WinBlue Soft Help Please
Page 1 of 2 1, 2  Next
Post by PatTheBaker on Fri May 29, 2009 4:46 pm
I've checked all other topics for help but I still can't do anything. WinBlueSoft does not allow me to run any programs (even taskmgr, regedit, etc) at all except for opening folders. It blocks any spyware remover even when I have it on a USP. I've tried running those programs like Avenger and Malwarebytes in Safe Mode but even Safe Mode does not allow me to run anything whatsoever expect opening folders (so I'm guessing it' preventing me from running any .exe). I would post a hijack log but the computer will block that program. What do I do?
PatTheBaker
Posts Posts : 67
Joined Joined : 2009-05-29
OS OS : XP Home Edition
Points Points : 27545
Re: WinBlue Soft Help Please
Post by PatTheBaker on Fri May 29, 2009 4:49 pm
And I have an XP op system.
PatTheBaker
Posts Posts : 67
Post by Belahzur on Fri May 29, 2009 5:29 pm
Try renaming the installer for Hijack This.
Doesn't matter what you rename it to, just as long as it's not got it's default name.
Points Points : 245059
Won't Let Me
Post by PatTheBaker on Fri May 29, 2009 7:14 pm
So I downloaded the HijackThis installer on another comp since I can't use any browser on mine, changed the name and put it onto a USB. I've tried to install it on both regular mode and Safe Mode. It doesnt block the installer but the installer only installs one application. I checked Add/Remove and it doesn't have it down as installed. I've tried to install it both on the comp itself and on the USB(on my computer and the computer I'm using right now). The application isn't blocked but it does nothing. I've tried to change the name of the app and the folder of the app but it still does not open.
If you need more details on how WinBlueSoft is acting on my comp I have the same problems as this guy: [You must be registered and logged in to see this link.]
except that I still can't run Avenger or Hijack this.
I do have Trend Micro Internet Security though, but the computer wont let me use the installation disk.
PatTheBaker
Posts Posts : 67
Post by Belahzur on Fri May 29, 2009 7:24 pm
Darn.
Thanks for the link, there's a big bunch of topics still need answering.
There's are other users across other forums I've been watching to see what idea other helpers come up with, because whatever this is, it's resistant to our tools.
Post by PatTheBaker on Fri May 29, 2009 7:31 pm
Alright, I'll go recheck those topics. Thank you for helping.
PatTheBaker
Posts Posts : 67
Post by Belahzur on Fri May 29, 2009 7:35 pm
Download and scan with the free trial of Sunbelt's Counterspy:
Save the report when it's finished:
1.Once Counterspy has done scanning,the 'Scan Results' box will appear.
2.Click on 'View Results'.
3.Under (Recommended Action),using the drop down menu arrows at the side of each entry found,set them ALL to 'Remove'.
4.Then click on 'Take Action'.
5.Once everything has been removed,click on 'View Details'.
6.Copy and Paste those details into a Word/Text document,then save it to your desktop.
Post by PatTheBaker on Fri May 29, 2009 7:57 pm
K, so I tried both safe mode and regular mode but safe mode does nothing to let me install it and regular mode blocks the install program (when I try and run the install program it blocks the name cess cess cess). I tried renaming it but it won't work and the CounterSpy doesn't let me directly install it to the USB.
Do you think manually removing some WinBlueSoft files would work (except registry since I can't regedit)?
PatTheBaker
Posts Posts : 67
Post by Belahzur on Fri May 29, 2009 8:08 pm
I very much doubt that would help, I've only a brief idea where some of the files are located.
Delete this file(s) in bold (if you can/if it lets you)
C:\Windows\system32\setup2.exe
C:\Windows\system32\ieocx.dll
Post by PatTheBaker on Fri May 29, 2009 8:30 pm
It gave me the "File is write-protected...currently in use" message for the Setup2. I couldn't find the ieocx.dll.
