Hard drive question-- partitioned or separate drive
Solved Hard drive question-- partitioned or separate drive
Post by LadySmith on 3rd March 2009, 7:23 pm
I have a C drive and a D drive. How do you tell if these are actually 2 hard drives or if it's one drive partitioned.
Also, what is the purpose of a partitioned drive?
If indeed it is partitioned, is there any way to save stuff from D drive when the hard drive fails or since the whole drive is dead, is it gone as well?
Thanks in advance!
LadySmith
Posts Posts : 110
Joined Joined : 2008-12-04
Points Points : 29590
Solved Re: Hard drive question-- partitioned or separate drive
Post by Belahzur on 3rd March 2009, 7:26 pm
The advantage of having the OS on one partition and your files on the other is: if you run into a problem and need to reformat windows, it will wipe the whole of C:\, but D:\ will be left alone.
Points Points : 245121
Post by LadySmith on 3rd March 2009, 8:03 pm
@Belahzur wrote:The advantage of having the OS on one partition and your files on the other is: if you run into a problem and need to reformat windows, it will wipe the whole of C:\, but D:\ will be left alone.
So, like if Windows is installed on C:\ , then you recommend all other files like pictures, videos, documents, etc. be put on D:\ in case Windows needs to be reformatted?
What about installing Software? Still install it on C:\ or install it on D:\?
But, what about if you have a hard drive failure....does that mean that everything on D is gone as well?
Oh, and how can you tell if it's actually a separate hard drive or if it is partitioned?
LadySmith
Posts Posts : 110
Post by Belahzur on 3rd March 2009, 8:07 pm
Seperate hardrive will mean having two HD's inside your machine, take the lid and have a peek. (DO NOT touch the inside of the machine if it's left on, you'll fry it otherwise)
If it's partition, there will only be 1 HD.
Bingo.
Post by Doctor Inferno on 4th March 2009, 8:19 am
If you have an OEM computer and have never partitioned your hard drive before, then the D:\ drive is most likely to be the recovery partition, which I would not want to touch.
Most of the time people who partition their hard drive will store all their data on D:\ if the OS is installed on C:\, so you would not need to worry if you need to do a sudden format. If say, the OS crashes turns unusable overnight, you can format it without worrying to lose any data.
Points Points : 104650
