Installation Problem
Solved Installation Problem
Post by judegwapo16 on Fri Apr 17, 2009 2:33 am
I Have a Problem.I Can't Install Company Of Heroes.Theres An Error Reading"Error 1305.Error reading from file E:\program files\THQ\Company of Heroes\WW2\Movies\SR_06-01.lua. Verify that the file exists and that you can access it." I'm Using XP By The Way
judegwapo16
Posts Posts : 6
Joined Joined : 2009-04-17
Points Points : 27958
Solved Re: Installation Problem
Post by mariealabama on Fri May 01, 2009 1:06 am
Can you be more specific? I mean down to the simplest things of " I put the CD in my CD drive, it was not scratched. I started to install it and everything worked fine, but it wont open"
mariealabama
Posts Posts : 107
Joined Joined : 2009-04-09
OS OS : dual boot Win XP SP2 and Win 7 32 bit
Points Points : 28345
Post by judegwapo16 on Fri May 01, 2009 7:04 pm
Yes I Inserted The Cd In The Cd Drive but It was not scratched.But It Will Say In One Point In The Installation."Error 1305.Error reading from file E:\program files\THQ\Company of Heroes\WW2\Movies\SR_06-01.lua. Verify that the file exists and that you can access it."Sorry For The Late Reply
judegwapo16
Posts Posts : 6
Post by Doctor Inferno on Fri May 01, 2009 10:45 pm
Are you logged into an administrator account while installing?
Points Points : 104650
Post by judegwapo16 on Sat May 02, 2009 4:57 am
Yes.I Was Logged On The Administrator Account During Installation.
judegwapo16
Posts Posts : 6
Post by AuroraRange on Sat May 02, 2009 5:05 am
What media are you installing from?
Posts Posts : 507
Joined Joined : 2008-08-22
OS OS : Xubuntu & Windows 7
Points Points : 30839
Post by judegwapo16 on Sat May 02, 2009 5:08 am
I Don't Know.Sorry.
judegwapo16
Posts Posts : 6
Post by AuroraRange on Sat May 02, 2009 5:33 am
@judegwapo16 wrote:I Don't Know.Sorry.
like dvd or installer?
Posts Posts : 507
Post by judegwapo16 on Sat May 02, 2009 5:35 am
AH .Ok.Installer
judegwapo16
Posts Posts : 6
Post by AuroraRange on Sat May 02, 2009 5:41 am
@judegwapo16 wrote:AH .Ok.Installer
I think your installer got corrupted, tried getting a new copy?
Posts Posts : 507
Post by judegwapo16 on Sat May 02, 2009 5:41 am
OK.
judegwapo16
Posts Posts : 6
