Desperately seeking help to remove nuqel.e and others
Post by becksgilkes on Sun Feb 22, 2009 11:42 am
I would really welcome some help in removing Bankerfox.A, Spyware protect 2009 and nuqel.e ASAP.
I've run the DDS and Avenger and I have copied the resulting text in below. I am hoping that somebody can help me or advice me what to do as I am now balding from tearing my hair out.
Much appreciated
Bx
AVENGER TEXT:
Platform: Windows XP
Rootkit scan active.
Hidden driver "gaopdxserv.sys" found!
ImagePath: \systemroot\system32\drivers\gaopdxewnsxrqt.sys
Driver disabled successfully.
Rootkit scan completed.
Completed script processing.
Finished! Terminate.
becksgilkes
Posts Posts : 16
Joined Joined : 2009-02-22
OS OS : windows xp
Points Points : 28440
Re: Desperately seeking help to remove nuqel.e and others
Post by Belahzur on Sun Feb 22, 2009 2:40 pm
We ask that you do not run tools on your own, the avenger is VERY powerful. But since you have used it, we may as well remove the rootkit.
Drivers to delete:
gaopdxserv.sys
Files to delete:
C:\WINDOWS\system32\drivers\gaopdxewnsxrqt.sys
Points Points : 245069
Post by becksgilkes on Sun Feb 22, 2009 4:27 pm
Hi and many thanks,
I've followed the instructions and the following text came up at the end.
Do I need to repeat the process again, or am I cured?
humble thanks
Hidden driver "axbfrlycf" found!
DisplayName: axbfrlycf
ImagePath: \??\C:\WINDOWS\system32\drivers\spqhemlxobtb.sys
Driver "gaopdxserv.sys" deleted successfully.
File "C:\WINDOWS\system32\drivers\gaopdxewnsxrqt.sys" deleted successfully.
becksgilkes
Posts Posts : 16
OS OS : windows xp
Post by Belahzur on Sun Feb 22, 2009 4:43 pm
Hmmm.
Another rootkit jumped onto your machine.
Drivers to delete:
axbfrlycf
Files to delete:
Post by becksgilkes on Sun Feb 22, 2009 6:30 pm
OK Ive followed your instructions and no text came up at the end. Is this a good sign. Dare I hope that I am cured?
Many many thanks for helping me on this one
becksgilkes
Posts Posts : 16
OS OS : windows xp
Post by Belahzur on Sun Feb 22, 2009 6:50 pm
Nope, probably not.
Post by becksgilkes on Sun Feb 22, 2009 8:15 pm
Hi
Ive run Malwarebytes' Anti-Malware on a quick scan and a full scan and followed the instructions to clear infected objects. Is there anything else I can do to ensure Im clear?
becksgilkes
Posts Posts : 16
OS OS : windows xp
Post by Belahzur on Sun Feb 22, 2009 8:16 pm
Please post the MBAM report.
I want to have a look around to make sure we aren't missing anything.
  • Double click DDS.scr to run
  • When complete, DDS.txt will open.
  • Save the report to your Desktop.
Post by becksgilkes on Sun Feb 22, 2009 9:46 pm
Here is the report. I will download DDS now.
You will get bored of me thanking you but I really appreciate your advice
Malwarebytes' Anti-Malware 1.34
Database version: 1792
22/02/2009 19:58:03
mbam-log-2009-02-22 (19-58-03).txt
Objects scanned: 165925
Time elapsed: 49 minute(s), 57 second(s)
Memory Processes Infected: 5
Registry Keys Infected: 3
Registry Values Infected: 5
Files Infected: 11
C:\WINDOWS\system32\reader_s.exe (Trojan.Agent) -> Unloaded process successfully.
C:\Documents and Settings\LocalService\reader_s.exe (Trojan.Agent) -> Unloaded process successfully.
C:\Documents and Settings\Rebecca Gilkes\reader_s.exe (Trojan.Agent) -> Unloaded process successfully.
C:\WINDOWS\system32\winlogin.exe (Backdoor.Bot) -> Unloaded process successfully.
C:\WINDOWS\SVCHOST.exe (Trojan.Agent) -> Unloaded process successfully.
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet003\Services\protect (Trojan.NtRootkit.Agent) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\protect (Trojan.NtRootkit.Agent) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\synsend (Trojan.Agent) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\wgabejarivewava (Trojan.Agent) -> Delete on reboot.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\iqoru (Trojan.Agent) -> Delete on reboot.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\reader_s (Trojan.Agent) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\reader_s (Trojan.Agent) -> Quarantined and deleted successfully.
HKEY_USERS\.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\reader_s (Trojan.Agent) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Userinit (Trojan.Agent) -> Data: c:\windows\system32\userinit.exe -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Userinit (Trojan.Agent) -> Data: system32\userinit.exe -> Quarantined and deleted successfully.
C:\Documents and Settings\Rebecca Gilkes\My Documents\InstallAVg_770522166350.exe (Rogue.Installer) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\protect.sys (Trojan.NtRootkit.Agent) -> Quarantined and deleted successfully.
