System Security 4.51 removal help
Post by twaier on Wed May 27, 2009 5:44 am
Please help! I've tried many different ways to remove this virus & the response is always "application cannot be executed. file is infected" I can't use HijakThis, it's the same message bubble. Any help would be great!
twaier
Gender : Female
OS : xp
Re: System Security 4.51 removal help
Post by Origin on Thu May 28, 2009 12:30 am
OS : Windows Xp Sp3
Post by twaier on Thu May 28, 2009 12:36 am
Thank you for your help, I tried to download it, it says the file is infected
twaier
Gender : Female
OS : xp
Post by Origin on Thu May 28, 2009 12:37 am
Hello are you able to download HijackThis?
OS : Windows Xp Sp3
Post by twaier on Thu May 28, 2009 12:39 am
no, the comment bubble says it's infected
twaier
Gender : Female
OS : xp
Post by Origin on Thu May 28, 2009 12:49 am
Try to download Hijackthis from here:
OS : Windows Xp Sp3
Post by twaier on Thu May 28, 2009 12:52 am
I tried, same thing "application cannot be executed. file is infected"
twaier
Gender : Female
OS : xp
Post by Origin on Thu May 28, 2009 12:56 am
Can you try to run ComboFix in Safe Mode? Restart your computer-->As as it starts to boot keep hitting the F8 key until you get to a screen that has various options, choose Safe Mode with Networking, Then run ComboFix and post the contents of the log back here.
See [You must be registered and logged in to see this link.] for how to disable your AV..
  • Post C:combofix.txt back here.
OS : Windows Xp Sp3
Post by twaier on Thu May 28, 2009 2:04 am
Here you go!
c:\documents and settings\All Users\Application Data\11764814
c:\documents and settings\All Users\Application Data\11764814\11764814.exe
c:\documents and settings\All Users\Application Data\11764814\11764814.glu
c:\documents and settings\All Users\Application Data\11764814\pc11764814cnf
c:\documents and settings\All Users\Application Data\11764814\pc11764814ins
c:\windows\ieocx.dll
c:\windows\system32\drivers\UACpxbxnnkhbobquwb.sys
c:\windows\system32\UACdoyeljcerkrbltn.log
c:\windows\system32\UACfavyqotbuipiclp.dll
c:\windows\system32\UACigrkuqqjvyiduyy.dll
c:\windows\system32\uacinit.dll
c:\windows\system32\UACksefwomcjmtltxd.dat
c:\windows\system32\UACmlgetndjgewhorp.dll
c:\windows\system32\UACpjyuhrhcxeyrvkg.dll
c:\windows\system32\UACsnomtjnnedwagea.log
c:\windows\system32\UACtagjukfpvjlqgwx.log
c:\windows\system32\UACulkmxfakrvesodo.dll
Drivers/Services
-------\Service_UACd.sys
Files Created from 2009-04-28 to 2009-05-28
2009-05-26 23:04 . 2009-05-26 23:04 -------- d-sh--w c:\windows\system32\config\systemprofile\IETldCache
2009-05-26 05:48 . 2009-05-26 05:48 -------- d-----w c:\windows\McAfee.com
2009-05-24 17:30 . 2009-05-24 17:30 -------- d-----w c:\windows\system32\scripting
2009-05-24 17:30 . 2009-05-24 17:30 -------- d-----w c:\windows\l2schemas
2009-05-24 17:30 . 2009-05-24 17:30 -------- d-----w c:\windows\system32\en
2009-05-24 17:30 . 2009-05-24 17:30 -------- d-----w c:\windows\system32\bits
2009-05-24 17:27 . 2009-05-24 17:27 -------- d-----w c:\windows\ServicePackFiles
2009-05-24 03:02 . 2009-05-24 03:02 194 ----a-w c:\documents and settings\Administrator\Application Data\asd.bat
Find3M Report
2009-05-28 00:13 . 2008-11-23 05:37 -------- d-----w c:\program files\Common Files\Akamai
