System Security malware problem - Part 1
Solved Re: System Security malware problem - Part 1
Post by Belahzur on Fri Feb 20, 2009 10:05 pm
Select yes.
Points Points : 245069
Post by Enforcer on Fri Feb 20, 2009 10:24 pm
Well, as far as I know, my computer is working just fine. Your patience with me and your quick, and I mean very quick replies, were greatly appreciated. I followed your instructions word for word and every time you had a fix for my problem. Thank you so much for saving me from literally buying another computer. I had quite the scare for a while as I thought I would never have my computer running properly again. You just don't get this kind of help anymore. You guys are awesome.
Enforcer
Posts Posts : 27
Joined Joined : 2009-02-19
OS OS : windows xp version 2002
Points Points : 28484
Post by Doctor Inferno on Mon Jul 06, 2009 3:40 am
Since this issue has been addressed, a "solved" tag will be added and this topic will be closed.
Everyone else, please open a [You must be registered and logged in to see this link.] for your questions.
Points Points : 104600
