Trojan.Brisv.A!nf removal help.....
Re: Trojan.Brisv.A!nf removal help.....
Post by Belahzur on Thu Apr 02, 2009 1:08 am
Hmm.
Lets do an online scan.
You may want to do this while your away from the machine. Over night maybe, because depending on how many files are on this machine, it can take awhile. I've seen it take upto 5hrs. LMBO or ROFL
Please use the Internet Explorer browser, and do an online scan with [You must be registered and logged in to see this link.]
Note: If you have used this particular scanner before, you MAY HAVE TO UNINSTALL the program through Add/Remove Programs before downloading the new ActiveX component
Click Accept, when prompted to download and install the program files and database of malware definitions.
  • Click Run at the Security prompt.
  • The program will then begin downloading and installing and will also update the database.
  • Please be patient as this can take several minutes.
  • Once the update is complete, click on My Computer under the green Scan bar to the left to start the scan.
  • Once the scan is complete, it will display if your system has been infected. It does not provide an option to clean/disinfect. We only require a report from it.
  • Do NOT be alarmed by what you see in the report. Many of the finds have likely been quarantined.
  • Click View scan report at the bottom.
  • Click the Save as Text button to save the file to your desktop so that you may post it in your next reply.
    **Note**
    To optimize scanning time and produce a more sensible report for review:
  • Close any open programs.
  • Turn off the real-time scanner of all antivirus or antispyware programs while performing the online scan.
Note for Internet Explorer 7 users: If at any time you have trouble viewing the accept button of the license, click on the Zoom tool located at the bottom right of the IE window and set the zoom to 75%. Once the license is accepted, reset to 100%.
Points Points : 245049
Post by Pablohoney on Thu Apr 02, 2009 1:47 am
Well it's about 8:45 my time, I've got it downloading the Kaspersky updates right now. I'm going to go ahead and call it a night, run the scan and if nothing turns up I'm going to re-run my Norton. Earlier it was just finishing up a scan when I tried the OTMoveIt3, so maybe it read the viruses just before I moved them. I appreciate all the help, I will post the scan results tomorrow.
Pablohoney
Posts Posts : 23
Joined Joined : 2009-03-31
OS OS : Windows Vista Home Basic
Points Points : 28075
Post by Pablohoney on Thu Apr 02, 2009 6:16 am
KASPERSKY ONLINE SCANNER 7 REPORT
Thursday, April 2, 2009
Operating System: Microsoft Windows Vista Home Basic Edition, 32-bit Service Pack 1 (build 6001)
Kaspersky Online Scanner 7 version: 7.0.25.0
Program database last update: Thursday, April 02, 2009 00:13:53
Records in database: 1994982
Scan settings
Scan using the following database extended
Scan archives yes
Scan mail databases yes
Scan area My Computer
C:\
D:\
E:\
F:\
G:\
H:\
Scan statistics
Files scanned 83650
Threat name 1
Infected objects 2
Suspicious objects 0
Duration of the scan 00:54:17
File name Threat name Threats count
C:\Users\Owner\Shared\Biohazard - Down for life.mp3 Infected: Trojan-Downloader.WMA.GetCodec.aa 1
C:\Users\Owner\Shared\nas - best track ever.mp3 Infected: Trojan-Downloader.WMA.GetCodec.aa 1
The selected area was scanned.
Pablohoney
Posts Posts : 23
Post by Belahzur on Thu Apr 02, 2009 8:30 am
The scan only took 1hr. Big Grin
  • Please double-click OTMoveIt3.exe to run it.
    :files
  • Return to OTMoveIt3, right click in the "Paste instructions for items to be Moved" window (under the light blue bar) and choose Paste.
  • Close OTMoveIt3
Please post the OTMoveIt log.
Post by Pablohoney on Thu Apr 02, 2009 8:35 am
========== FILES ==========
C:\Users\Owner\Shared\Biohazard - Down for life.mp3 moved successfully.
C:\Users\Owner\Shared\nas - best track ever.mp3 moved successfully.
OTMoveIt3 by OldTimer - Version 1.0.10.0 log created on 04022009_033205
I didn't know what you meant by OTMoveIt log, other than the above...
Pablohoney
Posts Posts : 23
Post by Belahzur on Thu Apr 02, 2009 8:40 am
Yeah, it's fine.
The two files Kaspersky found are gone now, delete the OTMoveIt folder again.
The Brisv.A!nf should be gone now.
Post by Pablohoney on Thu Apr 02, 2009 8:44 am
Deleted the folder, should I do any additional scanning to make sure it's gone?
Pablohoney
Posts Posts : 23
Post by Belahzur on Thu Apr 02, 2009 8:46 am
You can do if you want to for the sake of your own security, but I wouldn't what it finds if anything actually poses a thread.
Post by Pablohoney on Thu Apr 02, 2009 8:56 am
Alright then, I thank you for all the help. I'm probably going to poke around and see if anything is still recognizing infection, and then I'll have to; "consider a donation to help keep you alive."
Pablohoney
Posts Posts : 23
Post by Belahzur on Thu Apr 02, 2009 10:37 am
Your choice if you want to donaete. Smile
If you do, thank you. Smile
