Cannot run dds.scr/system sercurity removal problem
Post by badger98 on Wed May 13, 2009 1:04 pm
I downloaded dds.scr/dds.pif and I was unable to run the program. A bubble from the toolbar came up "Application cannot be exectured. The file ddr.scr is infected. Please activate your antivirus software." That brings you to a screen where you have no choice but enter your credit card information and buy their bogus software. Please help.
-Badger98
badger98
OS : Windows XP
Re: Cannot run dds.scr/system sercurity removal problem
Post by Belahzur on Wed May 13, 2009 1:11 pm
Lets try oldschool LMBO or ROFL
cannot run winzip32
Post by badger98 on Wed May 13, 2009 6:04 pm
I get the same message. Is there a way to adjust the registry in safe mode so the messages do not come up?
-Badger98
badger98
OS : Windows XP
Post by Belahzur on Wed May 13, 2009 8:43 pm
    This is mirror is recommended as it will download a random name exe file
  1. Double click to start GMER.
GMER Scan Results
Post by badger98 on Thu May 14, 2009 12:02 am
Here is the log.
GMER 1.0.15.14972 - [You must be registered and logged in to see this link.]
Rootkit scan 2009-05-13 20:01:46
---- System - GMER 1.0.15 ----
Code \SystemRoot\system32\DRIVERS\css-dvp.sys (Dynamic Virus Protection/Command Software Systems, Inc.) ZwClose [0xF1F54B4C]
Code \SystemRoot\system32\DRIVERS\css-dvp.sys (Dynamic Virus Protection/Command Software Systems, Inc.) ZwCreateSection [0xF1F54DB7]
Code \SystemRoot\system32\DRIVERS\css-dvp.sys (Dynamic Virus Protection/Command Software Systems, Inc.) ZwSetInformationFile [0xF1F54235]
Code \SystemRoot\system32\DRIVERS\css-dvp.sys (Dynamic Virus Protection/Command Software Systems, Inc.) ZwWriteFile [0xF1F53E81]
Code \SystemRoot\system32\DRIVERS\css-dvp.sys (Dynamic Virus Protection/Command Software Systems, Inc.) IoCreateFile
Code \SystemRoot\system32\DRIVERS\css-dvp.sys (Dynamic Virus Protection/Command Software Systems, Inc.) NtClose
Code \SystemRoot\system32\DRIVERS\css-dvp.sys (Dynamic Virus Protection/Command Software Systems, Inc.) NtCreateSection
Code \SystemRoot\system32\DRIVERS\css-dvp.sys (Dynamic Virus Protection/Command Software Systems, Inc.) NtSetInformationFile
Code \SystemRoot\system32\DRIVERS\css-dvp.sys (Dynamic Virus Protection/Command Software Systems, Inc.) NtWriteFile
---- Kernel code sections - GMER 1.0.15 ----
PAGE ntoskrnl.exe!NtCreateSection 8056DB66 7 Bytes JMP F1F54DBB \SystemRoot\system32\DRIVERS\css-dvp.sys (Dynamic Virus Protection/Command Software Systems, Inc.)
PAGE ntoskrnl.exe!NtClose 8056FA48 5 Bytes JMP F1F54B50 \SystemRoot\system32\DRIVERS\css-dvp.sys (Dynamic Virus Protection/Command Software Systems, Inc.)
PAGE ntoskrnl.exe!IoCreateFile 8057C2C6 5 Bytes JMP F1F539AA \SystemRoot\system32\DRIVERS\css-dvp.sys (Dynamic Virus Protection/Command Software Systems, Inc.)
PAGE ntoskrnl.exe!NtSetInformationFile 8057F4E5 7 Bytes JMP F1F54239 \SystemRoot\system32\DRIVERS\css-dvp.sys (Dynamic Virus Protection/Command Software Systems, Inc.)
PAGE ntoskrnl.exe!NtWriteFile 8057F765 7 Bytes JMP F1F53E85 \SystemRoot\system32\DRIVERS\css-dvp.sys (Dynamic Virus Protection/Command Software Systems, Inc.)
PAGE Fastfat.SYS F1F229C8 7 Bytes JMP F1F5539E \SystemRoot\system32\DRIVERS\css-dvp.sys (Dynamic Virus Protection/Command Software Systems, Inc.)
Reg HKLM\SYSTEM\CurrentControlSet\Services\Eventlog\Application\ESENT@EventMessageFile c:\windows\system32\ESENT.dll
Reg HKLM\SYSTEM\CurrentControlSet\Services\Eventlog\Application\ESENT@CategoryMessageFile c:\windows\system32\ESENT.dll
Reg HKLM\SOFTWARE\Classes\CLSID\{47629D4B-2AD3-4e50-B716-A66C15C63153}\InprocServer32
Reg HKLM\SOFTWARE\Classes\CLSID\{47629D4B-2AD3-4e50-B716-A66C15C63153}\InprocServer32@ThreadingModel Apartment
Reg HKLM\SOFTWARE\Classes\CLSID\{47629D4B-2AD3-4e50-B716-A66C15C63153}\InprocServer32@ C:\WINDOWS\system32\OLE32.DLL
Reg HKLM\SOFTWARE\Classes\CLSID\{47629D4B-2AD3-4e50-B716-A66C15C63153}\InprocServer32@cd042efbbd7f7af1647644e76e06692b 0xE2 0x63 0x26 0xF1 ...
Reg HKLM\SOFTWARE\Classes\CLSID\{604BB98A-A94F-4a5c-A67C-D8D3582C741C}\InprocServer32
Reg HKLM\SOFTWARE\Classes\CLSID\{604BB98A-A94F-4a5c-A67C-D8D3582C741C}\InprocServer32@ThreadingModel Apartment
Reg HKLM\SOFTWARE\Classes\CLSID\{604BB98A-A94F-4a5c-A67C-D8D3582C741C}\InprocServer32@ C:\WINDOWS\system32\OLE32.DLL
Reg HKLM\SOFTWARE\Classes\CLSID\{604BB98A-A94F-4a5c-A67C-D8D3582C741C}\InprocServer32@bca643cdc5c2726b20d2ecedcc62c59b 0x46 0x47 0x15 0xB0 ...
