Problems with my other computer
Page 1 of 2 1, 2  Next
Solved Problems with my other computer
Post by spacephrawgg on 5th February 2009, 4:23 pm
I'm not sure how I contracted the problem(s);
I just removed all things viewpoint (i am in safe mode btw) but my computer runs awfully slowly still.
I have Macafee, which chronically refuses to a) run, and b) find anything ever. I'm about to uninstall ad-aware because as I recently found on another computer, it slows everything down.
I have yet to install spyware doctor and will shortly.
Can you advise? Thanks awfully much (again) 8D!
spacephrawgg
Posts Posts : 210
Joined Joined : 2009-02-02
Points Points : 29491
Solved Re: Problems with my other computer
Post by Belahzur on 5th February 2009, 4:50 pm
Need a HJT log please.
Points Points : 245101
Post by spacephrawgg on 5th February 2009, 5:09 pm
Please remind me how I get/make an HJT log.
Also, FF keeps crashing every so often for no reason.
spacephrawgg
Posts Posts : 210
Post by Belahzur on 5th February 2009, 5:11 pm
You are running an old version of Hijack This, and we need to use the new version before we can do anything else.
Post by spacephrawgg on 5th February 2009, 6:38 pm
The link you gave doesnt work 8>(
spacephrawgg
Posts Posts : 210
Post by Belahzur on 5th February 2009, 7:03 pm
A rootkit is blocking it, so lets do a rootkit scan.
2. Now, start The Avenger program by clicking on its icon on your desktop.
  • Leave the script box empty.
3. Please copy/paste the content of c:\avenger.txt into your reply.
Post by spacephrawgg on 6th February 2009, 4:46 am
I am unable to connect to either recommended link.
spacephrawgg
Posts Posts : 210
Post by spacephrawgg on 6th February 2009, 4:54 am
Sorry for the double post - I should also point out that my McAfee thing is giving me trouble too. I have McAfee site advisor installed and it keeps giving me this popup that says it's been updated and it asks if I want to make Yahoo my default search tool, and "enable [something or other]" and something else and if i click "finish" at the bottom, it crashes FF, so I X out of it but then it opens a brand new FF window opening to the FF/google start page. On my other computer I have Norton and don't have these problems. Is this a bug or is McAfee crap?
spacephrawgg
Posts Posts : 210
Post by Belahzur on 6th February 2009, 4:58 pm
Don't know, but we need to get the avenger on your machine.
Can you get the avenger from here?
Post by spacephrawgg on 7th February 2009, 12:59 am
Correction, I did get it to work. I will post the log file shortly.
spacephrawgg
Posts Posts : 210
Post by Belahzur on 7th February 2009, 1:04 am
Okay, standing by. Smile
Post by spacephrawgg on 7th February 2009, 5:12 pm
I think this is what you asked for:
Platform: Windows XP
Rootkit scan active.
Hidden driver "TDSSserv.sys" found!
ImagePath: \systemroot\system32\drivers\TDSSmxst.sys
Driver disabled successfully.
Rootkit scan completed.
Completed script processing.
Finished! Terminate.
spacephrawgg
Posts Posts : 210
Post by Belahzur on 7th February 2009, 5:25 pm
We need to use the avenger again to kill the rootkit.
Drivers to delete:
TDSSserv.sys
Files to delete:
C:\WINDOWS\system32\drivers\TDSSmxst.sys
Post by spacephrawgg on 7th February 2009, 6:34 pm
Here's the log file:
No rootkits found!
Driver "TDSSserv.sys" deleted successfully.
Error: file "C:\WINDOWS\system32\drivers\TDSSmxst.sys" not found!
Deletion of file "C:\WINDOWS\system32\drivers\TDSSmxst.sys" failed!
--> the object does not exist
Also simultaneously. McAfee periodically tells me it has found and blocked this "virando" trojan (not sure if that's the real name of it.)
spacephrawgg
Posts Posts : 210
Post by Belahzur on 7th February 2009, 6:43 pm
It's okay, now the rootkit is gone and files are unconvered, Mcafee will go crazy.
Please don't let Mcafee delete anything or do anything for us, I will do it all, this way I know where we stand and if any files remain.
  • Double click DDS.scr to run
  • When complete, DDS.txt will open.
  • Save the report to your Desktop.
Post by spacephrawgg on 7th February 2009, 6:52 pm
McAffee won't stop reporting that vundo.gen.ab trojan and wont allow me to stop McAffee itself.
Meanwhile, here's the DDS log file, in a few parts:
Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.1023.335 [GMT -5:00]
AV: McAfee VirusScan *On-access scanning enabled* (Updated)
FW: McAfee Personal Firewall *enabled*
C:\WINDOWS\system32\svchost -k rpcss
C:\WINDOWS\system32\svchost.exe -k NetworkService
C:\WINDOWS\system32\svchost.exe -k LocalService
C:\WINDOWS\System32\wltrysvc.exe
C:\WINDOWS\System32\bcmwltry.exe
C:\Program Files\Lavasoft\Ad-Aware\aawservice.exe
C:\WINDOWS\system32\NOTEPAD.EXE
C:\Program Files\Apoint\Apoint.exe
C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe
C:\WINDOWS\system32\WLTRAY.exe
C:\Program Files\CyberLink\PowerDVD\DVDLauncher.exe
C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe
C:\Program Files\BillP Studios\WinPatrol\winpatrol.exe
C:\Program Files\Clamware\ClamWin\bin\ClamTray.exe
C:\Program Files\Apoint\Apntex.exe
C:\Program Files\Dell\Media Experience\PCMService.exe
C:\Program Files\McAfee.com\Agent\mcagent.exe
C:\Program Files\Multimedia Card Reader\shwicon2k.exe
C:\Program Files\AWS\WeatherBug\Weather.exe
C:\Program Files\AIM6\aim6.exe
C:\Program Files\DellSupport\DSAgnt.exe
C:\PROGRA~1\COMMON~1\AOL\ACS\AOLacsd.exe
C:\Program Files\DNA\btdna.exe
C:\WINDOWS\system32\LxrJD31s.exe
C:\Documents and Settings\Jon\Local Settings\Application Data\Google\Update\GoogleUpdate.exe
C:\Program Files\Digital Line Detect\DLG.exe
c:\program files\common files\mcafee\mna\mcnasvc.exe
C:\Program Files\Microsoft SQL Server\MSSQL$MICROSOFTBCM\Binn\sqlservr.exe
C:\Program Files\Dell\NICCONFIGSVC\NICCONFIGSVC.exe
C:\WINDOWS\system32\HPZipm12.exe
C:\Program Files\Spyware Doctor\sdhelp.exe
C:\Program Files\AIM6\aolsoftware.exe
C:\WINDOWS\system32\wbem\wmiprvse.exe
C:\Program Files\Yahoo!\Messenger\ymsgr_tray.exe
C:\Program Files\Microsoft Office\OFFICE11\WINWORD.EXE
C:\Program Files\McAfee\SiteAdvisor\McSACore.exe
C:\WINDOWS\System32\alg.exe
C:\Program Files\Spybot - Search & Destroy\SpybotSD.exe
C:\Program Files\SpywareGuard\sgmain.exe
C:\Program Files\SpywareGuard\sgbhp.exe
C:\Program Files\dds.com
uStart Page = about:blank
uURLSearchHooks: AOLTBSearch Class: {ea756889-2338-43db-8f07-d1ca6fb9c90d} - c:\program files\aol\aol toolbar 3.1\aoltb.dll
uURLSearchHooks: H - No File
uURLSearchHooks: Yahoo! Toolbar: {ef99bd32-c1fb-11d2-892f-0090271d4f88} - c:\progra~1\yahoo!\companion\installs\cpn1\yt.dll
BHO: &Yahoo! Toolbar Helper: {02478d38-c3f9-4efb-9b51-7695eca05670} - c:\progra~1\yahoo!\companion\installs\cpn1\yt.dll
BHO: NoExplorer - No File
BHO: SpywareGuardDLBLOCK.CBrowserHelper: {4a368e80-174f-4872-96b5-0b27ddd11db2} - c:\program files\spywareguard\dlprotect.dll
BHO: Spybot-S&D IE Protection: {53707962-6f74-2d53-2644-206d7942484f} - c:\program files\spybot - search & destroy\SDHelper.dll
BHO: scriptproxy: {7db2d5a0-7241-4e79-b68d-6309f01c5231} - c:\program files\mcafee\virusscan\scriptsn.dll
BHO: McAfee SiteAdvisor BHO: {b164e929-a1b6-4a06-b104-2cd0e90a88ff} - c:\progra~1\mcafee\sitead~1\mcieplg.dll
TB: Super Ad Blocker Toolbar: {b4b3001e-0f56-4e51-8250-bde11547ec55} - c:\program files\superadblocker.com\super ad blocker\sabtb.dll
TB: Yahoo! Toolbar: {ef99bd32-c1fb-11d2-892f-0090271d4f88} - c:\progra~1\yahoo!\companion\installs\cpn1\yt.dll
TB: AOL Toolbar: {de9c389f-3316-41a7-809b-aa305ed9d922} - c:\program files\aol\aol toolbar 3.1\aoltb.dll
TB: McAfee SiteAdvisor Toolbar: {0ebbbe48-bad4-4b4c-8e5a-516abecae064} - c:\progra~1\mcafee\sitead~1\mcieplg.dll
uRun: [DW4]
uRun: [Weather] c:\program files\aws\weatherbug\Weather.exe 1
uRun: [Aim6] "c:\program files\aim6\aim6.exe" /d locale=en-US [You must be registered and logged in to see this link.]
