system recovery for pc Help Please!!!!
Solved system recovery for pc Help Please!!!!
Post by chico on Sat Jan 31, 2009 12:15 am
i recently did a system recovery on my computer and it said it would save the files that were created by me but i cant seem to find them i have done the following things
1.)i click on "my computer"and clicked on the the "c"hard drive to look there but nothing
2.)searched using the windows search feature on that come on every windows pc
thanks in advance
chico
OS : microsoft
Solved Re: system recovery for pc Help Please!!!!
Post by Jerry Parnell on Sat Jan 31, 2009 1:13 am
By recovery, do you mean that you re-installed Windows?
Sometimes when you reinstall, it can save your files. Other times, it cannot. This will just depend on if you chose to format or not, and what OS you had.
Click the button below if you would like to give this website a good rating on stumbleapon.
https://i73.servimg.com/u/f73/12/53/83/84/usebar11.png
Jerry Parnell
OS : Windows Vista Home Basic
Post by Sir $wat on Sat Jan 31, 2009 1:25 am
have u checked the desktop itself?
OS : Windows XP Professional SP3
Post by chico on Sun Feb 01, 2009 1:31 am
yeah i t reinstalled it putting it back to when i first bought it i always had windows on it
what do you mean search the desktop??
chico
OS : microsoft
Post by Doctor Inferno on Sun Feb 01, 2009 1:51 am
If you recover it back to when you first bought it, all your files are gone.
Post by chico on Mon Feb 02, 2009 11:19 pm
but it shows that my hard drive only has 6 g.b left so im guessin it still there?
chico
OS : microsoft
Post by Doctor Inferno on Tue Feb 03, 2009 10:03 am
Ok, open Windows Explorer and and see if there is a folder on the C drive called windows.old
If there is, it should be inside.
Post by chico on Wed Feb 04, 2009 12:46 am
yeah it wasn't there, but my friend just told me to search my hard drive using an external hard drive
chico
OS : microsoft
Post by Doctor Inferno on Wed Feb 04, 2009 8:43 am
Why would you need to perform a search using your external hard drive? YOu can use the search feature in windows.
Post by chico on Mon Feb 09, 2009 9:41 pm
windows is prevents me from entering certain folders
chico
OS : microsoft
Post by chico on Thu Feb 19, 2009 11:32 pm
thanks for the help it turns out that my computer didnt end up saving the files
chico
OS : microsoft