2009-05-26 22:47 . 2006-03-30 06:44 29304 ----a-w c:\documents and settings\Administrator\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2009-05-24 17:33 . 2006-01-26 18:41 87263 ----a-w c:\windows\pchealth\helpctr\OfflineCache\index.dat
2009-05-22 05:57 . 2009-01-22 04:12 -------- d-----w c:\documents and settings\Administrator\Application Data\Azureus
2009-05-22 00:36 . 2009-01-18 06:27 -------- d-----w c:\program files\V CAST Music with Rhapsody
2009-05-22 00:15 . 2009-01-22 04:11 -------- d-----w c:\program files\Vuze
2009-04-09 14:47 . 2009-04-09 14:47 -------- d-----w c:\program files\Microsoft Silverlight
2009-03-08 11:34 . 2004-08-04 12:00 914944 ----a-w c:\windows\system32\wininet.dll
2009-03-08 11:34 . 2004-08-04 12:00 43008 ----a-w c:\windows\system32\licmgr10.dll
2009-03-08 11:33 . 2004-08-04 12:00 18944 ----a-w c:\windows\system32\corpol.dll
2009-03-08 11:33 . 2004-08-04 12:00 420352 ----a-w c:\windows\system32\vbscript.dll
2009-03-08 11:32 . 2004-08-04 12:00 72704 ----a-w c:\windows\system32\admparse.dll
2009-03-08 11:32 . 2004-08-04 12:00 71680 ----a-w c:\windows\system32\iesetup.dll
2009-03-08 11:31 . 2004-08-04 12:00 34816 ----a-w c:\windows\system32\imgutil.dll
2009-03-08 11:31 . 2004-08-04 12:00 48128 ----a-w c:\windows\system32\mshtmler.dll
2009-03-08 11:31 . 2004-08-04 12:00 45568 ----a-w c:\windows\system32\mshta.exe
2009-03-08 11:22 . 2004-08-04 12:00 156160 ----a-w c:\windows\system32\msls31.dll
2009-03-06 14:22 . 2004-08-04 12:00 284160 ----a-w c:\windows\system32\pdh.dll
Reg Loading Points
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{201f27d4-3704-41d6-89c1-aa35e39143ed}]
2008-12-10 02:40 333192 ----a-w c:\program files\AskBarDis\bar\bin\askBar.dll
"updateMgr"="c:\program files\Adobe\Acrobat 7.0\Reader\AdobeUpdateManager.exe" [2006-03-31 313472]
"swg"="c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2007-08-19 68856]
"ATIPTA"="c:\program files\ATI Technologies\ATI Control Panel\atiptaxx.exe" [2004-06-11 339968]
"PRONoMgr.exe"="c:\program files\Intel\NCS\PROSet\PRONoMgr.exe" [2003-05-29 86016]
"SunJavaUpdateSched"="c:\program files\Java\jre1.6.0_07\bin\jusched.exe" [2008-06-10 144784]
"HP Software Update"="c:\program files\HP\HP Software Update\HPWuSchd2.exe" [2005-05-12 49152]
"QuickTime Task"="c:\program files\QuickTime\qttask.exe" [2008-09-06 413696]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2008-10-02 289576]
Adobe Reader Speed Launch.lnk - c:\program files\Adobe\Acrobat 7.0\Reader\reader_sl.exe [2005-9-23 29696]
HP Digital Imaging Monitor.lnk - c:\program files\HP\Digital Imaging\bin\hpqtra08.exe [2005-5-12 282624]
HP Image Zone Fast Start.lnk - c:\program files\HP\Digital Imaging\bin\hpqthb08.exe [2005-5-12 73728]
Microsoft Office.lnk - c:\program files\Microsoft Office\Office\OSA9.EXE [2001-6-5 65588]
Varian, Inc. VPN Client.lnk - c:\program files\Cisco Systems\VPN\vpngui.exe [2006-1-26 1454143]
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\Sebring]
2004-01-12 14:55 110592 ----a-w c:\windows\system32\LgNotify.dll
"AntiVirusDisableNotify"="1"
"UpdatesDisableNotify"="1"
"EnableFirewall"= 0 (0x0)