uRun: [DellSupport] "c:\program files\dellsupport\DSAgnt.exe" /startup
uRun: [updateMgr] "c:\program files\adobe\acrobat 7.0\reader\AdobeUpdateManager.exe" AcRdB7_0_9 -reboot 1
uRun: [Messenger (Yahoo!)] "c:\program files\yahoo!\messenger\YahooMessenger.exe" -quiet
uRun: [BitTorrent DNA] "c:\program files\dna\btdna.exe"
uRun: [Google Update] "c:\documents and settings\jon\local settings\application data\google\update\GoogleUpdate.exe" /c
uRun: [DW6] "c:\program files\the weather channel fw\desktop\DesktopWeather.exe"
uRun: [SpybotSD TeaTimer] c:\program files\spybot - search & destroy\TeaTimer.exe
mRun: [Apoint] c:\program files\apoint\Apoint.exe
mRun: [ATIPTA] c:\program files\ati technologies\ati control panel\atiptaxx.exe
mRun: [Dell Wireless Manager UI] c:\windows\system32\WLTRAY
mRun: [DVDLauncher] "c:\program files\cyberlink\powerdvd\DVDLauncher.exe"
mRun: [ISUSPM Startup] c:\progra~1\common~1\instal~1\update~1\ISUSPM.exe -startup
mRun: [ISUSScheduler] "c:\program files\common files\installshield\updateservice\issch.exe" -start
mRun: [dla] c:\windows\system32\dla\tfswctrl.exe
mRun: [WinPatrol] c:\program files\billp studios\winpatrol\winpatrol.exe
mRun: [ClamWin] "c:\program files\clamware\clamwin\bin\ClamTray.exe" --logon
mRun: [PCMService] "c:\program files\dell\media experience\PCMService.exe"
mRun: [mcagent_exe] c:\program files\mcafee.com\agent\mcagent.exe /runkey
mRun: [Sunkist2k] c:\program files\multimedia card reader\shwicon2k.exe
dRun: [Spyware Doctor]
StartupFolder: c:\docume~1\jon\startm~1\programs\startup\spywar~1.lnk - c:\program files\spywareguard\sgmain.exe
StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\americ~1.lnk - c:\program files\america online 9.0\aoltray.exe
StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\digita~1.lnk - c:\program files\digital line detect\DLG.exe
uPolicies-system: DisableRegistryTools = 1 (0x1)
IE: &AOL Toolbar Search - c:\program files\aol\aol toolbar 3.1\resources\en-us\local\search.html
IE: E&xport to Microsoft Excel - c:\progra~1\mi1933~1\office11\EXCEL.EXE/3000
IE: {AC9E2541-2814-11d5-BC6D-00B0D0A1DE45} - c:\program files\aim\aim.exe
IE: {CD67F990-D8E9-11d2-98FE-00C0F0318AFE}
IE: {d81ca86b-ef63-42af-bee3-4502d9a03c2d} - [You must be registered and logged in to see this link.]
IE: {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - {CAFEEFAC-0016-0000-0001-ABCDEFFEDCBC} - c:\program files\java\jre1.6.0_01\bin\ssv.dll
IE: {2D663D1A-8670-49D9-A1A5-4C56B4E14E84} - {A1EDC4A1-940F-48E0-8DFD-E38F1D501021} - c:\progra~1\spywar~1\tools\iesdpb.dll
IE: {3369AF0D-62E9-4bda-8103-B4C75499B578} - {DE9C389F-3316-41A7-809B-AA305ED9D922} - c:\program files\aol\aol toolbar 3.1\aoltb.dll
IE: {92780B25-18CC-41C8-B9BE-3C9C571A8263} - {FF059E31-CC5A-4E2E-BF3B-96E929D65503} - c:\progra~1\mi1933~1\office11\REFIEBAR.DLL
IE: {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - {53707962-6F74-2D53-2644-206D7942484F} - c:\program files\spybot - search & destroy\SDHelper.dll
spacephrawgg
Posts Posts : 210
Post by spacephrawgg on 7th February 2009, 6:53 pm
more:
DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} - [You must be registered and logged in to see this link.]
DPF: {B49C4597-8721-4789-9250-315DFBD9F525} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0014-0002-0003-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0015-0000-0004-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0015-0000-0006-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0016-0000-0001-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {FD0B6769-6490-4A91-AA0A-B5AE0DC75AC9} - [You must be registered and logged in to see this link.]
