\5497vz51900.exe
c:\windows\549dstzal2858.exe
c:\windows\54b99ownloazer2720.cpl
c:\windows\54bct59efz45.dll
c:\windows\55019ddwarz24955.dll
c:\windows\551789ot-a-virzs1b1.exe
c:\windows\551b9ownloadez463.exe
c:\windows\5534t9ief55z8.bin
c:\windows\5541spar9e227z.cpl
c:\windows\55592worm5z19.exe
c:\windows\555z9spy48a.exe
c:\windows\5567backdzor12699.bin
c:\windows\55789hacktool5d0z.ocx
c:\windows\5592wormz.exe
c:\windows\5599sp51z89.cpl
c:\windows\5599vir1985z.exe
c:\windows\55f7downloadzr9806.dll
c:\windows\55zethreat19778.bin
c:\windows\5619sparze9577.bin
c:\windows\5626dow5loader9759z.bin
c:\windows\5657b5ckd9zr2758.cpl
c:\windows\5663t9z5f3084.ocx
c:\windows\569zdware1528.exe
c:\windows\56e4addware96z.cpl
c:\windows\56fdzpyware9092.dll
c:\windows\5709worz397.cpl
c:\windows\5729worm5zb.dll
c:\windows\572ddoznloade92909.cpl
PatTheBaker
Posts Posts : 67
Post by PatTheBaker on 30th May 2009, 10:45 pm
c:\windows\5759v9rusz60.bin
c:\windows\575ds9ezl420.bin
c:\windows\5788not9azvirusef.dll
c:\windows\5792thie52z79.dll
c:\windows\579zac5tool4f4.bin
c:\windows\57afzackdoo9550.cpl
c:\windows\57c8do5nloader2z79.cpl
c:\windows\580ezownloader26559.dll
c:\windows\5815spyzc9.dll
c:\windows\584z5sp93bb.exe
c:\windows\5850zp5ware2950.bin
c:\windows\58bf9hiefz37.cpl
c:\windows\58d2backdoor297z5.ocx
c:\windows\58dbth5e9t7631z.cpl
c:\windows\58eca5z9are150.ocx
c:\windows\591ztroj540.ocx
c:\windows\5921downlo9dzr613.dll
c:\windows\5925spyware2326z.cpl
c:\windows\594esparse20z89.bin
c:\windows\5958backd5oz2159.dll
c:\windows\5961hzcktool299.bin
c:\windows\5967th5eaz9947.cpl
c:\windows\59904spa9bot37z.ocx
c:\windows\5991threat30253z.ocx
c:\windows\5995troj9fz.ocx
c:\windows\599athre9tz4508.dll
c:\windows\59c5steaz491.cpl
c:\windows\59e2thizf32215.ocx
c:\windows\5a02addwar517z69.exe
c:\windows\5a2z9teal2515.bin
c:\windows\5a55zir992.exe
c:\windows\5a9edownloader1046z.ocx
c:\windows\5b0daddwar95182z.bin
c:\windows\5bz7s9eal652.cpl
c:\windows\5bzedownloader794.bin
c:\windows\5c3daddw9re551z.dll
c:\windows\5c45do9nloadez1259.bin
c:\windows\5c7edz9nloader1053.exe
c:\windows\5d30t5izf9576.bin
c:\windows\5d51downzoa9er3213.cpl
c:\windows\5d99thr5at8099z.bin
c:\windows\5dfb9hizf5724.dll
c:\windows\5e51bz9kdoo5939.bin
c:\windows\5e94sparse5z54.ocx
c:\windows\5ea6spy9zre560.dll
c:\windows\5eb49parsez87.cpl
c:\windows\5ef1ad9ware42z5.cpl
c:\windows\5f53downlz5de9925.ocx
c:\windows\5z034spambot1e89.dll
c:\windows\5z26t5i9f1793.exe
c:\windows\5z30s5eal2495.cpl
c:\windows\5z405hief2389.bin
c:\windows\5z55troj6259.dll
c:\windows\5z59backdoor3134.bin
c:\windows\5z63ba5kdoor903.dll
c:\windows\5z675viru91a6.dll
c:\windows\5z87bac59oor1052.bin
c:\windows\5zafdow5loader2149.exe
c:\windows\5zb5th5eat25903.bin
c:\windows\5zc4th9eat32503.dll
c:\windows\5ze89t5al1676.ocx
c:\windows\60389zr5at6838.ocx
c:\windows\6057vzr2996.exe
c:\windows\6059zi595.ocx
c:\windows\6079spywzre155.ocx
c:\windows\609d5teal143z.dll
c:\windows\609zh5cktool3a4.exe
c:\windows\615zd9wnloader3212.cpl
c:\windows\6189hrez526026.cpl
c:\windows\6265azd9are1863.bin
c:\windows\6270spz9are375.bin
c:\windows\627est9az561.dll
c:\windows\6324t9ie532z6.cpl
c:\windows\639caddwa5ez538.cpl
c:\windows\63bcs9ezl1855.exe
c:\windows\63z5spar9e1593.bin
c:\windows\6486s5am9zt443.bin
c:\windows\64faspywzre594.bin
c:\windows\6505zteal9929.cpl
c:\windows\6530thzef969.dll
c:\windows\6559spywarez321.cpl
c:\windows\66959pyware359z.bin
c:\windows\669z5ownloader945.ocx
c:\windows\677este5l1z92.cpl
c:\windows\679zworm459.exe
c:\windows\67c15hizf1915.cpl
c:\windows\67d5sparsz1429.cpl
c:\windows\6866ad9warez795.exe
c:\windows\6895tr9z49f.exe
c:\windows\68dzteal1595.exe
c:\windows\6905spywa59z326.exe
c:\windows\6915haczto9l1ee.cpl
c:\windows\6937ad5waze2654.exe
c:\windows\69395pa9se8z9.bin
c:\windows\69ef5tezl27.ocx
c:\windows\6a9z5ddware2840.dll
c:\windows\6ae1sp9zse7105.exe
c:\windows\6b10thre9t155z.bin
c:\windows\6b4fd5wnloadez13299.dll
c:\windows\6bbbszars52991.cpl
c:\windows\6bd4v9r1035z.bin
c:\windows\6c7zdownlo5der1895.bin
c:\windows\6c94thrz5t14255.cpl
c:\windows\6cb6th9eat25845z.bin
c:\windows\6cbe5zdware3971.ocx
c:\windows\6e89th5ef2997z.cpl
c:\windows\6e8dtzreat25759.dll
c:\windows\6edzv9r15005.ocx
c:\windows\6f1adownloadez1592.exe
c:\windows\6f39spy5aze593.bin
c:\windows\6f595dd9are3z06.exe
c:\windows\6faaa9dw5ze1558.cpl
c:\windows\6fe5viz3079.cpl
c:\windows\6z3c5teal9519.bin
c:\windows\6z51bac9door2332.cpl
c:\windows\6z559roj3b.cpl
c:\windows\6ze2vir5529.bin
c:\windows\706ds5z9se2548.cpl
c:\windows\7092spyzf95.cpl
c:\windows\70z4s9y5e5.ocx
c:\windows\7285zirus4c9.bin
c:\windows\72c0add9a5e20z7.ocx
c:\windows\72ddvirz2559.cpl
c:\windows\7359st9zl1855.dll
c:\windows\73bc9z5rse985.cpl
c:\windows\742caddwa5z951.cpl
c:\windows\7453no9-a-v5rusza1.ocx
c:\windows\752dbackdoor9z44.ocx
c:\windows\758cspywar951z0.exe
c:\windows\759zt5r9at3073.exe
c:\windows\75bbs9arsz2857.bin
c:\windows\75cth9ea512756z.ocx
c:\windows\75fzsteal1915.bin
c:\windows\77239pywzre2395.exe
c:\windows\773ztro55c39.exe
c:\windows\7795adzware2649.bin
c:\windows\7851st9alz15.bin
c:\windows\78z3b5ckdoor2995.bin
c:\windows\791aaddwarz5406.dll
c:\windows\791cbac5dooz951.exe
c:\windows\79265acktooz299.cpl
c:\windows\7949b5ckdzor2774.ocx
c:\windows\7967threat1z578.dll
c:\windows\7994backdoo51z77.cpl
c:\windows\7998s5a9bzt39f.bin
c:\windows\79e8backdozr1952.bin
c:\windows\79f2thi5f1z53.exe
c:\windows\79z5vir13585.dll
c:\windows\7a509azkd5or1723.ocx
c:\windows\7b0zdownload5r9589.exe
c:\windows\7bbbz5arse339.cpl
c:\windows\7bf0steal5z69.ocx
c:\windows\7ce8ba5kdooz879.bin
c:\windows\7cz5vir1955.ocx
c:\windows\7d13s9eal251z.exe
c:\windows\7dz5bac5do9r167.dll
c:\windows\7e5bs9ez52745.ocx
c:\windows\7z8cbackdo9r3055.cpl
c:\windows\7zcdth9eat2547.dll
c:\windows\8500spz1d09.bin
c:\windows\859threat1z624.bin
c:\windows\86fsp95se1892z.exe
c:\windows\87bt5iez29.ocx
c:\windows\89549py4z95.cpl
c:\windows\8f0t5rezt39025.exe
c:\windows\903005pazbot768.dll
c:\windows\90637trzj25f.exe
c:\windows\90spywzre2755.bin
c:\windows\90zs5arse2654.exe
c:\windows\911335pz733.ocx
c:\windows\912spzrse515.exe
c:\windows\9135baczdoor2593.ocx
c:\windows\9165zspy40f.dll
c:\windows\91735z5y31f.bin
c:\windows\93414sp5431z.cpl
c:\windows\93dowzl5ader10329.bin
c:\windows\945659rusz7f.dll
c:\windows\948athreat1127z5.cpl
c:\windows\94z1downloader1425.cpl
c:\windows\95449ot-a-virzs5b1.cpl
c:\windows\95535oz-a-virus69c.ocx
c:\windows\955zvir1984.exe
c:\windows\95835spy11z.cpl
c:\windows\9591spzef5.exe
c:\windows\95933zroj40d.dll
c:\windows\95zathief5294.exe
c:\windows\96515hiefz37.bin
c:\windows\9659zhacktoole5.exe
c:\windows\9689tzoj55d.bin
c:\windows\96z85spyc8.exe
c:\windows\9723zp53f8.cpl
c:\windows\97433virus3z5.bin
c:\windows\97459orm3e8z.cpl
c:\windows\9795zspy65d.cpl
c:\windows\97a0th5eatz6644.dll
c:\windows\9863troj952z.cpl
c:\windows\98857nzt-a-5irus63a.cpl
c:\windows\98945teaz2069.ocx
c:\windows\9899iz3051.exe
c:\windows\989fv5r1z4.dll
c:\windows\990c5tealz11.cpl
c:\windows\990cst5al6z.cpl
c:\windows\99z65orm625.dll
c:\windows\9a23a5zware1931.ocx
c:\windows\9a58vi5z552.dll
c:\windows\9a8fspazse3531.ocx
c:\windows\9b2z9ywar5595.exe
c:\windows\9b85addwar51038z.dll
