i need help with problem
Solved i need help with problem
Post by brootaldomination101 on Sun Feb 01, 2009 10:44 pm
this is the hijack this log
Also my malewarebytes will not load nor will it uninstall so it makes me wonder
Scan saved at 10:24:33 PM, on 2/1/2009
MSIE: Internet Explorer v7.00 (7.00.6000.16414)
C:\Program Files\Winamp\winampa.exe
C:\Program Files\Eset\nod32kui.exe
C:\WINDOWS\system32\igfxtray.exe
C:\WINDOWS\system32\hkcmd.exe
C:\Program Files\Windows Media Player\WMPNSCFG.exe
C:\Program Files\Eset\nod32krn.exe
C:\Program Files\AIM6\aim6.exe
C:\Program Files\AIM6\aolsoftware.exe
C:\Documents and Settings\Owner\Desktop\hijackgpthis.exe
O4 - HKLM\..\Run: [High Definition Audio Property Page Shortcut] HDAShCut.exe
O4 - HKLM\..\Run: [WinampAgent] "C:\Program Files\Winamp\winampa.exe"
O4 - HKLM\..\Run: [nod32kui] "C:\Program Files\Eset\nod32kui.exe" /WAITSERVICE
O4 - HKLM\..\Run: [MSConfig] C:\WINDOWS\PCHealth\HelpCtr\Binaries\MSConfig.exe /auto
O4 - HKCU\..\Run: [WMPNSCFG] C:\Program Files\Windows Media Player\WMPNSCFG.exe
O4 - HKUS\S-1-5-19\..\RunOnce: [nltide_3] rundll32 advpack.dll,LaunchINFSectionEx nLite.inf,C,,4,N (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-19\..\RunOnce: [ShowDeskFix] regsvr32 /s /n /i:u shell32 (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\RunOnce: [nltide_3] rundll32 advpack.dll,LaunchINFSectionEx nLite.inf,C,,4,N (User 'NETWORK SERVICE')
O4 - HKUS\S-1-5-18\..\RunOnce: [nltide_3] rundll32 advpack.dll,LaunchINFSectionEx nLite.inf,C,,4,N (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\RunOnce: [nltide_3] rundll32 advpack.dll,LaunchINFSectionEx nLite.inf,C,,4,N (User 'Default user')
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~1\OFFICE11\REFIEBAR.DLL
O16 - DPF: {6F15128C-E66A-490C-B848-5000B5ABEEAC} (HP Download Manager) - [You must be registered and logged in to see this link.]
O16 - DPF: {73ECB3AA-4717-450C-A2AB-D00DAD9EE203} (GMNRev Class) - [You must be registered and logged in to see this link.]
O23 - Service: NOD32 Kernel Service (NOD32krn) - Eset - C:\Program Files\Eset\nod32krn.exe
End of file - 3964 bytes
Posts Posts : 9
Joined Joined : 2009-02-01
OS OS : windows xp pro
Points Points : 28660
Solved Re: i need help with problem
Post by Belahzur on Mon Feb 02, 2009 8:37 am
Log looks okay.
  • Double click DDS.scr to run
  • When complete, DDS.txt will open.
  • Click No for Optional Scan.
  • Save the report to your Desktop.
Points Points : 245091
Post by brootaldomination101 on Mon Feb 02, 2009 2:42 pm
i cant go to any of those links cause of the problem Sad tearing so is my last choice going to have to be a format?
Posts Posts : 9
Post by Belahzur on Mon Feb 02, 2009 3:29 pm
No.
I suspect it's tdss.
Link: [You must be registered and logged in to see this link.] or [You must be registered and logged in to see this link.]. <-- this second link should work
Folders to delete:
Post by brootaldomination101 on Mon Feb 02, 2009 9:07 pm
copied clipboard text first time incorrectly
Avenger Pre-Processor log
Platform: Windows XP (build 2600, Service Pack 2)
Mon Feb 02 21:01:03 2009
21:01:03: Error: Invalid script. A valid script must begin with a command directive.