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpofxm08.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hposfx08.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpqCopy.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpfccopy.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpzwiz01.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\Unload\\HpqPhUnl.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\Unload\\HpqDIA.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpoews01.exe"=
"c:\\Documents and Settings\\Administrator\\Local Settings\\Application Data\\Xenocode\\ApplianceCaches\\KumaClient.exe_v4B8EBC79\\Native\\STUBEXE\\@PROGRAMFILES@\\Kuma Games\\Kuma.exe"=
"c:\\Program Files\\Microsoft Games\\Age of Empires III\\age3.exe"=
"c:\\Program Files\\Vuze\\Azureus.exe"=
"3724:TCP"= 3724:TCP:blizz download
"6118:TCP"= 6118:TCP:blizz download 2
"9420:TCP"= 9420:TCP:Akamai NetSession Interface
"5000:UDP"= 5000:UDP:Akamai NetSession Interface
"1702:TCP"= 1702:TCP:Akamai NetSession Interface
"1038:TCP"= 1038:TCP:Akamai NetSession Interface
"1102:TCP"= 1102:TCP:Akamai NetSession Interface
"1091:TCP"= 1091:TCP:Akamai NetSession Interface
"2249:TCP"= 2249:TCP:Akamai NetSession Interface
"1077:TCP"= 1077:TCP:Akamai NetSession Interface
"1094:TCP"= 1094:TCP:Akamai NetSession Interface
"1093:TCP"= 1093:TCP:Akamai NetSession Interface
"1040:TCP"= 1040:TCP:Akamai NetSession Interface
"1088:TCP"= 1088:TCP:Akamai NetSession Interface
"1357:TCP"= 1357:TCP:Akamai NetSession Interface
"1039:TCP"= 1039:TCP:Akamai NetSession Interface
"1090:TCP"= 1090:TCP:Akamai NetSession Interface
"1049:TCP"= 1049:TCP:Akamai NetSession Interface
"1082:TCP"= 1082:TCP:Akamai NetSession Interface
"1092:TCP"= 1092:TCP:Akamai NetSession Interface
"1078:TCP"= 1078:TCP:Akamai NetSession Interface
"1085:TCP"= 1085:TCP:Akamai NetSession Interface
"1101:TCP"= 1101:TCP:Akamai NetSession Interface
"1108:TCP"= 1108:TCP:Akamai NetSession Interface
"1079:TCP"= 1079:TCP:Akamai NetSession Interface
"1080:TCP"= 1080:TCP:Akamai NetSession Interface
"1071:TCP"= 1071:TCP:Akamai NetSession Interface
"1070:TCP"= 1070:TCP:Akamai NetSession Interface
"1074:TCP"= 1074:TCP:Akamai NetSession Interface
"1548:TCP"= 1548:TCP:Akamai NetSession Interface
"1635:TCP"= 1635:TCP:Akamai NetSession Interface
"1114:TCP"= 1114:TCP:Akamai NetSession Interface
"1182:TCP"= 1182:TCP:Akamai NetSession Interface
"1103:TCP"= 1103:TCP:Akamai NetSession Interface
"1115:TCP"= 1115:TCP:Akamai NetSession Interface
"1119:TCP"= 1119:TCP:Akamai NetSession Interface
"1042:TCP"= 1042:TCP:Akamai NetSession Interface
"1087:TCP"= 1087:TCP:Akamai NetSession Interface
"1089:TCP"= 1089:TCP:Akamai NetSession Interface
"1067:TCP"= 1067:TCP:Akamai NetSession Interface
"1068:TCP"= 1068:TCP:Akamai NetSession Interface
"1065:TCP"= 1065:TCP:Akamai NetSession Interface
"1064:TCP"= 1064:TCP:Akamai NetSession Interface
"1055:TCP"= 1055:TCP:Akamai NetSession Interface
"1780:TCP"= 1780:TCP:Akamai NetSession Interface
"1809:TCP"= 1809:TCP:Akamai NetSession Interface
"1054:TCP"= 1054:TCP:Akamai NetSession Interface
"1053:TCP"= 1053:TCP:Akamai NetSession Interface
"1063:TCP"= 1063:TCP:Akamai NetSession Interface
"1069:TCP"= 1069:TCP:Akamai NetSession Interface
"1062:TCP"= 1062:TCP:Akamai NetSession Interface
"1073:TCP"= 1073:TCP:Akamai NetSession Interface
