Troj/Rustok-N help with removing please
Page 2 of 2 Previous  1, 2
Solved Re: Troj/Rustok-N help with removing please
Post by Belahzur on Fri Jan 02, 2009 10:31 pm
Copy all of what is in the box.
Post by zhengs on Fri Jan 02, 2009 10:42 pm
okay,it's done. here is the log:
Platform: Windows XP
Rootkit scan active.
No rootkits found!
Driver "msqpdxserv.sys" deleted successfully.
File "C:\WINDOWS\system32\drivers\msqpdxntidbwuc.sys" deleted successfully.
Completed script processing.
Finished! Terminate.
what i do next?
zhengs
OS : Windows Vista
Post by Belahzur on Fri Jan 02, 2009 10:46 pm
The rootkit is now dead. Smile
Please run another MBAM scan to be sure.
Post by zhengs on Fri Jan 02, 2009 10:59 pm
so the trojan is removed?? Let me think
if so,how you know?
and do i perform a full screen or quick scan for mbam?
zhengs
OS : Windows Vista
Post by Belahzur on Fri Jan 02, 2009 11:04 pm
This is how:
The driver was deleted.
The file was deleted.
Post by zhengs on Fri Jan 02, 2009 11:17 pm
and do i do a quick scan or full scan??
zhengs
OS : Windows Vista
Post by Belahzur on Fri Jan 02, 2009 11:19 pm
Quick scan.
If it's clean and no problems remain, we'll pass this off as clean.
Post by zhengs on Fri Jan 02, 2009 11:24 pm
and Thank you so much that i even thought that i can't even remove this trojan.. Thank You!
and thanks for your time helping me removing it and i kept going to places searching how to remove and looking.....well thanks alot Right On!
zhengs
OS : Windows Vista
Post by Belahzur on Fri Jan 02, 2009 11:37 pm
I'd say were done here.
Post by zhengs on Sat Jan 03, 2009 12:15 am
by the way,got any good anti virus software besides the list you gave up above??
zhengs
OS : Windows Vista
Post by Belahzur on Sat Jan 03, 2009 12:18 am
2) [You must be registered and logged in to see this link.]
-Anti-virus program for Windows.
-The home edition is freeware for noncommercial user.
3) [You must be registered and logged in to see this link.]
- Free edition of the AVG anti-virus program for Windows.
- Available for single computer use for home and non commercial use.
Post by zhengs on Sat Jan 03, 2009 12:23 am
and do you got any good software that let's you know when your entering a bad website that can give you virus or trojan
zhengs
OS : Windows Vista
Post by Belahzur on Sat Jan 03, 2009 12:24 am
Well if you took my advice on using Firefox, Firefox will tell you if the site you are visiting is a known attack site.
Post by zhengs on Sat Jan 03, 2009 12:33 am
ok i'll try that thank you. and do you want to be friends? Annoyed or Unimpress
zhengs
OS : Windows Vista
Post by Belahzur on Sat Jan 03, 2009 12:35 am
LOL Banner LOL Banner LOL Banner
Feel free to stick around if that's what you mean.
Post by zhengs on Sat Jan 03, 2009 12:46 am
is there a anti virus software call java something??
zhengs
OS : Windows Vista
Post by Belahzur on Sat Jan 03, 2009 12:48 am
Anti-virus and anti-spyware are different things.
Webroot spysweeper is (I think) owned by someone called Java.
There is also JavaRa (old) Java remover.
Post by zhengs on Sat Jan 03, 2009 12:56 am
okay,done with scaning and restore point. my computer is not running so slow like before now. ok i'll been seeing you next time if i have problems :victory:
and for the scan, it's clean
zhengs
OS : Windows Vista
Post by zhengs on Sat Jan 03, 2009 1:02 am
do i also delete or remove the downloads you told me to download for the trojan?
zhengs
OS : Windows Vista
Post by Belahzur on Sat Jan 03, 2009 1:10 am
Yes, please delete the tools we used.
Post by zhengs on Sat Jan 03, 2009 1:18 am
what do you suggest of me downloading which anti-virus software ?
zhengs
OS : Windows Vista
Post by Belahzur on Sat Jan 03, 2009 1:22 am
Preferably avast or avira, AVG doesn't like one of our best tools and if we need to use that for any reason, then we can't.
Post by zhengs on Sat Jan 03, 2009 3:31 am
what is service pack 2 for??
zhengs
OS : Windows Vista
Post by Doctor Inferno on Sat Jan 03, 2009 3:36 am
Service pack 2 include many security and bug patches for better defense against viruses, worms, and hackers.
Post by zhengs on Sat Jan 03, 2009 3:42 am
is there a service pack 3for XP ??
zhengs
OS : Windows Vista
is there a service pack 3 for XP ??
zhengs
OS : Windows Vista
Post by Doctor Inferno on Sat Jan 03, 2009 3:51 am
Yes.
Post by zhengs on Sat Jan 03, 2009 3:58 am
and by the way someone just help me removed Troj/Rustok-N and i thinking that it might still be there...
zhengs
OS : Windows Vista
Post by Belahzur on Sat Jan 03, 2009 2:33 pm
Trust us, the troj/rustock isn't there anymore, otherwise you really would know.
Post by Doctor Inferno on Sat Feb 21, 2009 9:58 am
