GeekPolice is a website which provides free Computer Technical Support & Virus/Spyware Removal to our members.
Take 30 seconds to register below and unlock the limitations of this website to discover new computer knowledge!
How to Remove General Antivirus [Delete Guide]
Post by Doctor Inferno on Sat 14 Mar 2009, 9:06 pm
This guide will give you easy instructions on how to remove General Antivirus for free.
What is General Antivirus? (Information)
General Antivirus is a fake security software which uses fraudulent strategies by displaying false or exaggerated security issues on your computer rather than any legitimate ones to coerce you into purchasing their software.
General Antivirus Screenshots:
Symptoms in a HijackThis log:
O4 - HKCU\..\Run: [Microsoft Windows logon process] C:\Documents and Settings\GeekPolice\Application Data\Microsoft\Windows\winlogon.exe
O4 - HKCU\..\Run: [General Antivirus] "c:\program files\General Antivirus\GenAvir.exe" /s
O4 - HKCU\..\Policies\Explorer\Run: [iv] "C:\Documents and Settings\GeekPolice\Local Settings\Application Data\Microsoft\Internet Explorer\iv.exe"
O23 - Service: Guard Service (ITGrdEngine) - Unknown owner - C:\Documents and Settings\GeekPolice\Local Settings\Application Data\Microsoft\Windows\services.exe
1. Please download Malwarebytes' Anti-Malware.
2. Install Malwarebytes' Anti-Malware by double clicking on Download_mbam-setup.exe
4. Malwarebytes' Anti-Malware will automatically update itself after the install, you can press the OK button to close that box and you will now be at the main program as shown below.
If you are having problems with the updater, you can use this link to manually update Malwarebytes' Anti-Malware with the latest database
Spoiler:
  • Malwarebytes' Anti-Malwares' latest database
Download the Full database to your Desktop or to your usual Download Folder and install it by double clicking the file. Make sure that Malwarebytes' Anti-Malware is closed before installing the update.
5. Close ALL open Windows, Programs, File or Folders.
6. Make sure you are on the Scanner tab. Select Perform quick scan then click the Scan button as shown above.
8. When the scan is finished a message box will appear, click Ok to continue.
9. Click Show Results.
11. Click on Remove seletced
12. When removing the files, Malwarebytes' Anti-Malware may require you to restart the computer in order to do a complete removal. If it displays a message stating that it needs to restart, please allow it to do so.
13. After that you can close the Malwarebytes' Anti-Malware window, your computer is now cleaned.
Files Associated With General Antivirus:
Spoiler:
c:\Documents and Settings\All Users\Desktop\General Antivirus.lnk
c:\Documents and Settings\All Users\Start Menu\Programs\General Antivirus
c:\Documents and Settings\All Users\Start Menu\Programs\General Antivirus\General Antivirus Home Page.lnk
c:\Documents and Settings\All Users\Start Menu\Programs\General Antivirus\General Antivirus.lnk
c:\Documents and Settings\All Users\Start Menu\Programs\General Antivirus\Purchase License.lnk
%UserProfile%\Application Data\General Antivirus
%UserProfile%\Application Data\General Antivirus\settings.ini
%UserProfile%\Application Data\General Antivirus\uill.ini
%UserProfile%\Application Data\General Antivirus\unins000.exe
%UserProfile%\Application Data\General Antivirus\Uninstall General Antivirus.lnk
%UserProfile%\Application Data\General Antivirus\db
%UserProfile%\Application Data\General Antivirus\db\config.cfg
%UserProfile%\Application Data\General Antivirus\db\Timeout.inf
%UserProfile%\Application Data\General Antivirus\db\Urls.inf
%UserProfile%\Application Data\Microsoft\Internet Explorer\Quick Launch\General Antivirus.lnk
%UserProfile%\Application Data\Microsoft\Windows\winlogon.exe
%UserProfile%\Local Settings\Application Data\Microsoft\Internet Explorer\iGSh.png
%UserProfile%\Local Settings\Application Data\Microsoft\Internet Explorer\iMSh.png
%UserProfile%\Local Settings\Application Data\Microsoft\Internet Explorer\iPSh.png
%UserProfile%\Local Settings\Application Data\Microsoft\Internet Explorer\iv.exe
%UserProfile%\Local Settings\Application Data\Microsoft\Windows\log.txt
%UserProfile%\Local Settings\Application Data\Microsoft\Windows\pguard.ini
%UserProfile%\Local Settings\Application Data\Microsoft\Windows\services.exe
c:\Program Files\Common Files\file.exe
c:\Program Files\Common Files\GeneralAntivirus.exe
c:\Program Files\General Antivirus
c:\Program Files\General Antivirus\activate.ico
c:\Program Files\General Antivirus\Explorer.ico
c:\Program Files\General Antivirus\GenAvir.exe
c:\Program Files\General Antivirus\unins000.dat
c:\Program Files\General Antivirus\uninstall.ico
c:\Program Files\General Antivirus\working.log
c:\Program Files\General Antivirus\db
c:\Program Files\General Antivirus\db\DBInfo.ver
c:\Program Files\General Antivirus\db\ga090122.db
c:\Program Files\General Antivirus\Languages
c:\WINDOWS\system32\log.txt
If you are still experiencing problems or difficulties following this guide or require any assistance removing this software, please post your questions in our Virus, Spyware & Malware Removal forums for free help.
You have to be logged in to post questions. Registration is free. By registering you are privileged to other virus removal resources in future.
popup pop up alert get rid of security centre alert for free report serial registration crack keygen removal remover uninstall tool GeneralAntivirus GenAvir.exe GenAvir
The GeekPolice
The GeekPolice
Won't Work
Post by darrider1957 on Sat 14 Mar 2009, 10:00 pm
It will not work for me. It keeps trying to block the download and it is saying the download site is spyware. What do I do?
darrider1957
Unborn
Unborn
Re: How to Remove General Antivirus [Delete Guide]
Post by Doctor Inferno on Sun 15 Mar 2009, 6:19 am
You would have to boot into Safe mode with networking by doing the following:
  • Restart your computer
  • After hearing your computer beep once during startup, but before the Windows icon appears, keep tapping F8.
  • Instead of Windows loading as normal, a menu should appear
  • Select the option, to run Windows in Safe Mode with Networking.
In safe mode with networking, download the file and run malware bytes.
The GeekPolice
The GeekPolice
Post by Pc Jedi on Mon 16 Mar 2009, 2:53 am
mmm new stuff
Pc Jedi
Rookie Surfer
Rookie Surfer
Operating System: Windows XP, WIndows Vista, Windows 7
