Help with spore =s? Won't load...
Solved Help with spore =s? Won't load...
Post by jimybob3 on 28th January 2009, 2:14 am
I don't know if i am posting this in the right place or if i am even alowed to post about this sort fo thing here buy... oh well you can delete if you want.
OK, so i installed spore again after a long while and when i went to load the game i get an error saying this:
Runtime Error!
Program D:\sporebin\sporeapp.exe
r6025
-pire virtual function call
i don't have a clue in the world on how to get the game running, i am on windows vista ultimate 32bit, 2gb ram amd 6x x2 4400+ processor, nvidia 9600gt 512mb OBM. way above the min requirements. i have tried to re install game in different places, and have alo tried re installing graphics driver... and i cannot get the damned thing running, please help! =(
jimybob3
Posts Posts : 54
Joined Joined : 2009-01-03
OS OS : vista
Points Points : 28986
Solved Re: Help with spore =s? Won't load...
Post by Doctor Inferno on 28th January 2009, 8:27 am
I noticed it is running off the (D) drive. Some softwares won't work properly when it is not installed in the same partition as the OS. Have you tried installing it in the C drive?
Points Points : 104630
Post by Jerry Parnell on 29th January 2009, 12:41 am
Have you made sure your .net framework is up to date?
Jerry Parnell
Posts Posts : 670
Joined Joined : 2008-08-04
OS OS : Windows Vista Home Basic
Points Points : 30754
