System Problems - MCI command handling window
Solved System Problems - MCI command handling window
Post by Voods on Tue 27 Jan 2009, 9:50 pm
I've recentley started having problems with my system again. It has been running awfully slow, especially when online. It also keeps rebooting itself. It seems there is something trying to access my usb drive frequently too, even when my computer is static.
I am behind a firewall, and havent noticed any traffic coming in, and I don't appear to have any spyware/malware, at least I hope I don't.
Also I keep getting the windows explorer needs to close message, then my computer locks up completely.
Any help would be appreciated
Regards
Dave
Last edited by Doctor Inferno on Sun 08 Feb 2009, 8:53 pm; edited 4 times in total (Reason for editing : Solved one of the problems.)
Voods
Senior Surfer
Senior Surfer
Operating System : Windows 7 Professional
Solved Re: System Problems - MCI command handling window
Post by Sir $wat on Thu 29 Jan 2009, 11:09 am
you should post a HJT log in the appropriate section and they'' help u out ASAP
Master Surfer
Master Surfer
Operating System : Windows XP Professional SP3
Post by Doctor Inferno on Thu 29 Jan 2009, 8:49 pm
Let's try Digitalocksmith's earlier solution on some else's topic for the explorer crashes.
Digitalocksmith wrote:Ok......Often Windows Explorer crashes are also caused by 3rd party shell extensions that are not functioning properly.
To try and find if a 3rd party shell extension is causing your Windows Explorer to crash on certain actions, you'll need to download this file below.
It will let you view & disable shell extensions.
http://www.snapfiles.com/get/shellexview.html
After you downloaded & executed it, ShelExView will show all shell extensions installed on your system.
You could sort the entries so that you'll have all non Microsoft shell extensions grouped together.
Next, select all these non Microsoft shell extensions, and disable them.
If this does not help with the issue then we need to go to the next level and do some debugging!
From: http://www.geekpolice.net/operating-systems-f20/windows-explorer-again-t5370.htm#30780
Let us know how you go.
The GeekPolice
The GeekPolice
Post by Voods on Sun 01 Feb 2009, 11:28 pm
Thanks for that. I follow the steps and see how we go. Will disabling the non Microsoft shells stop some of my apps/programs from working?
Dave
Voods
Senior Surfer
Senior Surfer
Post by Doctor Inferno on Sun 01 Feb 2009, 11:42 pm
Nope, it won't.
The GeekPolice
The GeekPolice
Post by vikneshwaren on Mon 02 Feb 2009, 1:47 am
Scan ur pc with MBAM and post your log...Plz mention what antivirus u have in ur pc?
vikneshwaren
Senior Surfer
Senior Surfer
Operating System : Microsoft Windows 7 Ultimate
Post by Voods on Mon 02 Feb 2009, 4:11 am
Hi
I have done the scan, and no threats were found, I can still post the log if you need.
I am using Kaspersky 2009, and hacker smacker for the firewall. I was using ZoneAlarm Pro, before my license expired
Is this an appropiate place to post a HJT Log?
Regards
Voods
Senior Surfer
Senior Surfer
Post by Voods on Mon 02 Feb 2009, 7:31 am
When I rebooted my system after disabling the non-Microsoft shells. I got the message..
"Windows can't shutdown MCI command handling window"
I've never seen this before. I restored the shells that I disabled, and to no avail. I haven't made any other changes to my system.
Regards
Dave
Voods
Senior Surfer
Senior Surfer
Post by Doctor Inferno on Mon 02 Feb 2009, 7:50 pm
Voods wrote: "Windows can't shutdown MCI command handling window"
There should be more to that message, can you provide the whole message?
The GeekPolice
The GeekPolice
Post by Voods on Mon 02 Feb 2009, 9:23 pm
Yeah, sorry about that.
End Program - MCI command handling window" cant shut down
This appears in the end program dialogue box, my system hangs for a short while when I choose to end the the program.
Regards
Voods
Senior Surfer
Senior Surfer
Post by Doctor Inferno on Mon 02 Feb 2009, 9:40 pm
Ah. I was expecting there to be some application name behind. Anyway, try this, download CCleaner:
http://www.filehippo.com/download_ccleaner/
Clear the temporary files and the registry, if it asks to you backup the registry allow it to do so.
Do you still have the same problem?
The GeekPolice
The GeekPolice
Post by Voods on Tue 03 Feb 2009, 10:33 am
Ok I did that and still had the same problem. But I did update my "cc" and the problem did not happen. After 4 reboots the message has come back, and I am still getting heinously slow startup and boot down times.
I've checked my autostart entries for this and there isn't much there, and i've also disabled automatic updates to see if that was an issue...
So maybe I should do a reboot?
Regards
Voods
Senior Surfer
Senior Surfer
Post by Doctor Inferno on Wed 04 Feb 2009, 1:02 am
If it worked properly 4 times then it should be something creating a certain temp file or registry key causing this.
Start >> msconfig >> startup tab find anything similar to Media Control Interface or MCI and uncheck it.
In the services tab find anything similar to Media Control Interface or MCI and uncheck it.
The GeekPolice
The GeekPolice
Post by Voods on Sat 07 Feb 2009, 5:37 am
Ok, all appears to be ok now. Much thanks.. I'll Keep watch!
Regards
Last edited by Voods on Sat 07 Feb 2009, 10:20 am; edited 2 times in total (Reason for editing : solved)
Voods
Senior Surfer
Senior Surfer
Post by Doctor Inferno on Sat 07 Feb 2009, 12:15 pm
Ah! I didn't expect such a simple solution to solve the problem. Glad it's solved.
The GeekPolice
The GeekPolice
Post by Voods on Sat 14 Feb 2009, 12:26 am
Sorry couldn't delete my post
Last edited by Voods on Sat 14 Feb 2009, 3:08 am; edited 1 time in total (Reason for editing : solved)
Voods
Senior Surfer
Senior Surfer
Post by Sponsored content Today at 6:13 am