Handler: junomsg - {C4D10830-379D-11d4-9B2D-00C04F1579A5} - c:\program files\juno\bin\jmsgpph.dll
Handler: sacore - {5513F07E-936B-4E52-9B00-067394E91CC5} - c:\progra~1\mcafee\sitead~1\McIEPlg.dll
Notify: AtiExtEvent - Ati2evxx.dll
Notify: SABWinLogon - c:\program files\superadblocker.com\super ad blocker\SABWINLO.DLL
Notify: __c00D99BF - c:\windows\system32\__c00D99BF.dat
AppInit_DLLs: agckiu.dll xmjisw.dll ghekwx.dll
STS: c:\windows\system32\tyshb36rfjdf.dll: {d5bf49a2-94f1-42bd-f434-3604812c807d} - c:\windows\system32\tyshb36rfjdf.dll
SEH: Microsoft AntiMalware ShellExecuteHook: {091eb208-39dd-417d-a5dd-7e2c2d8fb9cb} - c:\progra~1\window~4\MpShHook.dll
SEH: SpywareGuard.Handler: {81559c35-8464-49f7-bb0e-07a383bef910} - c:\program files\spywareguard\spywareguard.dll
LSA: Authentication Packages = msv1_0 c:\windows\system32\fcccaXno
FF - ProfilePath - c:\docume~1\jon\applic~1\mozilla\firefox\profiles\viz2txmf.default\
FF - component: c:\program files\mcafee\siteadvisor\components\McFFPlg.dll
FF - component: c:\program files\mozilla firefox\components\SABFF.DLL
FF - plugin: c:\documents and settings\jon\local settings\application data\google\update\1.2.141.5\npGoogleOneClick7.dll
FF - plugin: c:\program files\mozilla firefox\plugins\npbittorrent.dll
FF - plugin: c:\program files\mozilla firefox\plugins\NPMGWRAP.DLL
FF - plugin: c:\program files\mozilla firefox\plugins\npmozax.dll
FF - plugin: c:\program files\mozilla firefox\plugins\NPMySrWB.dll
FF - plugin: c:\program files\mozilla firefox\plugins\npunagi2.dll
FF - plugin: c:\program files\viewpoint\viewpoint experience technology\npViewpoint.dll
---- FIREFOX POLICIES ----
c:\program files\mozilla firefox\defaults\pref\activex.js - pref("capability.policy.default.ClassID.CIDFE0BD779-44EE-4A4B-AA2E-743C63F2E5E6", "AllAccess");
R1 ikhfile;File Security Kernel Anti-Spyware Driver;c:\windows\system32\drivers\ikhfile.sys [2006-5-9 30592]
R1 ikhlayer;Kernel Anti-Spyware Driver;c:\windows\system32\drivers\ikhlayer.sys [2006-1-12 51072]
R1 mfehidk;McAfee Inc. mfehidk;c:\windows\system32\drivers\mfehidk.sys [2007-8-6 201320]
R1 SABDIFSV;SABDIFSV;c:\program files\superadblocker.com\super ad blocker\SABDIFSV.SYS [2005-10-10 5632]
R2 aawservice;Lavasoft Ad-Aware Service;c:\program files\lavasoft\ad-aware\aawservice.exe [2008-5-12 611664]
R2 McAfee SiteAdvisor Service;McAfee SiteAdvisor Service;c:\program files\mcafee\siteadvisor\McSACore.exe [2008-9-5 206096]
R3 mfeavfk;McAfee Inc. mfeavfk;c:\windows\system32\drivers\mfeavfk.sys [2007-8-6 79304]
R3 mfebopk;McAfee Inc. mfebopk;c:\windows\system32\drivers\mfebopk.sys [2007-8-6 35240]
R3 mfesmfk;McAfee Inc. mfesmfk;c:\windows\system32\drivers\mfesmfk.sys [2007-8-6 40488]
S2 0100511233898305mcinstcleanup;McAfee Application Installer Cleanup (0100511233898305);c:\windows\temp\010051~1.exe c:\progra~1\common~1\mcafee\instal~1\cleanup.ini -cleanup -nolog -service --> c:\windows\temp\010051~1.exe c:\progra~1\common~1\mcafee\instal~1\cleanup.ini -cleanup -nolog -service [?]
S3 mferkdk;McAfee Inc. mferkdk;c:\windows\system32\drivers\mferkdk.sys [2007-8-6 33832]
S3 PWIPENUM;PWIPENUM;\??\c:\program files\panicware\pop-up stopper anti-spyware\pwipenum.sys --> c:\program files\panicware\pop-up stopper anti-spyware\PWIPENUM.SYS [?]
2009-02-07 13:51 368,961 a------- c:\program files\dds.com
2009-02-07 13:50 --d----- c:\program files\SpywareGuard
2009-02-07 13:49 2,062,665 a------- c:\program files\spywareguardsetup.exe
2009-02-07 13:45 --d----- c:\program files\Spybot - Search & Destroy
2009-02-07 13:45 --d----- c:\docume~1\alluse~1\applic~1\Spybot - Search & Destroy
2009-02-07 13:43 --d----- c:\program files\New Folder (2)
2009-02-05 11:49 --d----- c:\program files\Stopzilla
2009-02-05 09:45 1,557,715 ---sh--- c:\windows\system32\ckendvjc.ini
2009-02-05 09:44 129,024 a------- c:\windows\system32\fhwlblpo.dll
spacephrawgg
Posts Posts : 210
2009-02-06 09:16 460,099 a--sh--- c:\windows\system32\onXacccf.ini2
2009-02-05 10:29 2,710 a------- c:\windows\system32\TDSSdbcj.dll
2008-12-27 22:24 129,024 a------- c:\windows\system32\oudbmbpe.dll
2008-12-23 21:15 129,024 a------- c:\windows\system32\yarpycxp.dll
2008-12-20 18:21 129,024 a------- c:\windows\system32\umoyfple.dll
2008-12-20 18:21 129,024 a------- c:\windows\system32\lhutzn.dll
2008-12-19 10:11 129,024 a------- c:\windows\system32\pozccr.dll
2008-12-19 10:11 129,024 a------- c:\windows\system32\ktyrvmul.dll
2008-12-13 01:40 3,593,216 a------- c:\windows\system32\dllcache\mshtml.dll
2008-07-18 06:24 3,518,422 a------- c:\program files\flvplayer_setup.exe
2008-06-30 04:16 23,510,720 a------- c:\program files\dotnetfx.exe
2008-06-30 04:15 1,427,520 a------- c:\program files\Silverlight.exe
2008-04-06 03:12 1,565,191 a------- c:\program files\AntiSpywareDeluxeSetup.exe
2008-02-27 08:28 1,491,592 a------- c:\program files\install_flash_player.exe
2008-01-28 06:45 25,755,448 a------- c:\program files\wmp11-windowsxp-x86-enu.exe
2008-01-02 19:25 6,876,336 a------- c:\program files\RecoverMyFiles-Setup.exe
2007-04-12 01:45 9,453,630 a------- c:\program files\vlc-0.8.6a-win32.exe
2007-02-26 23:23 3,782,589 a------- c:\program files\LastFM_Win_1.1.3.0.exe
2007-02-26 06:00 3,537,447 a------- c:\program files\MP3Rocket-Win.exe
2007-02-19 02:16 3,428,033 a------- c:\program files\iMP3Tunes-Win.exe
2006-11-26 21:35 5,669,872 a------- c:\program files\wpsetup.exe
2006-11-25 21:33 3,789,316 a------- c:\program files\netpumper-1.25.1-setup-NP_0210.exe
2006-10-14 21:42 8,799,656 a------- c:\program files\Azureus_2.5.0.0_Win32.setup.exe
2006-10-14 21:37 8,963,034 a------- c:\program files\Azureus_2.5.0.0_OSX.dmg
2005-11-22 01:21 1,508 a------- c:\program files\uninstal.log
2005-09-05 14:16 353,888 a------- c:\program files\LimeWireWin.exe
2005-08-24 23:04 488,032 a------- c:\program files\PopUpStopper.exe
2005-08-24 23:00 4,436,776 a------- c:\program files\SuperAdBlocker.exe
2005-08-23 22:53 22,040,920 a------- c:\program files\iTunesSetup.exe
2005-08-23 19:27 2,855,080 a------- c:\program files\aawsepersonal.exe
2005-08-23 14:02 323,072 a------- c:\program files\ScreenShotSetup.msi
2002-05-21 10:00 1,362 a----r-- c:\program files\ReadMe.txt
2008-10-07 09:18 32,768 a--sh--- c:\windows\system32\config\systemprofile\local settings\history\history.ie5\mshist012008100720081008\index.dat
============= FINISH: 13:56:02.06 ===============
spacephrawgg
Posts Posts : 210
Post by Belahzur on 7th February 2009, 7:01 pm
Please close Mcafee, right click the M icon in the tray > exit it.
  • Save it to your desktop.
  • Please double-click OTMoveIt3.exe to run it.
  • Copy the file paths below to the clipboard by highlighting ALL of them and pressing CTRL + C (or, after highlighting, right-click and choose CopyCrying
    :services
    :files
    :reg
    [-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\__c00D99BF]
    [HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Windows]
    "AppInit_DLLs"=""
    "Authentication Packages"=hex(7):6d,73,76,31,5f,30,00,00
    :commands
    [purity]
    [emptytemp]
    [reboot]
  • Return to OTMoveIt3, right click in the "Paste instructions for items to be Moved" window (under the light blue bar) and choose Paste.
  • Close OTMoveIt3
Please post the OTMoveIt log.
Post by spacephrawgg on 8th February 2009, 2:53 am
Here's the OTmoveit log:
========== SERVICES/DRIVERS ==========
Service 0100511233898305mcinstcleanup stopped successfully.
Service 0100511233898305mcinstcleanup deleted successfully.
========== FILES ==========
File/Folder c:\windows\system32\ckendvjc.ini not found.