PatTheBaker
Posts Posts : 67
Post by Belahzur on Fri May 29, 2009 9:01 pm
Just been practising something on my virtual machine. There's another way to edit the registry without using the regedit or regedt32
    [Version]
    Signature=$CHICAGO$
    [DefaultInstall]
    AddReg=Del.Settings
    [Del.Settings]
    HKCU,SOFTWARE\Microsoft\Windows\CurrentVersion\Run\setup2.exe,0x00000000
  • Save this as fixreg.inf, save it to your desktop.
  • Right click fixreg.inf and select install.
Can you delete that setup2.exe file now?
Alright
Post by PatTheBaker on Fri May 29, 2009 9:49 pm
Alright, I deleted setup2.
PatTheBaker
Posts Posts : 67
Post by Belahzur on Fri May 29, 2009 10:12 pm
Can you try to run Hijack This now?
Post by PatTheBaker on Fri May 29, 2009 11:58 pm
I tried installing both Hijack This and Counterspy but no response. It doesn't say it's being blocked/terminated by WinBlue though.
PatTheBaker
Posts Posts : 67
Post by Belahzur on Sat May 30, 2009 12:28 am
Can you check something else for me please.
Go to C:\Program Files and see if this folder exists: Winiblue Software
Let me know if it does.
Post by PatTheBaker on Sat May 30, 2009 12:32 am
It didn't have a Wini but there was a WinBlue Soft folder. Someone deleted that yesterday before I posted.
PatTheBaker
Posts Posts : 67
Post by PatTheBaker on Sat May 30, 2009 12:33 am
PatTheBaker
Posts Posts : 67
Post by Belahzur on Sat May 30, 2009 12:40 am
Lets try running this.
Download MGTools from here and run it:
It will show you the internet as soon as it opens, so no need to explain that bit.
Allow it to run until it's done, then when it's tells you that MGTools.zip is in the C: drive, upload it to mediafire.com for me to see.
Post by PatTheBaker on Sat May 30, 2009 12:43 am
Link is giving error 403
PatTheBaker
Posts Posts : 67
Post by Belahzur on Sat May 30, 2009 12:46 am
Referal checks, hah.
You will need to get it from this link.
Post by PatTheBaker on Sat May 30, 2009 1:01 am
Comp still isn't letting me open an internet browser so I tried transferring the MG Tools onto the infected computer and it's doing nothing.
PatTheBaker
Posts Posts : 67
Post by Belahzur on Sat May 30, 2009 1:14 am
Lets try FileLister.
Run the .vbe file and let it run.
It will make two reports on your desktop.
Copy and paste both back here.
Post by PatTheBaker on Sat May 30, 2009 1:46 am
I tried in both modes and on the USB itself but it's responding like an .exe.
PatTheBaker
Posts Posts : 67
Post by Belahzur on Sat May 30, 2009 12:22 pm
I was wrong about the location of that ieocx file
Delete these two files in bold:
C:\Windows\ieocx.dll
C:\Documents and settings\USERNAME\winav.exe <== might be called sysav.exe too
Post by PatTheBaker on Sat May 30, 2009 4:00 pm
I couldn't find the files. I tried searching to but no dice. Here's something new though. When my computer forces me to log off every 5min, I log back in and it says I have a corrupted file in
C:/Documents and Settings/Username/Local Settings/Temp.
And along with that, I can use some basic programs like iTunes but still nothing else helpful.
PatTheBaker
Posts Posts : 67
Post by Belahzur on Sat May 30, 2009 4:38 pm
Lets give this a go, but I doubt it will work.
Please close all anti virus, anti malware and any other open programs/windows so they do not interfere with the running of RootRepeal.
  • Please download RootRepeal.zip from [You must be registered and logged in to see this link.].
  • Extract the program file to your Desktop.
  • Run the program RootRepeal.exe and go to the Report tab and click on the Scan button.
  • Select ALL of the checkboxes and then click OK and it will start scanning your system.
  • If you have multiple drives you only need to check the C: drive or the one Windows is installed on.
  • When done, click on Save Report
  • Save it to the Desktop.
  • Please copy/paste the contents of the report in your next reply.
Post by PatTheBaker on Sat May 30, 2009 4:47 pm
I couldn't run it but someone PM'd me and the said they checked their drive for all files modified on the infection date and got rid of files and he is now able to run .exe. I think I'm going to give this a try unless you disagree.