Reg HKLM\SOFTWARE\Classes\CLSID\{684373FB-9CD8-4e47-B990-5A4466C16034}\InprocServer32
Reg HKLM\SOFTWARE\Classes\CLSID\{684373FB-9CD8-4e47-B990-5A4466C16034}\InprocServer32@ThreadingModel Apartment
Reg HKLM\SOFTWARE\Classes\CLSID\{684373FB-9CD8-4e47-B990-5A4466C16034}\InprocServer32@ C:\WINDOWS\system32\OLE32.DLL
Reg HKLM\SOFTWARE\Classes\CLSID\{684373FB-9CD8-4e47-B990-5A4466C16034}\InprocServer32@2c81e34222e8052573023a60d06dd016 0x25 0xDA 0xEC 0x7E ...
Reg HKLM\SOFTWARE\Classes\CLSID\{74554CCD-F60F-4708-AD98-D0152D08C8B9}\InprocServer32
Reg HKLM\SOFTWARE\Classes\CLSID\{74554CCD-F60F-4708-AD98-D0152D08C8B9}\InprocServer32@ThreadingModel Apartment
Reg HKLM\SOFTWARE\Classes\CLSID\{74554CCD-F60F-4708-AD98-D0152D08C8B9}\InprocServer32@ C:\WINDOWS\system32\OLE32.DLL
Reg HKLM\SOFTWARE\Classes\CLSID\{74554CCD-F60F-4708-AD98-D0152D08C8B9}\InprocServer32@2582ae41fb52324423be06337561aa48 0x3E 0x1E 0x9E 0xE0 ...
Reg HKLM\SOFTWARE\Classes\CLSID\{7EB537F9-A916-4339-B91B-DED8E83632C0}\InprocServer32
Reg HKLM\SOFTWARE\Classes\CLSID\{7EB537F9-A916-4339-B91B-DED8E83632C0}\InprocServer32@ThreadingModel Apartment
Reg HKLM\SOFTWARE\Classes\CLSID\{7EB537F9-A916-4339-B91B-DED8E83632C0}\InprocServer32@ C:\WINDOWS\system32\OLE32.DLL
Reg HKLM\SOFTWARE\Classes\CLSID\{7EB537F9-A916-4339-B91B-DED8E83632C0}\InprocServer32@caaeda5fd7a9ed7697d9686d4b818472 0xF5 0x1D 0x4D 0x73 ...
Reg HKLM\SOFTWARE\Classes\CLSID\{948395E8-7A56-4fb1-843B-3E52D94DB145}\InprocServer32
Reg HKLM\SOFTWARE\Classes\CLSID\{948395E8-7A56-4fb1-843B-3E52D94DB145}\InprocServer32@ThreadingModel Apartment
Reg HKLM\SOFTWARE\Classes\CLSID\{948395E8-7A56-4fb1-843B-3E52D94DB145}\InprocServer32@ C:\WINDOWS\system32\OLE32.DLL
Reg HKLM\SOFTWARE\Classes\CLSID\{948395E8-7A56-4fb1-843B-3E52D94DB145}\InprocServer32@a4a1bcf2cc2b8bc3716b74b2b4522f5d 0xB0 0x18 0xED 0xA7 ...
Reg HKLM\SOFTWARE\Classes\CLSID\{AC3ED30B-6F1A-4bfc-A4F6-2EBDCCD34C19}\InprocServer32
Reg HKLM\SOFTWARE\Classes\CLSID\{AC3ED30B-6F1A-4bfc-A4F6-2EBDCCD34C19}\InprocServer32@ThreadingModel Apartment
Reg HKLM\SOFTWARE\Classes\CLSID\{AC3ED30B-6F1A-4bfc-A4F6-2EBDCCD34C19}\InprocServer32@ C:\WINDOWS\system32\OLE32.DLL
Reg HKLM\SOFTWARE\Classes\CLSID\{AC3ED30B-6F1A-4bfc-A4F6-2EBDCCD34C19}\InprocServer32@4d370831d2c43cd13623e232fed27b7b 0x31 0x77 0xE1 0xBA ...
Reg HKLM\SOFTWARE\Classes\CLSID\{DE5654CA-EB84-4df9-915B-37E957082D6D}\InprocServer32
Reg HKLM\SOFTWARE\Classes\CLSID\{DE5654CA-EB84-4df9-915B-37E957082D6D}\InprocServer32@ThreadingModel Apartment
Reg HKLM\SOFTWARE\Classes\CLSID\{DE5654CA-EB84-4df9-915B-37E957082D6D}\InprocServer32@ C:\WINDOWS\system32\OLE32.DLL
Reg HKLM\SOFTWARE\Classes\CLSID\{DE5654CA-EB84-4df9-915B-37E957082D6D}\InprocServer32@1d68fe701cdea33e477eb204b76f993d 0xAA 0x52 0xC6 0x00 ...
Reg HKLM\SOFTWARE\Classes\CLSID\{E39C35E8-7488-4926-92B2-2F94619AC1A5}\InprocServer32
Reg HKLM\SOFTWARE\Classes\CLSID\{E39C35E8-7488-4926-92B2-2F94619AC1A5}\InprocServer32@ThreadingModel Apartment
Reg HKLM\SOFTWARE\Classes\CLSID\{E39C35E8-7488-4926-92B2-2F94619AC1A5}\InprocServer32@ C:\WINDOWS\system32\OLE32.DLL
Reg HKLM\SOFTWARE\Classes\CLSID\{E39C35E8-7488-4926-92B2-2F94619AC1A5}\InprocServer32@1fac81b91d8e3c5aa4b0a51804d844a3 0xB2 0x46 0x9A 0xE2 ...
Reg HKLM\SOFTWARE\Classes\CLSID\{EACAFCE5-B0E2-4288-8073-C02FF9619B6F}\InprocServer32
Reg HKLM\SOFTWARE\Classes\CLSID\{EACAFCE5-B0E2-4288-8073-C02FF9619B6F}\InprocServer32@ThreadingModel Apartment
Reg HKLM\SOFTWARE\Classes\CLSID\{EACAFCE5-B0E2-4288-8073-C02FF9619B6F}\InprocServer32@ C:\WINDOWS\system32\OLE32.DLL
Reg HKLM\SOFTWARE\Classes\CLSID\{EACAFCE5-B0E2-4288-8073-C02FF9619B6F}\InprocServer32@f5f62a6129303efb32fbe080bb27835b 0x3D 0xCE 0xEA 0x26 ...
