Need Help Please.
Solved Need Help Please.
Post by Evil Dead on Tue Jan 08, 2008 2:56 am
I was not sure where to post this but I need to know if these temps are safe? and does this show the CPU temp?
Evil Dead
Posts Posts : 17
Joined Joined : 2008-01-05
Points Points : 32570
Solved Re: Need Help Please.
Post by Doctor Inferno on Tue Jan 08, 2008 10:36 am
The temperature is ok... but it doesn't show the CPU temp, only the GPU.
Good temps for a CPU are about 43 - 46C at idle, 46 - 50C on full load.
Post by Evil Dead on Tue Jan 08, 2008 3:59 pm
Well how do I check the CPU temp? because I installed a few different programs to do this but each time I tried to use them my computer would stall, the screen would go all black and I would have to restart in safe mode to uninstall the the program so the computer would work again.
I checked the Bios and it says my CPU has the temp read capability but it is turned off and there is no option to turn it on.
Evil Dead
Posts Posts : 17
Post by Doctor Inferno on Wed Jan 09, 2008 9:53 am
You can use a program like MotherBoard Monitor to check your temps. You can also check your CPU temperature in BIOS.
Post by bf2multi100 on Mon Jun 29, 2009 5:44 pm
i have a intel pentium D motherboard can i overclock it??
bf2multi100
Posts Posts : 11
Joined Joined : 2009-06-29
OS OS : Xp Pro SP3
Points Points : 27173