Aborting execution!
Rootkit scan active.
Hidden driver "TDSSserv.sys" found!
ImagePath: \systemroot\system32\drivers\TDSSrftc.sys
Driver disabled successfully.
Rootkit scan completed.
Error: folder "C:\Program Files\Viewpoint" not found!
Deletion of folder "C:\Program Files\Viewpoint" failed!
--> the object does not exist
Completed script processing.
Finished! Terminate.
Posts Posts : 9
Post by Belahzur on Mon Feb 02, 2009 9:14 pm
Lets kill this rootkit.
Drivers to delete:
TDSSserv.sys
Files to delete:
C:\WINDOWS\system32\drivers\TDSSrftc.sys
Then once the rootkit is gone, run this scan for me and I'll answer in the morning, late here.
Post by brootaldomination101 on Mon Feb 02, 2009 10:05 pm
Avenger log
No rootkits found!
Driver "TDSSserv.sys" deleted successfully.
File "C:\WINDOWS\system32\drivers\TDSSrftc.sys" deleted successfully.
Posts Posts : 9
DDS log
DDS (Ver_09-02-01.01) - NTFSx86
Run by Owner at 22:04:25.59 on Mon 02/02/2009
Internet Explorer: 7.0.5730.11
Microsoft Windows XP Professional 5.1.2600.2.1252.1.1033.18.503.260 [GMT -5:00]
svchost.exe
svchost.exe
svchost.exe
C:\WINDOWS\system32\NOTEPAD.EXE
C:\Documents and Settings\Owner\Desktop\dds.scr
mWinlogon: SfcDisable=-99 (0xffffff9d)
uRun: [Aim6]
uRun: [WMPNSCFG] c:\program files\windows media player\WMPNSCFG.exe
mRun: [High Definition Audio Property Page Shortcut] HDAShCut.exe
mRun: [WinampAgent] "c:\program files\winamp\winampa.exe"
mRun: [nod32kui] "c:\program files\eset\nod32kui.exe" /WAITSERVICE
mRun: [IgfxTray] c:\windows\system32\igfxtray.exe
mRun: [HotKeysCmds] c:\windows\system32\hkcmd.exe
mRun: [KernelFaultCheck] %systemroot%\system32\dumprep 0 -k
dRunOnce: [nltide_3] rundll32 advpack.dll,LaunchINFSectionEx nLite.inf,C,,4,N
dRunOnce: [ShowDeskFix] regsvr32 /s /n /i:u shell32
uPolicies-explorer: ForceClassicControlPanel = 1 (0x1)
uPolicies-explorer: NoSMConfigurePrograms = 1 (0x1)
dPolicies-explorer: ForceClassicControlPanel = 1 (0x1)
dPolicies-explorer: NoSMConfigurePrograms = 1 (0x1)
IE: E&xport to Microsoft Excel - c:\progra~1\micros~1\office11\EXCEL.EXE/3000
IE: {92780B25-18CC-41C8-B9BE-3C9C571A8263} - {FF059E31-CC5A-4E2E-BF3B-96E929D65503} - c:\progra~1\micros~1\office11\REFIEBAR.DLL
LSP: c:\windows\system32\imon.dll
DPF: {6F15128C-E66A-490C-B848-5000B5ABEEAC} - [You must be registered and logged in to see this link.]
DPF: {73ECB3AA-4717-450C-A2AB-D00DAD9EE203} - [You must be registered and logged in to see this link.]