c:\windows\9c95pyware143z.exe
c:\windows\9cf8sz5al981.cpl
c:\windows\9dd5spazse295.cpl
c:\windows\9e5bazdwa5e2083.ocx
c:\windows\9e7espa5ze2886.cpl
c:\windows\9e82tz5ef1031.dll
c:\windows\9ea7spyware1595z.cpl
c:\windows\9ec1back5oorz385.ocx
c:\windows\9z29thief2955.bin
c:\windows\9z652virus586.dll
c:\windows\9z91vi95s55b.cpl
c:\windows\9z9worm59a9.cpl
PatTheBaker
Posts Posts : 67
c:\windows\9zc2spar5e338.exe
c:\windows\a899ackzoor2315.exe
c:\windows\afaz95al1532.ocx
c:\windows\b51steal2119z.ocx
c:\windows\b99t9iefz825.cpl
c:\windows\c00s5eal92z0.bin
c:\windows\c04addwaze94815.dll
c:\windows\cadadzware2953.ocx
c:\windows\ce9z9ywar5822.ocx
c:\windows\d10s9arse58z.exe
c:\windows\d2259yware2229z.exe
c:\windows\d6azhi9f5555.ocx
c:\windows\d94spz5se849.exe
c:\windows\da1ad9wa5e27z8.cpl
c:\windows\dz8thief995.ocx
c:\windows\e99spar5ez923.cpl
c:\windows\ef6addwzr9565.dll
c:\windows\f38d9wnloadez5265.dll
c:\windows\f509teal36z.ocx
c:\windows\fb1s5azs9415.cpl
c:\windows\fbz95eal689.cpl
c:\windows\fc3addwa9z535.cpl
c:\windows\system32\101z1ha5ktool490.dll
c:\windows\system32\10255vi9u5z14.cpl
c:\windows\system32\10511zot-a-v5rus7da9.dll
c:\windows\system32\10551virus2za9.exe
c:\windows\system32\10853trzj49b.cpl
c:\windows\system32\10z6t59ef2698.ocx
c:\windows\system32\11061not-a-9iru56dz.dll
c:\windows\system32\11084spyzc59.bin
c:\windows\system32\11234wozm595.exe
c:\windows\system32\115599pz460.ocx
c:\windows\system32\11921spy752z.exe
c:\windows\system32\11986hacktozl6935.dll
c:\windows\system32\1199bazkdo5r1207.bin
c:\windows\system32\11z95viru5467.cpl
c:\windows\system32\12045s9am5ot74dz.dll
c:\windows\system32\12045szy995.cpl
c:\windows\system32\122585izus1d9.cpl
c:\windows\system32\122595r107z.bin
c:\windows\system32\12388no9-a-virus5z3.bin
c:\windows\system32\1253z9y205.ocx
c:\windows\system32\12559zorm314.bin
c:\windows\system32\12651nzt-a-vir9s60f.dll
c:\windows\system32\12950not-9-virus5bz5.exe
c:\windows\system32\132509roz7445.exe
c:\windows\system32\13304spz9bo5fd.cpl
c:\windows\system32\13591spamzo587.exe
c:\windows\system32\13596spamzo5755.cpl
c:\windows\system32\13905vir9s7cz.cpl
c:\windows\system32\139zvirus77d5.exe
c:\windows\system32\1446bzckdoor559.cpl
c:\windows\system32\145zsparse14999.bin
c:\windows\system32\1493thi9fz1195.exe
c:\windows\system32\1493zhrea91542.dll
c:\windows\system32\14c8spzrs91995.ocx
c:\windows\system32\14z115py1e9.cpl
c:\windows\system32\14z57not-a-v9rus56.bin
c:\windows\system32\150e9a5kdoor1548z.ocx
c:\windows\system32\15101h5z9tool573.cpl
c:\windows\system32\15157s9ambot8cz.cpl
c:\windows\system32\15391hac9toolz9c.exe
c:\windows\system32\15532zpy49c.dll
c:\windows\system32\157z5worm92.bin
c:\windows\system32\1594zworm2509.ocx
c:\windows\system32\1595zhac9tool714.cpl
c:\windows\system32\15994n5t-a-virus1e0z.dll
c:\windows\system32\159z5ha5ktoo9145.ocx
c:\windows\system32\159z7spam5ot589.exe
c:\windows\system32\15b5spywaze159.bin
c:\windows\system32\15b8zhre9t592.ocx
c:\windows\system32\15d5backdooz459.exe
c:\windows\system32\15e9virz229.ocx
c:\windows\system32\15z5add9are1870.cpl
c:\windows\system32\16048spa5zot493.bin
c:\windows\system32\16068hack5zol7b69.dll
c:\windows\system32\16100n95-azvirus1f0.dll
c:\windows\system32\16249v5rus9fz.exe
c:\windows\system32\16351s9amboz618.cpl
c:\windows\system32\166cdow5loz9er1098.bin
c:\windows\system32\166fbac9z5or2321.cpl
c:\windows\system32\16954szambo52ac.cpl
c:\windows\system32\171945acktozl2c4.ocx
c:\windows\system32\17194viru5z07.bin
c:\windows\system32\172905pambo96cz.dll
c:\windows\system32\17343spazbot295.ocx
c:\windows\system32\176z1not-59virus733.dll
c:\windows\system32\17906hackt59l2dbz.cpl
c:\windows\system32\17a3ste952z14.cpl
c:\windows\system32\17e5thzef5369.ocx
c:\windows\system32\17z5troj951.cpl
c:\windows\system32\18398not-a-zi5us28f.cpl
c:\windows\system32\184479o5za-virusb1.exe
c:\windows\system32\188929azktool2d5.ocx
c:\windows\system32\1895threat58z19.cpl
c:\windows\system32\19057not-a-5iru9z84.bin
c:\windows\system32\190z9acktool150.bin
c:\windows\system32\19549spy42z.ocx
c:\windows\system32\195bbackdoo5235z.bin
c:\windows\system32\19755spz6955.exe
c:\windows\system32\1975zno5-a9virus39d.ocx
c:\windows\system32\197739ackt5ol4z9.ocx
c:\windows\system32\197z3t5oj21a.bin
c:\windows\system32\19803hackzool395.cpl
c:\windows\system32\19833s9zmbot725.exe
c:\windows\system32\19855w9rmz60.bin
c:\windows\system32\19958hack9ool72z.cpl
c:\windows\system32\1995zspy9c5.cpl
c:\windows\system32\19cethzef2125.bin
c:\windows\system32\19d25hrzat5399.ocx
c:\windows\system32\19ezpa5se30669.dll
c:\windows\system32\1ab9downloadzr575.ocx
c:\windows\system32\1bbbszarse56909.dll
c:\windows\system32\1be59hief248z.cpl
c:\windows\system32\1c08sparse39z35.exe
c:\windows\system32\1d59zhief1424.ocx
c:\windows\system32\1dd9hiez2523.dll
c:\windows\system32\1e49zdd5are2719.dll
c:\windows\system32\1e96add5arez535.cpl
c:\windows\system32\1ff4downloa9er51z.exe
c:\windows\system32\1z1cs5eal2990.bin
c:\windows\system32\1z260spam5o95e2.exe
c:\windows\system32\1z559spambot15f9.cpl
c:\windows\system32\1z5cthreat95366.cpl
c:\windows\system32\1z90thie5817.exe
c:\windows\system32\1z9ddownloa5er3028.ocx
c:\windows\system32\1zee9h5ef517.cpl
c:\windows\system32\20093spzmbot20b5.ocx
c:\windows\system32\2040z9orm145.cpl
c:\windows\system32\2059ztroj591.dll
c:\windows\system32\207215acktozlc39.dll
c:\windows\system32\20793hac5tooz7cd.bin
c:\windows\system32\207z8s95380.ocx
c:\windows\system32\2097worm5z55.bin
c:\windows\system32\20f9s5yware14z4.bin
c:\windows\system32\21094s95za7.exe
c:\windows\system32\21170t9o52z6.bin
c:\windows\system32\21303s5amzot90.bin
c:\windows\system32\21399t5oj59z.cpl
c:\windows\system32\21509n5tza-virus2c9.bin
c:\windows\system32\21537w95m112z.exe
c:\windows\system32\2159spars91z45.cpl
c:\windows\system32\215cvzr2893.cpl
c:\windows\system32\21cst5al26z9.ocx
c:\windows\system32\21z29vi9u568d.cpl
c:\windows\system32\2225t9z5223.ocx
c:\windows\system32\2247995yza9.ocx
c:\windows\system32\22532spamb9t453z.bin
c:\windows\system32\2275zno9-a-virus20c.ocx
c:\windows\system32\23180worz4259.cpl
c:\windows\system32\23445zpy961.bin
c:\windows\system32\23479zpy5a9.exe
c:\windows\system32\23499z5y780.ocx
c:\windows\system32\2379s95zl1679.ocx
c:\windows\system32\2379threzt18556.bin
c:\windows\system32\23896spaz9ot665.dll
c:\windows\system32\24450s5az9ota6.exe
c:\windows\system32\24491ha5ztool6169.cpl
c:\windows\system32\24565hac95ool2z3.ocx
c:\windows\system32\24590hac9tozl5d0.exe
c:\windows\system32\24634wzr512e9.cpl
c:\windows\system32\247a5pa9sez47.dll
c:\windows\system32\24955zirus457.ocx
c:\windows\system32\24993wo5mz7a.exe
c:\windows\system32\25063spz9a2.cpl
c:\windows\system32\2513ad9ware85z.cpl
c:\windows\system32\2529zvirus5c2.ocx
c:\windows\system32\25322not-a-zir9s51d.exe
c:\windows\system32\254809i5us64z.bin
c:\windows\system32\25579n59-a-vizusea.dll
c:\windows\system32\2558zpyware5369.ocx
c:\windows\system32\2559dozn9oader1797.dll
c:\windows\system32\2564z9orm78d.exe
c:\windows\system32\256downlozder2938.dll
c:\windows\system32\25819wozm7c05.ocx
c:\windows\system32\25926sp9mbot7z35.ocx
c:\windows\system32\25940not-9-virusz30.exe