"1081:TCP"= 1081:TCP:Akamai NetSession Interface
"1066:TCP"= 1066:TCP:Akamai NetSession Interface
"1111:TCP"= 1111:TCP:Akamai NetSession Interface
"1061:TCP"= 1061:TCP:Akamai NetSession Interface
"2230:TCP"= 2230:TCP:Akamai NetSession Interface
"2637:TCP"= 2637:TCP:Akamai NetSession Interface
"1035:TCP"= 1035:TCP:Akamai NetSession Interface
"1072:TCP"= 1072:TCP:Akamai NetSession Interface
"1052:TCP"= 1052:TCP:Akamai NetSession Interface
"1060:TCP"= 1060:TCP:Akamai NetSession Interface
"1550:TCP"= 1550:TCP:Akamai NetSession Interface
"1037:TCP"= 1037:TCP:Akamai NetSession Interface
"2146:TCP"= 2146:TCP:Akamai NetSession Interface
"1076:TCP"= 1076:TCP:Akamai NetSession Interface
"1100:TCP"= 1100:TCP:Akamai NetSession Interface
"1084:TCP"= 1084:TCP:Akamai NetSession Interface
"1095:TCP"= 1095:TCP:Akamai NetSession Interface
"1086:TCP"= 1086:TCP:Akamai NetSession Interface
"1832:TCP"= 1832:TCP:Akamai NetSession Interface
"1876:TCP"= 1876:TCP:Akamai NetSession Interface
"1930:TCP"= 1930:TCP:Akamai NetSession Interface
"1289:TCP"= 1289:TCP:Akamai NetSession Interface
"1075:TCP"= 1075:TCP:Akamai NetSession Interface
"1097:TCP"= 1097:TCP:Akamai NetSession Interface
"1173:TCP"= 1173:TCP:Akamai NetSession Interface
"1414:TCP"= 1414:TCP:Akamai NetSession Interface
"1050:TCP"= 1050:TCP:Akamai NetSession Interface
"1048:TCP"= 1048:TCP:Akamai NetSession Interface
"2086:TCP"= 2086:TCP:Akamai NetSession Interface
"2093:TCP"= 2093:TCP:Akamai NetSession Interface
"2336:TCP"= 2336:TCP:Akamai NetSession Interface
"2344:TCP"= 2344:TCP:Akamai NetSession Interface
"2352:TCP"= 2352:TCP:Akamai NetSession Interface
"2662:TCP"= 2662:TCP:Akamai NetSession Interface
"1113:TCP"= 1113:TCP:Akamai NetSession Interface
"1196:TCP"= 1196:TCP:Akamai NetSession Interface
"4607:TCP"= 4607:TCP:Akamai NetSession Interface
"4756:TCP"= 4756:TCP:Akamai NetSession Interface
"1613:TCP"= 1613:TCP:Akamai NetSession Interface
"1044:TCP"= 1044:TCP:Akamai NetSession Interface
"1312:TCP"= 1312:TCP:Akamai NetSession Interface
"1153:TCP"= 1153:TCP:Akamai NetSession Interface
"1124:TCP"= 1124:TCP:Akamai NetSession Interface
"4489:TCP"= 4489:TCP:Akamai NetSession Interface
S2 Akamai;Akamai;c:\windows\System32\svchost.exe -k Akamai [8/4/2004 5:00 AM 14336]
S2 ASKService;ASKService;c:\program files\AskBarDis\bar\bin\AskService.exe [1/21/2009 9:12 PM 464264]
S2 ASKUpgrade;ASKUpgrade;c:\program files\AskBarDis\bar\bin\ASKUpgrade.exe [1/21/2009 9:12 PM 234888]
S2 FlipShare Service;FlipShare Service;c:\program files\Pure Digital Technologies\FlipShare\FlipShareService.exe [10/5/2008 2:55 PM 439616]
S3 OZSCR;O2Micro SmartCardBus Smartcard Reader;c:\windows\system32\drivers\ozscr.sys [1/26/2006 12:47 PM 92550]
Akamai REG_MULTI_SZ Akamai
2009-05-22 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2008-07-30 19:34]
2009-05-28 c:\windows\Tasks\SDMsgUpdate (TE).job
- c:\progra~1\SMARTD~2\Messages\SDNotify.exe [2008-09-20 14:29]
HKLM-Run-11764814 - c:\documents and settings\All Users\Application Data\11764814\11764814.exe
SafeBoot-procexp90.Sys
TCP: {EF73B182-2003-412F-ACB0-8EDC3EAD964A} = 4.22.69.3
Filter: x-sdch - {B1759355-3EEC-4C1E-B0F1-B719FE26E377} - c:\program files\Google\Google Toolbar\Component\fastsearch_A8904FB862BD9564.dll
FF - ProfilePath -
Rootkit scan 2009-05-27 18:40