Notify: igfxcui - igfxsrvc.dll
SSODL: WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - c:\windows\system32\wpdshserviceobj.dll
FF - ProfilePath - c:\docume~1\owner\applic~1\mozilla\firefox\profiles\itroe9tv.default\
FF - prefs.js: browser.startup.homepage - google.com
FF - plugin: c:\program files\k-lite codec pack\real\browser\plugins\nppl3260.dll
FF - plugin: c:\program files\k-lite codec pack\real\browser\plugins\nprpjplug.dll
FF - plugin: c:\program files\mozilla firefox\plugins\npPandoWebInst.dll
FF - plugin: c:\program files\mozilla firefox\plugins\npViewpoint.dll
FF - plugin: c:\program files\viewpoint\viewpoint media player\npViewpoint.dll
R1 nod32drv;nod32drv;c:\windows\system32\drivers\nod32drv.sys [2008-12-30 15424]
R2 NOD32krn;NOD32 Kernel Service;c:\program files\eset\nod32krn.exe [2008-12-30 552064]
S2 Viewpoint Manager Service;Viewpoint Manager Service;"c:\program files\viewpoint\common\viewpointservice.exe" --> c:\program files\viewpoint\common\ViewpointService.exe [?]
S3 NtApm;NT Apm/Legacy Interface Driver;c:\windows\system32\drivers\NtApm.sys [2008-12-29 9344]
2009-02-01 20:04 --d----- c:\windows\pss
2009-02-01 10:09 --d----- c:\program files\MagicISO
2009-01-30 16:00 2,190 a------- c:\windows\system32\TDSSriqp.dll
2009-01-30 16:00 441 a------- c:\windows\system32\TDSSpaxt.dat
2009-01-30 15:16 --d----- c:\docume~1\owner\applic~1\Malwarebytes
2009-01-30 15:16 15,504 a------- c:\windows\system32\drivers\mbam.sys
2009-01-30 15:16 38,496 a------- c:\windows\system32\drivers\mbamswissarmy.sys
2009-01-30 15:16 --d----- c:\program files\Malwarebytes' Anti-Malware
2009-01-30 15:16 --d----- c:\docume~1\alluse~1\applic~1\Malwarebytes
2009-01-06 16:35 --d----- c:\windows\system32\LogFiles
2009-01-05 23:30 376 a------- c:\windows\ODBC.INI
2009-01-05 23:30 17,920 a------- c:\windows\system32\mdimon.dll
2009-01-05 23:29 --d----- c:\program files\Microsoft ActiveSync
2009-01-05 23:29 --d----- c:\windows\SHELLNEW
2009-01-05 14:34 237 a------- c:\windows\Jakes Alarm Clock.INI
2009-01-05 00:23 --d----- c:\program files\Jakes Alarm Clock
2009-01-05 00:19 54,156 a---h--- c:\windows\QTFont.qfn
2009-01-05 00:19 1,409 a------- c:\windows\QTFont.for
2008-12-31 01:20 73,728 a------- c:\windows\ALCFDRTM.EXE
2008-12-30 23:57 86,327 a------- c:\windows\pchealth\helpctr\offlinecache\index.dat
2008-12-30 13:26 512,096 a------- c:\windows\system32\drivers\amon.sys
2008-12-30 13:26 298,104 a------- c:\windows\system32\imon.dll
2008-12-30 13:26 15,424 a------- c:\windows\system32\drivers\nod32drv.sys
2008-12-29 23:44 21,640 a------- c:\windows\system32\emptyregdb.dat
============= FINISH: 22:04:36.75 ===============
Posts Posts : 9
Post by Belahzur on Tue Feb 03, 2009 8:40 am
Lets finish this off.
Files to delete:
Post by brootaldomination101 on Tue Feb 03, 2009 2:39 pm
No rootkits found!
File "c:\windows\system32\TDSSriqp.dll" deleted successfully.
File "c:\windows\system32\TDSSpaxt.dat" deleted successfully.
Posts Posts : 9
Post by Belahzur on Tue Feb 03, 2009 2:50 pm
Looks good, how is the machine now?
Post by brootaldomination101 on Tue Feb 03, 2009 3:00 pm
works great thanks for the help. much props to you man. im willing to donate for this site Big Grin
Posts Posts : 9
Post by Belahzur on Tue Feb 03, 2009 3:03 pm
Post by Doctor Inferno on Sat May 09, 2009 6:12 am
Since this issue has been addressed, a "solved" tag will be added and this topic will be closed.
Everyone else, please open a [You must be registered and logged in to see this link.] for your questions.
