GeekPolice is a website which provides free Computer Technical Support & Virus/Spyware Removal to our members.
Take 30 seconds to register below and unlock the limitations of this website to discover new computer knowledge!
How to Remove System Guard 2009 [Removal Guide]
Page 1 of 2 1, 2  Next
Post by Doctor Inferno on Mon 26 Jan 2009, 9:51 pm
This guide will give you easy instructions on how to remove System Guard 2009 for free.
What is System Guard 2009? (Information)
System Guard 2009 is a fake security software which uses fraudulent strategies by displaying false or exaggerated security issues on your computer rather than any legitimate ones to coerce you into purchasing their software.
System Guard 2009 Screenshot:
Symptoms in a HijackThis Log:
O4 - HKLM\..\Run: [systemguard] C:\Program Files\System Guard 2009\systemguard.exe
O21 - SSODL: ieModule - {77C96E10-FDA7-4AA7-B318-0631C0D27DBB} - C:\Documents and Settings\All Users\Application Data\Microsoft\Network\DLLs\ieModule.dll
O21 - SSODL: InternetConnection - {AB6DAA8C-F726-4FDD-8B06-9537C5878612} - C:\Documents and Settings\All Users\Application Data\Microsoft\Network\DLLs\eewhptdpyl.dll
1. Please download this official version of Malwarebytes' Anti-Malware.
2. Install Malwarebytes' Anti-Malware by double clicking on mbam-setup
4. Malwarebytes' Anti-Malware will automatically update itself after the installation, click the OK button to close that box and you will now be at the main program Window as shown below.
If you are having problems with the updater, you can use this link to manually update Malwarebytes' Anti-Malware with the latest database. Make sure that Malwarebytes' Anti-Malware is closed before installing the update.
5. Close All opened Windows, Programs, File or Folders.
6. Make sure you are on the Scanner tab. Select Perform quick scan then click the Scan button as shown below.
8. When the scan is finished a message box will appear, click OK to continue.
9. Click Show Results.
11. Click on Remove selected.
12. When removing the files, Malwarebytes' Anti-Malware may require you to restart the computer in order to do a complete removal. If it displays a message stating that it needs to restart, click Yes.
13. After that you can close the Malwarebytes' Anti-Malware window, your computer is now cleaned from the malware infection.
To protect and prevent your computer from experiencing future threats like this, we highly recommend purchasing the FULL version of Malwarebytes' Anti-Malware with real-time protection from this link.
Malicious files associated with System Guard 2009 (click):
Spoiler:
c:\Program Files\System Guard 2009
c:\Program Files\System Guard 2009\conf.cfg
c:\Program Files\System Guard 2009\mbase.vdb
c:\Program Files\System Guard 2009\quarantine.vdb
c:\Program Files\System Guard 2009\queue.vdb
c:\Program Files\System Guard 2009\systemguard.exe
c:\Program Files\System Guard 2009\uninstall.exe
c:\Program Files\System Guard 2009\vbase.vdb
c:\WINDOWS\reged.exe
c:\WINDOWS\spoolsystem.exe
c:\WINDOWS\sys.com
c:\WINDOWS\syscert.exe
c:\WINDOWS\sysexplorer.exe
c:\WINDOWS\vmreg.dll
c:\WINDOWS\system32\winscenter.exe
c:\Documents and Settings\GeekPolice\Desktop\System Guard 2009.lnk
c:\Documents and Settings\GeekPolice\Start Menu\Programs\System Guard 2009
c:\Documents and Settings\GeekPolice\Start Menu\Programs\System Guard 2009\System Guard 2009.lnk
c:\Documents and Settings\GeekPolice\Start Menu\Programs\System Guard 2009\Uninstall.lnk
c:\Documents and Settings\All Users\Application Data\winlogon.exe
c:\Documents and Settings\All Users\Application Data\Microsoft\Network\svchost.exe
c:\Documents and Settings\All Users\Application Data\Microsoft\Network\track.sys
c:\Documents and Settings\All Users\Application Data\Microsoft\Network\DLLs
c:\Documents and Settings\All Users\Application Data\Microsoft\Network\DLLs\c.cgm
c:\Documents and Settings\All Users\Application Data\Microsoft\Network\DLLs\eewhptdpyl.dll
c:\Documents and Settings\All Users\Application Data\Microsoft\Network\DLLs\ieModule.dll
c:\Documents and Settings\All Users\Application Data\Microsoft\Network\DLLs\moduleie.dll
If you are still experiencing problems or difficulties following this guide or require any assistance removing this malware, please post your questions in our Virus, Spyware & Malware Removal forums for free help.
