Although I have read your request for downloads my problem s
Page 2 of 2 Previous  1, 2
Re: Although I have read your request for downloads my problem s
Post by happymom on 19th May 2009, 10:45 pm
I thought you said to get rid of my Ad-Aware and Spybot programs? Should I keep them or get rid of them I am now confused as this last post says to install them.
happymom
Posts Posts : 34
Joined Joined : 2009-05-19
OS OS : windows xp
Points Points : 27636
Post by Belahzur on 19th May 2009, 10:49 pm
Don't install them. LMBO or ROFL
Sorry, I didn't think to edit them out.
Posts Posts : 34917
Points Points : 245090
Post by happymom on 19th May 2009, 10:59 pm
So what about not being able to uninstall Lycos Search??? Should I be worried??
happymom
Posts Posts : 34
OS OS : windows xp
Post by Belahzur on 19th May 2009, 11:01 pm
What error does it give you?
Posts Posts : 34917
Post by happymom on 19th May 2009, 11:04 pm
Nothing...it just blips on the screen and doesn't do anything. Exactly like what my computer was doing before when I was trying to open any of my programs.
happymom
Posts Posts : 34
OS OS : windows xp
Post by Belahzur on 19th May 2009, 11:06 pm
Download RevoUninstall from here:
Install it, and run the program.
Find Lycos Search on the list and press the "Uninstall" or "Remove" button at the top.
Posts Posts : 34917
Post by happymom on 19th May 2009, 11:09 pm
You have an answer for everything don't you! Smile
Should I keep all the programs we used today installed on my computer or should I delete some of them?
happymom
Posts Posts : 34
OS OS : windows xp
Post by Belahzur on 19th May 2009, 11:13 pm
You can get rid of Hijack This, etc if you want, but I would keep MBAM and Revo Uninstaller, both can be quite useful.
Posts Posts : 34917
Post by happymom on 20th May 2009, 12:00 am
Ok...last question...I think! Should I change my Network Proxy setting back? It is now on "No Proxy".
Thank you so much for all of your help! You are a miracle worker! I have added you to all my blog sites...they are all mom sites they have already gotten really excited at the prospect of having a site to help them out. After I am sure my computer isn't infected with anything in a few days I will make a donation...right now as confident as I am that it is fixed I am still leery of putting my credit card info on it just yet! My laptop is using someone elses wireless (shhh!) so I know I won't use my card on that computer!
Thanks again.
Lisa
happymom
Posts Posts : 34
OS OS : windows xp
Post by Belahzur on 20th May 2009, 12:06 am
No, the proxy settings were changed by malware to block out internet connection, that's why you had internet connection problems in the first place.
Don't get infected again. LMBO or ROFL
Posts Posts : 34917
Post by happymom on 20th May 2009, 12:30 am
Ha Ha Ha...your pretty funny there Belahzur. Annoyed or Unimpress I will do my best not to get infected again! Thanks again for all of your help!
happymom
Posts Posts : 34
OS OS : windows xp