PatTheBaker
Posts Posts : 67
Post by Belahzur on Sat May 30, 2009 4:53 pm
Worth a try, but note down the file names and dates, one wrong move and there goes your OS, you'll trash it if you delete a needed system file.
I was wrong about that winav file located.
  1. Open My Computer.
  2. Go to Tools > Folder Options.
  3. Select the View tab.
  4. Scroll down to Hidden files and folders.
  5. Select Show hidden files and folders.
  6. Uncheck (untick) Hide extensions of known file types.
  7. Uncheck (untick) Hide protected operating system files (Recommended).
  8. Click Yes when prompted.
  9. Click OK.
  10. Close My Computer.
Now follow this path and see if winav is present here.
C:\Documents and settings\USERNAME\Application Data\winav.exe
If so, delete it.
Post by PatTheBaker on Sat May 30, 2009 5:09 pm
I couldn't find any winav or sysav so I'm trying to find and delete those files. I'll post back with an update.
PatTheBaker
Posts Posts : 67
Post by PatTheBaker on Sat May 30, 2009 5:24 pm
OK, I deleted most of the .exe and .dll files on that day. They were all found in windows and system32 folder. I can now use my internet browser on the infected computer but it won't work after I had to reboot. I can't run hijack this but it's letting me run MGTools. The only files left from that day are:
d47adwa5e14z99.dll
blocker.dll
z497add5are2568.dll
z4dba9kdoor20385.dll
z9665ackdoor1568.dll
PatTheBaker
Posts Posts : 67
Post by PatTheBaker on Sat May 30, 2009 5:36 pm
OK, once it gave me the blue screen, I can't run the browser nor MGTools. But I'll give you what MG Tools put in my C: before my comp rebooted.
the log file .zip
the tools .zip
PatTheBaker
Posts Posts : 67
Post by Origin on Sat May 30, 2009 5:39 pm
Hello can you download files from Safe mode and Networking or do you have to install them via a USB stick?
Posts Posts : 2685
Joined Joined : 2009-05-05
OS OS : Windows Xp Sp3
Points Points : 31473
Post by Belahzur on Sat May 30, 2009 5:53 pm
Hey Origin, I'll PM you shortly, new theories I've found on beating this somewhat.
Were getting somewhere. Since INF worked once before, were gonna use it again.
    [Version]
    Signature=$CHICAGO$
    [DefaultInstall]
    AddReg=Del.Settings
    [Del.Settings]
    HKCU,SOFTWARE\Microsoft\Windows\CurrentVersion\Run,setup2.exe,0x00000000
    HKLM,software\microsoft\windows\currentVersion\Run,WinBlueSoft,0x00000000
    HKU,DEFAULT\Software\Microsoft\Windows\CurrentVersion\Run,setup2.exe,0x00000000
    HKLM.software\microsoft\windows nt\currentversion\windows,AppInit_DLLs,0x00000000
Post by PatTheBaker on Sat May 30, 2009 5:56 pm
I could dl MG Tools on Regular Mode and could use an internet browser and it worked for about 5 until it gave me the blue screen.
I tried again on Safe Mode Networking but it still won't let me run any .exe or anything of the sort. Up until that point, I had been trying to use a USB and if it failed I trid to directly install the programs on the USB itself but nothing works.
PatTheBaker
Posts Posts : 67
Post by PatTheBaker on Sat May 30, 2009 5:58 pm
[You must be registered and logged in to see this link.] wrote:Hey Origin, I'll PM you shortly, new theories I've found on beating this somewhat.
    [Version]
    Signature=$CHICAGO$
    [DefaultInstall]
    AddReg=Del.Settings
    [Del.Settings]
I deleted setup2.exe already. Should I still keep the .inf file?
PatTheBaker
Posts Posts : 67
Post by Belahzur on Sat May 30, 2009 5:59 pm
Sorry, don't know how that got in there, didn't see that bit.
I need you to run my new inf script there, it will delete some run values and tools might work then.
Post by PatTheBaker on Sat May 30, 2009 6:06 pm
Alright, I saved it onto the desktop and hit install. My icons blinked a bit but no installation wizard or anything of the sort.