Reg HKLM\SOFTWARE\Classes\CLSID\{F8F02ADD-7366-4186-9488-C21CB8B3DCEC}\InprocServer32
Reg HKLM\SOFTWARE\Classes\CLSID\{F8F02ADD-7366-4186-9488-C21CB8B3DCEC}\InprocServer32@ThreadingModel Apartment
Reg HKLM\SOFTWARE\Classes\CLSID\{F8F02ADD-7366-4186-9488-C21CB8B3DCEC}\InprocServer32@ C:\WINDOWS\system32\OLE32.DLL
Reg HKLM\SOFTWARE\Classes\CLSID\{F8F02ADD-7366-4186-9488-C21CB8B3DCEC}\InprocServer32@fd4e2e1a3940b94dceb5a6a021f2e3c6 0x2A 0xB7 0xCC 0xB5 ...
Reg HKLM\SOFTWARE\Classes\CLSID\{FEE45DE2-A467-4bf9-BF2D-1411304BCD84}\InprocServer32
Reg HKLM\SOFTWARE\Classes\CLSID\{FEE45DE2-A467-4bf9-BF2D-1411304BCD84}\InprocServer32@ThreadingModel Apartment
Reg HKLM\SOFTWARE\Classes\CLSID\{FEE45DE2-A467-4bf9-BF2D-1411304BCD84}\InprocServer32@ C:\WINDOWS\system32\OLE32.DLL
Reg HKLM\SOFTWARE\Classes\CLSID\{FEE45DE2-A467-4bf9-BF2D-1411304BCD84}\InprocServer32@8a8aec57dd6508a385616fbc86791ec2 0x6C 0x43 0x2D 0x1E ...
---- EOF - GMER 1.0.15 ----
badger98
OS : Windows XP
Post by Belahzur on Thu May 14, 2009 12:07 am
That looks okay. Lets try this.
Please close all anti virus, anti malware and any other open programs/windows so they do not interfere with the running of RootRepeal.
  • Please download RootRepeal.zip from [You must be registered and logged in to see this link.].
  • Extract the program file to your Desktop.
  • Run the program RootRepeal.exe and go to the Report tab and click on the Scan button.
  • Select ALL of the checkboxes and then click OK and it will start scanning your system.
  • If you have multiple drives you only need to check the C: drive or the one Windows is installed on.
  • When done, click on Save Report
  • Save it to the Desktop.
  • Please copy/paste the contents of the report in your next reply.
Post by badger98 on Thu May 14, 2009 12:27 am
I get the bubble telling me the rootrepeal.exe. is infected and it is not letting me open or run it.
-Badger98
badger98
OS : Windows XP
Post by Belahzur on Thu May 14, 2009 12:29 am
Lets try this manually.
    regedit /e peek1.txt "HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run"
    regedit /e peek2.txt "HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run"
    type peek1.txt >> look.txt
    type peek2.txt >> look.txt
    del peek*.txt
    start notepad look.txt
  • Save this as look.bat, save it to your desktop.
  • Double click look.bat to run it.
  • Copy and paste the report back here.
Post by badger98 on Thu May 14, 2009 12:43 am
I am not able to open notepad.exe. It gives me the same message.
badger98
OS : Windows XP
Post by Belahzur on Thu May 14, 2009 12:53 am
This is seriously limiting what we can do here. I'll think about this through the night.
Post by badger98 on Thu May 14, 2009 3:58 am
Thanks for working with me.
badger98
OS : Windows XP
Post by Belahzur on Thu May 14, 2009 8:45 am
Lets try an online scan.
Please use the Internet Explorer browser, and do an online scan with [You must be registered and logged in to see this link.]
Note: If you have used this particular scanner before, you MAY HAVE TO UNINSTALL the program through Add/Remove Programs before downloading the new ActiveX component
Click Accept, when prompted to download and install the program files and database of malware definitions.
  • Click Run at the Security prompt.
  • The program will then begin downloading and installing and will also update the database.
  • Please be patient as this can take several minutes.
  • Once the update is complete, click on My Computer under the green Scan bar to the left to start the scan.
  • Once the scan is complete, it will display if your system has been infected. It does not provide an option to clean/disinfect. We only require a report from it.
  • Do NOT be alarmed by what you see in the report. Many of the finds have likely been quarantined.
  • Click View scan report at the bottom.
  • Click the Save as Text button to save the file to your desktop so that you may post it in your next reply.
    **Note**
    To optimize scanning time and produce a more sensible report for review:
  • Close any open programs.
  • Turn off the real-time scanner of all antivirus or antispyware programs while performing the online scan.
Note for Internet Explorer 7 users: If at any time you have trouble viewing the accept button of the license, click on the Zoom tool located at the bottom right of the IE window and set the zoom to 75%. Once the license is accepted, reset to 100%.
Post by badger98 on Thu May 14, 2009 4:42 pm
Error Bubble. "Application cannot be executed. File iedw.exe is infected. Please activate your antivirus software."
badger98
OS : Windows XP
Post by Belahzur on Thu May 14, 2009 4:56 pm
See if you can run this version of DDS:
Post by badger98 on Thu May 14, 2009 5:05 pm
I cannot run either of the dds version from techsupportforum.com. I get that same message. The only way I am able to run any program is in safe mode. I know that is not much help, sorry.
badger98
OS : Windows XP
Post by Belahzur on Thu May 14, 2009 5:14 pm
Ah, see if you can run DDS in safe mode then.
Post by badger98 on Thu May 14, 2009 6:17 pm
Here is the DDS scan. I restarted from the safe mode and the problem seems to have disappeared.
