mouse problems
Solved mouse problems
Post by charvie on 10th April 2009, 1:00 pm
I have this USB mouse. It was working fine for the past months that i have it, but then now it wouldn't work.
I tried transferring it to another port and it worked, for just a couple of minutes.
What do you think I should do?
THIS SIGNATURE IS BY::: AGENT COSMIC ----------QUOTE BY:::TECHY
charvie
Posts Posts : 484
Joined Joined : 2008-04-13
Points Points : 32192
Solved Re: mouse problems
Post by Doctor Inferno on 10th April 2009, 1:23 pm
What happens if you transfer it back?
Post by charvie on 10th April 2009, 1:25 pm
the mouse pointer won't move
charvie
Posts Posts : 484
Post by Doctor Inferno on 10th April 2009, 1:33 pm
I meant what happened if you plug it back into the other port.
Anyway, try this.
Start >> Control Panel >> Performance and Maintenance >> In the Performance and Maintenance window, click on the System icon near the bottom of the window. In the System Properties window, click on the Hardware tab then click on the Device Manager button.
Right click Mice & other pointing devices >> Uninstall.
Post by charvie on 10th April 2009, 2:08 pm
there's still no change doc. Sad tearing
charvie
Posts Posts : 484
Post by tarzan on 16th April 2009, 6:09 pm
Try the same mouse on some other PC and check, if it works properly then your need to check your, USB port/connections
Also check other USB devices on the "defective" Port
tarzan
Posts Posts : 427
Joined Joined : 2008-10-31
OS OS : xp.pro,vista, Windows 7
Points Points : 30028
Post by charvie on 20th April 2009, 10:35 pm
thnx for the help....the mouse is ok now. Cheesy Grin (sparkly Thank You!
charvie
Posts Posts : 484
Post by tarzan on 21st April 2009, 5:12 am
how did u solve, plz let us know, so that we assume a proper solution for the same
tarzan
Posts Posts : 427
Post by charvie on 23rd April 2009, 5:13 pm
I changed the battery Cheesy Grin (sparkly I know, i should've done that first, but i panicked Ahahaha
charvie
Posts Posts : 484