File/Folder c:\windows\system32\fhwlblpo.dll not found.
c:\windows\system32\onXacccf.ini2 moved successfully.
LoadLibrary failed for c:\windows\system32\TDSSdbcj.dll
c:\windows\system32\TDSSdbcj.dll NOT unregistered.
c:\windows\system32\TDSSdbcj.dll moved successfully.
File/Folder c:\windows\system32\oudbmbpe.dll not found.
File/Folder c:\windows\system32\yarpycxp.dll not found.
File/Folder c:\windows\system32\umoyfple.dll not found.
File/Folder c:\windows\system32\lhutzn.dll not found.
File/Folder c:\windows\system32\pozccr.dll not found.
File/Folder c:\windows\system32\ktyrvmul.dll not found.
File/Folder c:\windows\system32\__c00D99BF.dat not found.
c:\program files\netpumper-1.25.1-setup-NP_0210.exe moved successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\__c00D99BF\\ deleted successfully.
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Windows\\"AppInit_DLLs"|"" /E : value set successfully!
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa\\"Authentication Packages"|hex(7):6d,73,76,31,5f,30,00,00 /E : value set successfully!
File delete failed. C:\DOCUME~1\Jon\LOCALS~1\Temp\ClamWin1.log scheduled to be deleted on reboot.
File delete failed. C:\DOCUME~1\Jon\LOCALS~1\Temp\etilqs_d0quQVqmcd1O7z0SWG6U scheduled to be deleted on reboot.
File delete failed. C:\DOCUME~1\Jon\LOCALS~1\Temp\Perflib_Perfdata_17f8.dat scheduled to be deleted on reboot.
File delete failed. C:\DOCUME~1\Jon\LOCALS~1\Temp\~DF7054.tmp scheduled to be deleted on reboot.
File delete failed. C:\DOCUME~1\Jon\LOCALS~1\Temp\~DF721F.tmp scheduled to be deleted on reboot.
File delete failed. C:\DOCUME~1\Jon\LOCALS~1\Temp\~DFA39A.tmp scheduled to be deleted on reboot.
File delete failed. C:\DOCUME~1\Jon\LOCALS~1\Temp\~DFAB5C.tmp scheduled to be deleted on reboot.
File delete failed. C:\DOCUME~1\Jon\LOCALS~1\Temp\~DFB1AF.tmp scheduled to be deleted on reboot.
File delete failed. C:\DOCUME~1\Jon\LOCALS~1\Temp\~DFC79A.tmp scheduled to be deleted on reboot.
File delete failed. C:\DOCUME~1\Jon\LOCALS~1\Temp\~DFD1A5.tmp scheduled to be deleted on reboot.
User's Temp folder emptied.
User's Temporary Internet Files folder emptied.
User's Internet Explorer cache folder emptied.
Local Service Temp folder emptied.
File delete failed. C:\Documents and Settings\LocalService\Local Settings\Temporary Internet Files\Content.IE5\index.dat scheduled to be deleted on reboot.
Local Service Temporary Internet Files folder emptied.
File delete failed. C:\WINDOWS\temp\mcafee_QhdTL9GkGdi1w4b scheduled to be deleted on reboot.
File delete failed. C:\WINDOWS\temp\mcmsc_8gNFeiTUpdpQv9b scheduled to be deleted on reboot.
File delete failed. C:\WINDOWS\temp\mcmsc_gStGgahzpNJAa5c scheduled to be deleted on reboot.
File delete failed. C:\WINDOWS\temp\mcmsc_NZFahAu9d1iNZS7 scheduled to be deleted on reboot.
File delete failed. C:\WINDOWS\temp\mcmsc_q3BTM2fdSNjaDFO scheduled to be deleted on reboot.
File delete failed. C:\WINDOWS\temp\mcmsc_sBeAV5xecoF1bWT scheduled to be deleted on reboot.
File delete failed. C:\WINDOWS\temp\Perflib_Perfdata_a90.dat scheduled to be deleted on reboot.
File delete failed. C:\WINDOWS\temp\sqlite_glrnKUKtmhk4xIO scheduled to be deleted on reboot.
File delete failed. C:\WINDOWS\temp\sqlite_pGoLMYPGAA999Sx scheduled to be deleted on reboot.
File delete failed. C:\WINDOWS\temp\sqlite_sojw5wgGwASnMeP scheduled to be deleted on reboot.
File delete failed. C:\WINDOWS\temp\WFV16.tmp scheduled to be deleted on reboot.
Windows Temp folder emptied.
Java cache emptied.
File delete failed. C:\Documents and Settings\Jon\Local Settings\Application Data\Mozilla\Firefox\Profiles\viz2txmf.default\Cache\_CACHE_001_ scheduled to be deleted on reboot.
File delete failed. C:\Documents and Settings\Jon\Local Settings\Application Data\Mozilla\Firefox\Profiles\viz2txmf.default\Cache\_CACHE_002_ scheduled to be deleted on reboot.
File delete failed. C:\Documents and Settings\Jon\Local Settings\Application Data\Mozilla\Firefox\Profiles\viz2txmf.default\Cache\_CACHE_003_ scheduled to be deleted on reboot.
File delete failed. C:\Documents and Settings\Jon\Local Settings\Application Data\Mozilla\Firefox\Profiles\viz2txmf.default\Cache\_CACHE_MAP_ scheduled to be deleted on reboot.
File delete failed. C:\Documents and Settings\Jon\Local Settings\Application Data\Mozilla\Firefox\Profiles\viz2txmf.default\urlclassifier3.sqlite scheduled to be deleted on reboot.
FireFox cache emptied.
Temp folders emptied.
OTMoveIt3 by OldTimer - Version 1.0.8.0 log created on 02072009_143227
Files moved on Reboot...
C:\DOCUME~1\Jon\LOCALS~1\Temp\ClamWin1.log moved successfully.
File C:\DOCUME~1\Jon\LOCALS~1\Temp\etilqs_d0quQVqmcd1O7z0SWG6U not found!
File C:\DOCUME~1\Jon\LOCALS~1\Temp\Perflib_Perfdata_17f8.dat not found!
File C:\DOCUME~1\Jon\LOCALS~1\Temp\~DF7054.tmp not found!
C:\DOCUME~1\Jon\LOCALS~1\Temp\~DF721F.tmp moved successfully.
File C:\DOCUME~1\Jon\LOCALS~1\Temp\~DFA39A.tmp not found!
C:\DOCUME~1\Jon\LOCALS~1\Temp\~DFAB5C.tmp moved successfully.
File C:\DOCUME~1\Jon\LOCALS~1\Temp\~DFB1AF.tmp not found!
File C:\DOCUME~1\Jon\LOCALS~1\Temp\~DFC79A.tmp not found!
File C:\DOCUME~1\Jon\LOCALS~1\Temp\~DFD1A5.tmp not found!
File move failed. C:\Documents and Settings\LocalService\Local Settings\Temporary Internet Files\Content.IE5\index.dat scheduled to be moved on reboot.
C:\WINDOWS\temp\mcafee_QhdTL9GkGdi1w4b moved successfully.
C:\WINDOWS\temp\mcmsc_8gNFeiTUpdpQv9b moved successfully.
File C:\WINDOWS\temp\mcmsc_gStGgahzpNJAa5c not found!
File C:\WINDOWS\temp\mcmsc_NZFahAu9d1iNZS7 not found!
File C:\WINDOWS\temp\mcmsc_q3BTM2fdSNjaDFO not found!
File C:\WINDOWS\temp\mcmsc_sBeAV5xecoF1bWT not found!
C:\WINDOWS\temp\Perflib_Perfdata_a90.dat moved successfully.
C:\WINDOWS\temp\sqlite_glrnKUKtmhk4xIO moved successfully.
C:\WINDOWS\temp\sqlite_pGoLMYPGAA999Sx moved successfully.
C:\WINDOWS\temp\sqlite_sojw5wgGwASnMeP moved successfully.