C:\WINDOWS\Ecudexobeditexet.dll (Trojan.Agent) -> Delete on reboot.
C:\WINDOWS\apipirano.dll (Trojan.Agent) -> Delete on reboot.
C:\WINDOWS\services.exe (Trojan.Agent) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\ndetect.exe (Trojan.Agent) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\reader_s.exe (Trojan.Agent) -> Quarantined and deleted successfully.
C:\Documents and Settings\LocalService\reader_s.exe (Trojan.Agent) -> Quarantined and deleted successfully.
C:\Documents and Settings\Rebecca Gilkes\reader_s.exe (Trojan.Agent) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\winlogin.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\WINDOWS\SVCHOST.exe (Trojan.Agent) -> Quarantined and deleted successfully.
becksgilkes
Posts Posts : 16
OS OS : windows xp
Post by becksgilkes on Sun Feb 22, 2009 9:53 pm
Sorry about that. I dont know how to create a zip file so will send the DDS text tomorrow with the help of a friend.
becksgilkes
Posts Posts : 16
OS OS : windows xp
Post by Belahzur on Sun Feb 22, 2009 9:57 pm
Bad news. You have an infection known as Virut. Virut is a file infector, it infects every .exe and .scr files on the machine.
I ask that you backup any files you do not want to lose, because Virut cannot be fixed and to get out of this mess, you'll have to reformat the machine.
Your computer has multiple infections, including a backdoor. A backdoor gives intruders complete control of your computer, logs your keystrokes, steal personal information, etc.
You are strongly advised to do the following:
  • Disconnect the computer from the Internet and from any networked computers until it is cleaned.
  • Back up all your important data except programs. The programs can be reinstalled back from the original disc or from the Net.
  • Call all your banks, financial institutions, credit card companies and inform them that you may be a victim of identity theft and put a watch on your accounts. If you don't mind the hassle, change all your account numbers.
  • From a clean computer, change all your passwords (ISP login password, your email address(es) passwords, financial accounts, PayPal, eBay, Amazon, online groups and forums and any other online activities you carry out which require a username and password).
Do NOT change your passwords from this computer as the attacker will be able to get all the new passwords and transaction records.
Due to its backdoor functionality, your computer is very likely to have been compromised and there is no way that it can be trusted again. Many experts in the security community believe that once infected with this type of Trojan, the best course of action would be to do a reformat and reinstallation of the operating system (OS). However, if you do not have the resources to reinstall your OS and would like me to attempt to clean your machine, I will be happy to do so.
To help you understand more, please take some time to read the following articles:
Post by becksgilkes on Mon Feb 23, 2009 5:28 pm
Hi again,
Firstly many thanks for your comprehensive reply. I would welcome help to clean it up properly and I don't have anything on it that needs backing up as I did so a while back. I don't however have access to a disk to restore the computer so how do I go about it or what is the best next step.
I have contacted all companies and changed passwords etc from my friends computer.
Many thanks.
becksgilkes
Posts Posts : 16
OS OS : windows xp
Post by Belahzur on Mon Feb 23, 2009 5:30 pm
Okay, but as I said, this infection cannot be 100% fixed. The damage is already done and can't be reversed.
Please run DDS and the post the log.
Post by becksgilkes on Mon Feb 23, 2009 6:48 pm
Hi again
As I can't fit the whole log in one message I'll send it in the next two consecutive messages.
DDS (Ver_09-02-01.01) - NTFSx86
Run by Rebecca Gilkes at 21:47:25.07 on 22/02/2009
Internet Explorer: 7.0.5730.11 BrowserJavaVersion: 1.6.0_03
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.502.204 [GMT 0:00]
AV: Sophos Anti-Virus *On-access scanning enabled* (Outdated)
svchost.exe
svchost.exe
svchost.exe
C:\Program Files\Dell Network Assistant\hnm_svc.exe
C:\Program Files\Kontiki\KService.exe
c:\Program Files\Sophos\Sophos Anti-Virus\SAVAdminService.exe
"C:\WINDOWS\system32\svchost.exe"
C:\Program Files\Java\jre1.6.0_03\bin\jusched.exe
C:\Program Files\Dell\Media Experience\DMXLauncher.exe