c:\windows\system32\259435iz9s556.cpl
c:\windows\system32\2598zsp927.ocx
c:\windows\system32\25fzad9war53209.exe
c:\windows\system32\25z7t9ief282.cpl
c:\windows\system32\25z93spambot509.bin
c:\windows\system32\26222zi5us290.cpl
c:\windows\system32\2655ztroj4149.cpl
c:\windows\system32\2698not9a-vir5sza1.exe
c:\windows\system32\26c5zi520389.dll
c:\windows\system32\26c79hreatz24485.bin
c:\windows\system32\27066virzs5079.ocx
c:\windows\system32\274345iru93ze.dll
c:\windows\system32\27589rzj297.exe
c:\windows\system32\2763thze516409.cpl
c:\windows\system32\27729v9r5s4bz.bin
c:\windows\system32\27974notza-viru5493.bin
PatTheBaker
Posts Posts : 67
Post by PatTheBaker on 30th May 2009, 10:46 pm
c:\windows\system32\27z09worm5625.dll
c:\windows\system32\2805s9yware218z5.dll
c:\windows\system32\2827b9ckdooz852.bin
c:\windows\system32\28659tzo57a9.dll
c:\windows\system32\28698vir9z71e5.dll
c:\windows\system32\2896vizus5415.dll
c:\windows\system32\28z08w5rm1f9.dll
c:\windows\system32\2915tzreat1499.dll
c:\windows\system32\29222sz562c.bin
c:\windows\system32\292z0troj755.exe
c:\windows\system32\2930zhack5o9l213.exe
c:\windows\system32\2932z5dware3095.cpl
c:\windows\system32\29373vi5usz88.cpl
c:\windows\system32\2939zn5t-a-virus586.cpl
c:\windows\system32\293z9spy1795.dll
c:\windows\system32\29495spa9boz6155.dll
c:\windows\system32\294z3not-a-virus557.exe
c:\windows\system32\29538wor9215z.bin
c:\windows\system32\29568virus64fz.ocx
c:\windows\system32\2961znot-a-5irus99e.bin
c:\windows\system32\29785t9oj32z.exe
c:\windows\system32\29968tzojc25.dll
c:\windows\system32\29992sz951a.cpl
c:\windows\system32\299baddwa5z2615.bin
c:\windows\system32\29b5s9arsz1199.ocx
c:\windows\system32\29z7wor52d9.ocx
c:\windows\system32\2a1zdown9oade5621.bin
c:\windows\system32\2a29thi5z1855.bin
c:\windows\system32\2a59t9r5at12z55.exe
c:\windows\system32\2a6avi91075z.ocx
c:\windows\system32\2a7cback9ooz1525.cpl
c:\windows\system32\2az9a5dware2699.exe
c:\windows\system32\2b205z93154.bin
c:\windows\system32\2b80szy5are9301.dll
c:\windows\system32\2bc9bzckdoo95475.bin
c:\windows\system32\2bde9zeal5040.bin
c:\windows\system32\2c38ad9warz2135.cpl
c:\windows\system32\2dzadown9oader1154.ocx
c:\windows\system32\2e35backdoor2359z.cpl
c:\windows\system32\2ebbs9arse157z.dll
c:\windows\system32\2f59ztea96995.cpl
c:\windows\system32\2fz5downlo5der24219.exe
c:\windows\system32\2z298t5oj690.exe
c:\windows\system32\2z757h5c9tool527.bin
c:\windows\system32\2z870vir592a3.ocx
c:\windows\system32\2z885spambo9684.cpl
c:\windows\system32\2z9259roj5b1.ocx
c:\windows\system32\2z99spars511579.exe
c:\windows\system32\30194spambot5e9z.dll
c:\windows\system32\30439not-a5virus77z.ocx
c:\windows\system32\30914sp9mzot55c.cpl
c:\windows\system32\3099z5ot-a-vi9us4a4.exe
c:\windows\system32\309downl9adez1051.cpl
c:\windows\system32\31796hacztool595.exe
c:\windows\system32\31927not-a-viru59cz.bin
c:\windows\system32\31z345py6649.cpl
c:\windows\system32\320athz9at549.bin
c:\windows\system32\322099ir5s1dz.ocx
c:\windows\system32\323575o9m4z.cpl
c:\windows\system32\32429t5oj7z9.bin
c:\windows\system32\324699irzs7235.ocx
c:\windows\system32\3261spaz5ot949.bin
c:\windows\system32\33ddspywarez4295.cpl
c:\windows\system32\342bt5rea9198z9.exe
c:\windows\system32\349cd9wnl5azer1008.bin
c:\windows\system32\3515backdoor193z9.exe
c:\windows\system32\3526ha5ktzol5c99.cpl
c:\windows\system32\352ft9iez2621.bin
c:\windows\system32\3569download95947z.dll
c:\windows\system32\3597spzware3557.ocx
c:\windows\system32\3597zdd5ar9363.ocx
c:\windows\system32\359c9pywarz5623.ocx
c:\windows\system32\359dsparse15z2.ocx
c:\windows\system32\3659thief409z.bin
c:\windows\system32\3666downzo5de91037.dll
c:\windows\system32\36d8thief2z859.dll
c:\windows\system32\36z0t5r9at17708.cpl
c:\windows\system32\3793spz95re157.cpl
c:\windows\system32\379dst5az2381.dll
c:\windows\system32\38e25pywaze1998.bin
c:\windows\system32\3901vi5z919.exe
c:\windows\system32\39353spamboz6e7.bin
c:\windows\system32\393adownlzad9r1596.ocx
c:\windows\system32\3966thz5f3993.dll
c:\windows\system32\3a3dba9kdoor2057z.ocx
c:\windows\system32\3az9th5ef2739.exe
c:\windows\system32\3b97steal1z915.ocx
c:\windows\system32\3b9zthief2425.dll
c:\windows\system32\3bfcdowzlo5der2119.exe
c:\windows\system32\3c885hief94z5.bin
c:\windows\system32\3d0dthi59z688.dll
c:\windows\system32\3d21vi532z19.dll
c:\windows\system32\3d95ba5zdoor2694.dll
c:\windows\system32\3dc5downloader55z59.bin
c:\windows\system32\3dccspz9are5709.bin
c:\windows\system32\3e51zir4779.exe
c:\windows\system32\3e8c9ownload5rz052.exe
c:\windows\system32\3ez0spy9are2465.exe
c:\windows\system32\3ez3th5eat4967.ocx
c:\windows\system32\3z1spar591459.dll
c:\windows\system32\3z35thr9at13166.bin
c:\windows\system32\3z51vir895.exe
c:\windows\system32\3z575not-a-virus7599.dll
c:\windows\system32\3z59spyware2410.exe
c:\windows\system32\3z5ddownlo5de92044.cpl
c:\windows\system32\3z98downloader2571.bin
c:\windows\system32\40759py1z5.dll
c:\windows\system32\41ddt59zf1948.exe
c:\windows\system32\42149pamzotf5.bin
c:\windows\system32\4284t9zj5ef.cpl
c:\windows\system32\42aedowzloader659.cpl
c:\windows\system32\42f4zir29805.cpl
c:\windows\system32\43cbt5zef3209.bin
c:\windows\system32\442d5ddw9rz2895.dll
c:\windows\system32\445vir9z7a5.bin
c:\windows\system32\44z4spam59t59f.dll
c:\windows\system32\452est9zl2383.ocx
c:\windows\system32\4553zor9525.ocx
c:\windows\system32\4588spyzare9199.dll
c:\windows\system32\45cfsparze5195.bin
c:\windows\system32\4625t9rza529536.cpl
c:\windows\system32\4690addwar5202z.exe
c:\windows\system32\4693zacktoo54139.cpl
c:\windows\system32\46a9zir575.cpl
c:\windows\system32\46dz9i52596.ocx
c:\windows\system32\472cdo5nloader98z0.ocx
c:\windows\system32\473zw5rm292.bin
c:\windows\system32\4932spazse2405.exe
c:\windows\system32\496ddownl9aderz52.exe
c:\windows\system32\4997ad5ware1z31.exe
c:\windows\system32\49a05ir2z94.ocx
c:\windows\system32\49a1threaz76135.dll
c:\windows\system32\49b7downzoade5987.dll
c:\windows\system32\49bzback5oor24949.dll
c:\windows\system32\49c5tzief5289.dll
c:\windows\system32\49z95roj459.bin
c:\windows\system32\4a5z9ief3058.cpl
c:\windows\system32\4b4thr59t94z9.dll
c:\windows\system32\4b67doznload5r1219.cpl
c:\windows\system32\4c56backd9zr3056.bin
c:\windows\system32\4c65threat90z67.ocx
c:\windows\system32\4d189teal4z55.cpl
c:\windows\system32\4d85spa9se3158z.cpl
c:\windows\system32\4ddfza5kdoo91956.dll
c:\windows\system32\4de7spywa5e2z99.cpl
c:\windows\system32\4effdow5loader9z04.exe
c:\windows\system32\4f01dozn9oade51316.cpl
c:\windows\system32\4f149hreat32z395.ocx
c:\windows\system32\4f95viz19589.ocx
c:\windows\system32\4fe6downl9adez5919.ocx
c:\windows\system32\4ze8downloa9er5416.bin
c:\windows\system32\5005vzr5549.cpl
c:\windows\system32\50509ackt5ol4z1.ocx
c:\windows\system32\50609spamb9t4ze.bin
c:\windows\system32\50620not9a-virus55ez.cpl
c:\windows\system32\511499irus66z.cpl
c:\windows\system32\51444zo9m28a.dll
c:\windows\system32\51593wormz86.bin
c:\windows\system32\5176z9r1579.bin
c:\windows\system32\5195threat4z1.cpl
c:\windows\system32\5199sz5al1980.cpl
c:\windows\system32\519zspy9ca.bin
c:\windows\system32\51c295ief326z.bin