PatTheBaker
Posts Posts : 67
Post by Belahzur on Sat May 30, 2009 6:24 pm
Yeah, the blinking normally happens.
The registry values should be killed off now, see if you can run anything you haven't been able to.
Post by PatTheBaker on Sat May 30, 2009 6:38 pm
No dice. I tried all the programs you posted and Avenger but no response. I did manage to delete all the .dll files I listed before except for blocker.dll
PatTheBaker
Posts Posts : 67
Post by Belahzur on Sat May 30, 2009 6:46 pm
I made another mistake on the inf file, time for another inf file.
    [Version]
    Signature=$CHICAGO$
    [DefaultInstall]
    AddReg=Del.Settings
    [Del.Settings]
    HKLM,software\microsoft\windows nt\currentversion\windows,AppInit_DLLs,0x00000000
Try and delete blocker.dll now.
Post by PatTheBaker on Sat May 30, 2009 7:01 pm
It won't delete blocker.dll but the .inf is letting me running my browser. I also dl'd CounterSpy and installing it right now. Counterspy won't scan because I don't have any risk definitions.
Update: OK I deleted blocker.dll. I'm running MGTools again, do you want me to upload the .zips to mediafire?
PatTheBaker
Posts Posts : 67
Update Again
Post by PatTheBaker on Sat May 30, 2009 7:11 pm
Blocker.dll is gone. I can run taskmgr and regedit. It still won't let me run Hijack This but the computer doesn't auto reboot for me anymore.
I can install Hijack This and Malwarebytes but after installation it won't let me run it.
Also, I checked the Registry Keys and found 2 setup2's. Both are in the Windows folder, should I delete?
PatTheBaker
Posts Posts : 67
Post by Belahzur on Sat May 30, 2009 8:04 pm
The registry value? yes, delete it.
Post by PatTheBaker on Sat May 30, 2009 8:21 pm
Alright, I deleted all the setup2 values but only CounterSpy works but won't let me update definitions for threats so I can't use it.
PatTheBaker
Posts Posts : 67
Post by Belahzur on Sat May 30, 2009 8:47 pm
I didn't see your last post, please upload the new MGlogs for me.
Run a scan without updating it, see what happens.
Post by PatTheBaker on Sat May 30, 2009 8:57 pm
CounterSpy just says I haven't defined any threats and tells me I need to update my definitions.
MG Log:
PatTheBaker
Posts Posts : 67
Post by Belahzur on Sat May 30, 2009 9:13 pm
More logs, more detail.
Them few files you deleted, I don't know what they are, but there's hundreds of them. There's also a rootkit, which I suspect is causing all these problems.
Are you able to run regedit.exe, or regedt32.exe?
Post by PatTheBaker on Sat May 30, 2009 9:19 pm
I can run regedit in Run, but don't know how to run regedit32.
PatTheBaker
Posts Posts : 67
Post by Belahzur on Sat May 30, 2009 9:26 pm
Good, we can do a proper reg fix.
I also have a new way to go. The logs come with a proper Hijack This log, meaning the Hijack This that is included in MGTools was able to run.
Open this folder in bold:
C:\MGTools
Inside there, there is a file called "Analyze.exe", try running it for me, does it run?