C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe
C:\Program Files\Real\RealPlayer\RealPlay.exe
C:\Program Files\QuickTime\QTTask.exe
C:\WINDOWS\System32\DLA\DLACTRLW.EXE
C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe
C:\Program Files\Kontiki\KHost.exe
C:\Program Files\MSN Messenger\msnmsgr.exe
C:\Program Files\Veoh Networks\Veoh\VeohClient.exe
C:\Program Files\Dell Network Assistant\ezi_hnm2.exe
C:\Program Files\Digital Line Detect\DLG.exe
C:\Program Files\Microsoft Office\Office\FINDFAST.EXE
C:\Program Files\Microsoft Office\Office\OSA.EXE
C:\Program Files\Tiscali\Tiscali Internet\DialerOEM.exe
svchost.exe
C:\Program Files\Malwarebytes' Anti-Malware\mbam.exe
C:\WINDOWS\system32\NOTEPAD.EXE
C:\Program Files\Windows Live Toolbar\msn_sl.exe
C:\Documents and Settings\Rebecca Gilkes\Local Settings\Temporary Internet Files\Content.IE5\XDPQJDMR\dds[1].scr
uURLSearchHooks: Yahoo! Toolbar: {ef99bd32-c1fb-11d2-892f-0090271d4f88} - c:\program files\yahoo!\companion\installs\cpn\yt.dll
BHO: &Yahoo! Toolbar Helper: {02478d38-c3f9-4efb-9b51-7695eca05670} - c:\program files\yahoo!\companion\installs\cpn\yt.dll
BHO: NoExplorer - No File
BHO: Sophos Web Content Scanner: {39ea7695-b3f2-4c44-a4bc-297ada8fd235} - c:\program files\sophos\sophos anti-virus\SophosBHO.dll
BHO: Windows Live Toolbar Helper: {bdbd1dad-c946-4a17-adc1-64b5b4ff55d0} - c:\program files\windows live toolbar\msntb.dll
TB: EPSON Web-To-Page: {ee5d279f-081b-4404-994d-c6b60aaeba6d} - c:\program files\epson\epson web-to-page\EPSON Web-To-Page.dll
TB: Windows Live Toolbar: {bdad1dad-c946-4a17-adc1-64b5b4ff55d0} - c:\program files\windows live toolbar\msntb.dll
TB: Veoh Browser Plug-in: {d0943516-5076-4020-a3b5-aefaf26ab263} - c:\program files\veoh networks\veoh\plugins\reg\VeohToolbar.dll
TB: Yahoo! Toolbar: {ef99bd32-c1fb-11d2-892f-0090271d4f88} - c:\program files\yahoo!\companion\installs\cpn\yt.dll
TB: &Google Toolbar: {2318c2b1-4965-11d4-9b18-009027a5cd4f} - c:\program files\google\google toolbar\GoogleToolbar.dll
TB: {A057A204-BACC-4D26-9990-79A187E2698E} - No File
EB: Real.com: {fe54fa40-d68c-11d2-98fa-00c0f0318afe} - c:\windows\system32\Shdocvw.dll
uRun: [msnmsgr] "c:\program files\msn messenger\msnmsgr.exe" /background
uRun: [swg] c:\program files\google\googletoolbarnotifier\GoogleToolbarNotifier.exe
uRun: [OM_Monitor] c:\program files\olympus\olympus master\Monitor.exe -NoStart
uRun: [kdx] c:\program files\kontiki\KHost.exe -all
uRun: [updateMgr] "c:\program files\adobe\acrobat 7.0\reader\AdobeUpdateManager.exe" AcRdB7_0_9 -reboot 1
uRun: [Veoh] "c:\program files\veoh networks\veoh\VeohClient.exe" /VeohHide
uRun: []
uRun: [Clip] Recycled.exe -mon
uRun: [jsf8uiw3jnjgffght] c:\docume~1\rebecc~1\locals~1\temp\winlognn.exe
uRun: [tezrtsjhfr84iusjfo84f] c:\docume~1\rebecc~1\locals~1\temp\csrssc.exe
uRun: [nfr] rundll32.exe nfr.dll,ServiceMain /pid=6007
mRun: [igfxtray] c:\windows\system32\igfxtray.exe
mRun: [igfxhkcmd] c:\windows\system32\hkcmd.exe
mRun: [igfxpers] c:\windows\system32\igfxpers.exe
mRun: [SunJavaUpdateSched] "c:\program files\java\jre1.6.0_03\bin\jusched.exe"
mRun: [DMXLauncher] c:\program files\dell\media experience\DMXLauncher.exe
mRun: [ISUSPM Startup] "c:\program files\common files\installshield\updateservice\isuspm.exe" -startup
mRun: [ISUSScheduler] "c:\program files\common files\installshield\updateservice\issch.exe" -start
mRun: [RealTray] c:\program files\real\realplayer\RealPlay.exe SYSTEMBOOTHIDEPLAYER
mRun: [DLA] c:\windows\system32\dla\DLACTRLW.EXE
mRun: [Google Desktop Search] "c:\program files\google\google desktop search\GoogleDesktop.exe" /startup
mRun: [YeppStudioAgent] c:\program files\samsung\samsung media studio\SamsungMediaStudioAgent.exe
mRun: [EPSON Stylus DX5000 Series] c:\windows\system32\spool\drivers\w32x86\3\e_fatibve.exe /fu "c:\windows\temp\E_S9D.tmp" /EF "HKLM"
mRun: [MSKDetectorExe] c:\program files\mcafee\spamkiller\MSKDetct.exe /uninstall
mRun: [OM_Monitor] c:\program files\olympus\olympus master\FirstStart.exe
mRun: [4oD] "c:\program files\kontiki\KHost.exe" -all
mRun: [jsf8uiw3jnjgffght] c:\docume~1\rebecc~1\locals~1\temp\winlognn.exe
mRun: [winlogin] winlogin.exe
dRun: [CTFMON.EXE] c:\windows\system32\CTFMON.EXE
dRun: [Picasa Media Detector] c:\program files\picasa2\PicasaMediaDetector.exe
StartupFolder: c:\docume~1\rebecc~1\startm~1\programs\startup\micros~1.lnk - c:\program files\microsoft office\office\FINDFAST.EXE