c:\windows\system32\51e49zyware46.bin
c:\windows\system32\51fz9teal2195.dll
c:\windows\system32\52058not9a-vzrus3e2.ocx
c:\windows\system32\5224w5rm5fz9.cpl
c:\windows\system32\5237ba9kdoz5588.cpl
c:\windows\system32\5245vir9z36.bin
c:\windows\system32\525bthief98z2.bin
c:\windows\system32\5289tzief5785.cpl
c:\windows\system32\5289zpyware526.ocx
c:\windows\system32\52919worz26d.exe
c:\windows\system32\5299not-a-viruz5cb.dll
c:\windows\system32\529etzreat8495.dll
c:\windows\system32\531ebackd5or9z9.ocx
c:\windows\system32\532btzief21079.exe
c:\windows\system32\53345zrm39e9.ocx
c:\windows\system32\534349roj5z5.bin
c:\windows\system32\536zsp9ware1951.ocx
c:\windows\system32\5399spyz9re2145.ocx
c:\windows\system32\54403z9oj35b.dll
c:\windows\system32\5451b9ckdoo5213z.cpl
c:\windows\system32\545zspar9e31635.ocx
c:\windows\system32\54925virus66dz.ocx
c:\windows\system32\54dedown5oazer94.exe
c:\windows\system32\54fevzr22129.cpl
c:\windows\system32\55395ownlozder3211.dll
c:\windows\system32\5546vir1922z.cpl
c:\windows\system32\5591hzcktoo9392.bin
c:\windows\system32\5599s5yz95.ocx
c:\windows\system32\559spa5se3z92.cpl
c:\windows\system32\55adownloz9er1649.bin
c:\windows\system32\55b9pyware7z6.dll
c:\windows\system32\55c6vir962z.bin
c:\windows\system32\55f5downlza9er1566.dll
c:\windows\system32\55z6thie995.dll
c:\windows\system32\55z8steal17769.ocx
c:\windows\system32\5600zackdoo95351.exe
c:\windows\system32\5638backd9orz645.dll
c:\windows\system32\564bb9ckdoor2358z.cpl
c:\windows\system32\565bth9ez1432.dll
c:\windows\system32\56706vzrus9c5.cpl
c:\windows\system32\56z0backdo9r1548.dll
c:\windows\system32\57012vizus590.cpl
c:\windows\system32\5709downl5ader2z96.ocx
c:\windows\system32\5709spy2z.bin
c:\windows\system32\570t9zj1d.dll
c:\windows\system32\572z2worm9f4.ocx
c:\windows\system32\5752spa5sez905.bin
c:\windows\system32\57652szy99b.ocx
c:\windows\system32\5791znot-a-virus335.cpl
c:\windows\system32\57b9spywzre495.cpl
c:\windows\system32\57cfzow9loader5393.bin
c:\windows\system32\581edownl9ad5r1164z.bin
c:\windows\system32\588dth9ef16z45.ocx
c:\windows\system32\58912spa9bztbf.exe
c:\windows\system32\5895spy9are14z0.cpl
c:\windows\system32\5895steal39z4.bin
c:\windows\system32\589etzrea54095.cpl
c:\windows\system32\589z5spambot6a2.bin
c:\windows\system32\58b5downloader289z.bin
c:\windows\system32\590zworm93.bin
c:\windows\system32\591bz5kdoor2134.bin
c:\windows\system32\5920vir2233z.ocx
c:\windows\system32\595aspyzare593.bin
c:\windows\system32\597fzhreat96858.dll
c:\windows\system32\597z5ot-a-viruse9.ocx
c:\windows\system32\598addware5609z.ocx
c:\windows\system32\5994zteal9583.ocx
c:\windows\system32\5999tzoj650.bin
c:\windows\system32\599z5hief3.cpl
c:\windows\system32\599zvir2590.ocx
c:\windows\system32\59cthrzat90213.bin
c:\windows\system32\59e2vi52853z.exe
c:\windows\system32\59ezthre5t5781.ocx
c:\windows\system32\5a755hre9tz987.cpl
c:\windows\system32\5a9dszar5e22679.ocx
c:\windows\system32\5azbspar592112.bin
c:\windows\system32\5b32sp9rse194z.exe
c:\windows\system32\5b49d9wnl5ader10z4.bin
c:\windows\system32\5b5fbackdoorz5199.exe
c:\windows\system32\5b8czownl95der1069.cpl
c:\windows\system32\5b9cspar5z2824.dll
c:\windows\system32\5bcbadd9arez553.dll
c:\windows\system32\5bz4vir559.cpl
c:\windows\system32\5c55zp9ware1019.dll
c:\windows\system32\5c70z9a5se984.bin
c:\windows\system32\5c76stealz958.exe
c:\windows\system32\5cbbbzckdoor2394.dll
c:\windows\system32\5ce5bac9doz52266.dll
c:\windows\system32\5d19spywaze3085.ocx
c:\windows\system32\5d955hizf2409.bin
c:\windows\system32\5df3spzr5e9323.bin
c:\windows\system32\5e7cdow5loader189z.dll
c:\windows\system32\5fcfdownl95zer3071.bin
c:\windows\system32\5z0asp9ware1466.cpl
c:\windows\system32\5z2a5hrea917185.ocx
c:\windows\system32\5z54thie9862.dll
c:\windows\system32\5z56stea9527.dll
c:\windows\system32\5z995spy5c5.bin
c:\windows\system32\5zb9sp5rs91067.ocx
c:\windows\system32\6021azdw9re523.exe
c:\windows\system32\6096worz795.bin
c:\windows\system32\6114nzt-5-virus9c9.exe
c:\windows\system32\6124z9wnloader5740.exe
c:\windows\system32\6157not5a-vzrus491.ocx
c:\windows\system32\61a4bzc9door2158.cpl
c:\windows\system32\61cfdow5loa9er2z27.ocx
c:\windows\system32\621cdownzoad5r909.dll
c:\windows\system32\622aspa5s9195z.exe
c:\windows\system32\6235spyware2z949.bin
c:\windows\system32\625zspar9e2689.ocx
c:\windows\system32\625zvirus5799.cpl
c:\windows\system32\62a5vir250z9.cpl
c:\windows\system32\6591doznloader869.exe
c:\windows\system32\6599vzru553b.bin
c:\windows\system32\65c9vzr537.dll
c:\windows\system32\65dabaczdoor92.cpl
PatTheBaker
Posts Posts : 67
c:\windows\system32\65e1thzef901.bin
c:\windows\system32\65z9vir2599.dll
c:\windows\system32\6633bzck9o5r560.cpl
c:\windows\system32\6635thzef492.cpl
c:\windows\system32\665b5hi9f15z3.bin
c:\windows\system32\669bspyw5ze1350.exe
c:\windows\system32\6721s5z9bot13b.ocx
c:\windows\system32\6723hzc9too5151.dll
c:\windows\system32\67335ot-9-zirus529.bin
c:\windows\system32\6765vir1900z.cpl
c:\windows\system32\6823vi5us1z9.bin
c:\windows\system32\689bthizf1175.bin
c:\windows\system32\6907stea52z77.bin
c:\windows\system32\694cdownloa5er1z59.exe
c:\windows\system32\6959zi91115.exe
c:\windows\system32\695fsze5l3259.dll
c:\windows\system32\695zspyware2651.ocx
c:\windows\system32\6984v5r156z.dll
c:\windows\system32\69azaddw9re857.ocx
c:\windows\system32\69b6spy9aze4835.ocx
c:\windows\system32\69e1z5r893.bin
c:\windows\system32\69zaddware5760.exe
c:\windows\system32\6b84s5za91018.ocx
c:\windows\system32\6c5b9ackdoorz995.dll
c:\windows\system32\6d24thze9475.bin
c:\windows\system32\6e64thizf18459.exe
c:\windows\system32\6z5cs9yware2681.bin
c:\windows\system32\6zfcspywa9e1345.exe
c:\windows\system32\7055thief139z.ocx
c:\windows\system32\709es9ywarz1657.bin
c:\windows\system32\7116virus4z59.exe
c:\windows\system32\713zw9rm2585.cpl
c:\windows\system32\7222vzru9205.cpl
c:\windows\system32\722c5zea91403.cpl
c:\windows\system32\72329pambot7zc5.ocx
c:\windows\system32\734f5ownloadz9748.exe
c:\windows\system32\735zdow9loader2688.bin
c:\windows\system32\7399spy5are534z.dll
c:\windows\system32\73z3sp9mb5t6e8.ocx
c:\windows\system32\7412spzrse2592.bin
c:\windows\system32\7439spyz5f.bin
c:\windows\system32\7495addzare15859.exe
c:\windows\system32\7495zhrea55937.bin
c:\windows\system32\755bdownzoader1079.dll
c:\windows\system32\756zvir19455.dll
c:\windows\system32\7584hzckto9l757.exe
c:\windows\system32\7598thief2857z.bin
c:\windows\system32\75fbthief599z.ocx
c:\windows\system32\75z8steal21319.cpl
c:\windows\system32\7624zack59ol397.bin
c:\windows\system32\766f5iz2931.exe
c:\windows\system32\7717szy6905.ocx
c:\windows\system32\77b1spa5s9z95.bin
c:\windows\system32\77e2szy95re965.exe
c:\windows\system32\7820sp5wzre1992.cpl
c:\windows\system32\78235pywaze1269.dll
c:\windows\system32\78459zyware827.bin
c:\windows\system32\787z5parse3949.ocx
c:\windows\system32\789nzt-a-virus495.cpl
c:\windows\system32\7931spyware25z7.dll
c:\windows\system32\7932vir975z.cpl
c:\windows\system32\79a5add9aze167.ocx
c:\windows\system32\79f4ste9l5z79.bin
c:\windows\system32\79z9vir4519.bin
c:\windows\system32\7a53thzef493.bin
c:\windows\system32\7ec8do9nzoad5r2083.cpl
