cpu problems
Solved cpu problems
Post by ba2269 on 9th February 2009, 12:30 am
Hello. I have been getting some up and down readings on my cpu usage. I know my system is limited and outdated but I don't do much outside of just browsing and limited gaming. I thought this racing of my cpu was only happening when looking at videos and things like that. But I started noticing that it was happening on and off even if I was not using the computer. I originally thought it was my limited RAM on this machine but not so sure now. I was wondering if this is a widespread problem with a machine like I have or is there something I can do? Just wondering if its worth looking into. thx.
model is a compaq presario intel(R) pentium(R) 4 cpu 2.26ghz 512 ram
ba2269
Posts Posts : 28
Joined Joined : 2009-02-06
OS OS : windows xp
Points Points : 28725
Solved Re: cpu problems
Post by Belahzur on 9th February 2009, 12:34 am
512mb of RAM is probably your problem.
In my opinion, XP needs atleast 1gb to run without the CPU being hogged constantly. LMBO or ROFL
Points Points : 245091
Post by ba2269 on 9th February 2009, 1:13 am
So I'm pretty sure when I looked up an upgrade in RAM I could not find one for this machine. Is it likely for a machine this old? The other thing that bothers me is that it makes that hung up noise (like a plane) even when not being used. how can that be with nothing running? thx.
ba2269
Posts Posts : 28
OS OS : windows xp
Post by Belahzur on 9th February 2009, 1:49 am
While you think nothing is running, a lot is running.
Judging from your first Hijack This log, there is a lot running at startup and they run as a process.
Press Start > Run, type in msconfig and press enter.
Under the "Startrup" tab, untick everything that isn't needed (itunes, etc)
If your not confident doing this, submit a new Hijack This log and we'll do it that way.
Post by ba2269 on 9th February 2009, 2:00 am
I had no problems getting to that but unsure with programs like realsched, coloreal, jusched,promon, qtask, wkdetect, wkssb,carpserv, directcd and money express.
ba2269
Posts Posts : 28
OS OS : windows xp
Post by Belahzur on 9th February 2009, 2:04 am
Post a new Hijack This log here then and we'll see what we can do.
Post by ba2269 on 9th February 2009, 2:12 am
Scan saved at 9:11:30 PM, on 2/8/2009
MSIE: Internet Explorer v7.00 (7.00.6000.16762)
C:\WINDOWS\system32\csrss.exe
C:\Program Files\COMPAQ\Compaq Advisor\bin\compaq-rba.exe
C:\Program Files\Common Files\Portrait Displays\Shared\DTSRVC.exe
C:\Program Files\Norton Internet Security\Engine\16.2.0.7\ccSvcHst.exe
C:\WINDOWS\System32\nvsvc32.exe
C:\WINDOWS\System32\MsPMSPSv.exe
C:\WINDOWS\System32\alg.exe
C:\PROGRA~1\QUICKENW\QAGENT.EXE
C:\WINDOWS\system32\PROMon.exe
C:\WINDOWS\System32\NMSSvc.exe
C:\Program Files\Portrait Displays\HP My Display\DTHtml.exe
C:\Program Files\COMPAQ\Easy Access Button Support\StartEAK.exe
C:\WINDOWS\system32\carpserv.exe
C:\Program Files\Compaq\Easy Access Button Support\CPQEADM.EXE
C:\Program Files\Common Files\Portrait Displays\Shared\HookManager.exe
C:\Compaq\EAKDRV\EAUSBKBD.EXE
C:\PROGRA~1\Compaq\EASYAC~1\BttnServ.exe
C:\WINDOWS\system32\mrtMngr.EXE
C:\Program Files\Common Files\Microsoft Shared\Works Shared\wkcalrem.exe
C:\WINDOWS\PCHealth\HelpCtr\Binaries\MSConfig.exe
C:\Documents and Settings\RALPH\Desktop\hijackgpthis.exe
C:\WINDOWS\System32\wbem\wmiprvse.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Bar = http://www.yahoo.com/search/ie.html
