Nobody seems to know how to help me!
Re: Nobody seems to know how to help me!
Post by Origin on Sun May 31, 2009 10:59 pm
Download Dr.Web CureIt to the desktop:
  • Double-click the launch.exe or cureit.exe file and Allow to run the express scan
  • This will scan the files currently running in memory and when something is found, click the yes button when it asks you if you want to cure it. This is only a short scan.
  • Once the short scan has finished, just let it cure whatever it finds...
    o Now, go to Settings >> Change Settings
    o Go to Actions tab >> under Objects section, change the settings to below
    Infected objects - Cure
    Incurable objects - Report
    Suspicious objects - Report
    o Don't change any other settings
  • Start the scan again. This time, choose Complete Scan
  • Click the green arrow button at the right, and the scan will start.
  • After the scan finished, click Select all
  • Click on Cure and choose Report incurable (means take no actions.. Don't "move", or "rename" or "delete")
  • When the scan has finished, in the menu, click File and choose Save report list
  • Save the report to your Desktop. The report will be called DrWeb.csv
  • Post DrWeb.csv in your next reply (Open it as Notepad).. Do NOT reboot the computer yet..
OS : Windows Xp Sp3
# Likes : 0
Post by xxdarkwolfrosexx on Mon Jun 01, 2009 3:07 pm
Cure was grayed out so I just clicked save report list, here's what I got.
Combo-Fix.exe/data002\32788R22FWJFW\FIND3M.bat;C:\Documents and Settings\Rayne\Desktop\Combo-Fix.exe/data002;Probably BATCH.Virus;;
data002;C:\Documents and Settings\Rayne\Desktop;Archive contains infected objects;;
Combo-Fix.exe;C:\Documents and Settings\Rayne\Desktop;Container contains infected objects;;
Process.exe.vir;C:\Qoobox\Quarantine\C\WINDOWS\system32;Tool.Prockill;;
gxvxctyxumfoafvaswuxrlnsrtufjwmrfvpix.sys.vir;C:\Qoobox\Quarantine\C\WINDOWS\system32\drivers;BackDoor.Tdss.167;;
A0260143.bat;C:\System Volume Information\_restore{E618FDC6-6616-4930-B0B0-A3813029C383}\RP418;Probably BATCH.Virus;;
A0260251.bat;C:\System Volume Information\_restore{E618FDC6-6616-4930-B0B0-A3813029C383}\RP418;Probably BATCH.Virus;;
A0261424.bat;C:\System Volume Information\_restore{E618FDC6-6616-4930-B0B0-A3813029C383}\RP434;Probably BATCH.Virus;;
A0261528.bat;C:\System Volume Information\_restore{E618FDC6-6616-4930-B0B0-A3813029C383}\RP434;Probably BATCH.Virus;;
xxdarkwolfrosexx
OS : XP
# Likes : 0
Hello?
Post by xxdarkwolfrosexx on Mon Jun 08, 2009 4:18 pm
Why did everyone stop helping me? I'm still having problems if not more now! Now my computer internet icon for my wireless adapter randomly shows up red (Off line) when it's still online and letting me browse around! Please don't stop helping me! This is the only place I go to for computer help!
xxdarkwolfrosexx
OS : XP
# Likes : 0
Post by Belahzur on Mon Jun 08, 2009 4:36 pm
Sorry, we didn't stop helping you, your post just got bumped back and we didn't notice. I'm sure you can see how much traffic were dealing with lately. Sad tearing
The problems don't appear to be malware related.
# Likes : 1
Post by xxdarkwolfrosexx on Mon Jun 08, 2009 4:45 pm
Oh sorry, It's ok Smile Sorry you guys have your hands full.
What do you think it may be? It doesn't make sense to me, or really to anybody it seems. Why is redtube still saying the Rustok thing? I only go there to see if I still have it. Before it didn't but now it always says I do.
xxdarkwolfrosexx
OS : XP
# Likes : 0
Post by Belahzur on Mon Jun 08, 2009 4:48 pm
  1. Unzip it and start GMER.
The log will be quite big, so please upload it to rapidshare.com.
# Likes : 1
Post by xxdarkwolfrosexx on Tue Jun 09, 2009 10:05 am
Ok, it wasn't too big but I put it on rapidshare anyway. This is the link.
xxdarkwolfrosexx
OS : XP
# Likes : 0
Post by Belahzur on Tue Jun 09, 2009 1:13 pm
That found the problem. Looks like maybe a new variant of a rootkit CF isn't catching yet.
Drivers to delete:
gaopdxserv.sys
# Likes : 1
Post by xxdarkwolfrosexx on Tue Jun 09, 2009 2:35 pm
Platform: Windows XP
Rootkit scan active.
No rootkits found!
Error: registry key "\Registry\Machine\System\CurrentControlSet\Services\gaopdxserv.sys" not found!
Deletion of driver "gaopdxserv.sys" failed!
--> the object does not exist
Completed script processing.
Finished! Terminate.
xxdarkwolfrosexx
OS : XP
# Likes : 0
Post by Belahzur on Tue Jun 09, 2009 3:33 pm
That didn't get it, hopefully this will this time.
1. Copy all the text contained in the code box below to your Clipboard by highlighting it and pressing (Ctrl+CCrying
Registry keys to delete:
HKLM\SYSTEM\ControlSet002\Services\gaopdxserv.sys
2. Now, start The Avenger program by clicking on its icon on your desktop.
3. Please copy/paste the content of c:\avenger.txt into your reply.
# Likes : 1
Post by xxdarkwolfrosexx on Tue Jun 09, 2009 5:56 pm
No rootkits found!
Registry key "HKLM\SYSTEM\ControlSet002\Services\gaopdxserv.sys" deleted successfully.
xxdarkwolfrosexx
OS : XP
# Likes : 0
Post by Belahzur on Tue Jun 09, 2009 8:56 pm
Okay, try updating stuff now.
# Likes : 1
Awesome!
Post by xxdarkwolfrosexx on Tue Jun 09, 2009 9:06 pm
Yes yes yes! I updated antivirus and everything! Hooray! Thank You!
xxdarkwolfrosexx
OS : XP
# Likes : 0
Post by Belahzur on Tue Jun 09, 2009 9:07 pm
ComboFix /u
# Likes : 1
Post by xxdarkwolfrosexx on Wed Jun 10, 2009 6:22 pm
Everything seems to be going great! I can update and my computer is faster now! Thank you so much for all your help, there is no way I could have done it without you! Thank you thank you thank you!
xxdarkwolfrosexx
OS : XP
# Likes : 0