You have to be logged in to post questions. Registration is free. By registering you will be privileged to other resources and to ask questions.
Last edited by Doctor Inferno on Sat 29 May 2010, 12:10 am; edited 12 times in total (Reason for editing : Information Update)
The GeekPolice
The GeekPolice
Re: How to Remove System Guard 2009 [Removal Guide]
Post by kcline on Mon 23 Feb 2009, 6:22 pm
I have downloaded the malwarebytes removal tool but when I try to run it I loose the whole internet page and have to start over. Any suggestions?
kcline
Unborn
Unborn
Operating System: Windows XP
Post by Belahzur on Mon 23 Feb 2009, 6:24 pm
Can you try posting us a Hijack This log?
Please download the current version of HijackThis from HERE
If I have helped, please consider a donation to help keep us alive.
"Faith through unity. Unity through faith."
Manager | Tech Officer
Operating System: XP SP3 Media Centre
Post by awhite23 on Sun 01 Mar 2009, 9:35 pm
This is the virus I am trying to conquer on my PC, unfortuneately it has completely taken over. Anytime I go to any virus protection site, my I.E will disappear. I can not download the Malwarebytes nor can I download the HiJack form. What else can I do?
awhite23
Unborn
Unborn
Operating System: compaq
Post by Doctor Inferno on Mon 02 Mar 2009, 1:52 am
Are you able to download HijackThis from any of the links provided here?
http://www.geekpolice.net/HiJackThis-202-Download-h1.htm
The GeekPolice
The GeekPolice
Post by awhite23 on Tue 03 Mar 2009, 11:00 pm
No =(
awhite23
Unborn
Unborn
Post by Belahzur on Wed 04 Mar 2009, 8:28 am
It's TDSS, if you want help awhite, please open a thread in the Hijack This log area.
Post by Micutzu_BH on Sun 10 May 2009, 3:25 pm
I had a problem (System Guard 2009) with my PC and I solved all with the help of your forum. Thanks a lot!
Micutzu_BH
Unborn
Unborn
Post by tmitev23 on Sat 23 May 2009, 11:35 am
Hi there i downloaded MalwareBytes but when i start to download there an error occured - error:399 or somethinglike that and i cannot start the malware, please help me
tmitev23
Unborn
Unborn
Post by Origin on Sat 23 May 2009, 12:44 pm
Hello tmitev23,
Seems you might have a rootkit, please start a new thread here post a HijackThis log:
http://www.geekpolice.net/virus-spyware-malware-removal-f11/
While my help is always free, please consider donating to keep this site alive: Donate
Tech Staff
Tech Staff
Operating System: Windows Xp Sp3
Post by computeruser on Sat 23 May 2009, 11:24 pm
somehow an antivirus got downloaded on my computer...its called WnPC Antivirus...please help me to get it off
computeruser
Unborn
Unborn
Operating System: xp
Post by Doctor Inferno on Sun 24 May 2009, 4:48 am
computeruser wrote:somehow an antivirus got downloaded on my computer...its called WnPC Antivirus...please help me to get it off
Please read this: http://www.geekpolice.net/-t3821.htm
And post your HijackThis log here: http://www.geekpolice.net/virus-spyware-malware-removal-f11/
The GeekPolice
The GeekPolice
help
Post by airtas on Wed 10 Jun 2009, 8:54 pm
I ran the program and can not connect to the internet now?
airtas
Post by Chevy396z on Thu 25 Jun 2009, 8:44 am
Hey folks.
Found you through a search on malware removal for the bankerfox.a problem.
Windows XP, AVG antivirus.
At first it was just a nuisance. Now I can't get to the internet Am writing from a spare computer.
I've read the thread on "How to Remove System Guard 2009 [Removal Guide]". I tried downloading the recommended software to another computer on a wired network and scanning the infected computer. The program just hangs.
What should my first steps be? Many thanks in advance.
Mark
My apologies for posting this in the intro section
Chevy396z
Post by VincentUkikiMonkey on Thu 25 Jun 2009, 3:51 pm
Hello,I'm new...I can't open any files or programs...Everything that I download,I can't install it...Anything...How do I remove System Security if I can't open or install anything?
(sorry,my english in not very good,but I need to help)...
VincentUkikiMonkey
Unborn
Unborn
