Problem with Ubuntu
Problem with Ubuntu
Post by drak2223 on Sun 04 Jan 2009, 6:41 pm
Well I dual booted Vista and Ubuntu today.My problem is it doesn't detect my router(i'm on a laptop) and Windows Vista detects it.I need to fix this problem since I will be getting slackware later and I don't want this problem to happen with that distro.If it helps my router is a Belkin. Thanks
Drak aka B1uEScreen
Edit:I think it may be my router its old belkin model and I have heard stories Linux doesn't pick up belkins i'll switch to a linksys
drak2223
Unborn
Unborn
Operating System : Linux and Windows
Re: Problem with Ubuntu
Post by Digitalocksmith on Sun 04 Jan 2009, 8:38 pm
Please run a "sudo lspci" from the command prompt to see if it's being detected. hopefully that should throw up your card....
After that, run "sudo ifconfig -a" to list the status of your network cards....
Finally, run "sudo ifconfig eth0 up"
Post the results back here.
Regards
Digitalocksmith
Advanced Surfer
Advanced Surfer
Operating System : Windows 7 Ultimate x64 beta 1 (build 7048) - Testing Bluewhite64 Linux 12.2
