Nuqel.E and other various little problems
Solved Nuqel.E and other various little problems
Post by stevo322 on 31st January 2009, 1:15 am
I have never been smart about virus protection...and I think its time I start.
I have the Win32/Nuqel.E worm, I can't access my folder options. I get a random white box on the middle of my screen that won't go away...my computer is just screwed up.
I guess we will start with a Hijack This log, I am not so great with computers so forgive any dumb mistakes I make.
Scan saved at 8:06:56 PM, on 1/30/2009
C:\WINDOWS\system32\csrss.exe
C:\Program Files\CDBurnerXP\NMSAccessU.exe
C:\Program Files\Viewpoint\Common\ViewpointService.exe
C:\WINDOWS\explorer.exe
C:\Program Files\Razer\Diamondback 3G\razerhid.exe
C:\DOCUME~1\Stevo\LOCALS~1\Temp\winlognn.exe
C:\WINDOWS\System32\regsvr32.exe
C:\Documents and Settings\Stevo\winlogon.exe
C:\WINDOWS\system32\rundll32.exe
C:\DOCUME~1\Stevo\LOCALS~1\Temp\csrssc.exe
C:\Program Files\Razer\Diamondback 3G\razertra.exe
C:\Program Files\Razer\Diamondback 3G\razerofa.exe
C:\WINDOWS\TEMP\rdl9.tmp
C:\WINDOWS\system32\svschost.exe
C:\WINDOWS\system32\svŮshost.exe
C:\WINDOWS\system32\m3V02\m3V022328.exe
C:\WINDOWS\system32\notepad.exe
C:\Documents and Settings\Stevo\Desktop\hijackgpthis.exe
O2 - BHO: (no name) - {41a4b986-5290-4f3b-89b3-efd4f94c9932} - C:\WINDOWS\system32\cbXOeeDw.dll
O2 - BHO: (no name) - {6d794cb4-c7cd-4c6f-bfdc-9b77afbdc02c} - C:\WINDOWS\system32\opnMgdEx.dll
O2 - BHO: C:\WINDOWS\system32\hgdfeeeh4fdg.dll - {c5bf49a2-94f3-42bd-f434-3604812c8955} - C:\WINDOWS\system32\hgdfeeeh4fdg.dll
O2 - BHO: BHO - {c9c42510-9b21-41c1-9dcd-8382a2d07c61} - C:\WINDOWS\system32\iehelper.dll
O3 - Toolbar: Ask Toolbar - {3041d03e-fd4b-44e0-b742-2d9b88305f98} - C:\Program Files\AskBarDis\bar\bin\askBar.dll
O4 - HKLM\..\Run: [Diamondback] C:\Program Files\Razer\Diamondback 3G\razerhid.exe
O4 - HKLM\..\Run: [jsf8uiw3jnjgffght] C:\DOCUME~1\Stevo\LOCALS~1\Temp\winlognn.exe
O4 - HKLM\..\Run: [quabyvptzqp] C:\WINDOWS\System32\regsvr32.exe /s "C:\WINDOWS\system32\elvbqyweebnw.dll"
O4 - HKLM\..\Run: [Windows Logon Applicationedc] C:\Documents and Settings\Stevo\winlogon.exe
O4 - HKLM\..\Run: [Microsoft Windows Installer] C:\Documents and Settings\Stevo\Application Data\msiexec.exe
O4 - HKLM\..\Run: [Fbazagubin] rundll32.exe "C:\WINDOWS\Kmoje.dll",e
O4 - HKLM\..\Run: [20b5f75f] rundll32.exe "C:\WINDOWS\system32\mybtvcex.dll",b
O4 - HKLM\..\Run: [Srecogevopebasus] rundll32.exe "C:\WINDOWS\uqijobecebepaguh.dll",e
O4 - HKCU\..\Run: [jsf8uiw3jnjgffght] C:\DOCUME~1\Stevo\LOCALS~1\Temp\winlognn.exe
O4 - HKCU\..\Run: [tezrtsjhfr84iusjfo84f] C:\DOCUME~1\Stevo\LOCALS~1\Temp\csrssc.exe
O4 - HKCU\..\Run: [sysguard] C:\WINDOWS\sysguard.exe
O4 - HKCU\..\Run: [A00F5FDD0.exe] C:\DOCUME~1\Stevo\LOCALS~1\Temp\_A00F5FDD0.exe
O4 - HKCU\..\Run: [svschost.exe] C:\WINDOWS\system32\svschost.exe -check
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_05\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_05\bin\ssv.dll
O9 - Extra button: (no name) - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\Spybot\SDHelper.dll
O9 - Extra 'Tools' menuitem: Spybot - Search & Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\Spybot\SDHelper.dll
