Netgear Wireless DG834G v4 wireless problem
Post by kalak278 on 7th February 2009, 11:15 am
My Netgear Router recently stopped connecting to the internet.. My router shows all lights Green, (Power, Wireless, DSL) But not the Internet Light. The Router connects straight to the laptop I am using, But just will not connect to the internet, Like I try to use the web browser and it says page can not be displayed. This occured when i reset the factory settings, however this shouldnt have been an issue because I've seen people reset the settings before and it work fine.
Please help!
kalak278
Posts Posts : 3
Joined Joined : 2009-02-07
OS OS : netgear
Points Points : 28610
Re: Netgear Wireless DG834G v4 wireless problem
Post by Doctor Inferno on 7th February 2009, 1:06 pm
What kind of reset did you use? Did you try pressing the small button at the back of the router?
Post by kalak278 on 7th February 2009, 1:33 pm
Yes, thats the button i pressed to reset it firstly
kalak278
Posts Posts : 3
OS OS : netgear
Post by Digitalocksmith on 9th February 2009, 7:28 am
If your modem is inbuilt within the router, you will need to re-configure all of your ISP settings again after the reset.
You can either do this manually with username and password or use the install disc that was supplied by your ISP!
Regards
Digitalocksmith
Posts Posts : 625
Joined Joined : 2007-12-22
Points Points : 48941
