help with ftp
help with ftp
Post by grasshoper on Mon Apr 06, 2009 8:39 am
Hi there,
I have just brought a nas device and have connected it to my home router. It has a built in ftp client which i have set up.
I have 2 questions:
1) How can I make it so the ftp server can be accessed over the internet, not just locally on my network. I think I have done this, but not sure if its set up correctly. I went into my routers config page, and added the nas's ip address to the "default dmz server"? Can someone clarify?
2) WHen i visit my ip address over the internet, i get the nas config login page, how can i change the port of the login? I did this with the router login, changed the ip to 8080.. Does port forwarding/triggering have something to do with this?
Any help would be appreciated.
Thanks tonnes. Smile Smile
grasshoper
Posts Posts : 68
Joined Joined : 2008-12-01
OS OS : Windows XP Home edition, Windows Vista Business
Points Points : 29446
Re: help with ftp
Post by Doctor Inferno on Tue Apr 07, 2009 8:41 am
1) That's one way.
2) Are you using your public IP address to connect from outside your network? It is the external IP address shown at www.portforward.com.
Points Points : 104600
Re: help with ftp
Post by grasshoper on Tue Apr 07, 2009 9:30 am
Yes, i'm using my public ip address.
grasshoper
Posts Posts : 68
Re: help with ftp
Post by grasshoper on Wed Apr 08, 2009 4:53 am
Okay, i think i have it, i just need one thing:
when i visit my external ip address, i get my nas login page, how can I change the port of the nas login, or better yet, make it so I cant login over the internet.
Thanks.
grasshoper
Posts Posts : 68
Re: help with ftp
Post by Doctor Inferno on Thu Apr 09, 2009 10:14 am
If there is remote control in the router on that port, try disabling the remote control entry for it.
Re: help with ftp
Post by grasshoper on Thu Apr 09, 2009 11:50 am
Thanks for your reply, All i really want to do now is host a website on my nas. Everything else is working fine now. Is it possible to, say, install xampp or something onto the nas to host a website?
grasshoper
Posts Posts : 68
Re: help with ftp
Post by Doctor Inferno on Fri Apr 10, 2009 3:09 am
I really doubt the NAS has the capability to host a website, best it's going to do is an FTP server.
By the way, FTP uses port 21, not port 80 or 8080.
Re: help with ftp
Post by grasshoper on Fri Apr 10, 2009 6:05 am
Yes, i know ftp runs on port 21.
As for nas not being able to run a website, shame, but thats what I needed to know. Thanks for your help.
grasshoper
Posts Posts : 68
