spyware alert 2009 removal help
Post by skate1234 on Tue 26 May 2009, 1:05 pm
Hi - I am new to this forum and am hoping I can find a solution to my computer problem. I started receiving "Spyware Alert 2009" Popup messages that my computer is infected with bankerfox.a and 34 other viruses. I immediately shut down and rebooted in safe mode to run my antivirus (ESOFT) program. It found several viruses that I deleted, but now when I try to run my system in normal mode, it freezes as my desktop is loading. I can run in safe mode, but I am not sure if the problem can be fixed here. Any assistance is greatly appreciated.
Thanks, B
Operating System : xp
Re: spyware alert 2009 removal help
Post by Origin on Wed 27 May 2009, 11:32 am
Hello, if you can boot in normal mode can you please run HijackThis and post the contents of the log back here, if not reply saying you can't:
Please download the current version of HijackThis from HERE
Tech Staff
Tech Staff
Operating System : Windows Xp Sp3