StartupFolder: c:\docume~1\rebecc~1\startm~1\programs\startup\office~1.lnk - c:\program files\microsoft office\office\OSA.EXE
StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\adober~1.lnk - c:\program files\adobe\acrobat 7.0\reader\reader_sl.exe
StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\dellne~1.lnk - c:\windows\installer\{0240bdfb-2995-4a3f-8c96-18d41282b716}\Icon0240BDFB3.exe
StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\digita~1.lnk - c:\program files\digital line detect\DLG.exe
StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\xccstart.lnk - c:\windows\system\xccef090131.exe
IE: &Windows Live Search - c:\program files\windows live toolbar\msntb.dll/search.htm
IE: E&xport to Microsoft Excel - c:\progra~1\micros~3\office12\EXCEL.EXE/3000
IE: {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - {CAFEEFAC-0016-0000-0003-ABCDEFFEDCBC} - c:\program files\java\jre1.6.0_03\bin\ssv.dll
IE: {92780B25-18CC-41C8-B9BE-3C9C571A8263} - {FF059E31-CC5A-4E2E-BF3B-96E929D65503} - c:\progra~1\micros~3\office12\REFIEBAR.DLL
IE: {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - {FE54FA40-D68C-11d2-98FA-00C0F0318AFE} - c:\windows\system32\Shdocvw.dll
IE: {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - {53707962-6F74-2D53-2644-206D7942484F} - c:\progra~1\spybot~1\SDHelper.dll
DPF: {149E45D8-163E-4189-86FC-45022AB2B6C9} - [You must be registered and logged in to see this link.]
DPF: {193C772A-87BE-4B19-A7BB-445B226FE9A1} - [You must be registered and logged in to see this link.]
DPF: {20A60F0D-9AFA-4515-A0FD-83BD84642501} - [You must be registered and logged in to see this link.]
DPF: {4F1E5B1A-2A80-42CA-8532-2D05CB959537} - [You must be registered and logged in to see this link.]
DPF: {C3F79A2B-B9B4-4A66-B012-3EE46475B072} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0015-0000-0006-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0016-0000-0001-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0016-0000-0002-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0016-0000-0003-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CC450D71-CC90-424C-8638-1F2DBAC87A54} - [You must be registered and logged in to see this link.]
DPF: {DB7BF79A-FC51-4B5A-92BC-A65731174380} - [You must be registered and logged in to see this link.]
TCP: {194897B6-09F6-426F-874F-6B63386D22D1} = 212.139.132.24 212.139.132.25
Filter: application/x-internet-signup - {A173B69A-1F9B-4823-9FDA-412F641E65D6} - c:\program files\tiscali\tiscali internet\dlls\tiscalifilter.dll
Notify: igfxcui - igfxdev.dll
AppInit_DLLs: c:\progra~1\google\google~1\goec62~1.dll,jbsobl.dll,c:\progra~1\sophos\sophos~1\SOPHOS~1.DLL
LSA: Authentication Packages = msv1_0 c:\windows\system32\wvUljKaA
becksgilkes
Posts Posts : 16
OS OS : windows xp
Post by becksgilkes on Mon Feb 23, 2009 6:49 pm
FF - ProfilePath - c:\docume~1\rebecc~1\applic~1\mozilla\firefox\profiles\5akhjr8g.default\
FF - prefs.js: browser.search.selectedEngine - Ask
FF - prefs.js: network.proxy.http - localhost
FF - prefs.js: network.proxy.http_port - 7070
FF - prefs.js: network.proxy.type - 1
FF - component: c:\program files\mozilla firefox\components\GoogleDesktopMozilla.dll
FF - plugin: c:\program files\mozilla firefox\plugins\npGoogleGadgetPluginFirefoxWin.dll
FF - plugin: c:\program files\veoh networks\veoh\plugins\noreg\NPVeohVersion.dll
FF - plugin: c:\program files\viewpoint\viewpoint experience technology\npViewpoint.dll
FF - HiddenExtension: XUL Cache: {95F9D201-CECB-4C81-9D02-EFD26F8908FF} - c:\documents and settings\rebecca gilkes\local settings\application data\{95F9D201-CECB-4C81-9D02-EFD26F8908FF}
FF - HiddenExtension: XUL Cache: {AC013CF3-BAE3-42F2-8B16-9118A06692DB} - c:\documents and settings\anya gilkes-furness\local settings\application data\{ac013cf3-bae3-42f2-8b16-9118a06692db}\
R1 SAVOnAccessControl;SAVOnAccessControl;c:\windows\system32\drivers\savonaccesscontrol.sys [2009-2-20 104704]
R1 SAVOnAccessFilter;SAVOnAccessFilter;c:\windows\system32\drivers\savonaccessfilter.sys [2009-2-20 35584]
R2 SAVAdminService;Sophos Anti-Virus status reporter;c:\program files\sophos\sophos anti-virus\SAVAdminService.exe [2008-9-22 90112]
R2 SAVService;Sophos Anti-Virus;c:\program files\sophos\sophos anti-virus\SavService.exe [2008-8-21 118784]
S0 FSFW;F-Secure Firewall Driver;c:\windows\system32\drivers\fsdfw.sys --> c:\windows\system32\drivers\fsdfw.sys [?]
