Help with Photo Shop Photo X2
Solved Help with Photo Shop Photo X2
Post by Tami19 on 12th April 2009, 9:34 am
Umm I am not sure if this is where I post this, but I need help with downloaded Brushes for Corel Paint Shop Pro Photo X2.
Whenever I download the brushes I change the .abr files to .PspBrush and the program seems to work. BUT however, when I go to File>Import Brush> Add menu I can select the brushes that I want to import and then I click on the Add button and then I get the following error message:
" Invalid parameter has been pasted to a function"
I have tried following all sorts of tutorials but nothing seems to work. Can someone please help me?
Tami19
Posts Posts : 24
Joined Joined : 2008-12-30
Points Points : 29028
Solved Re: Help with Photo Shop Photo X2
Post by Doctor Inferno on 12th April 2009, 10:24 am
You can't just change the file extension just like that. The brush you downloaded is made for Photoshop and not for Paint Shop Pro, so changing the file extension will result in Paint Shop Pro unable to read it.
Points Points : 104630
Post by Tami19 on 13th April 2009, 1:27 am
Yes I know but leaving it as a .abr file results in the same thing. An error message comes up and tells me that it is an newer format version and is unsupported. Like I said I am trying everything I can to figure this out.
Tami19
Posts Posts : 24
Post by Doctor Inferno on 13th April 2009, 12:32 pm
Leaving it as .abr means that it can only be opened in photohsop, not paint shop pro. The only way you can get around this is to get brushes for paint shop pro, not photoshop.
Post by charvie on 30th April 2009, 2:03 pm
photohsop is photohsop and paint shop pro is paint shop pro. don't mix their brushes, their unmixable (if there's such a word..hehe)...just google for paint shop pro brushes.
here are some sites.
http://celestial-star.net/psp-brushes/
http://browse.deviantart.com/resources/applications/pspbrushes/
never really used paint shop pro, so i just used google. i hope those are the right brushes for you. Cheesy Grin (sparkly
THIS SIGNATURE IS BY::: AGENT COSMIC ----------QUOTE BY:::TECHY
charvie
Posts Posts : 484
Joined Joined : 2008-04-13
Points Points : 32202
Post by Tami19 on 30th April 2009, 11:41 pm
Thank you Smile
Tami19
Posts Posts : 24
