Troj/Rustok-N - Have read other posts and still need some he
Solved Re: Troj/Rustok-N - Have read other posts and still need some he
Post by Belahzur on Sun Jan 04, 2009 10:29 pm
No rootkit there neither.
I think whatever website is telling you that, is just crap.
Lets try this though.
Start > Run
Type in:
ipconfig /flushdns
Press enter.
Post by RPal129 on Sun Jan 04, 2009 11:34 pm
Ok. Did all that. I assume its just total crap. Thanks a bunch for all your help.
RPal129
OS : Windows XP Professional
Post by Belahzur on Sun Jan 04, 2009 11:46 pm
Post by Doctor Inferno on Sat Feb 21, 2009 10:05 am