O20 - AppInit_DLLs: C:\WINDOWS\System32\dmime32.dll cdxlio.dll,C:\WINDOWS\System32\dmime32.dll
O20 - Winlogon Notify: 20b5f7f0517 - C:\WINDOWS\System32\dmime32.dll
O20 - Winlogon Notify: crypt - C:\WINDOWS\SYSTEM32\crypts.dll
O20 - Winlogon Notify: opnmgdex - C:\WINDOWS\SYSTEM32\opnMgdEx.dll
O20 - Winlogon Notify: __c0022fa0 - C:\WINDOWS\system32\__c0022FA0.dat
O22 - SharedTaskScheduler: jgzfkj9w38rksndfi7r4 - {C5BF49A2-94F3-42BD-F434-3604812C8955} - C:\WINDOWS\system32\hgdfeeeh4fdg.dll
O23 - Service: NMSAccessU - Unknown owner - C:\Program Files\CDBurnerXP\NMSAccessU.exe
End of file - 5112 bytes
I guess now I wait until someone much smarter then me replies =P
stevo322
Posts Posts : 7
Joined Joined : 2009-01-31
Points Points : 28670
Solved Re: Nuqel.E and other various little problems
Post by Belahzur on 31st January 2009, 1:35 am
Now would be a good time to start, because you have seriously damaged your machine.
Your system is severly infected. Problem with these infections nowadays is, it causes a lot of damage. Even if we clean the malware off your system, I can't guarantee that your system will be clean afterwards, because these infections/bundles leave a lot of leftovers behind that most scanners won't even recognise and logs won't show.
Also, I can't promise you we can repair all the damage it caused... Even after cleaning the malware, you can still get errors afterwards because of the damage. Solving these is not always possible since it will be searching for a needle in a haystack to find the right cause and solution.
So, we can try to clean this up and do what we can, but keep in mind that we can't solve ALL problems this malware already caused.
In light of this it would be wise for you to back up any files and folders that you don't want to lose before we start. Reason I am telling this is because when a system is so terribly infected and we try to clean this up manually, the damage that is already present may interfere with our removal attempts.
Actually, this doesn't suprise me at all...
I notice that you never scanned with an Antivirus previously before starting this thread - because you don't even have an Antivirus installed!
This is somewhat suicidal in today's digital world.
That's why I want you to install one first!!
* Please install Avira Antivirus: [You must be registered and logged in to see this link.]
This is a free Antivirus.
Perform a full scan with Avira and let it delete everything it is finding.
Then reboot.
After reboot, open your Avira and select "reports".
There doubleclick the report from the Full scan you have done. Click the "Report File" button and copy and paste this report in your next reply together with a new HijackThislog.
Then we'll start from there, because it really makes no sense otherwise that we clean this up manually if an Antivirusscan is not present which should be able to deal with most and prevent further reinfection.
Points Points : 245079
Post by stevo322 on 31st January 2009, 3:28 am
I actually can't use that anti virus program because I get an error that says:
The CRC sum of
C:\DOCUME~1\Stevo\LOCALS~1\Temp\RarSFX0\basic\setup.exe
has been changed! This could be due to a virus!
Do you want to shut down Setup?
And then the only option it gives me is to click OK.
