downloading problem
Solved downloading problem
Post by zhengs on 8th April 2009, 7:19 pm
hello, The problem i got is that everytime i download something, the Internet Explorer Information Bar (near the top of your Web browser) wont pop up. It's usually is like a yellow with a blue shield on the front bar.
thanks if you can help me.
zhengs
Posts Posts : 228
Joined Joined : 2009-01-02
OS OS : Windows Vista
Points Points : 30495
Solved Re: downloading problem
Post by Doctor Inferno on 10th April 2009, 11:51 am
What version of Internet Explorer are you using?
Points Points : 104630
Post by zhengs on 10th April 2009, 5:15 pm
it's Internet Explorer 7.
zhengs
Posts Posts : 228
Post by zhengs on 18th April 2009, 1:12 am
Soo any help?
zhengs
Posts Posts : 228
Post by Doctor Inferno on 19th April 2009, 1:35 am
Try verifying if what your popup setting is set to, whether it is set to OFF or allow.
Here is how you would go about this.
1. Open Internet Explorer / Tools / Pop-up Blocker
2. You have the option to Turn off Pop-up Blocker - if this is off now pop-ups are permitted.
3. Or you can allow certain sites for the pop-up; from IE select Tools / Pop-up Blocker / Pop-up Blocker Settings
4. Here you can add a site URL that you would allow POP-ups from. Be certain the location you are downloading from is included in that SAFE list- if you wish to receive a download.
After you add that site, try your download again.
