Desperately seeking help to remove nuqel.e and others
Re: Desperately seeking help to remove nuqel.e and others
Post by Belahzur on 23rd February 2009, 8:01 pm
That should do, hopefully.
Give it a try.
Points Points : 245121
Post by becksgilkes on 23rd February 2009, 8:25 pm
I've followed the instructions and it seems to have worked. Can I assume that the computer is now not infected or will there be some underlying threats still hidden. If it is fine to go, I will sort out the internet connection, download anti malware, a good AV, super anti spyware etc before I do anything else.
becksgilkes
Posts Posts : 16
Joined Joined : 2009-02-22
OS OS : windows xp
Points Points : 28490
Post by Belahzur on 23rd February 2009, 8:36 pm
Yep, it should be fine now.
Post by becksgilkes on 23rd February 2009, 9:20 pm
thank you thank you thank you thank you thank you thank you...........
You are worth your weight in gold. I will complete the feedback form now.
"If your computer is down and not working at all, who you gonna call? GEEKPOLICE!"
becksgilkes
Posts Posts : 16
OS OS : windows xp