Man...I guess I really did screw my PC up, should I possibly consider just deleting everything on my PC and starting fresh? Also I really appreciate you taking the time to help me, I honestly feel like I owe you some money, taking time out of your day (or night depending on where you live) to help a random person =P. I really do appreciate it.
stevo322
Posts Posts : 7
Post by Belahzur on 31st January 2009, 2:02 pm
It's up to you.
If you start clean, the infection is gone and the damage is fixed.
If you don't, we can remove only what we can, but the damage will remain,
Post by stevo322 on 31st January 2009, 3:00 pm
I am gonna try to reformat, I will post a new Hijack this log once that i
stevo322
Posts Posts : 7
Post by stevo322 on 1st February 2009, 1:29 am
I wiped my system and started from scratch, I assume everything is hopefully fixed, but here is a new hijack this log just in case.
Scan saved at 8:28:44 PM, on 1/31/2009
C:\Program Files\NVIDIA Corporation\NvMixer\NVMixerTray.exe
C:\NVIDIA\NetworkAccessManager\bin\nTrayFw.exe
C:\NVIDIA\NetworkAccessManager\Apache Group\Apache2\bin\apache.exe
C:\NVIDIA\NetworkAccessManager\bin\nSvcIp.exe
C:\NVIDIA\NetworkAccessManager\bin\nSvcLog.exe
C:\NVIDIA\NetworkAccessManager\bin\nSvcAppFlt.exe
C:\WINDOWS\system32\wpabaln.exe
C:\Program Files\Ventrilo\Ventrilo.exe
C:\Games\Steam\Steam.exe
C:\Program Files\Spybot\TeaTimer.exe
O2 - BHO: Spybot-S&D IE Protection - {53707962-6F74-2D53-2644-206D7942484F} - C:\PROGRA~1\Spybot\SDHelper.dll
O4 - HKLM\..\Run: [NVMixerTray] "C:\Program Files\NVIDIA Corporation\NvMixer\NVMixerTray.exe"
O4 - HKLM\..\Run: [nTrayFw] C:\NVIDIA\NetworkAccessManager\bin\nTrayFw.exe
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [MSConfig] C:\WINDOWS\PCHealth\HelpCtr\Binaries\MSConfig.exe /auto
O4 - HKCU\..\Run: [SpybotSD TeaTimer] C:\Program Files\Spybot\TeaTimer.exe
O23 - Service: app_filter - Unknown owner - C:\NVIDIA\NetworkAccessManager\bin\nSvcAppFlt.exe
O23 - Service: Forceware Web Interface (ForcewareWebInterface) - Apache Software Foundation - C:\NVIDIA\NetworkAccessManager\Apache Group\Apache2\bin\apache.exe
O23 - Service: ForceWare IP service (nSvcIp) - Unknown owner - C:\NVIDIA\NetworkAccessManager\bin\nSvcIp.exe
O23 - Service: ForceWare user log service (nSvcLog) - Unknown owner - C:\NVIDIA\NetworkAccessManager\bin\nSvcLog.exe
End of file - 3149 bytes
stevo322
Posts Posts : 7
Post by Belahzur on 1st February 2009, 1:32 am
Log is clean, but still no AV.
After that, should be all good, and I'll post some prevention tips.
Post by stevo322 on 2nd February 2009, 3:33 pm
I downloaded Avira, and a buddy of mine recommended Spybot, but I wanted to make sure I ran it by you first in case you knew of a better program to use. But those tips you offered would be greatly appreciated =P. My PC is running very smooth for the first time in years, and I would love to keep it up.
stevo322
Posts Posts : 7
Post by Belahzur on 2nd February 2009, 4:02 pm
Spybot is okay if you run TeaTimer, but it can also cause some accidents, so I don't really recommend it.
I'd stay with MBAM for on demand scanning. [Remember to update the databse when you scan with it]
Post by stevo322 on 4th February 2009, 10:44 pm
I downloaded MBAM, rand it, it found 11 things and cleaned them, here is the log.