DDS (Ver_09-03-16.01) - NTFSx86
Run by User at 13:42:30.75 on Thu 05/14/2009
Internet Explorer: 7.0.5730.11
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.511.100 [GMT -4:00]
svchost.exe
C:\Program Files\Windows Defender\MsMpEng.exe
svchost.exe
svchost.exe
C:\Program Files\Lavasoft\Ad-Aware\aawservice.exe
C:\WINDOWS\BCMSMMSG.exe
C:\Program Files\SPT\Accessories Plus\clockplus.exe
C:\WINDOWS\system32\PPCRunOnce.exe
C:\PROGRA~1\VERIZO~1\HELPSU~1\VERIZO~1.EXE
C:\Program Files\Verizon\Servicepoint\VerizonServicepoint.exe
C:\Program Files\ISP50\Bin\Bartshel.exe
C:\Program Files\Windows Defender\MSASCui.exe
C:\Program Files\Common Files\Verizon Online\ConnMgr\cmisrv.exe
C:\Program Files\Real\RealPlayer\RealPlay.exe
C:\Documents and Settings\All Users\Application Data\63126089\63126089.exe
C:\Program Files\Microsoft ActiveSync\Wcescomm.exe
C:\PROGRA~1\Sony\SONICS~1\SsAAD.exe
C:\Documents and Settings\User\Desktop\dds.scr
C:\Program Files\Microsoft Money Plus\MNYCoreFiles\mnyinsit.exe
C:\Program Files\Microsoft Money Plus\MNYCoreFiles\mnybbsvc.exe
C:\Documents and Settings\User\Application Data\Smilebox\SmileboxTray.exe
C:\Program Files\DNA\btdna.exe
C:\PROGRA~1\MI3AA1~1\rapimgr.exe
C:\Program Files\AdsGone\adsgone.exe
C:\Program Files\Amazon\Amazon Unbox Video\ADVWindowsClientSystemTray.exe
C:\Program Files\Kodak\Kodak EasyShare software\bin\EasyShare.exe
C:\Program Files\Expedia\Expedia Fare Alert\ExpediaFareAlert.exe
svchost.exe
C:\Program Files\Amazon\Amazon Unbox Video\ADVWindowsClientService.exe
C:\PROGRA~1\ISP50\bin\ppshared.exe
C:\Program Files\Executive Software\Diskeeper\DkService.exe
C:\Program Files\Common Files\Command Software\dvpapi.exe
C:\Program Files\Kodak\printer\center\KodakSvc.exe
C:\Program Files\Sony\MD Simple Burner\NetMDSB.exe
C:\WINDOWS\System32\svchost.exe -k imgsvc
C:\Program Files\Sony\MD Simple Burner\mdrcreg.exe
C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\csc.exe
uInternet Connection Wizard,ShellNext = [You must be registered and logged in to see this link.]
BHO: AcroIEHlprObj Class: {06849e9f-c8d7-4d59-b87d-784b7d6be0b3} - c:\program files\adobe\acrobat 6.0\acrobat\activex\AcroIEHelper.dll
BHO: Spybot-S&D IE Protection: {53707962-6f74-2d53-2644-206d7942484f} - c:\progra~1\spybot~1\SDHelper.dll
BHO: PeoplePal Toolbar: {a8fb8eb3-183b-4598-924d-86f0e5e37085} - c:\program files\peoplepc\toolbar\PPCToolbar.dll
BHO: Google Toolbar Helper: {aa58ed58-01dd-4d91-8333-cf10577473f7} - c:\program files\google\google toolbar\GoogleToolbar.dll
BHO: AcroIEToolbarHelper Class: {ae7cd045-e861-484f-8273-0445ee161910} - c:\program files\adobe\acrobat 6.0\acrobat\AcroIEFavClient.dll
BHO: Google Toolbar Notifier BHO: {af69de43-7d58-4638-b6fa-ce66b5ad205d} - c:\program files\google\googletoolbarnotifier\5.1.1309.3572\swg.dll
BHO: Google Dictionary Compression sdch: {c84d72fe-e17d-4195-bb24-76c02e2e7c4e} - c:\program files\google\google toolbar\component\fastsearch_A8904FB862BD9564.dll
TB: Adobe PDF: {47833539-d0c5-4125-9fa8-0819e2eaac93} - c:\program files\adobe\acrobat 6.0\acrobat\AcroIEFavClient.dll
TB: PeoplePal Toolbar: {a8fb8eb3-183b-4598-924d-86f0e5e37085} - c:\program files\peoplepc\toolbar\PPCToolbar.dll
TB: Yahoo! Toolbar: {ef99bd32-c1fb-11d2-892f-0090271d4f88} - c:\program files\yahoo!\companion\installs\cpn\yt.dll
TB: Google Toolbar: {2318c2b1-4965-11d4-9b18-009027a5cd4f} - c:\program files\google\google toolbar\GoogleToolbar.dll
EB: Adobe PDF: {182ec0be-5110-49c8-a062-beb1d02a220b} - c:\program files\adobe\acrobat 6.0\acrobat\AcroIEFavClient.dll
EB: {32683183-48a0-441b-a342-7c2a440a9478} - No File
uRun: [H/PC Connection Agent] "c:\program files\microsoft activesync\Wcescomm.exe"
uRun: [SsAAD.exe] c:\progra~1\sony\sonics~1\SsAAD.exe
uRun: [swg] c:\program files\google\googletoolbarnotifier\GoogleToolbarNotifier.exe
uRun: [MoneyInsights] "c:\program files\microsoft money plus\mnycorefiles\mnyinsit.exe"
uRun: [MoneyBackgoundBanking] "c:\program files\microsoft money plus\mnycorefiles\mnybbsvc.exe"
uRun: [SpybotSD TeaTimer] c:\program files\spybot - search & destroy\TeaTimer.exe
uRun: [SmileboxTray] "c:\documents and settings\user\application data\smilebox\SmileboxTray.exe"
uRun: [BitTorrent DNA] "c:\program files\dna\btdna.exe"
mRun: [BCMSMMSG] BCMSMMSG.exe
mRun: [AccessoriesPlus] "c:\program files\spt\accessories plus\clockplus.exe"
mRun: [Bart Station] c:\program files\isp50\bin\PPCOLink -STATION
mRun: [PPCRunonce] c:\windows\system32\PPCRunOnce.exe
mRun: [PinnacleDriverCheck] c:\windows\system32\PSDrvCheck.exe -CheckReg
mRun: [A Verizon App] c:\progra~1\verizo~1\helpsu~1\VERIZO~1.EXE
mRun: [VerizonServicepoint.exe] c:\program files\verizon\servicepoint\VerizonServicepoint.exe
mRun: [Windows Defender] "c:\program files\windows defender\MSASCui.exe" -hide
mRun: [EKIJ5000StatusMonitor] c:\windows\system32\spool\drivers\w32x86\3\EKIJ5000MUI.exe
mRun: [13106094] c:\documents and settings\all users\application data\13106094\13106094.exe
mRun: [93116086] c:\documents and settings\all users\application data\93116086\93116086.exe
mRun: [63126089] c:\documents and settings\all users\application data\63126089\63126089.exe
mRun: [KernelFaultCheck] %systemroot%\system32\dumprep 0 -k
dRun: [DWQueuedReporting] "c:\progra~1\common~1\micros~1\dw\dwtrig20.exe" -t
StartupFolder: c:\docume~1\user\startm~1\programs\startup\expedi~1.lnk - c:\program files\expedia\expedia fare alert\ExpediaFareAlert.exe
StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\adsgon~1.lnk - c:\program files\adsgone\adsgone.exe
StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\amazon~1.lnk - c:\program files\amazon\amazon unbox video\ADVWindowsClientSystemTray.exe
StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\kodake~1.lnk - c:\program files\kodak\kodak easyshare software\bin\EasyShare.exe
IE: E&xport to Microsoft Excel - c:\progra~1\micros~2\office11\EXCEL.EXE/3000
IE: {2EAF5BB1-070F-11D3-9307-00C04FAE2D4F} - {2EAF5BB0-070F-11D3-9307-00C04FAE2D4F} - c:\progra~1\mi3aa1~1\INetRepl.dll
IE: {2EAF5BB2-070F-11D3-9307-00C04FAE2D4F} - {2EAF5BB0-070F-11D3-9307-00C04FAE2D4F} - c:\progra~1\mi3aa1~1\INetRepl.dll
IE: {92780B25-18CC-41C8-B9BE-3C9C571A8263} - {FF059E31-CC5A-4E2E-BF3B-96E929D65503} - c:\progra~1\micros~2\office11\REFIEBAR.DLL
IE: {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - {53707962-6F74-2D53-2644-206D7942484F} - c:\progra~1\spybot~1\SDHelper.dll
Trusted Zone: plaxo.com\www
DPF: {1239CC52-59EF-4DFA-8C61-90FFA846DF7E} - [You must be registered and logged in to see this link.]