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.yahoo.com/
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Bar = http://rd.yahoo.com/customize/yessentials_cq/defaults/sb/*http://www.yahoo.com/search/ie.html
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKCU\Software\Microsoft\Internet Explorer\SearchURL,(Default) = http://us.rd.yahoo.com/customize/ie/defaults/su/msgr8/*http://www.yahoo.com
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Window Title = Microsoft Internet Explorer provided by Compaq
R3 - URLSearchHook: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll
N3 - Netscape 7: user_pref("browser.startup.homepage", "http://home.netscape.com/bookmark/7_0/home.html"); (C:\Documents and Settings\RALPH\Application Data\Mozilla\Profiles\default\r9eiari2.slt\prefs.js)
N3 - Netscape 7: user_pref("browser.search.defaultengine", "engine://C%3A%5CProgram%20Files%5CNetscape%5CNetscape%206%5Csearchplugins%5CSBWeb_01.src"); (C:\Documents and Settings\RALPH\Application Data\Mozilla\Profiles\default\r9eiari2.slt\prefs.js)
O2 - BHO: Yahoo! Toolbar Helper - {02478D38-C3F9-4EFB-9B51-7695ECA05670} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll
O2 - BHO: PCTools Site Guard - {5C8B2A36-3DB1-42A4-A3CB-D426709BBFEB} - C:\PROGRA~1\SPYWAR~2\tools\iesdsg.dll
O2 - BHO: Symantec NCO BHO - {602ADB0E-4AFF-4217-8AA1-95DAC4DFA408} - C:\Program Files\Norton Internet Security\Engine\16.2.0.7\coIEPlg.dll
O2 - BHO: Symantec Intrusion Prevention - {6D53EC84-6AAE-4787-AEEE-F4628F01010C} - C:\Program Files\Norton Internet Security\Engine\16.2.0.7\IPSBHO.DLL
O2 - BHO: Java(tm) Plug-In SSV Helper - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre6\bin\ssv.dll
O2 - BHO: PCTools Browser Monitor - {B56A7D7D-6927-48C8-A975-17DF180C71AC} - C:\PROGRA~1\SPYWAR~2\tools\iesdpb.dll
O2 - BHO: (no name) - {FDD3B846-8D59-4ffb-8758-209B6AD74ACC} - C:\Program Files\Microsoft Money\System\mnyviewer.dll
O3 - Toolbar: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll
O3 - Toolbar: Norton Toolbar - {7FEBEFE3-6B19-4349-98D2-FFB09D4B49CA} - C:\Program Files\Norton Internet Security\Engine\16.2.0.7\coIEPlg.dll
O4 - HKLM\..\Run: [UMonit] C:\WINDOWS\system32\umonit.exe
O4 - HKLM\..\Run: [WCOLOREAL] "C:\Program Files\COMPAQ\Coloreal\coloreal.exe"
O4 - HKLM\..\Run: [srmclean] C:\Cpqs\Scom\srmclean.exe
O4 - HKLM\..\Run: [QAGENT] C:\PROGRA~1\QUICKENW\QAGENT.EXE
O4 - HKLM\..\Run: [PROMon.exe] PROMon.exe
O4 - HKLM\..\Run: [PerfectOptimizer] C:\Program Files\Perfect Optimizer\PerfectOptimizer.exe
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE NvQTwk,NvCplDaemon initialize
O4 - HKLM\..\Run: [Microsoft Works Update Detection] C:\Program Files\Microsoft Works\WkDetect.exe
O4 - HKLM\..\Run: [Microsoft Works Portfolio] C:\Program Files\Microsoft Works\WksSb.exe /AllUsers
O4 - HKLM\..\Run: [DT HPW] C:\Program Files\Portrait Displays\HP My Display\DTHtml.exe -startup_folder
O4 - HKLM\..\Run: [CPQEASYACC] C:\Program Files\COMPAQ\Easy Access Button Support\StartEAK.exe
O4 - HKLM\..\Run: [CARPService] carpserv.exe
O4 - HKLM\..\Run: [AdaptecDirectCD] "C:\Program Files\Roxio\Easy CD Creator 5\DirectCD\DirectCD.exe"
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 9.0\Reader\Reader_sl.exe"
O4 - HKCU\..\Run: [MsnMsgr] "C:\Program Files\MSN Messenger\MsnMsgr.Exe" /background
O4 - HKCU\..\Run: [MoneyAgent] "C:\Program Files\Microsoft Money\System\Money Express.exe"
O4 - Global Startup: Microsoft Works Calendar Reminders.lnk = ?