c:\windows\system32\7f22s5ea92z85.cpl
c:\windows\system32\7f5avir9z5.ocx
c:\windows\system32\7z559arse3068.bin
c:\windows\system32\7z58v5r32459.exe
c:\windows\system32\7z95ba5kdoor615.exe
c:\windows\system32\81645irus697z.bin
c:\windows\system32\8572z9y597.cpl
c:\windows\system32\85zt9reat20607.cpl
c:\windows\system32\871z9p5615.cpl
c:\windows\system32\87ddown5oader16z19.exe
c:\windows\system32\8876spam9oz6c5.bin
c:\windows\system32\89z5hi9f2691.bin
c:\windows\system32\8z7tr9j2685.cpl
c:\windows\system32\90152spyzb45.ocx
c:\windows\system32\902czir555.exe
c:\windows\system32\902zthi5f167.bin
c:\windows\system32\90350spazbot110.cpl
c:\windows\system32\903z3not-a-virus5b5.bin
c:\windows\system32\905025pambotzd3.exe
c:\windows\system32\908thr9at41z15.exe
c:\windows\system32\910troj25z.exe
c:\windows\system32\91445zirus6f8.exe
c:\windows\system32\9159troz4a35.bin
c:\windows\system32\9167n5t9a-zirus6f.ocx
c:\windows\system32\9175tro9z7c.cpl
c:\windows\system32\917espa5sez445.ocx
c:\windows\system32\9190zh5ef2776.cpl
c:\windows\system32\91z6troj46b5.cpl
c:\windows\system32\925915acztool59a.cpl
c:\windows\system32\926z59y693.bin
c:\windows\system32\931downloade5462z.dll
c:\windows\system32\931spz5bot162.exe
c:\windows\system32\9354z9oj476.ocx
c:\windows\system32\93e5viz3010.exe
c:\windows\system32\93z63vir5s5a4.bin
c:\windows\system32\9414tzoj519.cpl
c:\windows\system32\941sparsz258.ocx
c:\windows\system32\9436zpambot531.ocx
c:\windows\system32\9446b5zkdoor362.ocx
c:\windows\system32\9505ir1z0.exe
c:\windows\system32\95108hacktoo55z1.exe
c:\windows\system32\952f5parsez165.cpl
c:\windows\system32\95339irus93z.cpl
c:\windows\system32\953975irus23z.cpl
c:\windows\system32\955woz5129.ocx
c:\windows\system32\9592zo9m7595.dll
c:\windows\system32\9598zwor5212.bin
c:\windows\system32\95996zpy57.bin
c:\windows\system32\9599spam5ot2zc.exe
c:\windows\system32\9599steal1z4.cpl
c:\windows\system32\959o5z92.cpl
c:\windows\system32\95z7t9o5140.bin
c:\windows\system32\9651sparsez32.ocx
c:\windows\system32\96f5thiez2172.dll
c:\windows\system32\973f5ir12z8.exe
c:\windows\system32\9771sp5z99.bin
c:\windows\system32\9802w5r9zbe.cpl
c:\windows\system32\9891spyz3e5.dll
c:\windows\system32\9912not-z-viru5c3.ocx
c:\windows\system32\9952sparse356z.cpl
c:\windows\system32\9953spamzot59c.bin
c:\windows\system32\9953zhreat57565.bin
c:\windows\system32\9a31vir31z45.bin
c:\windows\system32\9b6zvir5425.cpl
c:\windows\system32\9cedthie5912z.ocx
c:\windows\system32\9d1bdoznloader9805.ocx
c:\windows\system32\9dzaddware2545.bin
c:\windows\system32\9e9fdownz5ader1981.dll
c:\windows\system32\9fbdbac5doorz36.dll
c:\windows\system32\9fddow9zoader9485.cpl
c:\windows\system32\9z10spywa5e1696.exe
c:\windows\system32\9z20t5reat28195.ocx
c:\windows\system32\9z2fbackdo5r1388.cpl
c:\windows\system32\9z785teal3011.exe
c:\windows\system32\9z9cthreat15500.dll
c:\windows\system32\9zf5vir1821.ocx
c:\windows\system32\a05addwar91z10.dll
c:\windows\system32\bdbs9ez51585.dll
c:\windows\system32\c7cz5ea92526.bin
c:\windows\system32\caav5r195z.dll
c:\windows\system32\cfzth95at20521.ocx
c:\windows\system32\d36stza93500.exe
c:\windows\system32\d55t9reat25z88.bin
c:\windows\system32\dcad5wnzoa9er2550.exe
c:\windows\system32\disk.dll
c:\windows\system32\drivers\gxvxcappxmqwuthextuwykrgrfvyviqqhxwxo.sys
c:\windows\system32\drivers\gxvxcbnijgjruenxoducjyotfrmqrfrmdvtmn.sys
c:\windows\system32\drivers\gxvxcpqjrutpkdaiyqvdkmoypuplvbphrrvrs.sys
c:\windows\system32\drivers\gxvxcqpttivjmrgftjecbeybinspjipxnssrx.sys
c:\windows\system32\drivers\gxvxcrrprtuoqpttiqxducbnmyqbaixjeyneh.sys
c:\windows\system32\dz5th9ef97.ocx
c:\windows\system32\e35b5ckz9or169.ocx
c:\windows\system32\e58sp9w5re3z46.bin
c:\windows\system32\e79st9al1z65.cpl
c:\windows\system32\ef79hreat54185z.ocx
c:\windows\system32\f559ac5zoor1453.bin
c:\windows\system32\f78dow5loader9z.ocx
c:\windows\system32\fe1s9zal13905.cpl
c:\windows\system32\g
c:\windows\system32\gxvxcklvrjoehucnamwxwbuvrmoqbdtdahwwc.dll
c:\windows\system32\gxvxcltairqltapqeqfpqakddxyjduwnxvipp.dll
c:\windows\system32\msni.exe
c:\windows\system32\z0429viru9155.exe
c:\windows\system32\z0665pambot7449.bin
c:\windows\system32\z152t5ief1956.bin
c:\windows\system32\z1833troj4955.exe
c:\windows\system32\z1940spamb5t9ac.ocx
c:\windows\system32\z2030w5rm7719.cpl
c:\windows\system32\z279spyware594.exe
c:\windows\system32\z2939w5rm2dd.exe
c:\windows\system32\z33bthi5f689.exe
c:\windows\system32\z34849orm2c5.exe
c:\windows\system32\z4548virus509.ocx
c:\windows\system32\z4563vi9us35.ocx
c:\windows\system32\z459spy65b.bin
c:\windows\system32\z45bthief52619.exe
c:\windows\system32\z5299wo9m675.ocx
c:\windows\system32\z5747hacktoo598d.exe
c:\windows\system32\z579threat71389.bin
c:\windows\system32\z595spyware1723.bin
c:\windows\system32\z5ba9kdoor1022.cpl
c:\windows\system32\z5c9st9al2654.bin
c:\windows\system32\z5desparse955.exe
c:\windows\system32\z696steal1058.cpl
c:\windows\system32\z69csteal2549.ocx
c:\windows\system32\z721st5al5279.cpl
c:\windows\system32\z767spambot5c9.bin
c:\windows\system32\z8225spy9b3.bin
c:\windows\system32\z865threat12957.exe
c:\windows\system32\z939t5oj5b1.ocx
c:\windows\system32\z95faddware2018.dll
c:\windows\system32\z9706worm5f9.ocx
c:\windows\system32\z9c8a5dware2913.dll
c:\windows\system32\z9da5ir1909.bin
c:\windows\system32\za5downl9ader23.cpl
c:\windows\system32\zabbackdo9r2550.ocx
c:\windows\system32\zabfstea520949.exe
c:\windows\system32\zb85ba5kdoor3926.exe
c:\windows\system32\zd69hief2451.exe
c:\windows\system32\zd6backdo5r2397.cpl
c:\windows\system32\zeb5sp5war92454.dll
c:\windows\system32\zf15vir159.cpl
c:\windows\system32\zf48addware50499.exe
c:\windows\Tasks\{5B57CF47-0BFA-43c6-ACF9-3B3653DCADBA}.job
c:\windows\winhelp.ini
c:\windows\z02625py6679.ocx
c:\windows\z0692hacktool1935.dll
c:\windows\z0915sp9mbot6bc.ocx
c:\windows\z095threat24001.dll
c:\windows\z0a9s59al2560.exe
c:\windows\z1173worm4795.cpl
c:\windows\z135vir9s3b7.bin
c:\windows\z1979spam5ot565.cpl
c:\windows\z2592not-a-vi9us695.cpl
c:\windows\z2905ddware2505.cpl
c:\windows\z299sparse2305.exe
c:\windows\z2f39pyware155.dll
c:\windows\z3041spambo54369.ocx
c:\windows\z3569hief857.dll
c:\windows\z36steal7539.ocx
c:\windows\z39dow9l5ader79.exe
c:\windows\z3c6t95eat26466.ocx
c:\windows\z3d8t9reat15518.cpl
c:\windows\z41bst59l639.ocx
c:\windows\z424thie51291.cpl
c:\windows\z45steal9422.cpl
c:\windows\z556thief2694.bin
c:\windows\z577wo9m500.dll
c:\windows\z5800sp9mbot50b.cpl
c:\windows\z5962sp5914.bin
c:\windows\z5c9steal1693.exe
c:\windows\z69fsp9rs5541.exe
c:\windows\z6eaddwar91559.cpl
c:\windows\z81faddw9re5757.cpl
c:\windows\z8359worm56c.dll
c:\windows\z845downloader95275.cpl
c:\windows\z85ethr9at6212.cpl
c:\windows\z8891h5ckt9ol155.dll
c:\windows\z9307s5y3fb.exe
c:\windows\z9335not-a-virus9a85.dll
c:\windows\z975hackto5l9fb.ocx
c:\windows\z998095cktool46d.bin
c:\windows\z9f4spywar517049.ocx
c:\windows\za1t9re5t23293.dll
c:\windows\zae39ir5071.exe
c:\windows\zb27steal3359.cpl
c:\windows\zb5fbackdoor27339.dll
c:\windows\zbb7threat97549.bin
c:\windows\zcf5threat95867.exe
c:\windows\zd05vir982.ocx
c:\windows\zd51a59ware2357.dll
c:\windows\zd95threat24785.exe