DPF: {341FF14B-00CB-49F5-A427-A164DF1D5E1F} - [You must be registered and logged in to see this link.]
DPF: {406B5949-7190-4245-91A9-30A17DE16AD0} - [You must be registered and logged in to see this link.]
DPF: {A8F2B9BD-A6A0-486A-9744-18920D898429} - [You must be registered and logged in to see this link.]
Filter: x-sdch - {B1759355-3EEC-4C1E-B0F1-B719FE26E377} - c:\program files\google\google toolbar\component\fastsearch_A8904FB862BD9564.dll
Handler: mctp - {d7b95390-b1c5-11d0-b111-0080c712fe82} -
WinCE Filter: image/bmp - {86F59FAE-FB3A-11D1-AA72-00C04FAE2D4B} -
WinCE Filter: image/gif - {86F59FAE-FB3A-11D1-AA72-00C04FAE2D4B} -
WinCE Filter: image/jpeg - {86F59FAE-FB3A-11D1-AA72-00C04FAE2D4B} -
WinCE Filter: image/xbm - {86F59FAE-FB3A-11D1-AA72-00C04FAE2D4B} -
WinCE Filter: text/asp - {6C5C3074-FFAB-11d1-8EC4-00C04F98D57A} -
WinCE Filter: text/html - {6C5C3074-FFAB-11d1-8EC4-00C04F98D57A} -
SEH: Microsoft AntiMalware ShellExecuteHook: {091eb208-39dd-417d-a5dd-7e2c2d8fb9cb} - c:\progra~1\wifd1f~1\MpShHook.dll
R2 aawservice;Lavasoft Ad-Aware Service;c:\program files\lavasoft\ad-aware\aawservice.exe [2008-5-12 611664]
R2 KodakSvc;Kodak AiO Device Service;c:\program files\kodak\printer\center\KodakSvc.exe [2008-2-28 18944]
R2 WinDefend;Windows Defender;c:\program files\windows defender\MsMpEng.exe [2006-11-3 13592]
S3 Ad-Watch Connect Filter;Ad-Watch Connect Kernel Filter;c:\windows\system32\drivers\NSDriver.sys [2008-4-29 15648]
S3 rootrepeal;rootrepeal;\??\c:\windows\system32\drivers\rootrepeal.sys --> c:\windows\system32\drivers\rootrepeal.sys [?]
S3 USB100;USB 10/100 Network Adapter;c:\windows\system32\drivers\USB100.sys [2004-4-14 27326]
2009-05-11 13:34 --d----- c:\docume~1\alluse~1\applic~1\63126089
2009-05-11 13:34 --d----- c:\docume~1\alluse~1\applic~1\13106094
2009-05-11 09:28 274,432 a------- c:\windows\TLCUninstall.exe
2009-05-11 09:28 --d----- c:\program files\The Learning Company
2009-05-11 09:21 0 a------- c:\windows\SETUP32.INI
2009-04-15 12:38 284,160 -c------ c:\windows\system32\dllcache\pdh.dll
2009-04-15 12:38 729,088 -c------ c:\windows\system32\dllcache\lsasrv.dll
2009-04-15 12:38 714,752 -c------ c:\windows\system32\dllcache\ntdll.dll
2009-04-15 12:38 617,472 -c------ c:\windows\system32\dllcache\advapi32.dll
2009-04-15 12:38 473,600 -c------ c:\windows\system32\dllcache\fastprox.dll
2009-04-15 12:38 453,120 -c------ c:\windows\system32\dllcache\wmiprvsd.dll
2009-04-15 12:38 401,408 -c------ c:\windows\system32\dllcache\rpcss.dll
2009-04-15 12:38 227,840 -c------ c:\windows\system32\dllcache\wmiprvse.exe
2009-04-15 12:38 110,592 -c------ c:\windows\system32\dllcache\services.exe
2009-04-15 12:36 215,552 -c------ c:\windows\system32\dllcache\wordpad.exe
2009-04-15 12:36 2,560 -------- c:\windows\system32\xpsp4res.dll
2009-04-30 01:36 75,776 a------- c:\windows\system32\WS2Fix.exe
2009-03-19 16:32 23,400 a------- c:\windows\system32\drivers\GEARAspiWDM.sys
2009-03-06 10:22 284,160 a------- c:\windows\system32\pdh.dll
2009-03-02 20:18 826,368 a------- c:\windows\system32\wininet.dll
2009-02-20 14:09 78,336 a------- c:\windows\system32\ieencode.dll
2008-08-22 09:19 16,384 ac-sh--- c:\windows\system32\config\systemprofile\cookies\index.dat
2008-08-22 09:19 32,768 ac-sh--- c:\windows\system32\config\systemprofile\local settings\history\history.ie5\index.dat
2008-08-22 09:19 32,768 ac-sh--- c:\windows\system32\config\systemprofile\local settings\history\history.ie5\mshist012008082220080823\index.dat
2008-08-22 09:19 32,768 ac-sh--- c:\windows\system32\config\systemprofile\local settings\temporary internet files\content.ie5\index.dat
2008-12-13 08:17 16,384 ac-sh--- c:\windows\temp\cookies\index.dat
2008-12-13 08:17 16,384 ac-sh--- c:\windows\temp\history\history.ie5\index.dat
2008-12-13 08:17 49,152 ac-sh--- c:\windows\temp\temporary internet files\content.ie5\index.dat
============= FINISH: 13:45:47.35 ===============
badger98
OS : Windows XP
Post by Belahzur on Thu May 14, 2009 6:33 pm
  • Save it to your desktop.