Post by PatTheBaker on Sat May 30, 2009 9:33 pm
Runs perfectly. Here's the log
Scan saved at 3:32:37 PM, on 5/30/2009
MSIE: Internet Explorer v7.00 (7.00.6000.16827)
C:\WINDOWS\system32\LEXBCES.EXE
C:\WINDOWS\system32\LEXPPS.EXE
C:\Program Files\Dell AIO Printer A920\dlbkbmgr.exe
C:\WINDOWS\BCMSMMSG.exe
C:\Program Files\Dell AIO Printer A920\dlbkbmon.exe
C:\WINDOWS\system32\hkcmd.exe
C:\Program Files\PowerISO\PWRISOVM.EXE
C:\Program Files\Veoh Networks\VeohWebPlayer\veohwebplayer.exe
C:\Documents and Settings\Khank\Local Settings\Application Data\Google\Update\GoogleUpdate.exe
C:\Program Files\Common Files\Nikon\Monitor\NkMonitor.exe
C:\Program Files\Symantec\LiveUpdate\AluSchedulerSvc.exe
C:\Program Files\Sunbelt Software\CounterSpy\SBAMSvc.exe
C:\Program Files\Viewpoint\Common\ViewpointService.exe
C:\Program Files\Compact Wireless-G USB Adapter Wireless Network Monitor\WLService.exe
C:\Program Files\Compact Wireless-G USB Adapter Wireless Network Monitor\WUSB54GC.exe
C:\Program Files\Sunbelt Software\CounterSpy\SBAMTray.exe
C:\Program Files\iTunes\iTunes.exe
C:\Documents and Settings\Khank\Local Settings\Application Data\Google\Chrome\Application\chrome.exe
C:\Program Files\Vuze\Azureus.exe
C:\MGtools\analyse.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = about:blank
R3 - URLSearchHook: (no name) - {37D2CDBF-2AF4-44AA-8113-BD0D2DA3C2B8} - (no file)
O2 - BHO: DriveLetterAccess - {5CA3D70E-1895-11CF-8E15-001234567890} - C:\WINDOWS\system32\dla\tfswshx.dll
O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - C:\Program Files\Google\Google Toolbar\GoogleToolbar.dll (file missing)
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.1.1309.3572\swg.dll
O2 - BHO: Google Dictionary Compression sdch - {C84D72FE-E17D-4195-BB24-76C02E2E7C4E} - C:\Program Files\Google\Google Toolbar\Component\fastsearch_A8904FB862BD9564.dll (file missing)
O3 - Toolbar: Veoh Web Player Video Finder - {0FBB9689-D3D7-4f7a-A2E2-585B10099BFC} - C:\Program Files\Veoh Networks\VeohWebPlayer\VeohIEToolbar.dll
O3 - Toolbar: Google Toolbar - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - C:\Program Files\Google\Google Toolbar\GoogleToolbar.dll (file missing)
O4 - HKLM\..\Run: [Dell AIO Printer A920] "C:\Program Files\Dell AIO Printer A920\dlbkbmgr.exe"
O4 - HKLM\..\Run: [BCMSMMSG] BCMSMMSG.exe
O4 - HKLM\..\Run: [StorageGuard] "C:\Program Files\Common Files\Sonic\Update Manager\sgtray.exe" /r
O4 - HKLM\..\Run: [IMJPMIG8.1] "C:\WINDOWS\IME\imjp8_1\IMJPMIG.EXE" /Spoil /RemAdvDef /Migration32
O4 - HKLM\..\Run: [MSPY2002] C:\WINDOWS\system32\IME\PINTLGNT\ImScInst.exe /SYNC
O4 - HKLM\..\Run: [PHIME2002ASync] C:\WINDOWS\system32\IME\TINTLGNT\TINTSETP.EXE /SYNC
O4 - HKLM\..\Run: [PHIME2002A] C:\WINDOWS\system32\IME\TINTLGNT\TINTSETP.EXE /IMEName
O4 - HKLM\..\Run: [igfxtray] C:\WINDOWS\system32\igfxtray.exe
O4 - HKLM\..\Run: [igfxhkcmd] C:\WINDOWS\system32\hkcmd.exe
O4 - HKLM\..\Run: [igfxpers] C:\WINDOWS\system32\igfxpers.exe
O4 - HKLM\..\Run: [NBKeyScan] "C:\Program Files\Nero\Nero8\Nero BackItUp\NBKeyScan.exe"
O4 - HKLM\..\Run: [PWRISOVM.EXE] C:\Program Files\PowerISO\PWRISOVM.EXE
O4 - HKLM\..\Run: [UnlockerAssistant] "C:\Program Files\Unlocker\UnlockerAssistant.exe"
O4 - HKLM\..\Run: [SBAMTray] C:\Program Files\Sunbelt Software\CounterSpy\SBAMTray.exe
