Trojan Horse Dropper.VB.BXQ (Please Help)
Post by CoolKat45 on Fri Feb 27, 2009 11:47 am
I'm running Windows XP Home Edition
I really don't get my luck with viruses lately. I wasn't even doing anything, I was asleep when this happened. I was running Malwarebytes just for a routine check and it didn't find anything but when I wake up I see that my AVG found this:
I don't know if it's off or not, I but this is what I saw, I wanted to remove it but don't know if it will make stuff stop working.
CoolKat45
OS : Windows XP Home Edition
Re: Trojan Horse Dropper.VB.BXQ (Please Help)
Post by Belahzur on Fri Feb 27, 2009 5:20 pm
Unlikely it will.
Post by CoolKat45 on Fri Feb 27, 2009 11:28 pm
Thanks, i think that did it.
CoolKat45
