I downloaded hijackthis and it seems to work and then nothing happens
Post by Heidilla on 10th January 2009, 1:47 pm
I'm trying to download hijackthis and it seems to work and then nothing happens. My computer is really messed up and I would like some help. It is really slow, I think it has a spyware/adware thing on it and I'm not very good at figuring this out. I tried to run the download of HJT and nothing is happening. I have windows xp. not sure what else to do.
Heidilla
Joined Joined : 2009-01-10
OS OS : windows xp home edition
Points Points : 28890
Re: I downloaded hijackthis and it seems to work and then nothing happens
Post by Belahzur on 10th January 2009, 2:14 pm
2. Now, start The Avenger program by clicking on its icon on your desktop.
  • Leave the script box empty.
3. Please copy/paste the content of c:\avenger.txt into your reply.
  • Double click DDS.scr to run
  • When complete, DDS.txt will open.
  • Click No for Optional Scan.
  • Save the report to your Desktop.
Points Points : 245091
Post by Doctor Inferno on 2nd March 2009, 10:01 am
Due to lack of feedback, this topic is closed.
