tv tuner card playback sound choppy
Post by donmac on Sun Mar 29, 2009 7:50 pm
installed and got tv tuner card working great, except for some grainy issues. The recording is so easy, but the sound on play back is soppy in that it sounds like its sped up and then stops on then off every second. xphome 5.6 dualcore, onboard sound card, dual monitors, 4 gig ram.
please help with any ideas
gary
donmac
Posts Posts : 29
Joined Joined : 2009-02-04
OS OS : xp home
Protection Protection : MSE, MWB, Spybot,
Points Points : 28659
Re: tv tuner card playback sound choppy
Post by donmac on Sun Mar 29, 2009 7:51 pm
Who you calling a newbie?
donmac
Posts Posts : 29
OS OS : xp home
Post by Doctor Inferno on Mon Mar 30, 2009 10:51 am
I need the brand and model number of your TV tuner.
Thank you.
Post by donmac on Sat Apr 04, 2009 8:08 pm
v-stream studio tv terminator, quick tv software
Part Number:VS-LTV7131RF
General
Device Type TV tuner / video input adapter
Enclosure Type Plug-in card
Interface Type PCI
Video
Type Video capture adapter
Form Factor Plug-in card
Interface Type Composite video input , S-video input
Analog Video Format PAL , NTSC
Analog Video Signal S-Video , Composite video
Digital Video Format MPEG-4 , MPEG-1 , MPEG-2
Still Image Format JPEG , BMP
Audio Input Support Standard
Features Teletext , Sleep timer , Time shift function , TV tuner , A2 audio decoding , NICAM audio decoding
Audio Input
Type None
Expansion / Connectivity
Expansion Slots Total (Free) None
Interfaces 1.0 x Display / video - S-video input - Mini-phone stereo 3.5 mm , 1.0 x Audio - Input - 4 pin mini-DIN , 1.0 x Remote control - Composite video input - RCA , 1.0 x Display / video - Line-out , 1.0 x TV antenna
Connections None
Compatible Bays None
Compatible Slots 1.0 x PCI
Miscellaneous
Included Accessories IR receiver , Remote control
Cables Included 1.0 x A/V cable kit
Power
Type None
Software / System Requirements
Software Included Drivers & Utilities
OS Required Microsoft Windows 98SE/2000/ME/XP
Min Processor Type 800.0 MHz
Peripheral / Interface Devices CD-ROM , Graphics card , Sound card
System Requirements Details Windows 98SE/2000/ME/XP - Pentium III - RAM 128.0 MB
donmac
Posts Posts : 29
OS OS : xp home
