Microsoft Works Problem
Page 1 of 3
Page 1 of 3 • 1, 2, 3
- virus025Novice
OS : Windows
Rubies : 3441
Hello. Microsoft Works keeps saying "Works installed some files that will require a reboot. Please save your work before pressing OK." every time I start the computer and I have to restart. I want to delete Works but it doesn't let me.
- Doctor InfernoSite Admin
Anti-Malware : Kaspersky PURE and Malwarebytes' Anti-Malware
Rubies : 75704
Have you tried booting into safe mode to uninstall it?
Follow this guide on how to boot into safe mode:
http://www.geekpolice.net/tutorials-guides-f13/how-to-boot-into-safe-mode-t3651.htm
Try unistalling it and see what error message it produces.
- virus025Novice
OS : Windows
Rubies : 3441
Yes I have and it got an error message. Doesn't let me delete it. I've also tried deleting the folders in the Program Files and every file that I see of it but still comes up.
- Jerry ParnellTech Colleague
OS : Windows Vista Home Basic
Rubies : 3814
Can you please tell us what that error message says? This may aid us in figuring out what the problem is.
- virus025Novice
OS : Windows
Rubies : 3441
"The Windows Install Service could not be accessed. This can occur if you are running Windows in safe mode, or if the Windows Installer is not correctly installed. Contact your support personnel for assistance."
Rubies : 75704
Ahh. Your Windows Installer Service is corrupted.
Start >> Run >> type in cmd>> OK.
Type in typemsiexec.exe /unregister, and then hit Enter. Type in msiexec /regserver, and then hit Enter again.
Now, to verify that the SYSTEM account has full control access permissions to the HKEY_CLASSES_ROOT hive in the Windows registry. Before please backup your registry for security purposes, read on how to do it here:
http://www.geekpolice.net/tutorials-guides-f13/backup-your-registry-with-erunt-t7262.htm
After that, Start >> Run >> type in regedit >> OK.
On the left panel select HKEY_CLASSES_ROOT and on the Edit menu, click Permissions.
If SYSTEM is not listed in the Group or user names list, click Add, make sure that the local computer name appears in the From this location box, type system in the Enter the object names to select box, click Check Names, and then click OK.
Click SYSTEM in the Group or user names list, and then select the Full Control check box under Allow in the Permissions for SYSTEM box. Click Apply >> OK >> Quit Registry Editor.
Restart the computer and try again.
- virus025Novice
OS : Windows
Rubies : 3441
the typemsiexec.exe /unregister and msiexec /regserver
dont work
dont work
Rubies : 75704
What do you mean by 'don't work'? Does a message tell you elevation is required or nothing happens?
- BelahzurSite Admin
OS : 7 Home Premium x64
Rubies : 218221
I think Doc made a type, it should be msiexec.exe /unregister without the 'type' at the start.
Site Admin / Security Administrator
[Prework] - Please PM me if I fail to respond within 24hrs.
Rubies : 3814
LOL
I just noticed that.
Dont worrie doc, happens to us all.
Similar topics
Page 1 of 3