O9 - Extra button: Spyware Doctor - {2D663D1A-8670-49D9-A1A5-4C56B4E14E84} - C:\PROGRA~1\SPYWAR~2\tools\iesdpb.dll
O9 - Extra button: PokerStars - {3AD14F0C-ED16-4e43-B6D8-661B03F6A1EF} - C:\Program Files\PokerStars\PokerStarsUpdate.exe
O9 - Extra button: Real.com - {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - C:\WINDOWS\System32\Shdocvw.dll
O9 - Extra button: MoneySide - {E023F504-0C5A-4750-A1E7-A9046DEA8A21} - C:\Program Files\Microsoft Money\System\mnyviewer.dll
O12 - Plugin for .spop: C:\Program Files\Internet Explorer\Plugins\NPDocBox.dll
O14 - IERESET.INF: START_PAGE_URL=http://store.presario.net/scripts/redirectors/presario/storeredir2.dll?s=consumerfav&c=2c02&lc=0409
O16 - DPF: {11260943-421B-11D0-8EAC-0000C07D88CF} (iPIX ActiveX Control) - http://www.ipix.com/viewers/ipixx.cab
O16 - DPF: {1695C611-186A-4355-B777-0D85B325F07F} - http://espn.go.com/espnmotion/espnmotion.cab
O16 - DPF: {17492023-C23A-453E-A040-C7C580BBF700} (Windows Genuine Advantage Validation Tool) - http://go.microsoft.com/fwlink/?linkid=39204
O16 - DPF: {30528230-99f7-4bb4-88d8-fa1d4f56a2ab} (YInstStarter Class) - C:\Program Files\Yahoo!\Common\yinsthelper.dll
O16 - DPF: {352797A0-EFD0-4FA6-B229-145120EA4B8A} (Walt Disney Internet Group Hardware Control) - https://disneyblast.go.com/v3/setup/activex/DIGHardwareControl.cab
O16 - DPF: {41F17733-B041-4099-A042-B518BB6A408C} - http://a1540.g.akamai.net/7/1540/52/20021205/qtinstall.info.apple.com/borris/us/win/QuickTimeInstaller.exe
O16 - DPF: {54B52E52-8000-4413-BD67-FC7FE24B59F2} (EARTPatchX Class) - http://www.ea.com/downloads/rtpatch/v2/EARTPX.cab
O16 - DPF: {62475759-9E84-458E-A1AB-5D2C442ADFDE} - http://a1540.g.akamai.net/7/1540/52/20031216/qtinstall.info.apple.com/mickey/us/win/QuickTimeInstaller.exe
O16 - DPF: {644E432F-49D3-41A1-8DD5-E099162EEEC5} (Symantec RuFSI Utility Class) - http://security.symantec.com/sscv6/SharedContent/common/bin/cabsa.cab
O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} (MUWebControl Class) - http://update.microsoft.com/microsoftupdate/v6/V5Controls/en/x86/client/muweb_site.cab?1124137993031
O16 - DPF: {AB29A544-D6B4-4E36-A1F8-D3E34FC7B00A} - http://install.wildtangent.com/bgn/partners/wtgeneric/lilostitchpinball/install.cab
O16 - DPF: {C2FCEF52-ACE9-11D3-BEBD-00105AA9B6AE} (Symantec RuFSI Registry Information Class) - http://security.symantec.com/SSC/SharedContent/common/bin/cabsa.cab
O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - http://fpdownload2.macromedia.com/get/shockwave/cabs/flash/swflash.cab
O16 - DPF: {E77C0D62-882A-456F-AD8F-7C6C9569B8C7} - https://www-secure.symantec.com/techsupp/activedata/ActiveData.cab
O18 - Protocol: symres - {AA1061FE-6C41-421F-9344-69640C9732AB} - C:\Program Files\Norton Internet Security\Engine\16.2.0.7\coIEPlg.dll
O18 - Filter hijack: text/html - (no CLSID) - (no file)
O23 - Service: Compaq Advisor (Compaq_RBA) - NeoPlanet - C:\Program Files\COMPAQ\Compaq Advisor\bin\compaq-rba.exe
O23 - Service: Portrait Displays Display Tune Service (DTSRVC) - Unknown owner - C:\Program Files\Common Files\Portrait Displays\Shared\DTSRVC.exe
O23 - Service: Intel(R) NMS (NMSSvc) - Intel Corporation - C:\WINDOWS\System32\NMSSvc.exe
O23 - Service: Norton Internet Security - Symantec Corporation - C:\Program Files\Norton Internet Security\Engine\16.2.0.7\ccSvcHst.exe
O23 - Service: NVIDIA Driver Helper Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\System32\nvsvc32.exe
End of file - 12182 bytes
ba2269
Posts Posts : 28
OS OS : windows xp
Post by Belahzur on 9th February 2009, 2:17 am
Download ATF Cleaner
Reboot normally.
Startup should be somewhat faster, maybe not much, depends on how much work we have taken off the processor.
Let me know if it seems faster.
Post by ba2269 on 9th February 2009, 3:06 am
It does seem a little smoother even though the cpu will still takeoff even though RAM is telling me its using half of capacity under commit charge. I have tried to keep all temp internet files and cookies clean every so often but I appreciate the help and I am going to keep an eye on this machine's running. thx again.
ba2269
Posts Posts : 28
OS OS : windows xp
