Cannot run dds.scr/system sercurity removal problem
Re: Cannot run dds.scr/system sercurity removal problem
Post by Belahzur on 14th May 2009, 8:32 pm
I notice that you have Spybot's TeaTimer running. While this is normally a wonderful tool to protect against hijackers, it can also interfere with HijackThis fixes. So please disable TeaTimer by doing the following:
1) Run Spybot-S&D
2) Go to the Mode menu, and make sure "Advanced Mode" is selected
3) On the left hand side, choose Tools -> Resident
4) Uncheck "Resident TeaTimer" and OK any prompts
You can reenable TeaTimer once your system is clean.
Please make sure Teatimer is disable before we do this, otherwise this fix will fail.
    O4 - HKLM\..\Run: [63126089] C:\Documents and Settings\All Users\Application Data\63126089\63126089.exe
    O4 - HKCU\..\Run: [SmileboxTray] "C:\Documents and Settings\User\Application Data\Smilebox\SmileboxTray.exe"
    O4 - HKCU\..\Run: [BitTorrent DNA] "C:\Program Files\DNA\btdna.exe"
Now I want to get an uninstall log, and we can use Hijack This again to get that.
  • Open HijackThis again.
Points Points : 245101
Post by badger98 on 14th May 2009, 8:50 pm
Ad-Aware
Adobe Acrobat 6.0 Professional
Adobe Download Manager 2.0 (Remove Only)
Adobe Flash Player 10 ActiveX
Adobe Flash Player Plugin
Adobe Illustrator CS
Adobe Photoshop CS
Adobe Shockwave Player
Adobe SVG Viewer 3.0
AdsGone Popup Killer by A1Tech.com
aiofw
aioocr
aioprnt
aioscnnr
Amazon Unbox Video
Apple Mobile Device Support
Apple Software Update
BCM V.92 56K Modem
Bonjour
Canon Camera Window for ZoomBrowser EX
Canon PhotoRecord
Canon RAW Image Task for ZoomBrowser EX
Canon RemoteCapture Task for ZoomBrowser EX
Canon Utilities PhotoStitch 3.1
Canon Utilities ZoomBrowser EX
CCScore
center
CleanUp!
DebtFree(tm) for Windows Personal 5.1b
Diskeeper Professional Edition
Dolet Light for Finale
DV Network Software
DVD X Player Professional V3.0
DVD X Rescue
DVDXCopy Platinum 3.2.1
ESSBrwr
ESSCDBK
ESScore
ESSgui
ESSini
ESSPCD
ESSPDock
ESSSONIC
ESSTOOLS
essvatgt
Expedia Fare Alert
Finale 2003
Finale 2006
Finale 2008
Finale Performance Assessment
Fisher-Price Computer Cool School
Fisher-Price Dora and Diego's Classroom
Fisher-Price Scooby-Doo's Classroom
Fisher-Price SpongeBob's Classroom
Garritan Instruments for Finale
Help_CTR
helptut
helpug
HijackThis 2.0.2
Image Resizer Powertoy for Windows XP
Intel(R) PRO Network Adapters and Drivers
ItsDeductible Express
iTunes
Java 2 Runtime Environment Standard Edition v1.3.1_04
Juno 6
kgcbase
kgchday
kgchlwn
kgcinvt
kgckids
KODAK All-in-One Printer Software
ksdip
LimeWire
Malwarebytes' Anti-Malware
MD Simple Burner 2.0.03
Microsoft .NET Framework 1.1
Microsoft .NET Framework 2.0
Microsoft ActiveSync
Microsoft Money Plus
Microsoft Money Shared Libraries
Microsoft Office Professional Edition 2003
Microsoft Streets and Trips 2005
MobileMe Control Panel
MSXML 4.0 SP2 (KB927978)
MSXML 4.0 SP2 (KB936181)
MSXML 4.0 SP2 (KB954430)
netbrdg
OfotoXMI
OpenMG AAC Add-on Module 1.0.00
OpenMG Limited Patch 4.5-06-05-12-01
OpenMG Secure Module 4.5.01
PeoplePC Online
PeoplePC:PeoplePal Toolbar 3.0
Photo Viewer S3.0
PhotoParade Player
Pinnacle Hollywood FX for Studio
Prism Video Converter
QuickTime
RealPlayer
Rhapsody Player Engine
Roxio Easy Media Creator 7