Malwarebytes' Anti-Malware 1.33
Database version: 1728
2/4/2009 5:42:14 PM
mbam-log-2009-02-04 (17-42-14).txt
Objects scanned: 94839
Time elapsed: 1 hour(s), 1 minute(s), 14 second(s)
Registry Keys Infected: 8
Files Infected: 3
HKEY_CLASSES_ROOT\dnscache.dnscacheobj (Trojan.BHO) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{1fd79a59-37b1-459b-9097-09f9fab8a523} (Trojan.BHO) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{b97f9125-71a1-48d0-b920-f140ef8de809} (Trojan.BHO) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{376892ae-1825-4e5f-9f85-23f9640051cc} (Trojan.BHO) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{376892ae-1825-4e5f-9f85-23f9640051cc} (Trojan.BHO) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{376892ae-1825-4e5f-9f85-23f9640051cc} (Trojan.BHO) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\dnscache.dnscacheobj.1 (Trojan.BHO) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\media player classic (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\WINDOWS\mplayerplugin.dll (Trojan.BHO) -> Quarantined and deleted successfully.
C:\Program Files\K-Lite Codec Pack\Tools\CodecTweakTool.exe (Adware.SearchIt99) -> Quarantined and deleted successfully.
C:\Program Files\Media Player Classic\uninstall.exe (Trojan.Downloader) -> Quarantined and deleted successfully.
Here is a new Hijack This just in case.
Scan saved at 5:43:48 PM, on 2/4/2009
C:\Program Files\Avira\AntiVir PersonalEdition Classic\sched.exe
C:\Program Files\Avira\AntiVir PersonalEdition Classic\avguard.exe
C:\WINDOWS\system32\NOTEPAD.EXE
O2 - BHO: (no name) - {1FD79A59-37B1-459B-9097-09F9FAB8A523} - (no file)
O4 - HKLM\..\RunOnce: [Malwarebytes' Anti-Malware] C:\Program Files\Malwarebytes' Anti-Malware\mbamgui.exe /install /silent
O23 - Service: Avira AntiVir Personal - Free Antivirus Scheduler (AntiVirScheduler) - Avira GmbH - C:\Program Files\Avira\AntiVir PersonalEdition Classic\sched.exe
O23 - Service: Avira AntiVir Personal - Free Antivirus Guard (AntiVirService) - Avira GmbH - C:\Program Files\Avira\AntiVir PersonalEdition Classic\avguard.exe
O23 - Service: Forceware Web Interface (ForcewareWebInterface) - Unknown owner - C:\NVIDIA\NetworkAccessManager\Apache Group\Apache2\bin\apache.exe (file missing)
O23 - Service: ForceWare IP service (nSvcIp) - Unknown owner - C:\NVIDIA\NetworkAccessManager\bin\nSvcIp.exe (file missing)
O23 - Service: ForceWare user log service (nSvcLog) - Unknown owner - C:\NVIDIA\NetworkAccessManager\bin\nSvcLog.exe (file missing)
End of file - 2620 bytes
Is there anything I should still do?
stevo322
Posts Posts : 7
Post by Belahzur on 4th February 2009, 10:52 pm
Log looks okay, MBAM found a few thing, could be a false positive though, if the files were packed in UPX.
You still have minimum protection here, we need to keep you secure.
Post by stevo322 on 5th February 2009, 3:23 pm
You want me to download and use all those spyware programs? or just pick one?
Also, I don't know if you play any Half-Life 2 games, but I am having bad connection problems with the Steam network, could that be caused by something from my logs? or is it something that you wouldn't be able to help with much?
Reason I ask is because I have been plagued with connection problems with Steam. I have tried everything, I understand this probably isn't your field of expertise but I figured I would ask =P
stevo322
Posts Posts : 7
Post by Belahzur on 5th February 2009, 3:56 pm
Just install two.
Don't think I can help you with the Steam connection, no idea on that part.
Post by Doctor Inferno on 9th May 2009, 10:18 am
Since this issue has been addressed, a "solved" tag will be added and this topic will be closed.
Everyone else, please open a [You must be registered and logged in to see this link.] for your questions.
Points Points : 104610
Post by Doctor Inferno on 9th May 2009, 10:19 am
