Problem with Ethernet Controller
Solved Problem with Ethernet Controller
Post by Jenkins on 7th March 2009, 4:44 pm
I connect to the internet for my laptop through an ethernet cable but my compooty wont recognize it. I was told to look in the hardware manager in the control panel for anything to do with ethernet that has a yellow "!" next to it. And I found that exact thing. So then I updated it. The only problem is is that the updating wizard thing couldn't find an update anywhere. So I was wondering if there is a site that I can go to to get the driver or whatever it is that I need.
By the way:
I'm on a Windows XP Home Edition Dell Inspiron 600m
Rolling back the update is not an option because I had to reinstall XP after a little issue I had.
Thank You
Jenkins
Posts Posts : 56
Joined Joined : 2009-03-07
OS OS : Wndows Vista 64 Bit
Points Points : 28506
Solved Re: Problem with Ethernet Controller
Post by Doctor Inferno on 8th March 2009, 10:59 am
Solved Aghhh
Post by Jenkins on 10th March 2009, 1:20 am
I don't know which one to pick though, and I can't risk opening up my laptop. What shouuuuuuuuld I do?
Jenkins
Posts Posts : 56
Post by Doctor Inferno on 10th March 2009, 11:00 am
I need more inforamtion on the card you are using.
Start >> My Computer >> Right click on Properties >> Systems Properties >> Hardware tab.
Click Device Manager >> in dialog screen, expand the Network Adapters device from the list.
Post the details back here.
Post by Jenkins on 12th March 2009, 7:33 pm
Intel(R) PRO/Wireless 2200 BG Network Connection is the only thing under the network part. I'm not sure if that's the card. The actual ethernet controller icon is under other devices, I don't think that it is installed on my computer yet but I might be wrong.
Jenkins
Posts Posts : 56
Post by Doctor Inferno on 13th March 2009, 3:32 am
Post by Jenkins on 13th March 2009, 3:40 pm
Okay, so i downloaded it, ran the program, it extracted it and then i went into the device manager, right clicked on the ethernet controller thing, did upgrade, then upgrade from specific location then i chose the place that it was extracted to (C/dell/R11blahblah/DRIVERS) and it gave me the same error message. what should i do know?
Jenkins
Posts Posts : 56
Post by Jenkins on 13th March 2009, 3:46 pm
feck, so now, i was just looking, and the ethernet controller isnt anywhere on the device manager and, when i plug in an ethernet cord, my computer usually says LAN or something like that but no it wont say anything at all. (that was the original issue)
Jenkins
Posts Posts : 56
Post by Doctor Inferno on 19th March 2009, 2:13 pm
Does the internet work?
Try this: Start >> Control Panel >> Network Connections >> Right click your local area connection >> Properties >> uncheck the Notify me when this connection has limited or no connectivity option.
Post by Jenkins on 20th March 2009, 12:42 am
i guess it kinda doesnt really matter any more because my hard drive just went so im getting a new one with all tge necessary stuff so as far as i know i wont have this problem
Jenkins
Posts Posts : 56