S0 TfFsMon;TfFsMon;c:\windows\system32\drivers\tffsmon.sys [2009-2-9 138336]
S0 TfSysMon;TfSysMon;c:\windows\system32\drivers\tfsysmon.sys [2009-2-9 138336]
S2 bvmsfjada;bvmsfjada;\??\c:\windows\system32\drivers\wwowuwxj.sys --> c:\windows\system32\drivers\wwowuwxj.sys [?]
S2 ThreatFire;ThreatFire;c:\program files\threatfire\tfservice.exe service --> c:\program files\threatfire\TFService.exe service [?]
S3 GoogleDesktopManager-061008-081103;Google Desktop Manager 5.7.806.10245;c:\program files\google\google desktop search\GoogleDesktop.exe [2006-8-30 29744]
S3 TfNetMon;TfNetMon;c:\windows\system32\drivers\tfnetmon.sys [2009-2-9 138336]
S4 SophosBootDriver;SophosBootDriver;c:\windows\system32\drivers\SophosBootDriver.sys [2009-2-20 14976]
============== File Associations ===============
txtfile="c:\windows\system32\nxtepad.exe" "%1"
2009-02-22 21:39 67,585 a------- c:\windows\system32\5A.tmp
2009-02-22 21:38 24,577 a------- c:\windows\system32\59.tmp
2009-02-22 21:38 168 a------- c:\windows\system32\55.tmp
2009-02-22 20:11 67,585 a------- c:\windows\system32\77.tmp
2009-02-22 20:11 38,913 a------- c:\windows\system32\76.tmp
2009-02-22 20:11 168 a------- c:\windows\system32\75.tmp
2009-02-22 20:10 67,585 a------- c:\windows\system32\71.tmp
2009-02-22 20:10 38,913 a------- c:\windows\system32\70.tmp
2009-02-22 20:10 168 a------- c:\windows\system32\6F.tmp
2009-02-22 20:09 67,585 a------- c:\windows\system32\6B.tmp
2009-02-22 20:09 38,913 a------- c:\windows\system32\6A.tmp
2009-02-22 20:09 168 a------- c:\windows\system32\69.tmp
2009-02-22 20:08 67,585 a------- c:\windows\system32\65.tmp
2009-02-22 20:08 38,913 a------- c:\windows\system32\64.tmp
2009-02-22 20:08 168 a------- c:\windows\system32\63.tmp
2009-02-22 20:07 0 a------- c:\windows\system32\61.tmp
2009-02-22 20:06 67,585 a------- c:\windows\system32\5D.tmp
2009-02-22 20:06 25,601 a------- c:\windows\system32\5C.tmp
2009-02-22 20:06 168 a------- c:\windows\system32\5B.tmp
2009-02-22 20:05 47,104 a------- c:\windows\system32\reader_s.exe
2009-02-22 20:04 67,585 a------- c:\windows\system32\53.tmp
2009-02-22 20:04 25,601 a------- c:\windows\system32\4F.tmp
2009-02-22 20:04 168 a------- c:\windows\system32\4D.tmp
2009-02-22 18:27 67,585 a------- c:\windows\system32\58.tmp
2009-02-22 18:27 24,577 a------- c:\windows\system32\57.tmp
2009-02-22 18:27 168 a------- c:\windows\system32\56.tmp
2009-02-22 18:26 11,294 a------- c:\windows\system32\54.tmp
2009-02-22 18:26 67,585 a------- c:\windows\system32\52.tmp
2009-02-22 18:26 24,577 a------- c:\windows\system32\51.tmp
2009-02-22 18:26 168 a------- c:\windows\system32\50.tmp
2009-02-22 18:25 4,094 a------- c:\windows\system32\4E.tmp
2009-02-22 18:25 67,585 a------- c:\windows\system32\4C.tmp
2009-02-22 18:25 7,041 a------- c:\windows\system32\4B.tmp
2009-02-22 18:25 168 a------- c:\windows\system32\4A.tmp
2009-02-22 17:21 67,585 a------- c:\windows\system32\49.tmp
2009-02-22 17:20 38,913 a------- c:\windows\system32\48.tmp
2009-02-22 17:20 168 a------- c:\windows\system32\2B.tmp
2009-02-22 16:50 130,104 a------- c:\windows\system32\sdccoinstaller.dll
2009-02-22 16:49 --d----- c:\program files\common files\Cisco Systems
2009-02-22 16:49 23,552 a------- c:\windows\system32\SophosBootTasks.exe
2009-02-22 16:49 --d----- c:\program files\Sophos
2009-02-22 16:49 --d----- c:\docume~1\alluse~1\applic~1\Sophos
2009-02-22 16:21 67,585 -------- c:\windows\system32\40.tmp
