dvd burner will not burn with sony 16x dvd-r's
Solved dvd burner will not burn with sony 16x dvd-r's
Post by feast on Wed Apr 29, 2009 5:05 pm
hey, i have a NEC DVD+-RW ND-6500A that will read but not write to sony 16x dvd-r's, other brand seem to both read and write correctly. nero and other burning software tell me that the media is incompatible.
is there a way to make my dvd drive burn to these discs?
oh, btw, its in a dell latitude d510 laptop and has been flash to what is as far as i can tell the latest firmware 203E.
feast
Posts Posts : 9
Joined Joined : 2009-04-11
OS OS : windows xp
Points Points : 27965
Solved Re: dvd burner will not burn with sony 16x dvd-r's
Post by AuroraRange on Fri May 01, 2009 9:57 am
@feast wrote:hey, i have a NEC DVD+-RW ND-6500A that will read but not write to sony 16x dvd-r's, other brand seem to both read and write correctly. nero and other burning software tell me that the media is incompatible.
Looks like there is others like your experiencing the same problem. Since your burner's firmware is updated, I think the problem lies in NEC which didnt fix the problem properly as it cant even detect it as a DVD burner in the first place.
Posts Posts : 507
Joined Joined : 2008-08-22
OS OS : Xubuntu & Windows 7
Points Points : 30779
