Troj/Rustok-N help with removing please
Page 1 of 2 1, 2  Next
Solved Re: Troj/Rustok-N help with removing please
Post by Belahzur on Fri Jan 02, 2009 8:51 pm
Copy all of it to a notepad file and save it somewhere, like your desktop.
Then if it's small, post it here. If not, upload it at sendspace.com
Points Points : 245069
Post by zhengs on Fri Jan 02, 2009 8:52 pm
for the sendspace thing.it needs the recipient e-mail.....
zhengs
Posts Posts : 228
Joined Joined : 2009-01-02
OS OS : Windows Vista
Points Points : 30465
Post by Belahzur on Fri Jan 02, 2009 8:53 pm
No it doesn't, it says (optional)
Leave the optionals blank.
Post by zhengs on Fri Jan 02, 2009 8:53 pm
nope.....it's to big
zhengs
Posts Posts : 228
Post by zhengs on Fri Jan 02, 2009 8:54 pm
oh okay,sorry didn't see it
zhengs
Posts Posts : 228
so all i do it upload it and how you gonna get it??
zhengs
Posts Posts : 228
Post by Belahzur on Fri Jan 02, 2009 8:55 pm
When you upload it, it gives you a URL to use.
Post by zhengs on Fri Jan 02, 2009 8:59 pm
address not found.can't find the server. can't upload cause of this
zhengs
Posts Posts : 228
Post by Belahzur on Fri Jan 02, 2009 9:01 pm
Okay, look through the log yourself, probably down the bottom of the log somewhere, there might be a line that says this:
"<--- ROOTKIT !!!!"
If there is, please let me know.
Post by zhengs on Fri Jan 02, 2009 9:05 pm
ok i fix out the problem.it was my firewall.
zhengs
Posts Posts : 228
im uploading the text of the scan now
zhengs
Posts Posts : 228
Post by zhengs on Fri Jan 02, 2009 9:08 pm
[You must be registered and logged in to see this link.] this is the download link
zhengs
Posts Posts : 228
Post by zhengs on Fri Jan 02, 2009 9:14 pm
and by the way is the ROOTKIT in red in the GMer scan??
zhengs
Posts Posts : 228
Post by Belahzur on Fri Jan 02, 2009 9:17 pm
Yes, there is infact TWO rootkits we need to kill.
Link: [You must be registered and logged in to see this link.] or [You must be registered and logged in to see this link.]. <== the first link maybe blocked, so use the second link
2. Now, start The Avenger program by clicking on its icon on your desktop.
  • Leave the script box blank.
3. Please copy/paste the content of c:\avenger.txt into your reply.
Post by zhengs on Fri Jan 02, 2009 9:26 pm
isn't 6 rootkit we need to kill??
zhengs
Posts Posts : 228
Post by Belahzur on Fri Jan 02, 2009 9:27 pm
I just had a brief look at the log and noticed two rootkits, if there's more, the avenger will take them down also.
Post by zhengs on Fri Jan 02, 2009 9:30 pm
and so i check the box for "scan for rootkits" and check the box "disable any rootkits found" ??
zhengs
Posts Posts : 228
Post by Belahzur on Fri Jan 02, 2009 9:32 pm
Scan for rootkits should already be ticked.
Then tick the "Disable any rootkits found"
Then press the execute button.
Post by zhengs on Fri Jan 02, 2009 9:37 pm
it say:
first step completed --- The Avenger has been successfully set up to run on next boot . reboot now?
yes no
zhengs
Posts Posts : 228
Post by Belahzur on Fri Jan 02, 2009 9:37 pm
Yes.
Post by zhengs on Fri Jan 02, 2009 9:50 pm
okay it's done....this what it says:
Platform: Windows XP
Rootkit scan active.
Hidden driver "msqpdxserv.sys" found!
ImagePath: \systemroot\system32\drivers\msqpdxntidbwuc.sys
Driver disabled successfully.
Rootkit scan completed.
Completed script processing.
Finished! Terminate.
zhengs
Posts Posts : 228
Post by Belahzur on Fri Jan 02, 2009 9:57 pm
We need to delete the rootkit now.
Drivers to delete:
msqpdxserv.sys
Files to delete:
C:\WINDOWS\system32\drivers\msqpdxntidbwuc.sys
5. Please copy/paste the content of c:\avenger.txt into your reply.
Post by zhengs on Fri Jan 02, 2009 10:04 pm
what text contained in the code box?? and what clip board??
zhengs
Posts Posts : 228
Post by Belahzur on Fri Jan 02, 2009 10:14 pm
Clipboard is that copy/paste is called in tech terms.
The code box above with the Drivers to delete/files to delete.
