Piranha Web Cam Model PC5000
Post by tinkerman on Thu Mar 05, 2009 11:26 pm
hello, i have piranha web cam model pc5000, but lost the setup cd, so i think i need some software to make my web cam wrok and be active can you help me please?
Last edited by Jerry Parnell on Tue Mar 17, 2009 1:07 am; edited 2 times in total (Reason for editing : Solved changed to not solved. User responded, and confermed that the problem has not been solved.)
tinkerman
Posts Posts : 109
Joined Joined : 2009-02-11
OS OS : windows xp with sp3
Points Points : 29209
Re: Piranha Web Cam Model PC5000
Post by Jerry Parnell on Fri Mar 06, 2009 4:06 am
I was only able to find a driver for Vista.
If you are running XP, please let me know.
If you are running Vista: http://www.1driver.org/driver/?download=Piranha+PC5000+5+Mp+Webcam
Jerry Parnell
Posts Posts : 670
Joined Joined : 2008-08-04
OS OS : Windows Vista Home Basic
Points Points : 30724
Post by tinkerman on Fri Mar 06, 2009 8:03 pm
yes iam using xp, i also couldn't find anything for xp
tinkerman
Posts Posts : 109
Post by tinkerman on Mon Mar 09, 2009 10:52 am
isn't there any possibility to find xp drivers?
tinkerman
Posts Posts : 109
Post by Jerry Parnell on Sat Mar 14, 2009 9:44 pm
I have looked all over, but still have found no luck. I wish that I could find the company that makes it, but a google search doesnt turn up any other information.
I will leave this topic open for anyone who would like to answer it.
Jerry Parnell
Posts Posts : 670
Post by tinkerman on Sun Mar 15, 2009 1:10 pm
i am regretful to lose the original direver cd:) but hoping someone can help me..
tinkerman
Posts Posts : 109
Post by Doctor Inferno on Sun Mar 15, 2009 1:51 pm
I'm not sure if this will work, but I think I found it.
http://www.driverdownloading.com/files/piranha.rar
Points Points : 104600
Post by Jerry Parnell on Sun Mar 15, 2009 10:10 pm
Please be careful when downloading drivers. Make backups of all important files just incase somthing goes wrong. I know that a bad driver can cause your comptuer unable to start up.
Just please be careful.
Jerry Parnell
Posts Posts : 670
Post by tinkerman on Mon Mar 16, 2009 3:06 pm
sorry for delayed post but the driver didnt worked or i coudnt managed it to work properly..
tinkerman
Posts Posts : 109
Post by tinkerman on Mon Mar 16, 2009 3:09 pm
i think the direver was wrong because just you say machine was working slower then before after installing.. after i saw that it didnt worked i unistalled it..
tinkerman
Posts Posts : 109