[HKEY_USERS\S-1-5-21-790525478-152049171-854245398-500\Software\Microsoft\Internet Explorer\User Preferences]
@Denied: (2) (Administrator)
"88D7D0879DAB32E14DE5B3A805A34F98AFF34F5977"=hex:01,00,00,00,d0,8c,9d,df,01,15,
d1,11,8c,7a,00,c0,4f,c2,97,eb,01,00,00,00,f7,8c,9e,df,c8,ff,22,44,bf,d9,74,\
"2D53CFFC5C1A3DD2E97B7979AC2A92BD59BC839E81"=hex:01,00,00,00,d0,8c,9d,df,01,15,
[HKEY_LOCAL_MACHINE\software\Microsoft\Driver Signing]
@Denied: (2) (Administrators)
"Policy"=hex:00,00,00,00
- - - - - - - > 'winlogon.exe'(1152)
Completion time: 2009-05-28 18:42
ComboFix-quarantined-files.txt 2009-05-28 01:41
Pre-Run: 2,825,408,512 bytes free
Post-Run: 3,947,548,672 bytes free
Current=3 Default=3 Failed=2 LastKnownGood=1 Sets=1,2,3,4
276 --- E O F --- 2009-05-26 23:15
twaier
Gender : Female
OS : xp
Post by Origin on Thu May 28, 2009 2:15 am
OS : Windows Xp Sp3
Post by twaier on Thu May 28, 2009 2:32 am
MBAM log:
Malwarebytes' Anti-Malware 1.37
Database version: 2186
5/27/2009 7:26:56 PM
mbam-log-2009-05-27 (19-26-56).txt
Objects scanned: 84873
Time elapsed: 3 minute(s), 57 second(s)
Registry Keys Infected: 1
Files Infected: 1
HKEY_CURRENT_USER\SOFTWARE\WinPC Antivirus (Rogue.WinPCAntivirus) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\UpdatesDisableNotify (Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
c:\documents and settings\Administrator\Application Data\asd.bat (Rogue.WinPCDefender) -> Quarantined and deleted successfully.
twaier
Gender : Female
OS : xp
Post by Origin on Thu May 28, 2009 2:35 am
Can you boot in normal mode and try to download HijackThis now.
OS : Windows Xp Sp3
Post by twaier on Thu May 28, 2009 2:40 am
Wow! It actually worked!
Scan saved at 7:38:41 PM, on 5/27/2009
C:\WINDOWS\system32\S24EvMon.exe
C:\Program Files\AskBarDis\bar\bin\AskService.exe
C:\Program Files\AskBarDis\bar\bin\ASKUpgrade.exe
C:\Program Files\Cisco Systems\VPN\cvpnd.exe
C:\Program Files\Pure Digital Technologies\FlipShare\FlipShareService.exe
C:\WINDOWS\system32\RegSrvc.exe
C:\WINDOWS\system32\ZCfgSvc.exe
C:\WINDOWS\system32\1XConfig.exe
C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe
C:\Program Files\Java\jre1.6.0_07\bin\jusched.exe
C:\Program Files\HP\Digital Imaging\bin\hpqimzone.exe
C:\Program Files\internet explorer\iexplore.exe
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: AskBar BHO - {201f27d4-3704-41d6-89c1-aa35e39143ed} - C:\Program Files\AskBarDis\bar\bin\askBar.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0_07\bin\ssv.dll
O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - C:\Program Files\Google\Google Toolbar\GoogleToolbar.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.1.1309.3572\swg.dll
O2 - BHO: Google Dictionary Compression sdch - {C84D72FE-E17D-4195-BB24-76C02E2E7C4E} - C:\Program Files\Google\Google Toolbar\Component\fastsearch_A8904FB862BD9564.dll
O2 - BHO: MSN Toolbar Helper - {d2ce3e00-f94a-4740-988e-03dc2f38c34f} - C:\Program Files\MSN\Toolbar\3.0.1203.0\msneshellx.dll
O2 - BHO: XBTBPos00 - {FCBCCB87-9224-4B8D-B117-F56D924BEB18} - C:\Program Files\Fast Browser Search\IE\FBStoolbar.dll
O3 - Toolbar: Ask Toolbar - {3041d03e-fd4b-44e0-b742-2d9b88305f98} - C:\Program Files\AskBarDis\bar\bin\askBar.dll