File C:\WINDOWS\temp\WFV16.tmp not found!
C:\Documents and Settings\Jon\Local Settings\Application Data\Mozilla\Firefox\Profiles\viz2txmf.default\Cache\_CACHE_001_ moved successfully.
C:\Documents and Settings\Jon\Local Settings\Application Data\Mozilla\Firefox\Profiles\viz2txmf.default\Cache\_CACHE_002_ moved successfully.
C:\Documents and Settings\Jon\Local Settings\Application Data\Mozilla\Firefox\Profiles\viz2txmf.default\Cache\_CACHE_003_ moved successfully.
C:\Documents and Settings\Jon\Local Settings\Application Data\Mozilla\Firefox\Profiles\viz2txmf.default\Cache\_CACHE_MAP_ moved successfully.
C:\Documents and Settings\Jon\Local Settings\Application Data\Mozilla\Firefox\Profiles\viz2txmf.default\urlclassifier3.sqlite moved successfully.
spacephrawgg
Posts Posts : 210
Post by spacephrawgg on 8th February 2009, 3:10 am
A minute ago I was attempting to look at something in another tab in FF and the thing crashed on me without warning. Just thought I'd mention.
spacephrawgg
Posts Posts : 210
Post by Belahzur on 8th February 2009, 3:08 pm
What version of Firefox are you using?
Try re-installing it.
Post by spacephrawgg on 8th February 2009, 3:43 pm
I just updated FF to the latest version and still have the funny McAffee problem.
As for the scan reports, what now?
Thanks again!
spacephrawgg
Posts Posts : 210
Post by Belahzur on 8th February 2009, 3:44 pm
Please run DDS again, I think there maybe a leftover.
Post by spacephrawgg on 8th February 2009, 4:00 pm
By DDS you mean avenger?
Btw I ran spybot and it found among other things, three trojans. I anticipated that you would want me not to delete anything without hte proper scans so I did nothing about it.
spacephrawgg
Posts Posts : 210
Post by Belahzur on 8th February 2009, 4:04 pm
Where did Spybot find these trojans?
Can you post the Spybot report.
Post by spacephrawgg on 8th February 2009, 4:30 pm
I lost the old report because I had to reboot. How do I get a text version of the report?
spacephrawgg
Posts Posts : 210
Post by Belahzur on 8th February 2009, 4:35 pm
Okay, nevermind.
Allow Spybot to fix the items, they may just be leftovers, let me know if they come back.
Post by spacephrawgg on 8th February 2009, 4:49 pm
I will try to transcribe the listed items:
ad revolver (23 browser items)
anti-leech (6 entries, adware)
antispyware master (1 entry, malware)
bluestreak (1 browser entry)
burst media (7 entries, browser)
casalemedia (11 entries, browser)
CID.IE.Pop (2 entries, trojans)
doubleclick (2 entries browser)
fastclick (9 entries, browser)
hitslink (1 entry, browser)
irc.crt (1 entry, trojan)
mediaplex (8 entries browser)
microsoft.windowssecuritycenter.registrytools. (1 entry, security center)
netpumper (3 entries adware)
PWS.LDpinchIE (1 entry trojan)
Right Media (2 entries browser)
smitfraud-C. (1 entry malware)
Statcounter (52 entries browser)
virtumonde (2 entries, trojan)
virtumonde.sci (1 entry trojan)
Win32.agent.ammy (1 entry, trojan)
win32.TDSS.rtk (8 entries trojan)
zedo (7 entries, browser)
I am concerned about it "fixing" the windows security center thing despite the fact that it was giving me trouble. What do I do?
Also can i safely get out of safe mode now?
Last edited by spacephrawgg on 8th February 2009, 4:50 pm; edited 1 time in total (Reason for editing : thought of something else to say)
spacephrawgg
Posts Posts : 210
Post by Belahzur on 8th February 2009, 4:51 pm
Run DDS again.
You saved DDS here:
C:\Program Files\DDS.com
Post by spacephrawgg on 8th February 2009, 4:57 pm
DDS (Ver_09-02-01.01)
Install Date: 8/8/2005 11:45:55 PM
System Uptime: 2/8/2009 10:46:37 AM (2 hours ago)
Motherboard: Dell Inc. | |
Processor: Intel(R) Pentium(R) M processor 2.00GHz | Microprocessor | 1994/133mhz
C: is FIXED (NTFS) - 71 GiB total, 6.35 GiB free.
D: is CDROM ()
RP788: 12/18/2008 9:58:01 AM - Software Distribution Service 3.0
RP789: 12/18/2008 9:58:01 AM - Software Distribution Service 3.0
RP790: 12/18/2008 9:58:03 AM - Software Distribution Service 3.0
RP791: 12/18/2008 9:58:10 AM - Software Distribution Service 3.0
RP792: 12/18/2008 9:58:10 AM - Software Distribution Service 3.0
RP793: 12/18/2008 9:58:10 AM - System Checkpoint
RP794: 12/18/2008 9:58:15 AM - Software Distribution Service 3.0
RP795: 12/18/2008 9:58:15 AM - System Checkpoint
RP796: 12/18/2008 9:58:16 AM - Software Distribution Service 3.0
RP797: 12/18/2008 9:58:17 AM - System Checkpoint
RP798: 12/18/2008 9:58:18 AM - Removed QuickTime
RP799: 12/18/2008 9:58:18 AM - Installed QuickTime
RP800: 12/18/2008 9:58:19 AM - System Checkpoint
RP801: 12/18/2008 9:58:19 AM - System Checkpoint
RP802: 12/18/2008 9:58:20 AM - System Checkpoint
RP803: 12/18/2008 9:58:21 AM - System Checkpoint
RP804: 12/18/2008 9:58:22 AM - System Checkpoint
RP805: 12/18/2008 9:58:23 AM - Software Distribution Service 3.0
RP806: 12/18/2008 9:58:23 AM - Software Distribution Service 3.0
RP807: 12/18/2008 9:58:38 AM - Last known good configuration
RP808: 2/6/2009 3:08:52 AM - System Checkpoint
RP809: 2/7/2009 3:19:27 AM - System Checkpoint
RP810: 2/7/2009 10:38:19 PM - Removed Ad-Aware
6300
6300_Help
6300Trb
Adobe Flash Player 10 Plugin
Adobe Flash Player ActiveX
Adobe Reader 7.0.9
AIM 6
AiO_Scan_CDA
AiOSoftwareNPI
ALPS Touch Pad Driver
AOL Coach Version 1.0(Build:20040229.1 en)
AOL Connectivity Services
AOL Instant Messenger
AOL Uninstaller (Choose which Products to Remove)
AOLIcon
Apple Mobile Device Support
Apple Software Update
ATI Control Panel
ATI Display Driver
AutoUpdate
Azureus
BitTorrent
Blender (remove only)
Bonjour
Broadcom Management Programs 2
BufferChm
Business Contact Manager for Outlook 2003
CiD Help
ClamWin Free Antivirus 0.91.2
Conexant D110 MDC V.9x Modem
CP_AtenaShokunin1Config
CP_CalendarTemplates1
cp_OnlineProjectsConfig
CP_Package_Basic1
CP_Package_Variety1
CP_Package_Variety2
CP_Package_Variety3
CP_Panorama1Config
cp_PosterPrintConfig
CueTour
Dell Digital Jukebox Driver
Dell Driver Reset Tool
Dell Media Experience
Dell Picture Studio v3.0
Dell System Restore
Dell Wireless WLAN Card
DellSupport
Destinations
DeviceFunctionQFolder
DeviceManagementQFolder
Digital Line Detect
DivX
DivX Player
DivX Web Player
DNA
DocProc
DocumentViewer
DocumentViewerQFolder
EarthLink setup files
eSupportQFolder
Fax_CDA
FLV Player 2.0, build 24
FullDPAppQFolder
GdiplusUpgrade
Get High Speed Internet!