  • Please double-click OTMoveIt3.exe to run it.
    :files
    :reg
    "13106094"=-
    "93116086"=-
    "63126089"=-
  • Return to OTMoveIt3, right click in the "Paste instructions for items to be Moved" window (under the light blue bar) and choose Paste.
  • Close OTMoveIt3
Please post the OTMoveIt log.
Post by badger98 on Thu May 14, 2009 6:39 pm
========== FILES ==========
c:\documents and settings\all users\application data\13106094 moved successfully.
File/Folder c:\documents and settings\all users\application data\93116086 not found.
c:\documents and settings\all users\application data\63126089 moved successfully.
Registry value HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\\13106094 deleted successfully.
Registry value HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\\93116086 deleted successfully.
Registry value HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\\63126089 not found.
OTMoveIt3 by OldTimer - Version 1.0.11.0 log created on 05142009_143918
badger98
OS : Windows XP
Post by badger98 on Thu May 14, 2009 6:43 pm
I have Spybot-Search and Destroy and it detected the registry change.
"Category: System startup Global Entry, Change: Value Deleted, Entry: 63126089" It asked if I should allow change. I think I accidentally did. Another dialogue box came up for 13106094. I would assume another will come for the other if I go forward with the allowing of the change. Please advise.
badger98
OS : Windows XP
Post by Belahzur on Thu May 14, 2009 6:48 pm
Spybot warned you of values being DELETED, that's our attack, allow it to go through.
See if that put a stop to the false alerts.
Post by badger98 on Thu May 14, 2009 7:04 pm
The scan looks to have been a success. I have a message from Windows Defender (should I follow that up?), I have Adsgone always looking at pop-ups, and I run Spy-bot search and destroy. The virus RogueVirus2008. Is this the end of the line for the problem? What steps should I take to make sure I don't have a problem again (i.e. should I set up a restore point, work on a backup schedule, etc.)? Thanks for spending the time, it seems to have been a pretty annoying problem. I will definitely giving a donation.
badger98
OS : Windows XP
Post by badger98 on Thu May 14, 2009 7:07 pm
One other question I have is what should I do with all the .exe files on my desktop.
badger98
OS : Windows XP
Post by Belahzur on Thu May 14, 2009 7:08 pm
Delete everything we used.
Hold on because we aren't done.
Post by badger98 on Thu May 14, 2009 7:10 pm
Scan saved at 15:10:08, on 5/14/2009
MSIE: Internet Explorer v7.00 (7.00.6000.16827)
C:\Program Files\Common Files\Verizon Online\AppMgr\vzOpenUIServer.exe
C:\Documents and Settings\User\Desktop\HiJackThis.exe
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 6.0\Acrobat\ActiveX\AcroIEHelper.dll
O2 - BHO: PeoplePal Toolbar - {A8FB8EB3-183B-4598-924D-86F0E5E37085} - C:\Program Files\PeoplePC\Toolbar\PPCToolbar.dll
O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - C:\Program Files\Google\Google Toolbar\GoogleToolbar.dll
O2 - BHO: AcroIEToolbarHelper Class - {AE7CD045-E861-484f-8273-0445EE161910} - C:\Program Files\Adobe\Acrobat 6.0\Acrobat\AcroIEFavClient.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.1.1309.3572\swg.dll
O2 - BHO: Google Dictionary Compression sdch - {C84D72FE-E17D-4195-BB24-76C02E2E7C4E} - C:\Program Files\Google\Google Toolbar\Component\fastsearch_A8904FB862BD9564.dll
O3 - Toolbar: Adobe PDF - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Program Files\Adobe\Acrobat 6.0\Acrobat\AcroIEFavClient.dll
O3 - Toolbar: PeoplePal Toolbar - {A8FB8EB3-183B-4598-924D-86F0E5E37085} - C:\Program Files\PeoplePC\Toolbar\PPCToolbar.dll
O3 - Toolbar: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll
O3 - Toolbar: Google Toolbar - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - C:\Program Files\Google\Google Toolbar\GoogleToolbar.dll
O4 - HKLM\..\Run: [BCMSMMSG] BCMSMMSG.exe
O4 - HKLM\..\Run: [AccessoriesPlus] "C:\Program Files\SPT\Accessories Plus\clockplus.exe"
O4 - HKLM\..\Run: [Bart Station] C:\Program Files\ISP50\BIN\PPCOLink -STATION
O4 - HKLM\..\Run: [PPCRunonce] C:\WINDOWS\system32\PPCRunOnce.exe
O4 - HKLM\..\Run: [PinnacleDriverCheck] C:\WINDOWS\system32\PSDrvCheck.exe -CheckReg
O4 - HKLM\..\Run: [A Verizon App] C:\PROGRA~1\VERIZO~1\HELPSU~1\VERIZO~1.EXE
O4 - HKLM\..\Run: [VerizonServicepoint.exe] C:\Program Files\Verizon\Servicepoint\VerizonServicepoint.exe
O4 - HKLM\..\Run: [Windows Defender] "C:\Program Files\Windows Defender\MSASCui.exe" -hide
O4 - HKLM\..\Run: [EKIJ5000StatusMonitor] C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\EKIJ5000MUI.exe
O4 - HKLM\..\Run: [63126089] C:\Documents and Settings\All Users\Application Data\63126089\63126089.exe
O4 - HKLM\..\RunOnce: [Malwarebytes' Anti-Malware] C:\Program Files\Malwarebytes' Anti-Malware\mbamgui.exe /install /silent
O4 - HKCU\..\Run: [H/PC Connection Agent] "C:\Program Files\Microsoft ActiveSync\Wcescomm.exe"
O4 - HKCU\..\Run: [SsAAD.exe] C:\PROGRA~1\Sony\SONICS~1\SsAAD.exe
O4 - HKCU\..\Run: [MoneyInsights] "C:\Program Files\Microsoft Money Plus\MNYCoreFiles\mnyinsit.exe"
O4 - HKCU\..\Run: [MoneyBackgoundBanking] "C:\Program Files\Microsoft Money Plus\MNYCoreFiles\mnybbsvc.exe"
O4 - HKCU\..\Run: [SmileboxTray] "C:\Documents and Settings\User\Application Data\Smilebox\SmileboxTray.exe"
O4 - HKCU\..\Run: [BitTorrent DNA] "C:\Program Files\DNA\btdna.exe"
O4 - HKUS\S-1-5-18\..\Run: [DWQueuedReporting] "C:\PROGRA~1\COMMON~1\MICROS~1\DW\dwtrig20.exe" -t (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [DWQueuedReporting] "C:\PROGRA~1\COMMON~1\MICROS~1\DW\dwtrig20.exe" -t (User 'Default user')
O4 - Startup: Expedia Fare Alert.lnk = C:\Program Files\Expedia\Expedia Fare Alert\ExpediaFareAlert.exe
O4 - Global Startup: AdsGone 2003.lnk = C:\Program Files\AdsGone\adsgone.exe
O4 - Global Startup: Amazon Unbox.lnk = ?