2009-02-22 16:21 25,601 -------- c:\windows\system32\3F.tmp
2009-02-22 16:21 212 -------- c:\windows\system32\22.tmp
2009-02-22 16:04 0 -------- c:\windows\system32\47.tmp
2009-02-22 16:04 0 -------- c:\windows\system32\46.tmp
2009-02-22 16:04 0 -------- c:\windows\system32\45.tmp
2009-02-22 16:04 0 -------- c:\windows\system32\44.tmp
2009-02-22 16:04 6,974 -------- c:\windows\system32\43.tmp
2009-02-22 16:03 212 -------- c:\windows\system32\42.tmp
2009-02-22 15:52 --d----- c:\docume~1\rebecc~1\applic~1\Malwarebytes
2009-02-22 15:48 406,016 -------- c:\windows\system32\tmpxccacj0.exe
2009-02-22 12:58 33,351 a------- c:\windows\system32\drivers\str.sys
2009-02-22 12:58 67,585 -------- c:\windows\system32\41.tmp
2009-02-22 12:58 32,768 -------- c:\windows\system32\umtcdtw.sys
2009-02-22 12:57 212 -------- c:\windows\system32\3D.tmp
2009-02-22 11:34 67,585 -------- c:\windows\system32\3E.tmp
2009-02-22 11:34 168 -------- c:\windows\system32\3B.tmp
2009-02-22 11:11 67,585 -------- c:\windows\system32\3C.tmp
2009-02-22 11:11 168 -------- c:\windows\system32\3A.tmp
2009-02-22 11:03 130 -------- c:\windows\adobe.bat
2009-02-22 11:03 67,585 -------- c:\windows\system32\39.tmp
2009-02-22 11:03 25,601 -------- c:\windows\system32\38.tmp
2009-02-22 11:03 168 -------- c:\windows\system32\35.tmp
2009-02-22 10:26 67,585 -------- c:\windows\system32\37.tmp
2009-02-22 10:26 25,601 -------- c:\windows\system32\36.tmp
2009-02-22 10:26 212 -------- c:\windows\system32\34.tmp
2009-02-22 10:16 15,504 a------- c:\windows\system32\drivers\mbam.sys
2009-02-22 10:16 38,496 a------- c:\windows\system32\drivers\mbamswissarmy.sys
2009-02-22 10:16 --d----- c:\program files\Malwarebytes' Anti-Malware
2009-02-22 10:16 --d----- c:\docume~1\alluse~1\applic~1\Malwarebytes
2009-02-22 10:14 2,524 a------- C:\autorun.PNF
2009-02-21 16:24 33,792 -------- c:\windows\syssvc.exe
2009-02-21 16:18 67,585 -------- c:\windows\system32\33.tmp
2009-02-21 16:18 25,601 -------- c:\windows\system32\30.tmp
2009-02-21 16:18 168 -------- c:\windows\system32\2F.tmp
2009-02-21 16:11 0 -------- c:\windows\system32\nfr.gpref
2009-02-21 16:11 0 -------- c:\windows\system32\nfr.assembly
2009-02-21 16:11 67,585 -------- c:\windows\system32\2E.tmp
2009-02-21 16:11 25,601 -------- c:\windows\system32\20.tmp
2009-02-21 16:11 168 -------- c:\windows\system32\1F.tmp
2009-02-21 15:54 67,585 -------- c:\windows\system32\1D.tmp
2009-02-21 15:54 0 -------- c:\windows\system32\1C.tmp
2009-02-21 15:54 168 -------- c:\windows\system32\1B.tmp
2009-02-21 15:37 --d----- c:\program files\common files\ODBC
2009-02-21 15:31 --d----- c:\windows\SHELLNEW
2009-02-21 15:23 10,752 -------- c:\windows\system32\nfr.dll
2009-02-21 15:12 676,352 -------- c:\windows\system32\rtl60.bpl
2009-02-21 15:12 406,016 -------- c:\windows\system32\tmpxccacj1.exe
2009-02-21 15:11 67,585 -------- c:\windows\system32\1A.tmp
2009-02-21 15:11 24,577 -------- c:\windows\system32\19.tmp
2009-02-21 15:11 168 -------- c:\windows\system32\18.tmp
2009-02-21 14:08 --d----- c:\docume~1\alluse~1\applic~1\Avg8
2009-02-20 18:34 104,704 a------- c:\windows\system32\drivers\savonaccesscontrol.sys
2009-02-20 18:34 35,584 a------- c:\windows\system32\drivers\savonaccessfilter.sys
2009-02-20 18:34 14,976 a------- c:\windows\system32\drivers\SophosBootDriver.sys
2009-02-20 18:34 --d----- C:\escwsa
2009-02-20 10:22 5,044 -------- c:\windows\system32\tmp.reg
2009-02-19 12:04 28,573 -------- c:\windows\system32\32.tmp