O4 - HKCU\..\Run: [NetZero_uoltray] C:\Program Files\NetZero\exec.exe regrun
O4 - HKCU\..\Run: [IndxStoreSvr_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA}] "C:\Program Files\Common Files\Nero\Lib\NMIndexStoreSvr.exe" ASO-616B5711-6DAE-4795-A05F-39A1E5104020
O4 - HKCU\..\Run: [VeohPlugin] "C:\Program Files\Veoh Networks\VeohWebPlayer\veohwebplayer.exe"
O4 - HKCU\..\Run: [Google Update] "C:\Documents and Settings\Khank\Local Settings\Application Data\Google\Update\GoogleUpdate.exe" /c
O4 - HKUS\S-1-5-18\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe (User 'Default user')
O4 - Global Startup: Microsoft Office Fast Start.lnk = C:\MSOffice\Office\FASTBOOT.EXE
O4 - Global Startup: Microsoft Office Find Fast Indexer.lnk = C:\MSOffice\Office\FINDFAST.EXE
O4 - Global Startup: Microsoft Office Shortcut Bar.lnk = C:\MSOffice\Office\MSOFFICE.EXE
O4 - Global Startup: Nikon Monitor.lnk = C:\Program Files\Common Files\Nikon\Monitor\NkMonitor.exe
O8 - Extra context menu item: Display All Images with Full Quality - [You must be registered and logged in to see this link.] Files\NetZero\qsacc\appres.dll/228
O8 - Extra context menu item: Display Image with Full Quality - [You must be registered and logged in to see this link.] Files\NetZero\qsacc\appres.dll/227
O9 - Extra button: AIM - {AC9E2541-2814-11d5-BC6D-00B0D0A1DE45} - C:\Program Files\AIM\aim.exe
O17 - HKLM\System\CCS\Services\Tcpip\..\{329C4D81-999D-4FA6-9362-30ADD9F66163}: NameServer = 85.255.112.7,85.255.112.88
O17 - HKLM\System\CCS\Services\Tcpip\..\{43FD5B7D-2EAB-408E-8A51-0AD2B20A8475}: NameServer = 85.255.112.7,85.255.112.88
O17 - HKLM\System\CS1\Services\Tcpip\Parameters: NameServer = 85.255.112.7,85.255.112.88
O17 - HKLM\System\CS2\Services\Tcpip\Parameters: NameServer = 85.255.112.7,85.255.112.88
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: NameServer = 85.255.112.7,85.255.112.88
O18 - Filter: x-sdch - {B1759355-3EEC-4C1E-B0F1-B719FE26E377} - C:\Program Files\Google\Google Toolbar\Component\fastsearch_A8904FB862BD9564.dll
O23 - Service: Automatic LiveUpdate Scheduler - Symantec Corporation - C:\Program Files\Symantec\LiveUpdate\AluSchedulerSvc.exe
O23 - Service: FLEXnet Licensing Service - Macrovision Europe Ltd. - C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe
O23 - Service: LexBce Server (LexBceS) - Lexmark International, Inc. - C:\WINDOWS\system32\LEXBCES.EXE
O23 - Service: LiveUpdate - Symantec Corporation - C:\Program Files\Symantec\LiveUpdate\LuComServer_3_4.EXE
O23 - Service: Macromedia Licensing Service - Unknown owner - C:\Program Files\Common Files\Macromedia Shared\Service\Macromedia Licensing.exe
O23 - Service: Remote Packet Capture Protocol v.0 (experimental) (rpcapd) - CACE Technologies - C:\Program Files\WinPcap\rpcapd.exe
O23 - Service: CounterSpy Antispyware (SBAMSvc) - Sunbelt Software - C:\Program Files\Sunbelt Software\CounterSpy\SBAMSvc.exe
O23 - Service: PC Tools Auxiliary Service (sdAuxService) - PC Tools - C:\Program Files\Spyware Doctor\pctsAuxs.exe
O23 - Service: PC Tools Security Service (sdCoreService) - PC Tools - C:\Program Files\Spyware Doctor\pctsSvc.exe
O23 - Service: WUSB54GCSVC - GEMTEKS - C:\Program Files\Compact Wireless-G USB Adapter Wireless Network Monitor\WLService.exe
End of file - 11182 bytes
PatTheBaker
Posts Posts : 67
