Mounting problems with CPU Cooler
Solved Mounting problems with CPU Cooler
Post by TheWeave on 19th May 2009, 4:45 pm
I have had this Gateway 506GR computer for about five years. The CPU Cooler is beginning whine and grind. The motherboard is a Intel D915GAG pentium 4 processor 550 3.4 GHz Socket 775 4 Pin Connector. The old CPU Cooler is a Cooler Master CM V12 (screw in mount). I am about to show my ignorance here: Can I just purchase a Socket 775 cooler (screw in mount)and screw it into the existing mount. Would I have to use the back plate?
One cooler supplier said I had to use it for grounding. I'm thinking that the original mount is grounded.
Thanks in advance for your help.
Ron :hmm:
Last edited by Doctor Inferno on 28th May 2009, 6:57 am; edited 2 times in total (Reason for editing : Additional info)
TheWeave
Posts Posts : 60
Joined Joined : 2009-01-10
OS OS : XP Home, SP3,
Protection Protection : AVG Free
Points Points : 28974
Solved Re: Mounting problems with CPU Cooler
Post by AuroraRange on 21st May 2009, 6:05 am
The back plate is not needed for a back plate. I dont think that lga775 stock fan, most likely foxconn HSF screws, are able to fit through your existing back plate. In the end, its quite safe without a back plate because that HSF is very light weight and doesn't require a backplate.
Posts Posts : 507
Joined Joined : 2008-08-22
OS OS : Xubuntu & Windows 7
Points Points : 30809
Post by TheWeave on 21st May 2009, 4:42 pm
Thank you for your reply. I guess I will purchase a cooler such as the Masscool 8WT 15-17 (LGA775) which has the spring type screws and hope it will fasten to my mobo. I am not familiar with the "foxconn HSF screws". Can these be purchased separately?
Ron
TheWeave
Posts Posts : 60
Post by AuroraRange on 22nd May 2009, 2:02 pm
@TheWeave wrote:Thank you for your reply. I guess I will purchase a cooler such as the Masscool 8WT 15-17 (LGA775) which has the spring type screws and hope it will fasten to my mobo. I am not familiar with the "foxconn HSF screws". Can these be purchased separately?
Ron
I belief the stock fan is also using screw type fan like in the picture.
This fan is made by foxconn if Im not wrong.
Posts Posts : 507
Post by TheWeave on 22nd May 2009, 2:48 pm
Hi
The cooler shown in the picture does't screw in. Look here:http://www.pcstats.com/articleview.cfm?articleid=2231&page=6
Evidently my mobo has a backplate installed for the original cooler. I don't want to pull my mobo so I will try a cooler with the spring type screw connectors and hope the the threads match.
I appreciate your feedback.
Ron
TheWeave
Posts Posts : 60
Post by AuroraRange on 24th May 2009, 7:09 am
Its a screw in HSF-.-, see properly. If you dont want to remove the backplate, you can find other brands which uses the same kind of screws. I dont know what size your screw need to be but I will rather change the whole thing. Good luck on your search.
Posts Posts : 507
Post by TheWeave on 24th May 2009, 1:52 pm
Thank you. I have ordered a cooler with spring loaded screws. I will let you know this works.
Ron
TheWeave
Posts Posts : 60
Post by TheWeave on 27th May 2009, 10:08 pm
Hi
The cooler (Dynatron P-985) screwed right in and appears to be working fine. Thanks again for your response.
Ron
TheWeave
Posts Posts : 60
