ANG antivirus deletion guide (need help/not working)
Post by dmbfreak125 on 21st March 2009, 3:18 pm
Hi, I have downloaded malware bytes into my computer and have run multiple scans, but today was the first day it actually picked up something to do with ANG. It picked up these two things:
HKEY_CURRENT_USER\SOFTWARE\Total Virus Protection (Rogue.TotalVirusProtection) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\ANG AntiVirus 09 (Rogue.ANGav2009) -> Quarantined and deleted successfully.
It is still on my computer however. What do you suggest? Should I reboot?
dmbfreak125
Posts Posts : 3
Joined Joined : 2009-03-13
Points Points : 28284
Re: ANG antivirus deletion guide (need help/not working)
Post by Belahzur on 21st March 2009, 3:24 pm
Points Points : 245101
