ActiveX Controls help please (hurry)
Solved ActiveX Controls help please (hurry)
Post by zhengs on Sat 24 Jan 2009, 9:59 am
i got a message saying this:
One or more ActiveX controls could not be displayed because either:
1) Your current security settings prohibit running ActiveX controls on this page, or
2) You have blocked a publisher of one of the controls
As a result the page may not display correctly.
zhengs
Senior Surfer
Senior Surfer
Operating System : Windows Vista
Solved Re: ActiveX Controls help please (hurry)
Post by Doctor Inferno on Sat 24 Jan 2009, 9:58 pm
You're using IE7 right? What website gives you this message?
Go to Tools >> Options >> Security Tab and choose Default Level for the Internet Zone. That should prompt you for a question to "Run the ActiveX" instead of blocking it.
You should be careful with allowing ActiveX controls, they could be malicious.
The GeekPolice
The GeekPolice
Post by zhengs on Sun 25 Jan 2009, 1:44 am
i did put of default level but it keeps poping up saying it...
zhengs
Senior Surfer
Senior Surfer
Post by Doctor Inferno on Sun 25 Jan 2009, 2:07 am
IE7 will block all ActiveX controls from running in the browser except for controls that were explicitly intended for the browser. That list is under the userís control. Of course, to keep mainstream web sites running, the most commonly used, clearly intended for the web, ActiveX controls (like Flash) will be on that list by default.
The control may not be intended only for the browser from that site.
You should make sure you have the latest version of IE7 and all microsoft security updates. If you still have a problem download Firefox and use it, it is better and faster anyway.
The GeekPolice
The GeekPolice
Post by zhengs on Sun 25 Jan 2009, 2:14 am
i don't use IE7 no more...but i use Firefox...
zhengs
Senior Surfer
Senior Surfer
Post by Agent Cosmic on Sun 25 Jan 2009, 12:56 pm
According to my knowledge, Firefox does not support ActiveX. You would have to switch to IE to use it. Please provide us the link to the site you are referring to so that we have a better understanding of what is going on.
Manager | Developer
Manager | Developer
View user profile http://twitter.com/AgentCosmic/
Post by Sponsored content Today at 2:44 am
