Flash Player Doesn't Work in Firefox
Solved Flash Player Doesn''t Work in Firefox
Post by mcovotery on 22nd May 2009, 1:04 pm
I cant watch flash videos in Mozilla Firefox
What could the problem be
I have installed it and it works fine in I.
mcovotery
Posts Posts : 128
Joined Joined : 2008-09-23
OS OS : VISTA HOME EDITION
Points Points : 30325
Solved Re: Flash Player Doesn't Work in Firefox
Post by AuroraRange on 22nd May 2009, 1:54 pm
Did you downloaded the flash player for firefox? It is different from IE flash player
Posts Posts : 507
Joined Joined : 2008-08-22
OS OS : Xubuntu & Windows 7
Points Points : 30809
Post by mcovotery on 23rd May 2009, 12:02 am
Yeah, the flash version says it is for Firefox, IE and Opera
It seems to be working fine after i updated Firefox,
However i often have this problem
What could the reason be?
mcovotery
Posts Posts : 128
Post by Doctor Inferno on 23rd May 2009, 2:50 am
You probably have a conflict between Mozilla's ActiveX plugin and Flash (or any other ActiveX plugin).
Uninstall the Mozilla ActiveX plugin:
http://forums.mozillazine.org/viewtopic.php?t=206213#Uninstall
Here is some info on Mozilla's ActiveX plug in:
http://forums.mozillazine.org/viewtopic.php?t=206213#FF_1
Pay attention to the part that states: "Most methods of updating Firefox to a new version do not remove the ActiveX plugin, and there is no guarantee that the plugin version you have will work with the new version of Firefox. It is strongly recommended that you uninstall the ActiveX plugin before you update Firefox. Having the wrong version of the ActiveX plugin installed can cause other plugins (especially Flash) to malfunction."
Post by mcovotery on 24th May 2009, 11:25 pm
OK cool
If the problem comes up again i will try this
mcovotery
Posts Posts : 128