Google Chrome
Google Earth
HP Document Viewer 6.1
HP Imaging Device Functions 6.1
HP Photosmart Premier Software 6.1
HP PSC & OfficeJet 6.1.A
HP Solution Center and Imaging Support Tools 6.1
HP Update
HPProductAssistant
InstantShareDevices
Internal Network Card Power Management
Internet Explorer Default Page
iTunes
J2SE Runtime Environment 5.0 Update 4
Jasc Paint Shop Photo Album 5
Jasc Paint Shop Pro Studio, Dell Editon
Jasc Paint Shop Pro Studio.01 , Dell Edition 1.0.1.1 Patch
Java 2 Runtime Environment, SE v1.4.2_03
Java(TM) SE Runtime Environment 6 Update 1
JD Secure 3.1
Juno
Last.fm 1.3.1.1
Learn2 Player (Uninstall Only)
LEGO Digital Designer
LimeWire 4.18.8
Linksys PrintServer Driver
Macromedia Shockwave Player
McAfee SecurityCenter
Microsoft .NET Framework 1.1
Microsoft .NET Framework 2.0
Microsoft Office Small Business Edition 2003
Microsoft Plus! Digital Media Edition Installer
Microsoft Plus! Photo Story 2 LE
Microsoft Silverlight
MobileMe Control Panel
Modem Helper
Mozilla Firefox (3.0.6)
MSXML 4.0 SP2 (KB927978)
MSXML 4.0 SP2 (KB936181)
MSXML 4.0 SP2 (KB954430)
Musicmatch for Windows Media Player
My Way Search Assistant
NetWaiting
NetZeroInstallers
NewCopy_CDA
PanoStandAlone
PhotoGallery
PhotoShow Express
Plaxo Toolbar for Outlook (with AIM Enhancements)
Pop-Up Stopper Free Edition
PowerDVD 5.5
ProductContextNPI
Qualxserve Service Agreement
QuickBooks Simple Start Edition
QuickSet
QuickTime
RandMap
Readme
RealPlayer
Recover My Files
Safari
Scan
ScannerCopy
ScreenShotSetup
Security Update for Windows Internet Explorer 7 (KB928090)
Security Update for Windows Internet Explorer 7 (KB929969)
Security Update for Windows Internet Explorer 7 (KB931768)
SkinsHP1
SolutionCenter
Sonic Audio module
Sonic Copy Module
Sonic DLA
Sonic Express Labeler
Sonic MyDVD Plus
Sonic RecordNow Data
Sonic Update Manager
Sonic_PrimoSDK
SpywareGuard v2.2
Status
The Weather Channel Desktop 6
Toolbox
TrayApp
Trillian
Unload
VectorVest Online
VideoLAN VLC media player 0.8.6a
Weather Services
WeatherBug
WeatherBug Browser Bar - powered by MyWebSearch
WebCyberCoach 3.2 Dell
WebFldrs XP
WebReg
Windows Defender
Windows Defender Signatures
Windows Genuine Advantage v1.3.0254.0
Windows XP Service Pack 3
Wings 3D 0.98.36
WinPatrol
WinRAR archiver
Yahoo! Messenger
Yahoo! Toolbar
ZyGoVideo 2.0
2/5/2009 11:46:53 AM, error: DCOM [10005] - DCOM got error "%1084" attempting to start the service McAfee SiteAdvisor Service with arguments "" in order to run the server: {5A90F5EE-16B8-4C2A-81B3-FD5329BA477C}
2/5/2009 11:33:45 AM, error: DCOM [10005] - DCOM got error "%1084" attempting to start the service MSIServer with arguments "" in order to run the server: {000C101C-0000-0000-C000-000000000046}
2/5/2009 11:24:35 AM, error: DCOM [10005] - DCOM got error "%1058" attempting to start the service wuauserv with arguments "" in order to run the server: {E60687F7-01A1-40AA-86AC-DB1CBF673334}
2/5/2009 10:31:04 AM, error: DCOM [10005] - DCOM got error "%1084" attempting to start the service McNASvc with arguments "" in order to run the server: {24F616A1-B755-4053-8018-C3425DC8B68A}
2/5/2009 10:29:51 AM, error: DCOM [10005] - DCOM got error "%1084" attempting to start the service EventSystem with arguments "" in order to run the server: {1BE1F766-5536-11D1-B726-00C04FB926AF}
2/5/2009 10:29:49 AM, error: Service Control Manager [7026] - The following boot-start or system-start driver(s) failed to load: APPDRV Fips intelppm mfehidk SABDIFSV
2/5/2009 9:43:30 AM, error: Service Control Manager [7000] - The Viewpoint Manager Service service failed to start due to the following error: The service did not respond to the start or control request in a timely fashion.
2/5/2009 9:43:30 AM, error: Service Control Manager [7009] - Timeout (30000 milliseconds) waiting for the Viewpoint Manager Service service to connect.
2/5/2009 9:43:30 AM, error: Service Control Manager [7000] - The ASCTRM service failed to start due to the following error: The system cannot find the file specified.
2/6/2009 12:25:22 AM, error: Service Control Manager [7000] - The Viewpoint Manager Service service failed to start due to the following error: The system cannot find the path specified.
2/6/2009 12:25:22 AM, error: Service Control Manager [7026] - The following boot-start or system-start driver(s) failed to load: IntelIde
spacephrawgg
Posts Posts : 210
Post by Belahzur on 8th February 2009, 5:01 pm
That is attach.txt, please post DDS.txt
Post by spacephrawgg on 8th February 2009, 5:05 pm
DDS (Ver_09-02-01.01) - NTFSx86 NETWORK
Run by Jon at 12:02:19.46 on Sun 02/08/2009
Internet Explorer: 7.0.5730.11 BrowserJavaVersion: 1.6.0_01
Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.1023.576 [GMT -5:00]
AV: McAfee VirusScan *On-access scanning disabled* (Updated)
svchost.exe
C:\WINDOWS\system32\svchost.exe -k netsvcs
svchost.exe
svchost.exe
c:\PROGRA~1\mcafee\msc\mcuimgr.exe
STS: {D5BF49A2-94F1-42BD-F434-3604812C807D} - No File
S1 mfehidk;McAfee Inc. mfehidk;c:\windows\system32\drivers\mfehidk.sys [2007-8-6 201320]
S1 SABDIFSV;SABDIFSV;c:\program files\superadblocker.com\super ad blocker\SABDIFSV.SYS [2005-10-10 5632]
S2 McAfee SiteAdvisor Service;McAfee SiteAdvisor Service;c:\program files\mcafee\siteadvisor\McSACore.exe [2008-9-5 206096]
S2 McProxy;McAfee Proxy Service;c:\progra~1\common~1\mcafee\mcproxy\mcproxy.exe [2008-2-26 359248]
S2 McShield;McAfee Real-time Scanner;c:\progra~1\mcafee\viruss~1\mcshield.exe [2007-8-6 144704]
S2 Viewpoint Manager Service;Viewpoint Manager Service;"c:\program files\viewpoint\common\viewpointservice.exe" --> c:\program files\viewpoint\common\ViewpointService.exe [?]
S3 McSysmon;McAfee SystemGuards;c:\progra~1\mcafee\viruss~1\mcsysmon.exe [2007-8-6 695624]
S3 mfeavfk;McAfee Inc. mfeavfk;c:\windows\system32\drivers\mfeavfk.sys [2007-8-6 79304]
S3 mfebopk;McAfee Inc. mfebopk;c:\windows\system32\drivers\mfebopk.sys [2007-8-6 35240]
S3 mfesmfk;McAfee Inc. mfesmfk;c:\windows\system32\drivers\mfesmfk.sys [2007-8-6 40488]
S4 WinDefend;Windows Defender Service;c:\program files\windows defender\MsMpEng.exe [2006-4-3 14032]
2009-02-07 14:32 --d----- C:\_OTMoveIt
============= FINISH: 12:03:01.03 ===============
spacephrawgg
Posts Posts : 210
Post by Belahzur on 8th February 2009, 5:08 pm
Log loos okay.
Fix everything in Spybot and see if it comes back.
