Monitor color display problem
Solved Monitor color display problem
Post by bronbron81 on 17th April 2009, 9:09 pm
I just got an older monitor its a Hp Pavilion mx50 and I am trying to use it with my HP Pavillion dv6000 notebook. When I plug the VGA cord in it shows my wallpaper, because i'm trying to run dual monitors, with all the wrong colors. White text on my wallpaper is a sky blue color and when I open up my documents on that monitor my folders have a greenish tint to them. I already rolledback the driver and that didn't work. I also tried to update the driver and that didn't work either. I really need help so if you could that would be great
bronbron81
Posts Posts : 72
Joined Joined : 2009-03-02
OS OS : Window Xp Media center edition 2005
Points Points : 28666
Solved Re: Monitor color display problem
Post by Doctor Inferno on 18th April 2009, 3:14 am
Because I don't use this monitor, I can't tell where exactly the buttons are. Try changing With the settings on the monitor it self, there should be buttons on the front, bottom or sides. Adjust the RGB settings and see if it helps.
Points Points : 104640
Post by bronbron81 on 18th April 2009, 3:49 am
I already tried adjusting all the settings on the monitor and I had no luck. The thing is when I plug the monitor into the computer that it originally was packaged with it works fine and all the colors are perfectly fine but when I try to plug it into my laptop it distorts the colors and only shows like blue black and a yellowish tint
bronbron81
Posts Posts : 72
Post by tarzan on 18th April 2009, 4:26 am
Does it work if u try to run it Solo instead of Dual, try working on a single display mode for the Monitor
tarzan
Posts Posts : 427
Joined Joined : 2008-10-31
OS OS : xp.pro,vista, Windows 7
Points Points : 30048
Post by bronbron81 on 18th April 2009, 4:04 pm
I just tried that and I had no luck
bronbron81
Posts Posts : 72
Post by Doctor Inferno on 19th April 2009, 1:53 am
Could there be a possibility that the monitor is faulty in the first place?
Post by bronbron81 on 19th April 2009, 6:42 pm
I don't think so because the monitor works with the other two computers that I own
bronbron81
Posts Posts : 72
Post by tarzan on 20th April 2009, 4:57 am
@bronbron81 wrote:I don't think so because the monitor works with the other two computers that I own
Those 2 Computers are Desktop PC's or Laptops? and is the monitor a very old model?
And if the Monitor is too old , then there could be chances that your Laptop's VGA card doesn't support that Monitor or something with the Driver.
Last edited by tarzan on 20th April 2009, 5:01 am; edited 1 time in total (Reason for editing : Typo)
tarzan
Posts Posts : 427
Post by bronbron81 on 22nd April 2009, 4:15 am
the two computers are desktops and the monitor is kinds old its from like 2000. But I don't think that its because its old because I previously used an even older monitor from the 90s and that monitor worked perfectly fine.
bronbron81
Posts Posts : 72
Post by tarzan on 24th April 2009, 3:47 am
Try Connecting some other monitor to the same Laptop and check whether the Colours/Display is perfect or not, if not then You need to check The VGA port (HP Guys will do it)
I M not suggesting any Driver update as you have done that earlier.
tarzan
Posts Posts : 427
Post by AuroraRange on 26th April 2009, 10:08 am
Highly possible that it is ur graphic driver fault.
Posts Posts : 507
Joined Joined : 2008-08-22
OS OS : Xubuntu & Windows 7
Points Points : 30829