O4 - Global Startup: Kodak EasyShare software.lnk = C:\Program Files\Kodak\Kodak EasyShare software\bin\EasyShare.exe
O9 - Extra button: Create Mobile Favorite - {2EAF5BB1-070F-11D3-9307-00C04FAE2D4F} - C:\PROGRA~1\MI3AA1~1\INetRepl.dll
O9 - Extra button: (no name) - {2EAF5BB2-070F-11D3-9307-00C04FAE2D4F} - C:\PROGRA~1\MI3AA1~1\INetRepl.dll
O9 - Extra 'Tools' menuitem: Create Mobile Favorite... - {2EAF5BB2-070F-11D3-9307-00C04FAE2D4F} - C:\PROGRA~1\MI3AA1~1\INetRepl.dll
O16 - DPF: {1239CC52-59EF-4DFA-8C61-90FFA846DF7E} (Musicnotes Viewer) - [You must be registered and logged in to see this link.]
O16 - DPF: {341FF14B-00CB-49F5-A427-A164DF1D5E1F} (MALPlaybackCtrl Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {406B5949-7190-4245-91A9-30A17DE16AD0} (Snapfish Activia) - [You must be registered and logged in to see this link.]
O16 - DPF: {A8F2B9BD-A6A0-486A-9744-18920D898429} (ScorchPlugin Class) - [You must be registered and logged in to see this link.]
O18 - Filter: x-sdch - {B1759355-3EEC-4C1E-B0F1-B719FE26E377} - C:\Program Files\Google\Google Toolbar\Component\fastsearch_A8904FB862BD9564.dll
O23 - Service: Lavasoft Ad-Aware Service (aawservice) - Lavasoft - C:\Program Files\Lavasoft\Ad-Aware\aawservice.exe
O23 - Service: Adobe LM Service - Unknown owner - C:\Program Files\Common Files\Adobe Systems Shared\Service\Adobelmsvc.exe
O23 - Service: Amazon Unbox Video Service (ADVService) - Amazon.com - C:\Program Files\Amazon\Amazon Unbox Video\ADVWindowsClientService.exe
O23 - Service: Diskeeper - Executive Software International, Inc. - C:\Program Files\Executive Software\Diskeeper\DkService.exe
O23 - Service: DvpApi (dvpapi) - Command Software Systems, Inc. - C:\Program Files\Common Files\Command Software\dvpapi.exe
O23 - Service: Kodak Camera Connection Software (KodakCCS) - Unknown owner - C:\WINDOWS\system32\drivers\KodakCCS.exe (file missing)
O23 - Service: Kodak AiO Device Service (KodakSvc) - Eastman Kodak Company - C:\Program Files\Kodak\printer\center\KodakSvc.exe
O23 - Service: MSCSPTISRV - Sony Corporation - C:\Program Files\Common Files\Sony Shared\AVLib\MSCSPTISRV.exe
O23 - Service: MD Simple Burner Service (NetMDSB) - Sony Corporation - C:\Program Files\Sony\MD Simple Burner\NetMDSB.exe
O23 - Service: PACSPTISVR - Sony Corporation - C:\Program Files\Common Files\Sony Shared\AVLib\PACSPTISVR.exe
O23 - Service: Verizon Internet Security Suite Firewall (RP_FWS) - Unknown owner - C:\Program Files\Verizon\Verizon Internet Security Suite\fws.exe (file missing)
O23 - Service: Sony SPTI Service (SPTISRV) - Sony Corporation - C:\Program Files\Common Files\Sony Shared\AVLib\SPTISRV.exe
O23 - Service: SonicStage SCSI Service (SSScsiSV) - Sony Corporation - C:\Program Files\Common Files\Sony Shared\AVLib\SSScsiSV.exe
End of file - 11781 bytes
badger98
OS : Windows XP
Post by Belahzur on Thu May 14, 2009 8:32 pm
I notice that you have Spybot's TeaTimer running. While this is normally a wonderful tool to protect against hijackers, it can also interfere with HijackThis fixes. So please disable TeaTimer by doing the following:
1) Run Spybot-S&D
2) Go to the Mode menu, and make sure "Advanced Mode" is selected
3) On the left hand side, choose Tools -> Resident
4) Uncheck "Resident TeaTimer" and OK any prompts
You can reenable TeaTimer once your system is clean.
Please make sure Teatimer is disable before we do this, otherwise this fix will fail.
Now I want to get an uninstall log, and we can use Hijack This again to get that.
  • Open HijackThis again.
Post by badger98 on Thu May 14, 2009 8:50 pm
Ad-Aware
Adobe Acrobat 6.0 Professional
Adobe Download Manager 2.0 (Remove Only)
Adobe Flash Player 10 ActiveX
Adobe Flash Player Plugin
Adobe Illustrator CS
Adobe Photoshop CS
Adobe Shockwave Player
Adobe SVG Viewer 3.0
AdsGone Popup Killer by A1Tech.com
aiofw
aioocr
aioprnt
aioscnnr
Amazon Unbox Video
Apple Mobile Device Support
Apple Software Update
BCM V.92 56K Modem
Bonjour
Canon Camera Window for ZoomBrowser EX
Canon PhotoRecord
Canon RAW Image Task for ZoomBrowser EX
Canon RemoteCapture Task for ZoomBrowser EX
Canon Utilities PhotoStitch 3.1
Canon Utilities ZoomBrowser EX
CCScore
center
CleanUp!