Post by spacephrawgg on 8th February 2009, 5:18 pm
when i started up in normal mode, spybot asked me if i wanted to allow a change in something called "bootkit" or something like that. On impulse I told it no. And then i proceeded with things as per normal and things are ok but a bit slow still which doesnt make sense because I've got a gig of ram on this thing. True the harddrive is mostly full but still it shouldnt be silly like this.
spacephrawgg
Posts Posts : 210
Post by Belahzur on 8th February 2009, 5:21 pm
Post by spacephrawgg on 8th February 2009, 5:43 pm
Malwarebytes' Anti-Malware 1.33
Database version: 1738
2/8/2009 12:49:50 PM
mbam-log-2009-02-08 (12-49-50).txt
Objects scanned: 61629
Time elapsed: 12 minute(s), 31 second(s)
Registry Keys Infected: 20
Registry Values Infected: 2
Folders Infected: 3
Files Infected: 4
HKEY_CLASSES_ROOT\minibugtransporter.minibugtransporterx (Adware.Minibug) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\minibugtransporter.minibugtransporterx.1 (Adware.Minibug) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{04a38f6b-006f-4247-ba4c-02a139d5531c} (Adware.Minibug) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{2b96d5cc-c5b5-49a5-a69d-cc0a30f9028c} (Adware.Minibug) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Typelib\{3c2d2a1e-031f-4397-9614-87c932a848e0} (Adware.Minibug) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{d5bf49a2-94f1-42bd-f434-3604812c807d} (Trojan.BHO) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{6d794cb4-c7cd-4c6f-bfdc-9b77afbdc02c} (Trojan.Vundo) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\xpre (Trojan.Downloader) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MS Juan (Malware.Trace) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MS Track System (Trojan.Vundo) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\rdfa (Trojan.Vundo) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\FCOVM (Trojan.Vundo) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\The Weather Channel (Adware.Hotbar) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Weather Services (Adware.Hotbar) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearchwbbar.settingsplugin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearchwbbar.settingsplugin.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearchwbbar.toolbarplugin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearchwbbar.toolbarplugin.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearchwbtoolbar.temperaturebarbutton (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearchwbtoolbar.temperaturebarbutton.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\URLSearchHooks\{4d25f926-b9fe-4682-bf72-8ab8210d6d75} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\SharedTaskScheduler\{d5bf49a2-94f1-42bd-f434-3604812c807d} (Trojan.BHO) -> Quarantined and deleted successfully.
C:\Program Files\MyWaySA (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWaySA\SrchAsDe (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWaySA\SrchAsDe\1.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\AntiSpywareDeluxeSetup.exe (Rogue.Installer) -> Quarantined and deleted successfully.
C:\Documents and Settings\Jon\Local Settings\Temporary Internet Files\Content.IE5\7P6O5QTN\winsinstall[1].exe (Rogue.Installer) -> Quarantined and deleted successfully.
C:\Documents and Settings\Jon\Local Settings\Temporary Internet Files\Content.IE5\MKZXG94O\v3020[1].exe (Trojan.TDSS) -> Quarantined and deleted successfully.
C:\Documents and Settings\Jon\Local Settings\Temporary Internet Files\Content.IE5\I185Q7Q0\index[1] (Trojan.Vundo) -> Quarantined and deleted successfully.
edit: for the heck of it I am now running a full scan.
Last edited by spacephrawgg on 8th February 2009, 5:45 pm; edited 1 time in total (Reason for editing : thought of something else to say)
spacephrawgg
Posts Posts : 210
Post by spacephrawgg on 8th February 2009, 6:51 pm
should I turn the automatic updates for windows security center back on?
spacephrawgg
Posts Posts : 210
Post by Belahzur on 8th February 2009, 7:14 pm
Yes.
MBAM cleared quite alot. LMBO or ROFL
Things should be better now, there was no real files of malware present.
Post by spacephrawgg on 8th February 2009, 10:40 pm
the full system scan yielded this result:
c:/system volume information/_restore (46DE8921-1D39-44D2-A9E9-64119261F211)/RP809/A0121220.dll
c:/system volume information/_restore (46DE8921-1D39-44D2-A9E9-64119261F211)/RP809/A0121306
c:/system volume information/_restore (46DE8921-1D39-44D2-A9E9-64119261F211)/RP809/A0121307
c:/system volume information/_restore (46DE8921-1D39-44D2-A9E9-64119261F211)/RP809/A0121309
c:/system volume information/_restore (46DE8921-1D39-44D2-A9E9-64119261F211)/RP809/A0121311
c:/system volume information/_restore (46DE8921-1D39-44D2-A9E9-64119261F211)/RP809/A0121300
Things seem alright now. I'll post again if not. Thanks for your help. What is the link to the survey where i can voice my satisfaction? You are awesome!
spacephrawgg
Posts Posts : 210
Post by Belahzur on 8th February 2009, 10:42 pm
c:/system volume information is system restore points, we'll flush them soon.
Updating Java:
  • Select the first option where it says "This release includes the highly anticipated...".
  • First, unzip it.
  • Then run JavaRa.
  • This will open JavaRa.
  • Press Remove older versions
  • Press yes to the prompt.
Post by spacephrawgg on 8th February 2009, 11:14 pm
here's the full log file:
2/8/2009 6:20:46 PM
mbam-log-2009-02-08 (18-20-46).txt
Scan type: Full Scan (C:\|)
Objects scanned: 179421
Time elapsed: 2 hour(s), 23 minute(s), 3 second(s)
Files Infected: 6
C:\System Volume Information\_restore{46DE8921-1D39-44D2-A9E9-64119261F211}\RP809\A0121220.dll (Trojan.Vundo) -> Quarantined and deleted successfully.
C:\System Volume Information\_restore{46DE8921-1D39-44D2-A9E9-64119261F211}\RP809\A0121306.dll (Trojan.Vundo) -> Quarantined and deleted successfully.
C:\System Volume Information\_restore{46DE8921-1D39-44D2-A9E9-64119261F211}\RP809\A0121307.dll (Trojan.Vundo) -> Quarantined and deleted successfully.
C:\System Volume Information\_restore{46DE8921-1D39-44D2-A9E9-64119261F211}\RP809\A0121309.dll (Trojan.Vundo) -> Quarantined and deleted successfully.
C:\System Volume Information\_restore{46DE8921-1D39-44D2-A9E9-64119261F211}\RP809\A0121311.dll (Trojan.Vundo) -> Quarantined and deleted successfully.
C:\System Volume Information\_restore{46DE8921-1D39-44D2-A9E9-64119261F211}\RP809\A0121300.dll (Trojan.Vundo) -> Quarantined and deleted successfully.
spacephrawgg
Posts Posts : 210
Post by Belahzur on 8th February 2009, 11:18 pm
More restore points. LMBO or ROFL
Please update Java using my above instructions.
Post by spacephrawgg on 8th February 2009, 11:58 pm
Below is the java logfile:
JavaRa 1.12 Removal Log.
Report follows after line.