Post by zhengs on Fri Jan 02, 2009 10:22 pm
so do i also copy and paste the driver to delete and file to delete thing to the avenger box??
another question is do i just copy and paste the files name and drivers name above to delete in the avenger box??
zhengs
Posts Posts : 228
Post by Belahzur on Fri Jan 02, 2009 10:31 pm
Copy all of what is in the box.
Post by zhengs on Fri Jan 02, 2009 10:42 pm
okay,it's done. here is the log:
No rootkits found!
Driver "msqpdxserv.sys" deleted successfully.
File "C:\WINDOWS\system32\drivers\msqpdxntidbwuc.sys" deleted successfully.
what i do next?
zhengs
Posts Posts : 228
Post by Belahzur on Fri Jan 02, 2009 10:46 pm
The rootkit is now dead. Smile
Please run another MBAM scan to be sure.
Post by zhengs on Fri Jan 02, 2009 10:59 pm
so the trojan is removed?? Let me think
if so,how you know?
and do i perform a full screen or quick scan for mbam?
zhengs
Posts Posts : 228
Post by Belahzur on Fri Jan 02, 2009 11:04 pm
This is how:
The driver was deleted.
The file was deleted.
Post by zhengs on Fri Jan 02, 2009 11:17 pm
and do i do a quick scan or full scan??
zhengs
Posts Posts : 228
Post by Belahzur on Fri Jan 02, 2009 11:19 pm
Quick scan.
If it's clean and no problems remain, we'll pass this off as clean.
Post by zhengs on Fri Jan 02, 2009 11:24 pm
and Thank you so much that i even thought that i can't even remove this trojan.. Thank You!
and thanks for your time helping me removing it and i kept going to places searching how to remove and looking.....well thanks alot Right On!
zhengs
Posts Posts : 228
Post by Belahzur on Fri Jan 02, 2009 11:37 pm
I'd say were done here.
Post by zhengs on Sat Jan 03, 2009 12:15 am
by the way,got any good anti virus software besides the list you gave up above??
zhengs
Posts Posts : 228
Post by Belahzur on Sat Jan 03, 2009 12:18 am
2) [You must be registered and logged in to see this link.]
-Anti-virus program for Windows.
-The home edition is freeware for noncommercial user.
3) [You must be registered and logged in to see this link.]
- Free edition of the AVG anti-virus program for Windows.
- Available for single computer use for home and non commercial use.
Post by zhengs on Sat Jan 03, 2009 12:23 am
and do you got any good software that let's you know when your entering a bad website that can give you virus or trojan
zhengs
Posts Posts : 228
Post by Belahzur on Sat Jan 03, 2009 12:24 am
Well if you took my advice on using Firefox, Firefox will tell you if the site you are visiting is a known attack site.
Post by zhengs on Sat Jan 03, 2009 12:33 am
ok i'll try that thank you. and do you want to be friends? Annoyed or Unimpress
zhengs
Posts Posts : 228
Post by Belahzur on Sat Jan 03, 2009 12:35 am
LOL Banner LOL Banner LOL Banner
Feel free to stick around if that's what you mean.
Post by zhengs on Sat Jan 03, 2009 12:46 am
is there a anti virus software call java something??
zhengs
Posts Posts : 228
Post by Belahzur on Sat Jan 03, 2009 12:48 am
Anti-virus and anti-spyware are different things.
Webroot spysweeper is (I think) owned by someone called Java.
There is also JavaRa (old) Java remover.
Post by zhengs on Sat Jan 03, 2009 12:56 am
okay,done with scaning and restore point. my computer is not running so slow like before now. ok i'll been seeing you next time if i have problems :victory:
and for the scan, it's clean
zhengs
Posts Posts : 228
Post by zhengs on Sat Jan 03, 2009 1:02 am
do i also delete or remove the downloads you told me to download for the trojan?
zhengs
Posts Posts : 228
Post by Belahzur on Sat Jan 03, 2009 1:10 am
Yes, please delete the tools we used.
Post by zhengs on Sat Jan 03, 2009 1:18 am
what do you suggest of me downloading which anti-virus software ?
zhengs
Posts Posts : 228
Post by Belahzur on Sat Jan 03, 2009 1:22 am
Preferably avast or avira, AVG doesn't like one of our best tools and if we need to use that for any reason, then we can't.
Post by zhengs on Sat Jan 03, 2009 3:31 am
what is service pack 2 for??
zhengs
Posts Posts : 228
Post by Doctor Inferno on Sat Jan 03, 2009 3:36 am
Service pack 2 include many security and bug patches for better defense against viruses, worms, and hackers.
Points Points : 104600
Post by zhengs on Sat Jan 03, 2009 3:42 am
is there a service pack 3for XP ??
zhengs
Posts Posts : 228
