Having problems with a lot of Spyware
Re: Having problems with a lot of Spyware
Post by Belahzur on 4th March 2009, 2:45 pm
    [HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\SecurityProviders]
    "SecurityProviders"="msapsspc.dll, schannel.dll, digest.dll, msnsspc.dll"
How is the machine now?
Points Points : 245091
Post by jnason926 on 4th March 2009, 3:42 pm
The computer appears to be running perfectly fine. I will keep an eye on it over the next few days and post again if anything happens. Thanks so much for your help.
jnason926
Posts Posts : 17
Joined Joined : 2009-03-01
Points Points : 28390
Post by Belahzur on 4th March 2009, 3:48 pm
Post by jnason926 on 4th March 2009, 4:01 pm
Thanks again. I already use Mozilla as a browser, but I will download the add-ons. I also already was using Spybot S&D. Should I download the other programs as well? I wasn't entirely clear from your last post if you meant that all 4 programs should be downloaded and running simultaneously.
jnason926
Posts Posts : 17
Post by Belahzur on 4th March 2009, 4:28 pm
Just have one or two running.
Having all 4 running will slow your system down.
