svchost.exe application error! I need help please
Solved svchost.exe application error! I need help please
Post by WBar66 on Mon Mar 16, 2009 2:48 am
I logged on my other computer the other day and I got a error popup that says: The instruction "0x75606e6a" refrenced memory at "0x00000008". The memory could not be "read". This said svchost.exe at the top. All that I can do is press okay, press x but then it comes up again, or ignore it. Tis is causing problems though. Firefox and IE won't work, Malware Bytes won't even come up after I try to open it and System restore says that "it cannot protect my computer. Restart and try again. Restarting, however, accomplishes nothing. I have hijack this and combofix and AVG free. AVG free scan produces nothing. I really need some help here. I'm to sure what to do. I'm not the most computer savvy peron in the world but I can follow good directions and know my way around a computer. Please Help!!
WBar66
Posts Posts : 10
Joined Joined : 2009-03-16
Points Points : 28215
Solved Re: svchost.exe application error! I need help please
Post by Belahzur on Mon Mar 16, 2009 2:58 am
This could be either a hardware or software problem.
Try this.
Press Start > Run. In the Run box, type in:
sfc /scannow
Note the space between the c and /
Press enter.
If asked to insert your XP disc, put it and run it again.
Reboot and see if you still get the error.
Points Points : 245059
Post by WBar66 on Mon Mar 16, 2009 3:00 am
It says insert Windows XP Professional service pack 2 CD. I don't have that, this is a 2nd hand computer
WBar66
Posts Posts : 10
Post by Belahzur on Mon Mar 16, 2009 3:03 am
Okay.
It's late here so I'm heading off now, but I have found an article related to an svchost error. Did this start after/during a Windows Update?
Post by WBar66 on Mon Mar 16, 2009 3:06 am
I think I read the article you are referring to, the one from pchell? I ried that and it didn't help. I have my updates set on automatic so I am not exactly sure. Thanks for you patience Belahzur, I will contact you tomorrow.
WBar66
Posts Posts : 10
Post by Belahzur on Mon Mar 16, 2009 3:08 am
Yep, that's the one.
I'll think this through the night and contact someone who knows more in this area than I do.
Post by WBar66 on Mon Mar 16, 2009 3:13 am
Another weird symptom, don't know if it helps. The bars on top of my windows now sometimes look like they are from windows 98 or 2000. When my toolbar loads also it looks like its from a previous version. Anyways, Get some rest man you do a lot for this website.
WBar66
Posts Posts : 10
Post by Belahzur on Mon Mar 16, 2009 2:10 pm
I am moving this to hardware so Doctor can get involved and help me figure this out.
Post by WBar66 on Mon Mar 16, 2009 8:53 pm
Okay, thank you.
WBar66
Posts Posts : 10
Post by Belahzur on Tue Mar 17, 2009 3:51 pm
Not sure if this is fixable, as the error says, it's svchost that is causing the problem, but if you look at the Task Manager, there will be (probably) like 7 different svchosts.exe's running. Some tools tell us what some of the listed svchost's are doing, but it won't tell us what ALL of them are doing.
Closing svchost.exe from running may cause your machine to crash and become unstable, so it's hard to identify which svchost is causing the problem.
Post by WBar66 on Tue Mar 17, 2009 7:04 pm
So I'm screwed. Should I go ahaead and get a disc so I can reinstall windows XP
WBar66
Posts Posts : 10
Post by WBar66 on Tue Mar 17, 2009 7:39 pm
Wow. Of course. The only virus I get is unfixable.
WBar66
Posts Posts : 10
Post by Belahzur on Tue Mar 17, 2009 8:26 pm
We don't know that it's a virus.
We can take a look down that road, but I honestly don't think it is a virus.
Formatting would probably be the better option.
Post by WBar66 on Wed Mar 18, 2009 12:30 am
I'll look into that. Thanks again.
WBar66
Posts Posts : 10
Post by WBar66 on Wed Mar 18, 2009 2:03 am
What exactly should I be formatting?
WBar66
Posts Posts : 10
Post by Belahzur on Wed Mar 18, 2009 2:05 am
Post by WBar66 on Wed Mar 18, 2009 2:16 am
Thanks belahzur, you've been a huge help. This virus/malware/corrupted update/hardware screw up could not have come at a worse time.
WBar66
Posts Posts : 10
Post by Belahzur on Wed Mar 18, 2009 1:39 pm
We know how you feel. Me/Doctor Inferno were all infected at one point, that's why we got in this world, to fight back.