c:\windows\ze00spywa5e16909.cpl
c:\windows\zf15dow9loader1118.exe
c:\windows\zfdcs95rse747.cpl
c:\windows\zfe3addware9657.bin
E:\Autorun.inf
PatTheBaker
Posts Posts : 67
Joined Joined : 2009-05-29
OS OS : XP Home Edition
Points Points : 27605
Re: WinBlue Soft Help Please
Post by PatTheBaker on 30th May 2009, 10:47 pm
-------\Service_GXVXCSERV.SYS
((((((((((((((((((((((((( Files Created from 2009-04-28 to 2009-05-30 )))))))))))))))))))))))))))))))
2009-05-30 19:15 . 2009-05-26 19:20 40160 ----a-w c:\windows\system32\drivers\mbamswissarmy.sys
2009-05-30 19:15 . 2009-05-30 19:15 -------- d-----w c:\program files\Malwarebytes' Anti-Malware
2009-05-30 19:15 . 2009-05-30 19:15 -------- d-----w c:\documents and settings\All Users\Application Data\Malwarebytes
2009-05-30 19:15 . 2009-05-26 19:19 19096 ----a-w c:\windows\system32\drivers\mbam.sys
2009-05-30 19:01 . 2009-05-30 19:01 -------- d-----w c:\documents and settings\Khank\Application Data\Sunbelt
2009-05-30 19:01 . 2009-05-30 19:01 -------- d-----w c:\documents and settings\All Users\Application Data\Sunbelt
2009-05-30 19:00 . 2009-05-30 19:00 -------- d-----w c:\program files\Sunbelt Software
2009-05-30 17:22 . 2009-05-30 19:13 109897 ----a-w C:\MGlogs.zip
2009-05-30 17:22 . 2009-05-30 21:57 -------- d-----w C:\MGtools
2009-05-29 19:04 . 2009-05-29 19:04 -------- d-----w c:\program files\Trend Micro
2009-05-27 13:48 . 2009-05-27 14:08 -------- d-----w c:\documents and settings\LocalService\Local Settings\Application Data\Google
2009-05-11 21:53 . 2009-05-11 21:53 -------- d-----w c:\program files\iTunes
2009-05-11 21:53 . 2009-05-11 21:53 -------- d-----w c:\documents and settings\All Users\Application Data\{8CD7F5AF-ECFA-4793-BF40-D8F42DBFF906}
2009-05-11 21:43 . 2009-05-11 21:43 75048 ----a-w c:\documents and settings\All Users\Application Data\Apple Computer\Installer Cache\iTunes 8.1.1.10\SetupAdmin.exe
2009-05-11 13:01 . 2009-04-17 22:58 954368 ----a-w c:\documents and settings\Khank\Application Data\Mozilla\Firefox\Profiles\ulvay4f5.default\extensions\piclens@cooliris.com\libs\PicLensHelper.exe
2009-05-11 13:01 . 2009-04-17 22:58 103424 ----a-w c:\documents and settings\Khank\Application Data\Mozilla\Firefox\Profiles\ulvay4f5.default\extensions\piclens@cooliris.com\libs\pixomatic.dll
2009-05-11 13:01 . 2009-04-17 22:58 65536 ----a-w c:\documents and settings\Khank\Application Data\Mozilla\Firefox\Profiles\ulvay4f5.default\extensions\piclens@cooliris.com\components\coolirisstub.dll
2009-05-11 13:01 . 2009-04-17 22:58 1161626 ----a-w c:\documents and settings\Khank\Application Data\Mozilla\Firefox\Profiles\ulvay4f5.default\extensions\piclens@cooliris.com\libs\avcodec-51.dll
2009-05-11 13:01 . 2009-04-17 22:58 344064 ----a-w c:\documents and settings\Khank\Application Data\Mozilla\Firefox\Profiles\ulvay4f5.default\extensions\piclens@cooliris.com\libs\LaunchCooliris.exe
2009-05-11 13:01 . 2009-04-17 22:58 71652 ----a-w c:\documents and settings\Khank\Application Data\Mozilla\Firefox\Profiles\ulvay4f5.default\extensions\piclens@cooliris.com\libs\avutil-49.dll
2009-05-11 13:01 . 2009-04-17 22:58 4579328 ----a-w c:\documents and settings\Khank\Application Data\Mozilla\Firefox\Profiles\ulvay4f5.default\extensions\piclens@cooliris.com\libs\cooliris18.dll
2009-05-11 13:01 . 2009-04-17 22:58 4534272 ----a-w c:\documents and settings\Khank\Application Data\Mozilla\Firefox\Profiles\ulvay4f5.default\extensions\piclens@cooliris.com\libs\cooliris19.dll
2009-05-11 13:01 . 2009-04-17 22:58 131868 ----a-w c:\documents and settings\Khank\Application Data\Mozilla\Firefox\Profiles\ulvay4f5.default\extensions\piclens@cooliris.com\libs\avformat-52.dll
2009-05-09 05:53 . 2009-05-09 05:53 -------- d-----w c:\program files\FLV to MP3 Converter
2009-05-07 09:28 . 2009-05-07 09:28 14165 ----a-w c:\windows\9342noz-5-virus.exe
2009-05-30 22:11 . 2008-08-04 14:20 -------- d-----w c:\documents and settings\Khank\Application Data\Azureus
2009-05-30 21:55 . 2007-08-09 00:46 -------- d-----w c:\documents and settings\All Users\Application Data\Viewpoint
2009-05-30 15:39 . 2007-08-08 02:45 60592 ----a-w c:\documents and settings\BaoChau\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2009-05-28 19:50 . 2007-08-08 21:23 -------- d-----w c:\program files\Google
2009-05-28 19:35 . 2009-03-13 20:25 -------- d-----w c:\program files\Ipod Video Converter
2009-05-28 15:35 . 2008-06-28 16:12 -------- d-----w c:\documents and settings\All Users\Application Data\Google Updater
2009-05-27 14:14 . 2008-09-01 16:59 -------- d-----w c:\program files\Vuze
2009-05-27 00:11 . 2009-03-30 18:05 -------- d-----w c:\program files\PowerISO
2009-05-27 00:06 . 2008-06-28 18:05 -------- d---a-w c:\documents and settings\All Users\Application Data\TEMP
2009-05-26 12:59 . 2008-06-28 18:04 -------- d-----w c:\program files\Spyware Doctor
2009-05-11 21:53 . 2007-11-23 02:58 -------- d-----w c:\program files\iPod
2009-05-11 21:53 . 2008-07-03 21:57 -------- d-----w c:\program files\Common Files\Apple
2009-05-05 02:26 . 2008-11-12 02:24 1 ----a-w c:\documents and settings\Khank\Application Data\OpenOffice.org\3\user\uno_packages\cache\stamp.sys
2009-04-21 13:01 . 2009-04-21 03:15 -------- d-----w c:\program files\Unlocker
2009-04-21 03:30 . 2007-08-08 20:51 -------- d-----w c:\program files\Warcraft III
2009-04-21 03:19 . 2007-08-08 20:53 160889 ----a-w c:\windows\War3Unin.dat
2009-04-21 03:16 . 2009-04-21 03:16 -------- d-----w c:\documents and settings\Khank\Application Data\Desktopicon
2009-04-14 22:29 . 2007-10-01 02:30 -------- d-----w c:\program files\Java
2009-04-14 22:27 . 2009-04-14 22:27 152576 ----a-w c:\documents and settings\Khank\Application Data\Sun\Java\jre1.6.0_13\lzma.dll
2009-04-11 14:14 . 2009-03-17 23:55 -------- d-----w c:\documents and settings\Khank\Application Data\Skype
2009-04-02 20:07 . 2007-08-08 21:04 -------- d--h--w c:\program files\InstallShield Installation Information
2009-04-02 20:07 . 2007-08-08 21:04 -------- d-----w c:\program files\LucasArts
2009-04-02 03:38 . 2009-04-02 03:38 -------- d-----w c:\documents and settings\All Users\Application Data\PC Drivers HeadQuarters
2009-03-30 18:36 . 2007-08-10 18:05 60592 ----a-w c:\documents and settings\Khank\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2009-03-22 00:12 . 2009-03-22 00:12 22169 ----a-w c:\program files\setuplog.txt
2009-03-22 00:12 . 2009-03-22 00:12 20254 ----a-w c:\program files\uninstall.log
2009-03-19 22:32 . 2009-03-19 22:32 23400 ----a-w c:\documents and settings\All Users\Application Data\{8CD7F5AF-ECFA-4793-BF40-D8F42DBFF906}\x86\x86\GEARAspiWDM.sys
2009-03-19 22:32 . 2008-01-29 18:01 23400 ----a-w c:\windows\system32\drivers\GEARAspiWDM.sys
2009-03-17 19:26 . 2009-03-17 19:26 65320 ----a-w c:\windows\system32\sbbd.exe
2009-03-14 18:14 . 2009-03-14 18:14 152576 ----a-w c:\documents and settings\Khank\Application Data\Sun\Java\jre1.6.0_12\lzma.dll
2009-03-09 11:19 . 2008-11-24 03:33 410984 ----a-w c:\windows\system32\deploytk.dll
2009-03-06 14:22 . 2004-08-04 10:00 284160 ----a-w c:\windows\system32\pdh.dll
2009-03-06 05:59 . 2009-03-21 15:15 1900544 ----a-w c:\windows\system32\usbaaplrc.dll