2009-02-19 12:04 8,704 -------- c:\windows\system32\31.tmp
2009-02-19 12:04 128 -------- c:\windows\system32\2C.tmp
2009-02-19 12:04 217 -------- c:\windows\system32\xcchit32.ini
2009-02-19 10:11 182,656 -------- c:\windows\system32\dllcache\ndis.sys
2009-02-19 10:10 --d----- c:\windows\system32\inf
2009-02-19 10:10 156,733 -------- c:\windows\system32\2D.tmp
2009-02-19 10:10 599 -------- c:\windows\xccwinsys.ini
2009-02-19 10:10 8,192 -------- c:\windows\system32\24.tmp
2009-02-19 10:10 25,601 -------- c:\windows\system32\21.tmp
2009-02-19 10:10 168 -------- c:\windows\system32\1E.tmp
2009-02-18 15:08 181,248 a--shro- c:\windows\Recycled.exe
2009-02-10 15:44 162,397 -------- c:\windows\system32\2A.tmp
2009-02-10 15:44 32,256 a---h--- c:\documents and settings\rebecca gilkes\xmxwug.exe
2009-02-10 15:44 24,577 -------- c:\windows\system32\26.tmp
2009-02-10 15:44 128 -------- c:\windows\system32\23.tmp
2009-02-09 19:38 164,708 -------- c:\windows\system32\29.tmp
2009-02-09 19:38 29,184 -------- c:\windows\system32\28.tmp
2009-02-09 19:38 172 -------- c:\windows\system32\27.tmp
2009-02-09 19:26 0 -------- c:\windows\system32\25.tmp
2009-02-09 19:21 32,256 a---h--- c:\documents and settings\rebecca gilkes\jixv.exe
2009-02-09 19:15 164,708 -------- c:\windows\system32\17.tmp
2009-02-09 19:15 29,184 -------- c:\windows\system32\15.tmp
2009-02-09 19:15 172 -------- c:\windows\system32\13.tmp
2009-02-09 19:10 32,256 a---h--- c:\documents and settings\rebecca gilkes\bjgicy.exe
2009-02-09 19:10 66,560 -------- c:\windows\system32\secupdat.dat
2009-02-09 19:10 616 -------- c:\windows\system32\16.tmp
2009-02-09 19:08 138,336 -------- c:\windows\system32\drivers\wanatw4.sys
2009-02-09 19:08 138,336 -------- c:\windows\system32\drivers\tfsysmon.sys
2009-02-09 19:08 138,336 -------- c:\windows\system32\drivers\tfnetmon.sys
2009-02-09 19:08 138,336 -------- c:\windows\system32\drivers\tffsmon.sys
2009-02-09 19:03 164,708 -------- c:\windows\system32\12.tmp
2009-02-09 19:03 29,184 -------- c:\windows\system32\11.tmp
2009-02-09 19:03 172 -------- c:\windows\system32\10.tmp
2009-02-03 19:56 4 -------- c:\windows\system32\gaopdxcounter
2009-02-02 19:16 285 a------- c:\windows\system32\MRT.INI
2009-02-01 18:57 43,008 -------- c:\windows\system32\stu2.exe
2009-01-29 17:01 388,944 -------- c:\windows\system32\AaKjlUvw.ini2
2009-02-19 10:11 182,656 -------- c:\windows\system32\drivers\ndis.sys
2009-02-06 17:41 5,852 -------- c:\windows\system32\KGyGaAvL.sys
2009-02-02 13:19 26,112 -------- c:\windows\system32\userinit.exe
2009-01-19 17:21 129,024 -------- c:\windows\system32\wbaeeurq.dll
2009-01-19 17:21 129,024 -------- c:\windows\system32\_jbsobl.dll
2009-01-16 21:35 3,594,752 -------- c:\windows\system32\dllcache\mshtml.dll
2008-12-19 09:10 70,656 -------- c:\windows\system32\dllcache\ie4uinit.exe
2008-12-19 09:10 13,824 -------- c:\windows\system32\dllcache\ieudinit.exe
2008-12-19 05:25 634,024 -------- c:\windows\system32\dllcache\iexplore.exe
2008-12-19 05:23 161,792 -------- c:\windows\system32\dllcache\ieakui.dll
2008-12-11 10:57 333,952 -------- c:\windows\system32\dllcache\srv.sys
2006-09-09 12:17 0 ac------ c:\docume~1\rebecc~1\applic~1\wklnhst.dat
2006-09-13 15:43 181,248 a--shro- c:\windows\Recycled.exe
============= FINISH: 21:48:33.82 ===============
becksgilkes
Posts Posts : 16
OS OS : windows xp
Post by Belahzur on Mon Feb 23, 2009 6:54 pm
Omg, what a mess.