DebtFree(tm) for Windows Personal 5.1b
Diskeeper Professional Edition
Dolet Light for Finale
DV Network Software
DVD X Player Professional V3.0
DVD X Rescue
DVDXCopy Platinum 3.2.1
ESSBrwr
ESSCDBK
ESScore
ESSgui
ESSini
ESSPCD
ESSPDock
ESSSONIC
ESSTOOLS
essvatgt
Expedia Fare Alert
Finale 2003
Finale 2006
Finale 2008
Finale Performance Assessment
Fisher-Price Computer Cool School
Fisher-Price Dora and Diego's Classroom
Fisher-Price Scooby-Doo's Classroom
Fisher-Price SpongeBob's Classroom
Garritan Instruments for Finale
Help_CTR
helptut
helpug
HijackThis 2.0.2
Image Resizer Powertoy for Windows XP
Intel(R) PRO Network Adapters and Drivers
ItsDeductible Express
iTunes
Java 2 Runtime Environment Standard Edition v1.3.1_04
Juno 6
kgcbase
kgchday
kgchlwn
kgcinvt
kgckids
KODAK All-in-One Printer Software
ksdip
LimeWire
MD Simple Burner 2.0.03
Microsoft .NET Framework 1.1
Microsoft .NET Framework 2.0
Microsoft Money Shared Libraries
Microsoft Office Professional Edition 2003
Microsoft Streets and Trips 2005
MobileMe Control Panel
MSXML 4.0 SP2 (KB927978)
MSXML 4.0 SP2 (KB936181)
MSXML 4.0 SP2 (KB954430)
netbrdg
OfotoXMI
OpenMG AAC Add-on Module 1.0.00
OpenMG Limited Patch 4.5-06-05-12-01
OpenMG Secure Module 4.5.01
PeoplePC Online
PeoplePC:PeoplePal Toolbar 3.0
Photo Viewer S3.0
PhotoParade Player
Pinnacle Hollywood FX for Studio
Prism Video Converter
QuickTime
RealPlayer
Rhapsody Player Engine
Roxio Easy Media Creator 7
Safari
Security Update for Microsoft .NET Framework 2.0 (KB928365)
Security Update for Windows Internet Explorer 7 (KB928090)
Security Update for Windows Internet Explorer 7 (KB929969)
Security Update for Windows Internet Explorer 7 (KB931768)
SFR
SFR2
SHASTA
skin0001
SKINXSDK
SmartSound Quicktracks Plugin
SonicStage 4.0
SoundMAX
Spb Mobile DVD
Spiral Mile Sudoku Rules for PDASP (remove only)
SPT Accessories Plus 2002
StarFlyers Alien Space Chase
staticcr
S-Tris
Studio 9
Switch
Time Zone Data Update Tool for Microsoft Office Outlook
tooltips
TurboTax Deluxe 2004
Verizon Broadband Toolbar
Verizon Online Help & Support
Verizon PC Security Checkup
Verizon Servicepoint 1.3.21
VPRINTOL
WexTech AnswerWorks
Williams-Sonoma Guide to Good Cooking
Windows Defender
Windows Mobile Daylight Saving Time 2007 Updates
Windows XP Service Pack 3
WinMX
WinZip
WIRELESS
Yahoo! Toolbar
badger98
OS : Windows XP
Post by Belahzur on Thu May 14, 2009 9:11 pm
I see that you are running Limewire.
If Limewire is not removed, then I won't help you.
  • Java 2 Runtime Environment Standard Edition v1.3.1_04
  • LimeWire
Post by badger98 on Thu May 14, 2009 9:39 pm
Everything seems to be running fine. I did remove the Java 2 and it prompted me that it could not remove all files that I would have to remove some manually. I removed Limewire, I don't even think I have used it in more than a couple of years.
Should I delete all of the programs I downloaded for the repair (dds, OTMoveIt3, RootRepeal, GMER, Silentrunners, malwarebytes')?
Also I have a backup file on the desktop containing 3 1KB files, backup-20090514-164859-717, -862, and -936. What should I do with those?
Here's the updated uninstall list:
Ad-Aware
Adobe Photoshop CS
aiofw
aioocr
aioprnt
aioscnnr
Amazon Unbox Video
BCM V.92 56K Modem
Bonjour
Canon PhotoRecord
CCScore
center
CleanUp!
DV Network Software
DVD X Rescue
ESSBrwr
ESSCDBK
ESScore
ESSgui
ESSini
ESSPCD
ESSPDock
ESSSONIC
ESSTOOLS
essvatgt
Expedia Fare Alert
Finale 2003
Finale 2006
Finale 2008
Help_CTR
helptut
helpug
HijackThis 2.0.2
iTunes
Juno 6
kgcbase
kgchday
kgchlwn
kgcinvt
kgckids
ksdip
netbrdg
OfotoXMI
PeoplePC Online
Photo Viewer S3.0
PhotoParade Player
QuickTime
RealPlayer
Safari
SFR
SFR2
SHASTA
skin0001
SKINXSDK
SonicStage 4.0
SoundMAX
Spb Mobile DVD
staticcr
S-Tris
Studio 9
Switch
tooltips
VPRINTOL
WexTech AnswerWorks
Windows Defender
WinMX
WinZip
WIRELESS
Yahoo! Toolbar
badger98
OS : Windows XP
Post by Belahzur on Thu May 14, 2009 9:43 pm
Delete the toos we tried to use, and delete the backups.
You aren't running Anti Virus Software
Please install Avira antivirus otherwise you won't be protected.
Post by badger98 on Thu May 14, 2009 10:51 pm
Should I take off Spybot, and Adsgone? And should I stop Windows Defender?
badger98
OS : Windows XP
Post by Belahzur on Thu May 14, 2009 11:00 pm
Don't remove Windows Defender, but remove Spybot/Adsgone.
Post by badger98 on Thu May 14, 2009 11:18 pm
Thank you very much for your help. Is the Avira going to expire after a year? Would you suggest I try the premium? There is a free offer through trial pay.
badger98
OS : Windows XP
Post by Belahzur on Thu May 14, 2009 11:31 pm
No, the free version never expires. I use it myself.