2009-03-06 05:59 . 2008-07-03 21:57 36864 ----a-w c:\windows\system32\drivers\usbaapl.sys
2009-03-03 00:18 . 2006-03-04 03:33 826368 ----a-w c:\windows\system32\wininet.dll
"VeohPlugin"="c:\program files\Veoh Networks\VeohWebPlayer\veohwebplayer.exe" [2008-12-16 3528440]
"Google Update"="c:\documents and settings\Khank\Local Settings\Application Data\Google\Update\GoogleUpdate.exe" [2009-05-14 133104]
"Dell AIO Printer A920"="c:\program files\Dell AIO Printer A920\dlbkbmgr.exe" [2003-05-03 270336]
"dla"="c:\windows\system32\dla\tfswctrl.exe" [2003-08-06 114741]
"StorageGuard"="c:\program files\Common Files\Sonic\Update Manager\sgtray.exe" [2003-02-13 155648]
"IMJPMIG8.1"="c:\windows\IME\imjp8_1\IMJPMIG.EXE" [2004-08-04 208952]
"MSPY2002"="c:\windows\system32\IME\PINTLGNT\ImScInst.exe" [2004-08-04 59392]
"PHIME2002ASync"="c:\windows\system32\IME\TINTLGNT\TINTSETP.EXE" [2004-08-04 455168]
"PHIME2002A"="c:\windows\system32\IME\TINTLGNT\TINTSETP.EXE" [2004-08-04 455168]
"igfxtray"="c:\windows\system32\igfxtray.exe" [2005-09-20 94208]
"igfxhkcmd"="c:\windows\system32\hkcmd.exe" [2005-09-20 77824]
"igfxpers"="c:\windows\system32\igfxpers.exe" [2005-09-20 114688]
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 8.0\Reader\Reader_sl.exe" [2008-01-12 39792]
"AppleSyncNotifier"="c:\program files\Common Files\Apple\Mobile Device Support\bin\AppleSyncNotifier.exe" [2009-03-26 177472]
"PWRISOVM.EXE"="c:\program files\PowerISO\PWRISOVM.EXE" [2007-08-07 200704]
"SunJavaUpdateSched"="c:\program files\Java\jre6\bin\jusched.exe" [2009-03-09 148888]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2009-04-02 342312]
"SBAMTray"="c:\program files\Sunbelt Software\CounterSpy\SBAMTray.exe" [2009-03-17 681256]
"BCMSMMSG"="BCMSMMSG.exe" - c:\windows\BCMSMMSG.exe [2003-08-29 122880]
Microsoft Office Fast Start.lnk - c:\msoffice\Office\FASTBOOT.EXE [1995-9-27 14848]
Microsoft Office Find Fast Indexer.lnk - c:\msoffice\Office\FINDFAST.EXE [1995-9-27 86528]
Microsoft Office Shortcut Bar.lnk - c:\msoffice\Office\MSOFFICE.EXE [1995-9-27 365056]
Nikon Monitor.lnk - c:\program files\Common Files\Nikon\Monitor\NkMonitor.exe [2007-10-18 479232]
"NoDispBackgroundPage"= 1 (0x1)
HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\drivers32
"wave"= serwvdrv.dll
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\SBAMSvc]
PatTheBaker
Posts Posts : 67
"c:\\WINDOWS\\system32\\LEXPPS.EXE"=
"c:\\Program Files\\AIM\\aim.exe"=
"c:\\Program Files\\Warcraft III\\Warcraft III.exe"=
"c:\\Program Files\\Starcraft\\starcraft.exe"=
"c:\\Program Files\\Java\\jre1.6.0_02\\bin\\javaw.exe"=
"c:\\Program Files\\EA GAMES\\The Battle for Middle-earth (tm)\\game.dat"=
"c:\\Program Files\\Valve\\Steam\\SteamApps\\yellowpie\\counter-strike\\hl.exe"=
"c:\\Program Files\\Valve\\Steam\\SteamApps\\yellowpie\\condition zero\\hl.exe"=
"c:\\Program Files\\Valve\\Steam\\SteamApps\\yellowpie\\condition zero deleted scenes\\hl.exe"=
"c:\\Program Files\\Mozilla Firefox\\firefox.exe"=
"c:\\Program Files\\Valve\\Steam\\Steam.exe"=
"e:\\Khanh\\Warcraft III\\war3.exe"=
"c:\\Program Files\\Warcraft III\\war3.exe"=
"c:\\Program Files\\Valve\\Steam\\SteamApps\\yellowpie\\deathmatch classic\\hl.exe"=
"c:\\Program Files\\Valve\\Steam\\SteamApps\\yellowpie\\dedicated server\\hlds.exe"=
"c:\\Program Files\\Valve\\Steam\\SteamApps\\yellowpie\\team fortress classic\\hl.exe"=
"c:\\WINDOWS\\system32\\fxsclnt.exe"=
"c:\\Program Files\\OroBaduk\\OrO20.exe"=
"c:\\Program Files\\Vuze\\Azureus.exe"=
"c:\\Program Files\\qGo\\qGo.exe"=
"c:\\Program Files\\Veoh Networks\\VeohWebPlayer\\veohwebplayer.exe"=
"1723:TCP"= 1723:TCP:@xpsp2res.dll,-22015
"1701:UDP"= 1701:UDP:@xpsp2res.dll,-22016
"500:UDP"= 500:UDP:@xpsp2res.dll,-22017
R2 NwSapAgent;SAP Agent;c:\windows\system32\svchost.exe -k netsvcs [8/4/2004 4:00 AM 14336]
R2 SBAMSvc;CounterSpy Antispyware;c:\program files\Sunbelt Software\CounterSpy\SBAMSvc.exe [3/17/2009 1:26 PM 894248]
S3 getPlus(R) Helper;getPlus(R) Helper;c:\program files\NOS\bin\getPlus_HelperSvc.exe [10/18/2008 6:57 AM 33752]
S3 NPF;NetGroup Packet Filter Driver;c:\windows\system32\drivers\npf.sys [8/2/2005 3:10 PM 32512]
S3 SCREAMINGBDRIVER;Screaming Bee Audio;c:\windows\system32\drivers\ScreamingBAudio.sys --> c:\windows\system32\drivers\ScreamingBAudio.sys [?]
S3 sdAuxService;PC Tools Auxiliary Service;c:\program files\Spyware Doctor\pctsAuxs.exe [6/28/2008 12:04 PM 747912]
*NewlyCreated* - GTNDIS5
2008-12-29 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2008-07-30 18:34]
2009-05-30 c:\windows\Tasks\Google Software Updater.job
- c:\program files\Google\Common\Google Updater\GoogleUpdaterService.exe [2008-06-28 01:06]
2009-05-29 c:\windows\Tasks\GoogleUpdateTaskUserS-1-5-21-1409082233-823518204-839522115-1005.job
- c:\documents and settings\Khank\Local Settings\Application Data\Google\Update\GoogleUpdate.exe [2009-05-14 21:50]
HKCU-Run-NetZero_uoltray - c:\program files\NetZero\exec.exe
HKCU-Run-IndxStoreSvr_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA} - c:\program files\Common Files\Nero\Lib\NMIndexStoreSvr.exe
HKCU-Run-Aim6 - (no file)
HKLM-Run-NBKeyScan - c:\program files\Nero\Nero8\Nero BackItUp\NBKeyScan.exe
HKLM-Run-UnlockerAssistant - c:\program files\Unlocker\UnlockerAssistant.exe
HKLM-Run-WinBlueSoft - (no file)
SafeBoot-procexp90.Sys
IE: Display All Images with Full Quality - c:\program files\NetZero\qsacc\appres.dll/228
IE: Display Image with Full Quality - c:\program files\NetZero\qsacc\appres.dll/227
Filter: x-sdch - {B1759355-3EEC-4C1E-B0F1-B719FE26E377} -
FF - ProfilePath - c:\documents and settings\Khank\Application Data\Mozilla\Firefox\Profiles\ulvay4f5.default\
FF - prefs.js: browser.search.selectedEngine - Google
FF - component: c:\documents and settings\Khank\Application Data\Mozilla\Firefox\Profiles\ulvay4f5.default\extensions\piclens@cooliris.com\components\coolirisstub.dll
FF - component: c:\program files\Mozilla Firefox\extensions\{B13721C7-F507-4982-B2E5-502A71474FED}\components\NPComponent.dll
FF - plugin: c:\documents and settings\Khank\Local Settings\Application Data\Google\Update\1.2.145.5\npGoogleOneClick8.dll
FF - plugin: c:\program files\Google\Google Updater\2.4.1536.6592\npCIDetect13.dll
FF - plugin: c:\program files\Veoh Networks\VeohWebPlayer\NPVeohTVPlugin.dll
FF - plugin: c:\program files\Veoh Networks\VeohWebPlayer\npWebPlayerVideoPluginATL.dll
Rootkit scan 2009-05-30 16:35
[HKEY_LOCAL_MACHINE\software\Classes\ *O*** **_*a*u*t*o*_*f*i*l*e*\shell\Play]
@="Play with VLC"
[HKEY_LOCAL_MACHINE\software\Classes\ *O*** **_*a*u*t*o*_*f*i*l*e*\shell\Play\command]
@="c:\\Program Files\\VideoLAN\\VLC\\vlc.exe --started-from-file \"%1\""
Completion time: 2009-05-30 16:38
ComboFix-quarantined-files.txt 2009-05-30 22:37
Pre-Run: 31,602,720,768 bytes free
Post-Run: 32,510,558,208 bytes free
1551 --- E O F --- 2009-05-14 04:04
PatTheBaker
Posts Posts : 67
Post by Belahzur on 30th May 2009, 10:52 pm
I'm sure the machine is feeling better now, and much faster too. There is still some problems left though.
I see that you are running Ares.
If Ares is not removed, then I won't help you.
Now open a new notepad file.