DDS tells me Sophos is outdated, you can't expect to stay safe if your AV isn't upto date.
I'm not sure what do say here. There is so much damage done here, I'm not sure we can clean it at all.
Please download [You must be registered and logged in to see this link.] and save it to your Desktop. Please double-click GooredFix.exe on your Desktop to run it. Select 2. Fix Goored by typing 2 and pressing Enter. Make sure all instances of Firefox are closed at this point. Type y at the prompt and press Enter again. A log will open, please post the contents of that log in your next reply (it can also be found on your desktop, called GooredLog.txt).
Post by becksgilkes on Mon Feb 23, 2009 7:05 pm
I've downloaded it on my friends computer and copied it onto a usb pen but it won't let me copy it from the usb pen onto the infected computer.
becksgilkes
Posts Posts : 16
OS OS : windows xp
Post by Belahzur on Mon Feb 23, 2009 7:11 pm
Lets see if we can get this running. Please read very carefully.
  • Download combofix from here
  • Before you start the download, please rename Combofix seen like below.
  • Tools->Options->Main tab
  • Set to "Always ask me where to Save the files".
  • Please disable your local AV (Anti-virus) See [You must be registered and logged in to see this link.] for how to disable your AV. (Sophos)
Post by becksgilkes on Mon Feb 23, 2009 7:18 pm
thats great. Really dumb question though as I'm working two computers at the moment....
Do I download combofix (or combo-fix once renamed) to friends computer and then copy file onto usb pen and transfer it to infected computer and follow instructions from then on...
I know it may seem like a dumb question but as I can't connect infected computer to internet then thats my only option, unless I carry on tomorrow night. Let me know as I don't want to waste your time if it has to be downloaded onto infected computer.
becksgilkes
Posts Posts : 16
OS OS : windows xp
Post by Belahzur on Mon Feb 23, 2009 7:21 pm
Don't take this the wrong way, but as I said, Virut cannot be fixed, and I would rather you format than go through this because it just seems like a waste of time to me. But, I'll do it anyway.
Protect the stick using this: Plug the stick into the clean machine.
Please download Flash_Disinfector from [You must be registered and logged in to see this link.]
  • First, download it to your desktop.
  • Now double click it to run it and will tell it you what to do when you open it.
  • It will temporarily kill explorer.exe and your desktop will go blank.
  • Let Flash_Disinfector do it's job and it will restart explorer.exe for you.
  • It will make a dummy autorun.inf in the root of every drive.
  • You can now delete Flash_Disinfector.exe.
Then transfer Combo-fix onto it and use it on the infected machine if it will run.
Post by becksgilkes on Mon Feb 23, 2009 7:26 pm
If its a waste of time then I would rather format to be honest as I'd rather not flog a dead horse. I do appreciate your patience so please let me know what to do to format. My only question is if Virut can't be fixed etc then is there any point to format, i.e. will I be able to use my computer without any risks in future or will it still have virus in it. Sorry, yet again, for seeming so dumb, but I am really really new to all this and find it quite scary.
becksgilkes
Posts Posts : 16
OS OS : windows xp
Post by Belahzur on Mon Feb 23, 2009 7:28 pm
Formatting will wipe the machine clean and replace all the bad files now with clean files once the format is done.
I posted some links here for you back on page 1.
Post by becksgilkes on Mon Feb 23, 2009 7:51 pm
So, am I right in thinking that as my computer is a Dell, I should go on to their website and check how to format the computer, and then just follow instructions?
becksgilkes
Posts Posts : 16
OS OS : windows xp
Post by Belahzur on Mon Feb 23, 2009 7:54 pm
If they have a guide for that, then yes.
If not, I can supply a link or two.
Post by becksgilkes on Mon Feb 23, 2009 7:58 pm
I've found a "how to restore your computer software to factory settings", would that be the same as formating it?
becksgilkes
Posts Posts : 16
OS OS : windows xp
Post by Belahzur on Mon Feb 23, 2009 8:01 pm
That should do, hopefully.
Give it a try.
Post by becksgilkes on Mon Feb 23, 2009 8:25 pm
I've followed the instructions and it seems to have worked. Can I assume that the computer is now not infected or will there be some underlying threats still hidden. If it is fine to go, I will sort out the internet connection, download anti malware, a good AV, super anti spyware etc before I do anything else.
becksgilkes
Posts Posts : 16
OS OS : windows xp
Post by Belahzur on Mon Feb 23, 2009 8:36 pm
Yep, it should be fine now.
Post by becksgilkes on Mon Feb 23, 2009 9:20 pm
thank you thank you thank you thank you thank you thank you...........
You are worth your weight in gold. I will complete the feedback form now.
"If your computer is down and not working at all, who you gonna call? GEEKPOLICE!"
becksgilkes
Posts Posts : 16
OS OS : windows xp