O3 - Toolbar: Fast Browser Search - {1BB22D38-A411-4B13-A746-C2A4F4EC7344} - C:\Program Files\Fast Browser Search\IE\FBStoolbar.dll
O3 - Toolbar: MSN Toolbar - {1E61ED7C-7CB8-49d6-B9E9-AB4C880C8414} - C:\Program Files\MSN\Toolbar\3.0.1203.0\msneshellx.dll
O3 - Toolbar: Google Toolbar - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - C:\Program Files\Google\Google Toolbar\GoogleToolbar.dll
O4 - HKLM\..\Run: [ATIPTA] C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe
O4 - HKLM\..\Run: [PRONoMgr.exe] C:\Program Files\Intel\NCS\PROSet\PRONoMgr.exe
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre1.6.0_07\bin\jusched.exe"
O4 - HKCU\..\Run: [updateMgr] "C:\Program Files\Adobe\Acrobat 7.0\Reader\AdobeUpdateManager.exe" AcRdB7_0_9 -reboot 1
O4 - Global Startup: Adobe Reader Speed Launch.lnk = C:\Program Files\Adobe\Acrobat 7.0\Reader\reader_sl.exe
O4 - Global Startup: HP Image Zone Fast Start.lnk = C:\Program Files\HP\Digital Imaging\bin\hpqthb08.exe
O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office\OSA9.EXE
O4 - Global Startup: Varian, Inc. VPN Client.lnk = C:\Program Files\Cisco Systems\VPN\vpngui.exe
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_07\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_07\bin\ssv.dll
O16 - DPF: {EF791A6B-FC12-4C68-99EF-FB9E207A39E6} (McFreeScan Class) - [You must be registered and logged in to see this link.]
O17 - HKLM\System\CCS\Services\Tcpip\..\{EF73B182-2003-412F-ACB0-8EDC3EAD964A}: Domain = nmr.varianinc.com
O17 - HKLM\System\CCS\Services\Tcpip\..\{EF73B182-2003-412F-ACB0-8EDC3EAD964A}: NameServer = 4.22.69.3
O17 - HKLM\System\CS1\Services\Tcpip\Parameters: SearchList = varianinc.com,nmr.varianinc.com,csb.varianinc.com
O17 - HKLM\System\CS2\Services\Tcpip\Parameters: SearchList = varianinc.com,nmr.varianinc.com,csb.varianinc.com
O17 - HKLM\System\CS3\Services\Tcpip\Parameters: SearchList = varianinc.com,nmr.varianinc.com,csb.varianinc.com
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: SearchList = varianinc.com,nmr.varianinc.com,csb.varianinc.com
O18 - Filter: x-sdch - {B1759355-3EEC-4C1E-B0F1-B719FE26E377} - C:\Program Files\Google\Google Toolbar\Component\fastsearch_A8904FB862BD9564.dll
O23 - Service: ASKService - Unknown owner - C:\Program Files\AskBarDis\bar\bin\AskService.exe
O23 - Service: ASKUpgrade - Unknown owner - C:\Program Files\AskBarDis\bar\bin\ASKUpgrade.exe
O23 - Service: Cisco Systems, Inc. VPN Service (CVPND) - Cisco Systems, Inc. - C:\Program Files\Cisco Systems\VPN\cvpnd.exe
O23 - Service: FlipShare Service - Unknown owner - C:\Program Files\Pure Digital Technologies\FlipShare\FlipShareService.exe
O23 - Service: Intel NCS NetService (NetSvc) - Intel(R) Corporation - C:\Program Files\Intel\NCS\Sync\NetSvc.exe
O23 - Service: RegSrvc - Intel Corporation - C:\WINDOWS\system32\RegSrvc.exe
O23 - Service: Spectrum24 Event Monitor (S24EventMonitor) - Intel Corporation - C:\WINDOWS\system32\S24EvMon.exe
End of file - 8797 bytes
twaier
Gender : Female
OS : xp
Post by Origin on Thu May 28, 2009 2:45 am
    If you don't recognize these domains you can fix them as well, Keep in mind if they belong to your Internet Service provider there will be a big possibility that you will lose your internet connection if you fix them so choose carefully.