The JavaRa removal process was started on Sun Feb 08 18:54:03 2009
Found and removed: C:\Program Files\Java\j2re1.4.2_03
Found and removed: C:\Program Files\Java\jre1.5.0_04
Found and removed: C:\Program Files\Java\jre1.5.0_06
Found and removed: C:\Program Files\Java\jre1.6.0_01
Found and removed: C:\Windows\Installer\{7148F0A8-6813-11D6-A77B-00B0D0142030}
Found and removed: SOFTWARE\JavaSoft\Java Runtime Environment\1.4
Found and removed: Software\JavaSoft\Java2D\1.5.0_04
Found and removed: Software\JavaSoft\Java2D\1.5.0_06
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0004-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0006-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\Installer\Features\8A0F842331866D117AB7000B0D510004
Found and removed: SOFTWARE\Classes\Installer\Features\8A0F842331866D117AB7000B0D510006
Found and removed: SOFTWARE\Classes\Installer\Products\8A0F842331866D117AB7000B0D510004
Found and removed: SOFTWARE\Classes\Installer\Products\8A0F842331866D117AB7000B0D510006
Found and removed: SOFTWARE\Classes\Installer\UpgradeCodes\7A0F842331866D117AB7000B0D510004
Found and removed: SOFTWARE\Classes\Installer\UpgradeCodes\7A0F842331866D117AB7000B0D510006
Found and removed: SOFTWARE\Classes\JavaPlugin.150_04
Found and removed: SOFTWARE\Classes\JavaPlugin.150_06
Found and removed: SOFTWARE\Classes\JavaWebStart.isInstalled.1.5.0.0
Found and removed: SOFTWARE\JavaSoft\Java Plug-in\1.5.0_04
Found and removed: SOFTWARE\JavaSoft\Java Plug-in\1.5.0_06
Found and removed: SOFTWARE\JavaSoft\Java Runtime Environment\1.5
Found and removed: SOFTWARE\JavaSoft\Java Runtime Environment\1.5.0_04
Found and removed: SOFTWARE\JavaSoft\Java Runtime Environment\1.5.0_06
Found and removed: SOFTWARE\Microsoft\Code Store Database\Distribution Units\{CAFEEFAC-0015-0000-0004-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Microsoft\Code Store Database\Distribution Units\{CAFEEFAC-0015-0000-0006-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\ACBB9B2318A96D117A58000B0D510004
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\ACBB9B2318A96D117A58000B0D510006
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\8A0F842331866D117AB7000B0D510004
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\8A0F842331866D117AB7000B0D510006
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{3248F0A8-6813-11D6-A77B-00B0D0150040}
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{3248F0A8-6813-11D6-A77B-00B0D0150060}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0001-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0001-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0001-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\Installer\Features\8A0F842331866D117AB7000B0D610001
Found and removed: SOFTWARE\Classes\Installer\Products\8A0F842331866D117AB7000B0D610001
Found and removed: SOFTWARE\Classes\Installer\UpgradeCodes\7A0F842331866D117AB7000B0D610001
Found and removed: SOFTWARE\Classes\JavaPlugin.160_01
Found and removed: SOFTWARE\JavaSoft\Java Plug-in\1.6.0_01
Found and removed: SOFTWARE\JavaSoft\Java Runtime Environment\1.6.0_01
Found and removed: SOFTWARE\Microsoft\Code Store Database\Distribution Units\{CAFEEFAC-0016-0000-0001-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UpgradeCodes\7A0F842331866D117AB7000B0D610001
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\ACBB9B2318A96D117A58000B0D610001
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\8A0F842331866D117AB7000B0D610001
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{3248F0A8-6813-11D6-A77B-00B0D0160010}
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{7148F0A8-6813-11D6-A77B-00B0D0142030}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0003-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0003-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\Installer\Products\8A0F841731866D117AB7000B0D410203
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\8A0F841731866D117AB7000B0D410203
Found and removed: SOFTWARE\Classes\JavaPlugin.142_03
Found and removed: SOFTWARE\JavaSoft\Java Plug-in\1.4.2_03
Found and removed: SOFTWARE\JavaSoft\Java Runtime Environment\1.4.2_03
Found and removed: SOFTWARE\JavaSoft\Java Web Start\1.4.2_03
Found and removed: SOFTWARE\JavaSoft\Java Web Start\1.5.0_04
Found and removed: SOFTWARE\JavaSoft\Java Web Start\1.5.0_06
Found and removed: SOFTWARE\Microsoft\Code Store Database\Distribution Units\{CAFEEFAC-0014-0002-0003-ABCDEFFEDCBA}
Found and removed: Software\Classes\JavaPlugin.142_03
Found and removed: Software\Classes\JavaPlugin.160_01
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0000-0003-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0000-0004-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0000-0005-ABCDEFFEDCBA}
Found and removed: SOFTWARE\JavaSoft\Java Web Start\1.6.0_01
Found and removed: Software\JavaSoft\Java2D\1.6.0_01
Found and removed: Software\JavaSoft\Java Runtime Environment\1.6.0_01
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0000-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0001-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0001-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0002-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0002-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0003-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0003-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0004-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0004-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0005-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0005-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0006-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0006-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0007-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0007-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0010-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0010-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0011-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0011-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0012-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0012-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0013-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0013-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0014-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0014-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0015-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0015-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0016-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0016-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0017-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0017-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0018-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0018-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0019-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0019-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0020-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0020-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0021-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0021-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0022-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0022-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0023-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0023-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0024-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0024-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0025-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0025-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0026-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0026-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0027-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0027-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0028-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0028-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0029-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0029-ABCDEFFEDCBB}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0030-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0013-0001-0030-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Folders\\C:\Program Files\Common Files\Java\Update\Base Images\jre1.5.0.b64\
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Folders\\C:\Program Files\Java\jre1.5.0_04\
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Folders\\C:\Program Files\Java\jre1.5.0_06\
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Folders\\C:\Program Files\Java\jre1.6.0_01\
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Folders\\C:\Program Files\Java\jre1.6.0_01\bin\
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Folders\C:\Program Files\Common Files\Java\Update\Base Images\jre1.6.0.b105\patch-jre1.6.0_01.b06\
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls\C:\Program Files\Common Files\Java\Update\Base Images\jre1.5.0.b64\core1.zip
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls\C:\Program Files\Common Files\Java\Update\Base Images\jre1.5.0.b64\core2.zip
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls\C:\Program Files\Common Files\Java\Update\Base Images\jre1.5.0.b64\core3.zip
Finished reporting.
Spyware guard browser protection warns me that a " BHO (browser help object" has been added: (761397BB-D6F0-462C-B6EB-D4DAF1D9D92D43)
File location: c:/program files/Java/ire6/bin/ssv.dll
Should I remove or keep this?
spacephrawgg
Posts Posts : 210
Joined Joined : 2009-02-02
Points Points : 29491
Solved Re: Problems with my other computer
Post by Belahzur on 9th February 2009, 12:05 am
I see you have Adobe Reader version 7 installed on this machine, this is old and has holes malware can use to abuse to re-infect you, so we need to close these holes.
Go to Start > Control Panel > Add/Remove Programs and remove the following programs if present.
  • Adobe Reader 7
  • CiD Help
Then download and install version 9 from here:
You also have an old version of the VLC player installed.
Please update this too.
Remove version 0.8.6a and download version 0.9.8a from here:
Let me know once you've done that.
Points Points : 245101
Post by spacephrawgg on 9th February 2009, 12:30 am
One thing at a time: i installed the new VLC thing and am in the process of installing the new adobe thing. Also I have turned off and then on the systems restore.
Meanwhile, win patrol said a new Window Services thing has been installed:
getPlus(R) Helper
C:\Program Files\NOS\bin\getPlus_HelperSvc.exe
should I allow this change?
and Spywareguard browser protection says an attempt to change Internet Explorer settings has been detected in the form of a "BHO (browser help object):
(18DF081C-E8AD-4283-A596-FA578C2EBDC3)
progID: AcrolEHelperShim.AcroHelperShimObj.1
file location: C:/Program Files/common files/Adobe/acrobat/activeX/AcroIEHelperShim.dll
Should I remove or keep this thing?
Last edited by spacephrawgg on 9th February 2009, 12:31 am; edited 1 time in total (Reason for editing : thought of something else to say)
spacephrawgg
Posts Posts : 210
Post by Belahzur on 9th February 2009, 12:33 am
Please allow both.
Post by spacephrawgg on 9th February 2009, 12:41 am
K. So what now?
spacephrawgg
Posts Posts : 210
Post by Belahzur on 9th February 2009, 12:43 am
Post by spacephrawgg on 10th February 2009, 5:54 pm
One last question:
I use the film-strip view when looking through images but sometimes, like right now, when I hit the "view" pulldown menu, it doesnt give me the option of viewing things in "filmstrip". How do I get it to display that option?
Thanks.
spacephrawgg
Posts Posts : 210
Page 1 of 2 1, 2  Next