Safari
Security Update for Microsoft .NET Framework 2.0 (KB928365)
Security Update for Windows Internet Explorer 7 (KB928090)
Security Update for Windows Internet Explorer 7 (KB929969)
Security Update for Windows Internet Explorer 7 (KB931768)
SFR
SFR2
SHASTA
skin0001
SKINXSDK
SmartSound Quicktracks Plugin
SonicStage 4.0
SoundMAX
Spb Mobile DVD
Spiral Mile Sudoku Rules for PDASP (remove only)
SPT Accessories Plus 2002
Spybot - Search & Destroy
StarFlyers Alien Space Chase
staticcr
S-Tris
Studio 9
Switch
Time Zone Data Update Tool for Microsoft Office Outlook
tooltips
TurboTax Deluxe 2004
Verizon Broadband Toolbar
Verizon Online Help & Support
Verizon PC Security Checkup
Verizon Servicepoint 1.3.21
VPRINTOL
WexTech AnswerWorks
Williams-Sonoma Guide to Good Cooking
Windows Defender
Windows Mobile Daylight Saving Time 2007 Updates
Windows XP Service Pack 3
WinMX
WinZip
WIRELESS
Yahoo! Toolbar
badger98
Posts Posts : 28
Joined Joined : 2009-05-13
Points Points : 27807
Post by Belahzur on 14th May 2009, 9:11 pm
I see that you are running Limewire.
If Limewire is not removed, then I won't help you.
  • Java 2 Runtime Environment Standard Edition v1.3.1_04
  • LimeWire
Post by badger98 on 14th May 2009, 9:39 pm
Everything seems to be running fine. I did remove the Java 2 and it prompted me that it could not remove all files that I would have to remove some manually. I removed Limewire, I don't even think I have used it in more than a couple of years.
Should I delete all of the programs I downloaded for the repair (dds, OTMoveIt3, RootRepeal, GMER, Silentrunners, malwarebytes')?
Also I have a backup file on the desktop containing 3 1KB files, backup-20090514-164859-717, -862, and -936. What should I do with those?
Here's the updated uninstall list:
Ad-Aware
Adobe Photoshop CS
aiofw
aioocr
aioprnt
aioscnnr
Amazon Unbox Video
BCM V.92 56K Modem
Bonjour
Canon PhotoRecord
CCScore
center
CleanUp!
DV Network Software
DVD X Rescue
ESSBrwr
ESSCDBK
ESScore
ESSgui
ESSini
ESSPCD
ESSPDock
ESSSONIC
ESSTOOLS
essvatgt
Expedia Fare Alert
Finale 2003
Finale 2006
Finale 2008
Help_CTR
helptut
helpug
HijackThis 2.0.2
iTunes
Juno 6
kgcbase
kgchday
kgchlwn
kgcinvt
kgckids
ksdip
netbrdg
OfotoXMI
PeoplePC Online
Photo Viewer S3.0
PhotoParade Player
QuickTime
RealPlayer
Safari
SFR
SFR2
SHASTA
skin0001
SKINXSDK
SonicStage 4.0
SoundMAX
Spb Mobile DVD
staticcr
S-Tris
Studio 9
Switch
tooltips
VPRINTOL
WexTech AnswerWorks
Windows Defender
WinMX
WinZip
WIRELESS
Yahoo! Toolbar
badger98
Posts Posts : 28
Post by Belahzur on 14th May 2009, 9:43 pm
Delete the toos we tried to use, and delete the backups.
You aren't running Anti Virus Software
Please install Avira antivirus otherwise you won't be protected.
Post by badger98 on 14th May 2009, 10:51 pm
Should I take off Spybot, and Adsgone? And should I stop Windows Defender?
badger98
Posts Posts : 28
Post by Belahzur on 14th May 2009, 11:00 pm
Don't remove Windows Defender, but remove Spybot/Adsgone.
Post by badger98 on 14th May 2009, 11:18 pm
Thank you very much for your help. Is the Avira going to expire after a year? Would you suggest I try the premium? There is a free offer through trial pay.
badger98
Posts Posts : 28
Post by Belahzur on 14th May 2009, 11:31 pm
No, the free version never expires. I use it myself.