Also Run ComboFix in normal mode and paste back the log.
OS : Windows Xp Sp3
Post by twaier on Thu May 28, 2009 3:02 am
Here's the log:
2009-05-28 02:37 . 2009-05-28 02:37 -------- d-----w c:\program files\Trend Micro
2009-05-28 02:20 . 2009-05-28 02:20 -------- d-----w c:\documents and settings\Administrator\Application Data\Malwarebytes
2009-05-28 02:20 . 2009-05-26 20:20 40160 ----a-w c:\windows\system32\drivers\mbamswissarmy.sys
2009-05-28 02:20 . 2009-05-28 02:20 -------- d-----w c:\documents and settings\All Users\Application Data\Malwarebytes
2009-05-28 02:20 . 2009-05-28 02:20 -------- d-----w c:\program files\Malwarebytes' Anti-Malware
2009-05-28 02:20 . 2009-05-26 20:19 19096 ----a-w c:\windows\system32\drivers\mbam.sys
2009-05-28 02:29 . 2008-11-23 05:37 -------- d-----w c:\program files\Common Files\Akamai
+ 2009-05-28 02:29 . 2009-05-28 02:29 16384 c:\windows\temp\Perflib_Perfdata_2e0.dat
"1350:TCP"= 1350:TCP:Akamai NetSession Interface
R2 Akamai;Akamai;c:\windows\System32\svchost.exe -k Akamai [8/4/2004 5:00 AM 14336]
R2 ASKService;ASKService;c:\program files\AskBarDis\bar\bin\AskService.exe [1/21/2009 9:12 PM 464264]
R2 ASKUpgrade;ASKUpgrade;c:\program files\AskBarDis\bar\bin\ASKUpgrade.exe [1/21/2009 9:12 PM 234888]
R2 FlipShare Service;FlipShare Service;c:\program files\Pure Digital Technologies\FlipShare\FlipShareService.exe [10/5/2008 2:55 PM 439616]
R3 OZSCR;O2Micro SmartCardBus Smartcard Reader;c:\windows\system32\drivers\ozscr.sys [1/26/2006 12:47 PM 92550]
.------- Supplementary Scan -------
FF - ProfilePath -
Rootkit scan 2009-05-27 19:56
- - - - - - - > 'winlogon.exe'(668)
- - - - - - - > 'explorer.exe'(2584)
c:\progra~1\WINDOW~2\wmpband.dll
c:\windows\system32\OneX.DLL
c:\windows\system32\eappprxy.dll
Completion time: 2009-05-28 19:59
ComboFix-quarantined-files.txt 2009-05-28 02:58
ComboFix2.txt 2009-05-28 01:42
Pre-Run: 3,949,907,968 bytes free
Post-Run: 3,945,840,640 bytes free
257 --- E O F --- 2009-05-26 23:15
twaier
Gender : Female
OS : xp
Post by Origin on Thu May 28, 2009 3:13 am
Ok looks good, now run Malwarebytes in normal mode as well and post the contents of the log and make sure you have the latest updates before running the scan.
OS : Windows Xp Sp3
Post by twaier on Thu May 28, 2009 3:20 am
Looks good! Here's the log:
5/27/2009 8:19:11 PM
mbam-log-2009-05-27 (20-19-11).txt
Objects scanned: 84854
Time elapsed: 3 minute(s), 47 second(s)
twaier
Gender : Female
OS : xp
Post by Origin on Thu May 28, 2009 3:32 am
ComboFix /u
OS : Windows Xp Sp3
Post by twaier on Thu May 28, 2009 3:37 am
It's running GREAT!!!
twaier
Gender : Female
OS : xp
Post by twaier on Thu May 28, 2009 4:19 am
Am I all good to go now? If so, is there anything I can do to prevent something like this from happening again?
twaier
Gender : Female
OS : xp
Post by Origin on Thu May 28, 2009 8:55 pm
Glad to hear things are running smooth Wink
OS : Windows Xp Sp3
Post by twaier on Thu May 28, 2009 11:03 pm
Thank you so much!!! I can't tell you how much I appreciated your help & the time you spent resolving my issues!!! I will gladly donate!!
twaier
Gender : Female
OS : xp