KILLALL::
File::
C:\MGlogs.zip
Folder::
C:\MGtools
Registry::
"NoDispBackgroundPage"=-
"c:\\Program Files\\Vuze\\Azureus.exe"=-
Points Points : 245121
Post by PatTheBaker on 31st May 2009, 12:22 am
Here's the Log:
ComboFix 09-05-30.03 - Khank 05/30/2009 18:08.2 - NTFSx86
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.510.257 [GMT -6:00]
Running from: c:\documents and settings\Khank\Desktop\Combo-Fix.exe
Command switches used :: c:\documents and settings\Khank\Desktop\CFScript.txt
FILE ::
"C:\MGlogs.zip"
"c:\windows\9342noz-5-virus.exe"
C:\MGlogs.zip
C:\MGtools
c:\mgtools\analyse.exe
c:\mgtools\backups\backup-20090530-155740-160
c:\mgtools\backups\backup-20090530-155740-190
c:\mgtools\backups\backup-20090530-155740-358
c:\mgtools\backups\backup-20090530-155740-465
c:\mgtools\backups\backup-20090530-155740-512
c:\mgtools\backups\backup-20090530-155740-775
c:\mgtools\backups\backup-20090530-155740-795
c:\mgtools\backups\backup-20090530-155740-892
c:\mgtools\backups\backup-20090530-155740-974
c:\mgtools\chodefix.bat
c:\mgtools\config.reg
c:\mgtools\DisableUAC.reg
c:\mgtools\EnableUAC.reg
c:\mgtools\ffdata.txt
c:\mgtools\filelog.txt
c:\mgtools\FindOVL.bat
c:\mgtools\FixBagle.bat
c:\mgtools\fixBagle.reg
c:\mgtools\FixCF.bat
c:\mgtools\fixCF.reg
c:\mgtools\fixChode.reg
c:\mgtools\FixFA.bat
c:\mgtools\fixFA.reg
c:\mgtools\GetDetails.exe
c:\mgtools\GetLogs.Bat
c:\mgtools\GetRunKey.bat
c:\mgtools\GetUnKey.txt
c:\mgtools\GetUnKeys.bat
c:\mgtools\grep.exe
c:\mgtools\GRK64.bat
c:\mgtools\hide.reg
c:\mgtools\hijackthis.log
c:\mgtools\history.txt
c:\mgtools\HTAfind.bat
c:\mgtools\IEFIX.reg
c:\mgtools\locate.com
c:\mgtools\ltime.exe
c:\mgtools\newfiles.txt
c:\mgtools\procdll.txt
c:\mgtools\Process.exe
c:\mgtools\ProcessDll.exe
c:\mgtools\Regfix.bat
c:\mgtools\runkeys.txt
c:\mgtools\sed.exe
c:\mgtools\ShowNew.bat
c:\mgtools\SN64.bat
c:\mgtools\swreg.exe
c:\mgtools\swwhoami.exe
c:\mgtools\sysinfo.txt
c:\mgtools\sysrest.txt
c:\mgtools\unhide.reg
c:\mgtools\UserInfo.bat
c:\mgtools\UserInfo.txt
c:\mgtools\vfind.exe
c:\mgtools\VunFind.bat
c:\mgtools\winfiles.txt
c:\mgtools\zip.exe
c:\program files\Vuze\.install4j\_shfoldr.dll
c:\program files\Vuze\.install4j\autoUninstall.0
c:\program files\Vuze\.install4j\files.log
c:\program files\Vuze\.install4j\i4j_extf_0_5p83tu.utf8
c:\program files\Vuze\.install4j\i4j_extf_1_5p83tu_3ozw4w.png
c:\program files\Vuze\.install4j\i4j_extf_10_5p83tu.txt
c:\program files\Vuze\.install4j\i4j_extf_11_5p83tu.dll
c:\program files\Vuze\.install4j\i4j_extf_2_5p83tu_1vdagjj.png
c:\program files\Vuze\.install4j\i4j_extf_3_5p83tu_1hxg2db.png
c:\program files\Vuze\.install4j\i4j_extf_4_5p83tu_jhp9vg.png
c:\program files\Vuze\.install4j\i4j_extf_5_5p83tu.txt
c:\program files\Vuze\.install4j\i4j_extf_6_5p83tu_1kde336.ico
c:\program files\Vuze\.install4j\i4j_extf_7_5p83tu_62t8mu.icns
c:\program files\Vuze\.install4j\i4j_extf_8_5p83tu.exe
c:\program files\Vuze\.install4j\i4j_extf_9_5p83tu_1hamnt3.png
c:\program files\Vuze\.install4j\i4jdel.exe
c:\program files\Vuze\.install4j\i4jinst.dll
c:\program files\Vuze\.install4j\i4jparams.conf
c:\program files\Vuze\.install4j\i4jruntime.jar
c:\program files\Vuze\.install4j\inst_jre.cfg
c:\program files\Vuze\.install4j\install.prop
c:\program files\Vuze\.install4j\installation.log
c:\program files\Vuze\.install4j\MessagesDefault
c:\program files\Vuze\.install4j\response.varfile
c:\program files\Vuze\.install4j\unicows.dll
c:\program files\Vuze\.install4j\user.jar
c:\program files\Vuze\aereg.dll
c:\program files\Vuze\Azureus.exe
c:\program files\Vuze\Azureus.exe.manifest
c:\program files\Vuze\Azureus.properties
c:\program files\Vuze\Azureus2.jar
c:\program files\Vuze\AzureusUpdater.exe
c:\program files\Vuze\GPL.txt
c:\program files\Vuze\hs_err_pid2180.log
c:\program files\Vuze\installer.log
c:\program files\Vuze\msvcr71.dll
c:\program files\Vuze\plugins\azemp\azemp_2.0.16.jar
c:\program files\Vuze\plugins\azemp\azemp_2.0.28.jar
c:\program files\Vuze\plugins\azemp\azemp_2.0.28.zip
c:\program files\Vuze\plugins\azemp\azemp_2.0.30.jar
c:\program files\Vuze\plugins\azemp\azemp_2.0.30.zip
c:\program files\Vuze\plugins\azemp\azemp_2.0.32.jar
c:\program files\Vuze\plugins\azemp\azemp_2.0.32.zip
c:\program files\Vuze\plugins\azemp\azemp_2.0.34.jar
c:\program files\Vuze\plugins\azemp\azemp_2.0.34.zip
c:\program files\Vuze\plugins\azemp\azemp_2.1.02.jar
c:\program files\Vuze\plugins\azemp\azemp_2.1.02.zip
c:\program files\Vuze\plugins\azemp\azmplay.exe
c:\program files\Vuze\plugins\azemp\azmplay.exe.bak
c:\program files\Vuze\plugins\azemp\azureus.sig
c:\program files\Vuze\plugins\azemp\cp1250-a.raw
c:\program files\Vuze\plugins\azemp\cp1250-a.raw.bak
c:\program files\Vuze\plugins\azemp\cp1250-b.raw
c:\program files\Vuze\plugins\azemp\cp1250-b.raw.bak
c:\program files\Vuze\plugins\azemp\font.desc
c:\program files\Vuze\plugins\azemp\font.desc.bak
c:\program files\Vuze\plugins\azemp\mplayer\config
c:\program files\Vuze\plugins\azemp\osd-mplayer-a.raw
c:\program files\Vuze\plugins\azemp\osd-mplayer-a.raw.bak
c:\program files\Vuze\plugins\azemp\osd-mplayer-b.raw
c:\program files\Vuze\plugins\azemp\osd-mplayer-b.raw.bak
c:\program files\Vuze\plugins\azemp\plugin.properties
c:\program files\Vuze\plugins\azemp\plugin.properties_2.0.28
c:\program files\Vuze\plugins\azemp\plugin.properties_2.0.30
c:\program files\Vuze\plugins\azemp\plugin.properties_2.0.32
c:\program files\Vuze\plugins\azemp\plugin.properties_2.0.34
c:\program files\Vuze\plugins\azemp\plugin.properties_2.1.02
c:\program files\Vuze\plugins\azplugins\azplugins_2.1.6.jar
c:\program files\Vuze\plugins\azrating\azrating_1.3.1.jar
c:\program files\Vuze\plugins\azupdater\azupdaterpatcher_1.8.8.jar
c:\program files\Vuze\plugins\azupdater\azureus.sig
c:\program files\Vuze\plugins\azupdater\plugin.properties
c:\program files\Vuze\plugins\azupdater\Updater.jar
c:\program files\Vuze\plugins\azupnpav\azupnpav_0.2.17.jar
c:\program files\Vuze\plugins\azupnpav\azupnpav_0.2.17.zip
c:\program files\Vuze\plugins\azupnpav\azupnpav_0.2.2.jar
c:\program files\Vuze\plugins\azupnpav\azupnpav_0.2.5.jar
c:\program files\Vuze\plugins\azupnpav\azupnpav_0.2.5.zip
c:\program files\Vuze\plugins\azupnpav\azureus.sig
c:\program files\Vuze\plugins\azupnpav\plugin.properties
c:\program files\Vuze\plugins\azupnpav\plugin.properties_0.2.17
c:\program files\Vuze\plugins\azupnpav\plugin.properties_0.2.5
c:\program files\Vuze\swt.jar
c:\program files\Vuze\TOS.txt
c:\program files\Vuze\uninstall.exe
PatTheBaker
Posts Posts : 67
((((((((((((((((((((((((( Files Created from 2009-04-28 to 2009-05-31 )))))))))))))))))))))))))))))))
+ 2009-05-31 00:14 . 2009-05-31 00:14 40960 c:\windows\temp\rtdrvmon.exe
+ 2009-05-31 00:14 . 2009-05-31 00:14 16384 c:\windows\temp\Perflib_Perfdata_5c4.dat
PatTheBaker
Posts Posts : 67
2009-05-31 c:\windows\Tasks\Google Software Updater.job
Rootkit scan 2009-05-30 18:14
@="Play with VLC"
c:\program files\Symantec\LiveUpdate\AluSchedulerSvc.exe
c:\windows\system32\wdfmgr.exe
c:\program files\Compact Wireless-G USB Adapter Wireless Network Monitor\WLService.exe
c:\program files\Compact Wireless-G USB Adapter Wireless Network Monitor\WUSB54GC.exe
c:\program files\Dell AIO Printer A920\dlbkbmon.exe
c:\windows\system32\msiexec.exe
Completion time: 2009-05-31 18:20 - machine was rebooted
ComboFix-quarantined-files.txt 2009-05-31 00:19
ComboFix2.txt 2009-05-30 22:38
Pre-Run: 32,492,724,224 bytes free
Post-Run: 32,464,982,016 bytes free
379 --- E O F --- 2009-05-14 04:04
PatTheBaker
Posts Posts : 67
Post by Belahzur on 31st May 2009, 12:26 am
That should do it for the malware, now we need to make sure this doesn't come back.
  • Open HijackThis.
Post by PatTheBaker on 31st May 2009, 12:33 am
crobat.com
Acrobat.com
Adobe AIR
Adobe AIR
Adobe Flash Player 10 Plugin
Adobe Shockwave Player
AIM 6
Apple Mobile Device Support
ArcSoft Panorama Maker 4
Auto Gordian Knot 2.55
AviSynth 2.5
Bonjour
Download Updater (AOL LLC)
FLV to MP3 Converter 1.5
Google Updater
Graph 4.3
HijackThis 2.0.2
IrfanView (remove only)
iTunes
Java(TM) 6 Update 13
LucasArts' Grim Fandango
MathMagic Personal Edition 4.11
Microsoft Age of Empires II
MobileMe Control Panel
Mozilla Firefox (3.0.10)
MSXML 4.0 SP2 (KB954430)
Nikon Message Center
Nikon Transfer
OJOsoft Total Video Converter
OpenOffice.org 3.0
PowerISO
qGo 1.5.4-r2
QuickTime
Skype 4.0
Star Wars JK II Jedi Outcast
System Requirements Lab
Uninstall 1.0.0.1
Veoh Web Player Beta
VobSub v2.23 (Remove Only)
XviD MPEG4 Video Codec (remove only)
PatTheBaker
Posts Posts : 67
Post by Belahzur on 31st May 2009, 12:38 am
You aren't running Anti Virus Software
Please install Avira antivirus otherwise you won't be protected.
ComboFix /u
Post by PatTheBaker on 31st May 2009, 12:45 am
The computer is doing very well. Thank you very much for all your help and the fast service. I really appreciate it.
PatTheBaker
Posts Posts : 67
Post by Belahzur on 31st May 2009, 12:51 am
Did you install Avira?
Post by PatTheBaker on 31st May 2009, 2:03 am
Thanks for all the tips, I'm installing avira right now and Mozilla add-ons. Now I just need to fix some previous os problems.
PatTheBaker
Posts Posts : 67
Page 1 of 2 1, 2  Next
