PC will not turn on!!
Solved PC will not turn on!!
Post by jtrory on 5th March 2009, 9:35 pm
Well usually I'm here with malware questions, but now I'm really screwed. My computer won't turn on, and I am at a loss as to what the problem might be.
I thought that it was that the PSU had died, because prior to this problem, it would take several attempts and lots of flashing lights and fan-spinning for the computer to finally boot up properly. But a couple of days ago, I got nothing at all. Looking inside the case, I see no power light on the mobo, and the PSU makes a funny squealing noise when it's own power switch is turned on and off. I've also unplugged the HDD, tried different outlets in the apartment, and made sure all cables are attached correctly.
Trouble is, I literally just finished installing a new PSU from Newegg, and it has not fixed the problem. Still no juice. And so now I've got no idea what the problem is. Any help or advice would be greatly appreciated.
jtrory
Posts Posts : 11
Joined Joined : 2008-12-07
OS OS : Win XP SP3
Points Points : 29230
Solved Re: PC will not turn on!!
Post by Jerry Parnell on 6th March 2009, 4:08 am
I am not a hardware tech, but I can run you through your basic trouble shooting method.
Please power off and unplug your machine.
Hold the power button for 10-15 seconds.
Plug your machine back in.
Did this fix your problem?
Jerry Parnell
Posts Posts : 670
Joined Joined : 2008-08-04
OS OS : Windows Vista Home Basic
Points Points : 30744
Post by jtrory on 6th March 2009, 10:03 pm
No, I tried that with both PSU's and nothing happened. I've tried tripping the mobo out of the case, with a screwdriver, and nothing happened then either, which is making me think it could be that the new PSU is DOA. Otherwise, it's one of the four major components: CPU, mobo, GPU, or RAM. But I've got no way of testing those without buying new ones...
jtrory
Posts Posts : 11
OS OS : Win XP SP3
